[HowTo] Solve Keyring Related Issues in Manjaro
Wiki Page:
Manjaro and Arch users have a security keyring on their machine that allows them to safely download packages from the Manjaro and Arch repositories without those packages getting tampered with by a man-in-the-middle-attack.
Sometimes if a user doesn’t update their system for a long time, this keyring might expire. The keyring can also get corrupted for some reason.
To solve basic keyring issues do the following:
Resynchronise with the Manjaro repository servers to ensure that everything is up to date - by entering the command:
sudo pacman -Syy
Refresh and update the signature keys by entering the command:
sudo pacman-key --refresh-keys
Reload the signature keys by entering the command:
sudo pacman-key --populate archlinux manjaro
The three commands above should solve most (basic) keyring issues.
If they don’t, then you can also try more drastic measures.
Warning: The following commands only work if your system time is set correctly!
Remove all keys
sudo rm -rf /etc/pacman.d/gnupg
Reinitialize files & folders for keys
sudo pacman-key --init
Repopulate keys
Reinstall latest keyrings
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
Refresh the signature keys
Clear out the software packages downloaded during aborted installations (optional):
sudo pacman -Sc
Warning: The above command clears the pacman cache completely, and you will not be able to downgrade to a previous version of a package until you’ve updated the packages at least two times.
Finally, try updating your system to see if the errors were resolved.
sudo pacman -Syu
Imported & adapted from @Heart-Of-A-Lion’s and @arvind’s Posts on the archived forum.
Creating this as a wiki post so that experts can make the necessary changes :wink:
Invalid or corrupted database (PGP signature)
Update not possible, keyring errors
Can't download keyrings. key cannot be looked up remotely
Can’t import keys (Stable Update 2023-07-10)
Tried to do a system update, manjaro started using all resources and the computer is freezing
Pamac is behaving strangely
[HowTo] Work around gpg verification issue on left behind systems
Unable to update qpdfview
Unable to perform updates keyring issues
"Failed to commit transaction" error during routine update
[Stable Update] 2023-12-01 - Kernels, NVIDIA, Thunderbird, Deepin, PipeWire 1.0, QEMU
I can't update anything, i dont know what to do
Update fails with "keyring is not writable"
Signature problems after 2024-02-10 unstable update
[Stable Update] 2024-10-10 - Kernels, Pacman 7.0, KDE Frameworks 6.6, Virtualbox 7.1.2, Mesa
System update failed of invalid signatures
[Stable Update] 2022-12-20 - Kernels, XFCE 4.18, KDE Frameworks, Kde Gear, Mesa, Plasma-Mobile, Thunderbird, Firefox
Upgrading Manjaro ARM 21.03 seems impossible on Pinephone
Manjaro keyrings
No trusted keys
Corrupted package(s) - but pacman cache is empty
[Stable Update] 2026-02-01 - Kernels, COSMIC, Plasma, GNOME, Mesa
Unable to update due to invalid or corrupted package (PGP signature)
Cannot import key during an update?
Python application doesn't find tkinter but it's installed
Archlinux keyring fails to update
Problem with endless refreshing/skipping of pacman keys
A wiki page exists…
https://wiki.manjaro.org/index.php/Pacman_troubleshooting#Errors_about_Keys
Okay then, feel free to delete the entire post if necessary. :slightly_smiling_face:
[I just saw the post at archived forum a few days ago, wasn’t ware of the wiki page, very sorry for that]
Don’t be sorry.
I think the more places something, especially something as common as this, can be found, thee better.
Thank you so much, this solved my problem. appreciate it. :heart: :100:
