Wifi goes down after some time
Hello everyone.
  Kernel: 6.5.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    clocksource: tsc available: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=a58ccd07-1439-4d19-834b-cfdb281916a2 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
  Type: Laptop System: LENOVO product: 80QQ v: Lenovo ideapad 100-15IBD
    serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 100-15IBD
  Mobo: LENOVO model: Nano 5B6 v: NO DPK serial: <superuser required>
    UEFI-[Legacy]: LENOVO v: E0CN60WW date: 08/16/2016
  ID-1: BAT0 charge: 9.9 Wh (76.2%) condition: 13.0/31.7 Wh (41.0%)
    power: 4.9 W volts: 15.9 min: 14.4 model: GC 15L4A01 type: Li-ion
    serial: <filter> status: charging
  Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
    gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
    family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1895 high: 1896 min/max: 500/1900 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1896 2: 1895 3: 1896
    4: 1895 bogomips: 15971
    vulnerable
    STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
  Device-2: Chicony Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-6:5 chip-ID: 04f2:b572
  Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
    screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 model: BOE Display 0x061d built: 2014 res: 1366x768 hz: 60
    dpi: 112 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 389mm (15.3")
    ratio: 16:9, 15:9 modes: 1366x768
  API: OpenGL v: 4.6 Mesa 23.1.7-1 renderer: Mesa Intel HD Graphics 5500
    (BDW GT2) direct-render: Yes
  Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
    class-ID: 0403
  API: ALSA v: k6.5.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.80 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000
    bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
  Device-2: Realtek RTL8723BE PCIe Wireless Network Adapter vendor: Lenovo
    driver: rtl8723be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000
    bus-ID: 03:00.0 chip-ID: 10ec:b723 class-ID: 0280
  Device-1: Realtek RTL8723B Bluetooth driver: btusb v: 0.8 type: USB rev: 2.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-7:6 chip-ID: 0bda:b728
  Local Storage: total: 945.96 GiB used: 194.6 GiB (20.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: ST1000LM024 HN-M101MBB
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Silicon Power model: UFD 2.0 16G
    size: 14.45 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
    spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP
  ID-1: / raw-size: 480.8 GiB size: 472.18 GiB (98.21%) used: 194.6 GiB (41.2%)
    fs: ext4 dev: /dev/sda3 maj-min: 8:3
  ID-1: swap-1 type: zram size: 9.77 GiB used: 250.5 MiB (2.5%) priority: 100
    comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
  System Temperatures: cpu: 51.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 190 Uptime: 47m wakeups: 1 Memory: total: 4 GiB
  available: 3.75 GiB used: 2.69 GiB (71.8%) Init: systemd v: 254
  Packages: 1168 pm: pacman pkgs: 1159 libs: 324 tools: pamac pm: flatpak
  pkgs: 9 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.29
My wifi goes down and I have to reboot. I never paid attention to this until it started to annoy me. Here are logs:
kernel rtl8723be: Init MAC failed
wpa_supplicant wlp3s0: Failed to initialize driver interface
Could you help me please :slight_smile:
Hi @Preiwer, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
OK. Thanks for your attention :slight_smile: I immediately fix it
Not everything’s there yet. Please see:
FINE. I’ll take a screenshot of the logs ASAP. Because at the moment this error does not appear. But after a few times it will happen.
Again:
Edit:
Please do not post screenshots of text. Rather post them as preformatted text:
If there is no other way, please see:
And this might be handy:
Excuse me for my “ugliness”. I really haven’t know how to create a new topic in this forum.
But I think I provided broad information about my system and described some of the symptoms of my problem :3. But thanks for your patience.
You did. Sincere apologies for missing it. My glasses obviously needs cleaning.
Anyway, see:
Edit:
I suspect this part, specifically:
Some users may encounter errors with powersave on this card. This is shown with occasional disconnects that are not recognized by high level network managers (netctl, NetworkManager). This error can be confirmed by running dmesg -w as root or journalctl -f as root and looking for output related to powersave and the rtl8723ae/rtl8723be module. If you have this issue, use the fwlps=0 kernel module parameter which should prevent the WiFi card from automatically sleeping and halting connection.
thanks. But can I show you screenshot of error logs :3
:smiley:
ok.
Here is it:
<warn> [169...28] device (wlp3s0): device not up after timeout!
that was all there was to the error
Have you tried this:
Yes. Here what I did:
sudo nano /etc/modprobe.d/rtl8723be.conf
options rtl8723be fwlps=0
options rtl8723be ant_sel=2
but error still happens :frowning:
I think that this error that is happening to me is the most complex error, isn’t it? Or have you ever met errors more difficult.
sudo dmesg -w
[    0.001460]  gran_size: 64K  chunk_size: 2G  num_reg: 7      lose cover RAM: 60K
[    0.001462]  gran_size: 128K         chunk_size: 128K        num_reg: 10     lose cover RAM: 4194556K
[    0.001464]  gran_size: 128K         chunk_size: 256K        num_reg: 7      lose cover RAM: 124K
[    0.001466]  gran_size: 128K         chunk_size: 512K        num_reg: 7      lose cover RAM: 124K
[    0.001468]  gran_size: 128K         chunk_size: 1M  num_reg: 7      lose cover RAM: 124K
[    0.001470]  gran_size: 128K         chunk_size: 2M  num_reg: 7      lose cover RAM: 124K
[    0.001472]  gran_size: 128K         chunk_size: 4M  num_reg: 7      lose cover RAM: 124K
[    0.001474]  gran_size: 128K         chunk_size: 8M  num_reg: 7      lose cover RAM: 124K
[    0.001476]  gran_size: 128K         chunk_size: 16M         num_reg: 7      lose cover RAM: 124K
[    0.001478]  gran_size: 128K         chunk_size: 32M         num_reg: 8      lose cover RAM: 124K
[    0.001480]  gran_size: 128K         chunk_size: 64M         num_reg: 6      lose cover RAM: 124K
[    0.001482]  gran_size: 128K         chunk_size: 128M        num_reg: 6      lose cover RAM: 124K
[    0.001484]  gran_size: 128K         chunk_size: 256M        num_reg: 6      lose cover RAM: 124K
[    0.001486]  gran_size: 128K         chunk_size: 512M        num_reg: 6      lose cover RAM: 124K
[    0.001488]  gran_size: 128K         chunk_size: 1G  num_reg: 7      lose cover RAM: 124K
[    0.001490]  gran_size: 128K         chunk_size: 2G  num_reg: 7      lose cover RAM: 124K
[    0.001492]  gran_size: 256K         chunk_size: 256K        num_reg: 10     lose cover RAM: 4194556K
[    0.001494]  gran_size: 256K         chunk_size: 512K        num_reg: 7      lose cover RAM: 252K
[    0.001495]  gran_size: 256K         chunk_size: 1M  num_reg: 7      lose cover RAM: 252K
[    0.001497]  gran_size: 256K         chunk_size: 2M  num_reg: 7      lose cover RAM: 252K
[    0.001499]  gran_size: 256K         chunk_size: 4M  num_reg: 7      lose cover RAM: 252K
[    0.001501]  gran_size: 256K         chunk_size: 8M  num_reg: 7      lose cover RAM: 252K
[    0.001503]  gran_size: 256K         chunk_size: 16M         num_reg: 7      lose cover RAM: 252K
[    0.001505]  gran_size: 256K         chunk_size: 32M         num_reg: 8      lose cover RAM: 252K
[    0.001507]  gran_size: 256K         chunk_size: 64M         num_reg: 6      lose cover RAM: 252K
[    0.001509]  gran_size: 256K         chunk_size: 128M        num_reg: 6      lose cover RAM: 252K
[    0.001511]  gran_size: 256K         chunk_size: 256M        num_reg: 6      lose cover RAM: 252K
[    0.001513]  gran_size: 256K         chunk_size: 512M        num_reg: 6      lose cover RAM: 252K
[    0.001515]  gran_size: 256K         chunk_size: 1G  num_reg: 7      lose cover RAM: 252K
[    0.001517]  gran_size: 256K         chunk_size: 2G  num_reg: 7      lose cover RAM: 252K
[    0.001519]  gran_size: 512K         chunk_size: 512K        num_reg: 10     lose cover RAM: 508K
[    0.001521]  gran_size: 512K         chunk_size: 1M  num_reg: 7      lose cover RAM: 508K
[    0.001523]  gran_size: 512K         chunk_size: 2M  num_reg: 7      lose cover RAM: 508K
[    0.001525]  gran_size: 512K         chunk_size: 4M  num_reg: 7      lose cover RAM: 508K
[    0.001527]  gran_size: 512K         chunk_size: 8M  num_reg: 7      lose cover RAM: 508K
[    0.001529]  gran_size: 512K         chunk_size: 16M         num_reg: 7      lose cover RAM: 508K
[    0.001530]  gran_size: 512K         chunk_size: 32M         num_reg: 8      lose cover RAM: 508K
[    0.001532]  gran_size: 512K         chunk_size: 64M         num_reg: 6      lose cover RAM: 508K
[    0.001534]  gran_size: 512K         chunk_size: 128M        num_reg: 6      lose cover RAM: 508K
[    0.001536]  gran_size: 512K         chunk_size: 256M        num_reg: 6      lose cover RAM: 508K
[    0.001538]  gran_size: 512K         chunk_size: 512M        num_reg: 6      lose cover RAM: 508K
[    0.001540]  gran_size: 512K         chunk_size: 1G  num_reg: 7      lose cover RAM: 508K
[    0.001542]  gran_size: 512K         chunk_size: 2G  num_reg: 7      lose cover RAM: 508K
[    0.001544]  gran_size: 1M   chunk_size: 1M  num_reg: 9      lose cover RAM: 1020K
[    0.001546]  gran_size: 1M   chunk_size: 2M  num_reg: 7      lose cover RAM: 1020K
[    0.001548]  gran_size: 1M   chunk_size: 4M  num_reg: 7      lose cover RAM: 1020K
[    0.001550]  gran_size: 1M   chunk_size: 8M  num_reg: 7      lose cover RAM: 1020K
[    0.001552]  gran_size: 1M   chunk_size: 16M         num_reg: 7      lose cover RAM: 1020K
[    0.001554]  gran_size: 1M   chunk_size: 32M         num_reg: 8      lose cover RAM: 1020K
[    0.001556]  gran_size: 1M   chunk_size: 64M         num_reg: 6      lose cover RAM: 1020K
[    0.001558]  gran_size: 1M   chunk_size: 128M        num_reg: 6      lose cover RAM: 1020K
[    0.001560]  gran_size: 1M   chunk_size: 256M        num_reg: 6      lose cover RAM: 1020K
[    0.001562]  gran_size: 1M   chunk_size: 512M        num_reg: 6      lose cover RAM: 1020K
[    0.001564]  gran_size: 1M   chunk_size: 1G  num_reg: 7      lose cover RAM: 1020K
[    0.001566]  gran_size: 1M   chunk_size: 2G  num_reg: 7      lose cover RAM: 1020K
[    0.001568]  gran_size: 2M   chunk_size: 2M  num_reg: 8      lose cover RAM: 2044K
[    0.001569]  gran_size: 2M   chunk_size: 4M  num_reg: 7      lose cover RAM: 2044K
[    0.001571]  gran_size: 2M   chunk_size: 8M  num_reg: 7      lose cover RAM: 2044K
[    0.001573]  gran_size: 2M   chunk_size: 16M         num_reg: 7      lose cover RAM: 2044K
[    0.001575]  gran_size: 2M   chunk_size: 32M         num_reg: 8      lose cover RAM: 2044K
[    0.001577]  gran_size: 2M   chunk_size: 64M         num_reg: 6      lose cover RAM: 2044K
[    0.001579]  gran_size: 2M   chunk_size: 128M        num_reg: 6      lose cover RAM: 2044K
[    0.001581]  gran_size: 2M   chunk_size: 256M        num_reg: 6      lose cover RAM: 2044K
[    0.001583]  gran_size: 2M   chunk_size: 512M        num_reg: 6      lose cover RAM: 2044K
[    0.001585]  gran_size: 2M   chunk_size: 1G  num_reg: 7      lose cover RAM: 2044K
[    0.001587]  gran_size: 2M   chunk_size: 2G  num_reg: 7      lose cover RAM: 2044K
[    0.001589]  gran_size: 4M   chunk_size: 4M  num_reg: 7      lose cover RAM: 4092K
[    0.001591]  gran_size: 4M   chunk_size: 8M  num_reg: 7      lose cover RAM: 4092K
[    0.001593]  gran_size: 4M   chunk_size: 16M         num_reg: 7      lose cover RAM: 4092K
[    0.001594]  gran_size: 4M   chunk_size: 32M         num_reg: 8      lose cover RAM: 4092K
[    0.001596]  gran_size: 4M   chunk_size: 64M         num_reg: 6      lose cover RAM: 4092K
[    0.001598]  gran_size: 4M   chunk_size: 128M        num_reg: 6      lose cover RAM: 4092K
[    0.001600]  gran_size: 4M   chunk_size: 256M        num_reg: 6      lose cover RAM: 4092K
[    0.001602]  gran_size: 4M   chunk_size: 512M        num_reg: 6      lose cover RAM: 4092K
[    0.001604]  gran_size: 4M   chunk_size: 1G  num_reg: 7      lose cover RAM: 4092K
[    0.001606]  gran_size: 4M   chunk_size: 2G  num_reg: 7      lose cover RAM: 4092K
[    0.001608]  gran_size: 8M   chunk_size: 8M  num_reg: 6      lose cover RAM: 8188K
[    0.001610]  gran_size: 8M   chunk_size: 16M         num_reg: 7      lose cover RAM: 8188K
[    0.001612]  gran_size: 8M   chunk_size: 32M         num_reg: 8      lose cover RAM: 8188K
[    0.001614]  gran_size: 8M   chunk_size: 64M         num_reg: 6      lose cover RAM: 8188K
[    0.001616]  gran_size: 8M   chunk_size: 128M        num_reg: 6      lose cover RAM: 8188K
[    0.001618]  gran_size: 8M   chunk_size: 256M        num_reg: 6      lose cover RAM: 8188K
[    0.001619]  gran_size: 8M   chunk_size: 512M        num_reg: 6      lose cover RAM: 8188K
[    0.001621]  gran_size: 8M   chunk_size: 1G  num_reg: 7      lose cover RAM: 8188K
[    0.001623]  gran_size: 8M   chunk_size: 2G  num_reg: 7      lose cover RAM: 8188K
[    0.001625]  gran_size: 16M  chunk_size: 16M         num_reg: 5      lose cover RAM: 16380K
[    0.001627]  gran_size: 16M  chunk_size: 32M         num_reg: 5      lose cover RAM: 16380K
[    0.001629]  gran_size: 16M  chunk_size: 64M         num_reg: 5      lose cover RAM: 16380K
[    0.001631]  gran_size: 16M  chunk_size: 128M        num_reg: 4      lose cover RAM: 16380K
[    0.001633]  gran_size: 16M  chunk_size: 256M        num_reg: 4      lose cover RAM: 16380K
[    0.001635]  gran_size: 16M  chunk_size: 512M        num_reg: 4      lose cover RAM: 16380K
[    0.001637]  gran_size: 16M  chunk_size: 1G  num_reg: 5      lose cover RAM: 16380K
[    0.001639]  gran_size: 16M  chunk_size: 2G  num_reg: 5      lose cover RAM: 16380K
[    0.001641]  gran_size: 32M  chunk_size: 32M         num_reg: 5      lose cover RAM: 16380K
[    0.001643]  gran_size: 32M  chunk_size: 64M         num_reg: 5      lose cover RAM: 16380K
[    0.001645]  gran_size: 32M  chunk_size: 128M        num_reg: 4      lose cover RAM: 16380K
[    0.001647]  gran_size: 32M  chunk_size: 256M        num_reg: 4      lose cover RAM: 16380K
[    0.001649]  gran_size: 32M  chunk_size: 512M        num_reg: 4      lose cover RAM: 16380K
[    0.001651]  gran_size: 32M  chunk_size: 1G  num_reg: 5      lose cover RAM: 16380K
[    0.001653]  gran_size: 32M  chunk_size: 2G  num_reg: 5      lose cover RAM: 16380K
[    0.001655]  gran_size: 64M  chunk_size: 64M         num_reg: 5      lose cover RAM: 16380K
[    0.001657]  gran_size: 64M  chunk_size: 128M        num_reg: 4      lose cover RAM: 16380K
[    0.001659]  gran_size: 64M  chunk_size: 256M        num_reg: 4      lose cover RAM: 16380K
[    0.001661]  gran_size: 64M  chunk_size: 512M        num_reg: 4      lose cover RAM: 16380K
[    0.001663]  gran_size: 64M  chunk_size: 1G  num_reg: 5      lose cover RAM: 16380K
[    0.001665]  gran_size: 64M  chunk_size: 2G  num_reg: 5      lose cover RAM: 16380K
[    0.001666]  gran_size: 128M         chunk_size: 128M        num_reg: 4      lose cover RAM: 81916K
[    0.001669]  gran_size: 128M         chunk_size: 256M        num_reg: 4      lose cover RAM: 81916K
[    0.001670]  gran_size: 128M         chunk_size: 512M        num_reg: 4      lose cover RAM: 81916K
[    0.001672]  gran_size: 128M         chunk_size: 1G  num_reg: 5      lose cover RAM: 81916K
[    0.001674]  gran_size: 128M         chunk_size: 2G  num_reg: 5      lose cover RAM: 81916K
[    0.001676]  gran_size: 256M         chunk_size: 256M        num_reg: 3      lose cover RAM: 212988K
[    0.001678]  gran_size: 256M         chunk_size: 512M        num_reg: 4      lose cover RAM: 212988K
[    0.001680]  gran_size: 256M         chunk_size: 1G  num_reg: 5      lose cover RAM: 212988K
[    0.001682]  gran_size: 256M         chunk_size: 2G  num_reg: 5      lose cover RAM: 212988K
[    0.001684]  gran_size: 512M         chunk_size: 512M        num_reg: 2      lose cover RAM: 475132K
[    0.001686]  gran_size: 512M         chunk_size: 1G  num_reg: 2      lose cover RAM: 475132K
[    0.001688]  gran_size: 512M         chunk_size: 2G  num_reg: 2      lose cover RAM: 475132K
[    0.001690]  gran_size: 1G   chunk_size: 1G  num_reg: 2      lose cover RAM: 475132K
[    0.001692]  gran_size: 1G   chunk_size: 2G  num_reg: 2      lose cover RAM: 475132K
[    0.001694]  gran_size: 2G   chunk_size: 2G  num_reg: 2      lose cover RAM: 475132K
[    0.001696] mtrr_cleanup: can not find optimal value
[    0.001697] please specify mtrr_gran_size/mtrr_chunk_size
[    0.001700] MTRR map: 8 entries (5 fixed + 3 variable; max 25), built from 10 variable MTRRs
[    0.001702] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.002045] e820: update [mem 0x9cfff000-0xffffffff] usable ==> reserved
[    0.002051] last_pfn = 0x9cfff max_arch_pfn = 0x400000000
[    0.013200] found SMP MP-table at [mem 0x000fe1b0-0x000fe1bf]
[    0.013221] Using GB pages for direct mapping
[    0.014064] RAMDISK: [mem 0x3548d000-0x36a3dfff]
[    0.014071] ACPI: Early table checksum verification disabled
[    0.014075] ACPI: RSDP 0x00000000000FE020 000024 (v02 LENOVO)
[    0.014081] ACPI: XSDT 0x000000009CFCD188 0000DC (v01 LENOVO CB-01    00000001      01000013)
[    0.014088] ACPI: FACP 0x000000009CFF1000 00010C (v05 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014096] ACPI: DSDT 0x000000009CFDB000 01160E (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014100] ACPI: FACS 0x000000009CF67000 000040
[    0.014104] ACPI: UEFI 0x000000009CFFB000 000236 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014108] ACPI: SSDT 0x000000009CFF9000 000496 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014112] ACPI: TPM2 0x000000009CFF7000 000034 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014116] ACPI: ASF! 0x000000009CFF5000 0000A5 (v32 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014121] ACPI: BOOT 0x000000009CFF3000 000028 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014125] ACPI: LPIT 0x000000009CFEF000 000094 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014129] ACPI: MCFG 0x000000009CFED000 00003C (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014133] ACPI: SSDT 0x000000009CFD7000 0037AA (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014137] ACPI: SSDT 0x000000009CFD6000 000539 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014141] ACPI: SSDT 0x000000009CFCF000 005AC3 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014145] ACPI: UEFI 0x000000009CFFA000 000042 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014150] ACPI: POAT 0x000000009CFF6000 000055 (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014154] ACPI: DBGP 0x000000009CFF2000 000034 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014158] ACPI: APIC 0x000000009CFEE000 00008C (v03 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014162] ACPI: TCPA 0x000000009CFFC000 000032 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014167] ACPI: ASPT 0x000000009CFF4000 000034 (v07 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014171] ACPI: SSDT 0x000000009CFF8000 00004B (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014175] ACPI: SSDT 0x000000009CFD5000 000B74 (v02 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014179] ACPI: HPET 0x000000009CFF0000 000038 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014184] ACPI: DMAR 0x000000009CFCE000 0000F8 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014188] ACPI: CSRT 0x000000009CFCC000 0000C4 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014192] ACPI: FPDT 0x000000009CFCB000 000044 (v01 LENOVO CB-01    00000001 ACPI 00040000)
[    0.014195] ACPI: Reserving FACP table memory at [mem 0x9cff1000-0x9cff110b]
[    0.014197] ACPI: Reserving DSDT table memory at [mem 0x9cfdb000-0x9cfec60d]
[    0.014199] ACPI: Reserving FACS table memory at [mem 0x9cf67000-0x9cf6703f]
[    0.014200] ACPI: Reserving UEFI table memory at [mem 0x9cffb000-0x9cffb235]
[    0.014201] ACPI: Reserving SSDT table memory at [mem 0x9cff9000-0x9cff9495]
[    0.014202] ACPI: Reserving TPM2 table memory at [mem 0x9cff7000-0x9cff7033]
[    0.014203] ACPI: Reserving ASF! table memory at [mem 0x9cff5000-0x9cff50a4]
[    0.014205] ACPI: Reserving BOOT table memory at [mem 0x9cff3000-0x9cff3027]
[    0.014206] ACPI: Reserving LPIT table memory at [mem 0x9cfef000-0x9cfef093]
[    0.014207] ACPI: Reserving MCFG table memory at [mem 0x9cfed000-0x9cfed03b]
[    0.014208] ACPI: Reserving SSDT table memory at [mem 0x9cfd7000-0x9cfda7a9]
[    0.014209] ACPI: Reserving SSDT table memory at [mem 0x9cfd6000-0x9cfd6538]
[    0.014210] ACPI: Reserving SSDT table memory at [mem 0x9cfcf000-0x9cfd4ac2]
[    0.014211] ACPI: Reserving UEFI table memory at [mem 0x9cffa000-0x9cffa041]
[    0.014213] ACPI: Reserving POAT table memory at [mem 0x9cff6000-0x9cff6054]
[    0.014214] ACPI: Reserving DBGP table memory at [mem 0x9cff2000-0x9cff2033]
[    0.014215] ACPI: Reserving APIC table memory at [mem 0x9cfee000-0x9cfee08b]
[    0.014216] ACPI: Reserving TCPA table memory at [mem 0x9cffc000-0x9cffc031]
[    0.014217] ACPI: Reserving ASPT table memory at [mem 0x9cff4000-0x9cff4033]
[    0.014218] ACPI: Reserving SSDT table memory at [mem 0x9cff8000-0x9cff804a]
[    0.014220] ACPI: Reserving SSDT table memory at [mem 0x9cfd5000-0x9cfd5b73]
[    0.014221] ACPI: Reserving HPET table memory at [mem 0x9cff0000-0x9cff0037]
[    0.014222] ACPI: Reserving DMAR table memory at [mem 0x9cfce000-0x9cfce0f7]
[    0.014223] ACPI: Reserving CSRT table memory at [mem 0x9cfcc000-0x9cfcc0c3]
[    0.014224] ACPI: Reserving FPDT table memory at [mem 0x9cfcb000-0x9cfcb043]
[    0.014281] No NUMA configuration found
[    0.014282] Faking a node at [mem 0x0000000000000000-0x000000015effffff]
[    0.014286] NODE_DATA(0) allocated [mem 0x15eff9000-0x15effdfff]
[    0.014311] Zone ranges:
[    0.014312]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.014315]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.014317]   Normal   [mem 0x0000000100000000-0x000000015effffff]
[    0.014319]   Device   empty
[    0.014321] Movable zone start for each node
[    0.014322] Early memory node ranges
[    0.014322]   node   0: [mem 0x0000000000001000-0x000000000009dfff]
[    0.014324]   node   0: [mem 0x0000000000100000-0x000000007bd3efff]
[    0.014326]   node   0: [mem 0x000000007bd40000-0x000000007bd64fff]
[    0.014328]   node   0: [mem 0x000000007bd66000-0x0000000096cf8fff]
[    0.014329]   node   0: [mem 0x00000000975f9000-0x000000009c70dfff]
[    0.014330]   node   0: [mem 0x000000009cffe000-0x000000009cffefff]
[    0.014331]   node   0: [mem 0x0000000100000000-0x000000015effffff]
[    0.014333] Initmem setup node 0 [mem 0x0000000000001000-0x000000015effffff]
[    0.014339] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.014368] On node 0, zone DMA: 98 pages in unavailable ranges
[    0.020441] On node 0, zone DMA32: 1 pages in unavailable ranges
[    0.021819] On node 0, zone DMA32: 1 pages in unavailable ranges
[    0.022111] On node 0, zone DMA32: 2304 pages in unavailable ranges
[    0.022144] On node 0, zone DMA32: 2288 pages in unavailable ranges
[    0.027157] On node 0, zone Normal: 12289 pages in unavailable ranges
[    0.027211] On node 0, zone Normal: 4096 pages in unavailable ranges
[    0.027221] Reserving Intel graphics memory at [mem 0x9e000000-0x9fffffff]
[    0.027306] ACPI: PM-Timer IO Port: 0x1808
[    0.027326] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-39
[    0.027330] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.027332] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.027339] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.027340] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.027346] TSC deadline timer available
[    0.027347] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.027373] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.027376] PM: hibernation: Registered nosave memory: [mem 0x0009e000-0x0009efff]
[    0.027378] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x0009ffff]
[    0.027379] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000dffff]
[    0.027380] PM: hibernation: Registered nosave memory: [mem 0x000e0000-0x000fffff]
[    0.027382] PM: hibernation: Registered nosave memory: [mem 0x7bd3f000-0x7bd3ffff]
[    0.027384] PM: hibernation: Registered nosave memory: [mem 0x7bd65000-0x7bd65fff]
[    0.027387] PM: hibernation: Registered nosave memory: [mem 0x96cf9000-0x975f8fff]
[    0.027389] PM: hibernation: Registered nosave memory: [mem 0x9c70e000-0x9ce6dfff]
[    0.027390] PM: hibernation: Registered nosave memory: [mem 0x9ce6e000-0x9cf7dfff]
[    0.027391] PM: hibernation: Registered nosave memory: [mem 0x9cf7e000-0x9cffdfff]
[    0.027393] PM: hibernation: Registered nosave memory: [mem 0x9cfff000-0x9fffffff]
[    0.027394] PM: hibernation: Registered nosave memory: [mem 0xa0000000-0xdfffffff]
[    0.027395] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xefffffff]
[    0.027396] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xfeafffff]
[    0.027397] PM: hibernation: Registered nosave memory: [mem 0xfeb00000-0xfeb03fff]
[    0.027399] PM: hibernation: Registered nosave memory: [mem 0xfeb04000-0xfebfffff]
[    0.027400] PM: hibernation: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.027401] PM: hibernation: Registered nosave memory: [mem 0xfec01000-0xfed0ffff]
[    0.027402] PM: hibernation: Registered nosave memory: [mem 0xfed10000-0xfed19fff]
[    0.027403] PM: hibernation: Registered nosave memory: [mem 0xfed1a000-0xfed1bfff]
[    0.027404] PM: hibernation: Registered nosave memory: [mem 0xfed1c000-0xfed1ffff]
[    0.027405] PM: hibernation: Registered nosave memory: [mem 0xfed20000-0xfedfffff]
[    0.027406] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.027407] PM: hibernation: Registered nosave memory: [mem 0xfee01000-0xff9fffff]
[    0.027408] PM: hibernation: Registered nosave memory: [mem 0xffa00000-0xffffffff]
[    0.027410] [mem 0xa0000000-0xdfffffff] available for PCI devices
[    0.027412] Booting paravirtualized kernel on bare hardware
[    0.027417] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.035396] setup_percpu: NR_CPUS:320 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
[    0.035941] percpu: Embedded 64 pages/cpu s225280 r8192 d28672 u524288
[    0.035953] pcpu-alloc: s225280 r8192 d28672 u524288 alloc=1*2097152
[    0.035956] pcpu-alloc: [0] 0 1 2 3
[    0.035983] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64 root=UUID=a58ccd07-1439-4d19-834b-cfdb281916a2 rw quiet splash udev.log_priority=3
[    0.036092] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64", will be passed to user space.
[    0.036130] random: crng init done
[    0.036884] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.037288] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.037376] Fallback order for Node 0: 0
[    0.037381] Built 1 zonelists, mobility grouping on.  Total pages: 1011284
[    0.037383] Policy zone: Normal
[    0.037792] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[    0.037805] software IO TLB: area num 4.
[    0.080625] Memory: 3900604K/4109992K available (16384K kernel code, 2141K rwdata, 13028K rodata, 3400K init, 3856K bss, 209128K reserved, 0K cma-reserved)
[    0.080959] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.080978] Kernel/User page tables isolation: enabled
[    0.081025] ftrace: allocating 48643 entries in 191 pages
[    0.092645] ftrace: allocated 191 pages with 7 groups
[    0.092749] Dynamic Preempt: full
[    0.092789] rcu: Preemptible hierarchical RCU implementation.
[    0.092790] rcu:     RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[    0.092792] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.092794]  Trampoline variant of Tasks RCU enabled.
[    0.092794]  Rude variant of Tasks RCU enabled.
[    0.092795]  Tracing variant of Tasks RCU enabled.
[    0.092796] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.092797] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.096806] NR_IRQS: 20736, nr_irqs: 728, preallocated irqs: 16
[    0.097022] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.097168] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.097210] Console: colour dummy device 80x25
[    0.097213] printk: console [tty0] enabled
[    0.097294] ACPI: Core revision 20230331
[    0.097492] hpet: HPET dysfunctional in PC10. Force disabled.
[    0.097494] APIC: Switch to symmetric I/O mode setup
[    0.097497] DMAR: Host address width 39
[    0.097498] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.097506] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 7e1ff0505e
[    0.097509] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.097514] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c20660462 ecap f010da
[    0.097517] DMAR: RMRR base: 0x0000009ce13000 end: 0x0000009ce32fff
[    0.097519] DMAR: RMRR base: 0x0000009d800000 end: 0x0000009fffffff
[    0.097521] DMAR: ANDD device: 1 name: \_SB.PCI0.SDMA
[    0.097522] DMAR: ANDD device: 2 name: \_SB.PCI0.SDHC
[    0.097525] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.097527] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.097529] DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit.
[    0.097530] DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting.
[    0.098413] DMAR-IR: Enabled IRQ remapping in xapic mode
[    0.098416] x2apic: IRQ remapping doesn't support X2APIC mode
[    0.098955] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x39866f27d01, max_idle_ns: 881590561334 ns
[    0.098965] Calibrating delay loop (skipped), value calculated using timer frequency.. 3992.08 BogoMIPS (lpj=6651343)
[    0.099033] process: using mwait in idle threads
[    0.099037] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.099039] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.099044] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.099047] Spectre V2 : Mitigation: Retpolines
[    0.099048] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.099049] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[    0.099050] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.099052] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.099054] Spectre V2 : User space: Mitigation: STIBP via prctl
[    0.099055] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[    0.099059] MDS: Mitigation: Clear CPU buffers
[    0.099060] MMIO Stale Data: Unknown: No mitigations
[    0.099062] SRBDS: Mitigation: Microcode
[    0.099068] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.099070] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.099071] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.099073] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.099075] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format.
[    0.102294] Freeing SMP alternatives memory: 40K
[    0.102294] pid_max: default: 32768 minimum: 301
[    0.102294] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf,integrity
[    0.102294] landlock: Up and running.
[    0.102294] Yama: becoming mindful.
[    0.102294] LSM support for eBPF active
[    0.102294] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.102294] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.102294] smpboot: CPU0: Intel(R) Core(TM) i3-5005U CPU @ 2.00GHz (family: 0x6, model: 0x3d, stepping: 0x4)
[    0.102294] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.102294] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.102294] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1.
[    0.102294] Performance Events: PEBS fmt2+, Broadwell events, 16-deep LBR, full-width counters, Intel PMU driver.
[    0.102294] ... version:                3
[    0.102294] ... bit width:              48
[    0.102294] ... generic registers:      4
[    0.102294] ... value mask:             0000ffffffffffff
[    0.102294] ... max period:             00007fffffffffff
[    0.102294] ... fixed-purpose events:   3
[    0.102294] ... event mask:             000000070000000f
[    0.102294] signal: max sigframe size: 1776
[    0.102294] Estimated ratio of average max frequency by base frequency (times 1024): 1024
[    0.102294] rcu: Hierarchical SRCU implementation.
[    0.102294] rcu:     Max phase no-delay instances is 1000.
[    0.102294] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.102294] smp: Bringing up secondary CPUs ...
[    0.102294] smpboot: x86: Booting SMP configuration:
[    0.102294] .... node  #0, CPUs:      #1 #2 #3
[    0.106457] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.106457] smp: Brought up 1 node, 4 CPUs
[    0.106457] smpboot: Max logical packages: 1
[    0.106457] smpboot: Total of 4 processors activated (15969.35 BogoMIPS)
[    0.109177] devtmpfs: initialized
[    0.109177] x86/mm: Memory block size: 128MB
[    0.109536] ACPI: PM: Registering ACPI NVS region [mem 0x9ce6e000-0x9cf7dfff] (1114112 bytes)
[    0.109536] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.109536] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.109536] pinctrl core: initialized pinctrl subsystem
[    0.109536] PM: RTC time: 15:27:35, date: 2023-09-24
[    0.110006] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.110231] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.110300] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.110367] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.110390] audit: initializing netlink subsys (disabled)
[    0.110396] audit: type=2000 audit(1695569255.009:1): state=initialized audit_enabled=0 res=1
[    0.110396] thermal_sys: Registered thermal governor 'fair_share'
[    0.110396] thermal_sys: Registered thermal governor 'bang_bang'
[    0.110396] thermal_sys: Registered thermal governor 'step_wise'
[    0.110396] thermal_sys: Registered thermal governor 'user_space'
[    0.110396] thermal_sys: Registered thermal governor 'power_allocator'
[    0.110485] cpuidle: using governor ladder
[    0.110485] cpuidle: using governor menu
[    0.110485] Simple Boot Flag at 0x44 set to 0x1
[    0.110485] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.110485] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.110485] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[    0.110485] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved as E820 entry
[    0.110485] PCI: Using configuration type 1 for base access
[    0.110485] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.110485] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[    0.115684] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.115684] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[    0.115684] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.115684] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[    0.115784] ACPI: Added _OSI(Module Device)
[    0.115786] ACPI: Added _OSI(Processor Device)
[    0.115788] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.115789] ACPI: Added _OSI(Processor Aggregator Device)
[    0.141607] ACPI: 7 ACPI AML tables successfully acquired and loaded
[    0.143596] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.144642] ACPI: Dynamic OEM Table Load:
[    0.144642] ACPI: SSDT 0xFFFF963FC10D5800 0003D3 (v02 PmRef  Cpu0Cst  00003001 INTL 20121220)
[    0.146870] ACPI: Dynamic OEM Table Load:
[    0.146880] ACPI: SSDT 0xFFFF963FC0C95800 0005AA (v02 PmRef  ApIst    00003000 INTL 20121220)
[    0.148306] ACPI: Dynamic OEM Table Load:
[    0.148314] ACPI: SSDT 0xFFFF963FC0E58A00 000119 (v02 PmRef  ApCst    00003000 INTL 20121220)
[    0.150523] ACPI: EC: EC started
[    0.150525] ACPI: EC: interrupt blocked
[    0.152686] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.152689] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions
[    0.152692] ACPI: Interpreter enabled
[    0.152741] ACPI: PM: (supports S0 S3 S4 S5)
[    0.152743] ACPI: Using IOAPIC for interrupt routing
[    0.153905] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.153907] PCI: Using E820 reservations for host bridge windows
[    0.154416] ACPI: Enabled 7 GPEs in block 00 to 7F
[    0.183408] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-fe])
[    0.183419] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.184757] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[    0.184760] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.186196] PCI host bridge to bus 0000:00
[    0.186199] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.186202] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.186204] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.186206] pci_bus 0000:00: root bus resource [mem 0xa0000000-0xdfffffff window]
[    0.186208] pci_bus 0000:00: root bus resource [mem 0xfe101000-0xfe113fff window]
[    0.186210] pci_bus 0000:00: root bus resource [bus 00-fe]
[    0.186229] pci 0000:00:00.0: [8086:1604] type 00 class 0x060000
[    0.186319] pci 0000:00:02.0: [8086:1616] type 00 class 0x030000
[    0.186330] pci 0000:00:02.0: reg 0x10: [mem 0xc0000000-0xc0ffffff 64bit]
[    0.186338] pci 0000:00:02.0: reg 0x18: [mem 0xb0000000-0xbfffffff 64bit pref]
[    0.186344] pci 0000:00:02.0: reg 0x20: [io  0x5000-0x503f]
[    0.186362] pci 0000:00:02.0: DMAR: Disabling IOMMU for graphics on this chipset
[    0.186366] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.186687] pci 0000:00:03.0: [8086:160c] type 00 class 0x040300
[    0.186698] pci 0000:00:03.0: reg 0x10: [mem 0xc1210000-0xc1213fff 64bit]
[    0.186832] pci 0000:00:14.0: [8086:9cb1] type 00 class 0x0c0330
[    0.186849] pci 0000:00:14.0: reg 0x10: [mem 0xc1200000-0xc120ffff 64bit]
[    0.186910] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.187021] pci 0000:00:16.0: [8086:9cba] type 00 class 0x078000
[    0.187038] pci 0000:00:16.0: reg 0x10: [mem 0xc121b000-0xc121b01f 64bit]
[    0.187102] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.187167] pci 0000:00:1b.0: [8086:9ca0] type 00 class 0x040300
[    0.187184] pci 0000:00:1b.0: reg 0x10: [mem 0xc1214000-0xc1217fff 64bit]
[    0.187244] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.187336] pci 0000:00:1c.0: [8086:9c90] type 01 class 0x060400
[    0.187418] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.188074] pci 0000:00:1c.2: [8086:9c94] type 01 class 0x060400
[    0.188158] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[    0.188820] pci 0000:00:1c.3: [8086:9c96] type 01 class 0x060400
[    0.188904] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[    0.189571] pci 0000:00:1d.0: [8086:9ca6] type 00 class 0x0c0320
[    0.190311] pci 0000:00:1d.0: reg 0x10: [mem 0xc1219000-0xc12193ff]
[    0.192507] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.192507] pci 0000:00:1f.0: [8086:9cc5] type 00 class 0x060100
[    0.192664] pci 0000:00:1f.2: [8086:9c83] type 00 class 0x010601
[    0.192677] pci 0000:00:1f.2: reg 0x10: [io  0x5088-0x508f]
[    0.192684] pci 0000:00:1f.2: reg 0x14: [io  0x5094-0x5097]
[    0.192692] pci 0000:00:1f.2: reg 0x18: [io  0x5080-0x5087]
[    0.192699] pci 0000:00:1f.2: reg 0x1c: [io  0x5090-0x5093]
[    0.192706] pci 0000:00:1f.2: reg 0x20: [io  0x5060-0x507f]
[    0.192713] pci 0000:00:1f.2: reg 0x24: [mem 0xc1218000-0xc12187ff]
[    0.192750] pci 0000:00:1f.2: PME# supported from D3hot
[    0.192835] pci 0000:00:1f.3: [8086:9ca2] type 00 class 0x0c0500
[    0.192853] pci 0000:00:1f.3: reg 0x10: [mem 0xc121a000-0xc121a0ff 64bit]
[    0.192873] pci 0000:00:1f.3: reg 0x20: [io  0x5040-0x505f]
[    0.193011] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.193094] pci 0000:02:00.0: [10ec:8136] type 00 class 0x020000
[    0.193116] pci 0000:02:00.0: reg 0x10: [io  0x4000-0x40ff]
[    0.193145] pci 0000:02:00.0: reg 0x18: [mem 0xc1104000-0xc1104fff 64bit]
[    0.193163] pci 0000:02:00.0: reg 0x20: [mem 0xc1100000-0xc1103fff 64bit]
[    0.193276] pci 0000:02:00.0: supports D1 D2
[    0.193278] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.193510] pci 0000:00:1c.2: PCI bridge to [bus 02]
[    0.193515] pci 0000:00:1c.2:   bridge window [io  0x4000-0x4fff]
[    0.193518] pci 0000:00:1c.2:   bridge window [mem 0xc1100000-0xc11fffff]
[    0.193612] pci 0000:03:00.0: [10ec:b723] type 00 class 0x028000
[    0.193647] pci 0000:03:00.0: reg 0x10: [io  0x3000-0x30ff]
[    0.193693] pci 0000:03:00.0: reg 0x18: [mem 0xc1000000-0xc1003fff 64bit]
[    0.193892] pci 0000:03:00.0: supports D1 D2
[    0.193893] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.194209] pci 0000:00:1c.3: PCI bridge to [bus 03]
[    0.194213] pci 0000:00:1c.3:   bridge window [io  0x3000-0x3fff]
[    0.194216] pci 0000:00:1c.3:   bridge window [mem 0xc1000000-0xc10fffff]
[    0.195700] ACPI: PCI: Interrupt link LNKA configured for IRQ 7
[    0.195777] ACPI: PCI: Interrupt link LNKB configured for IRQ 10
[    0.195851] ACPI: PCI: Interrupt link LNKC configured for IRQ 11
[    0.195924] ACPI: PCI: Interrupt link LNKD configured for IRQ 10
[    0.195997] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.195998] ACPI: PCI: Interrupt link LNKE disabled
[    0.196071] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.196073] ACPI: PCI: Interrupt link LNKF disabled
[    0.196147] ACPI: PCI: Interrupt link LNKG configured for IRQ 11
[    0.196222] ACPI: PCI: Interrupt link LNKH configured for IRQ 7
[    0.196837] ACPI: EC: interrupt unblocked
[    0.196839] ACPI: EC: event unblocked
[    0.196843] ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.196845] ACPI: EC: GPE=0x7
[    0.196848] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC initialization complete
[    0.196851] ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to handle transactions and events
[    0.196959] iommu: Default domain type: Translated
[    0.196959] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.196959] SCSI subsystem initialized
[    0.196959] libata version 3.00 loaded.
[    0.196959] ACPI: bus type USB registered
[    0.196959] usbcore: registered new interface driver usbfs
[    0.196959] usbcore: registered new interface driver hub
[    0.196959] usbcore: registered new device driver usb
[    0.196959] pps_core: LinuxPPS API ver. 1 registered
[    0.196959] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.196959] PTP clock support registered
[    0.196959] EDAC MC: Ver: 3.0.0
[    0.196959] NetLabel: Initializing
[    0.196959] NetLabel:  domain hash size = 128
[    0.196959] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.196959] NetLabel:  unlabeled traffic allowed by default
[    0.196959] mctp: management component transport protocol core
[    0.196959] NET: Registered PF_MCTP protocol family
[    0.196959] PCI: Using ACPI for IRQ routing
[    0.203585] PCI: pci_cache_line_size set to 64 bytes
[    0.203625] e820: reserve RAM buffer [mem 0x0009e800-0x0009ffff]
[    0.203644] e820: reserve RAM buffer [mem 0x7bd3f000-0x7bffffff]
[    0.203646] e820: reserve RAM buffer [mem 0x7bd65000-0x7bffffff]
[    0.203647] e820: reserve RAM buffer [mem 0x96cf9000-0x97ffffff]
[    0.203649] e820: reserve RAM buffer [mem 0x9c70e000-0x9fffffff]
[    0.203650] e820: reserve RAM buffer [mem 0x9cfff000-0x9fffffff]
[    0.203652] e820: reserve RAM buffer [mem 0x15f000000-0x15fffffff]
[    0.203674] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.203674] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.203674] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.203674] vgaarb: loaded
[    0.205634] clocksource: Switched to clocksource tsc-early
[    0.219345] VFS: Disk quotas dquot_6.6.0
[    0.219367] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.219488] pnp: PnP ACPI init
[    0.220265] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.220271] system 00:00: [io  0xffff] has been reserved
[    0.220273] system 00:00: [io  0xffff] has been reserved
[    0.220275] system 00:00: [io  0xffff] has been reserved
[    0.220277] system 00:00: [io  0x1800-0x18fe] has been reserved
[    0.220279] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.220407] system 00:02: [io  0x1854-0x1857] has been reserved
[    0.221038] system 00:05: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.221042] system 00:05: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.221045] system 00:05: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.221048] system 00:05: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.221050] system 00:05: [mem 0xe0000000-0xefffffff] has been reserved
[    0.221052] system 00:05: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.221054] system 00:05: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.221057] system 00:05: [mem 0xfed45000-0xfed8ffff] could not be reserved
[    0.221059] system 00:05: [mem 0xff000000-0xffffffff] could not be reserved
[    0.221061] system 00:05: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.221063] system 00:05: [mem 0xa0010000-0xa001ffff] has been reserved
[    0.221066] system 00:05: [mem 0xa0000000-0xa000ffff] has been reserved
[    0.221455] pnp: PnP ACPI: found 6 devices
[    0.227465] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.227546] NET: Registered PF_INET protocol family
[    0.227637] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.228868] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.228923] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.228959] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.229111] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.229346] TCP: Hash tables configured (established 32768 bind 32768)
[    0.229425] MPTCP token hash table entries: 4096 (order: 4, 98304 bytes, linear)
[    0.229453] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.229471] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.229520] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.229532] NET: Registered PF_XDP protocol family
[    0.229538] pci 0000:00:1c.0: bridge window [io  0x1000-0x0fff] to [bus 01] add_size 1000
[    0.229544] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01] add_size 200000 add_align 100000
[    0.229549] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 01] add_size 200000 add_align 100000
[    0.229560] pci 0000:00:1c.0: BAR 14: assigned [mem 0xa0100000-0xa02fffff]
[    0.229564] pci 0000:00:1c.0: BAR 15: assigned [mem 0xa0300000-0xa04fffff 64bit pref]
[    0.229568] pci 0000:00:1c.0: BAR 13: assigned [io  0x2000-0x2fff]
[    0.229572] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.229575] pci 0000:00:1c.0:   bridge window [io  0x2000-0x2fff]
[    0.229580] pci 0000:00:1c.0:   bridge window [mem 0xa0100000-0xa02fffff]
[    0.229584] pci 0000:00:1c.0:   bridge window [mem 0xa0300000-0xa04fffff 64bit pref]
[    0.229590] pci 0000:00:1c.2: PCI bridge to [bus 02]
[    0.229592] pci 0000:00:1c.2:   bridge window [io  0x4000-0x4fff]
[    0.229596] pci 0000:00:1c.2:   bridge window [mem 0xc1100000-0xc11fffff]
[    0.229603] pci 0000:00:1c.3: PCI bridge to [bus 03]
[    0.229606] pci 0000:00:1c.3:   bridge window [io  0x3000-0x3fff]
[    0.229610] pci 0000:00:1c.3:   bridge window [mem 0xc1000000-0xc10fffff]
[    0.229618] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.229620] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.229622] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.229624] pci_bus 0000:00: resource 7 [mem 0xa0000000-0xdfffffff window]
[    0.229626] pci_bus 0000:00: resource 8 [mem 0xfe101000-0xfe113fff window]
[    0.229628] pci_bus 0000:01: resource 0 [io  0x2000-0x2fff]
[    0.229630] pci_bus 0000:01: resource 1 [mem 0xa0100000-0xa02fffff]
[    0.229631] pci_bus 0000:01: resource 2 [mem 0xa0300000-0xa04fffff 64bit pref]
[    0.229634] pci_bus 0000:02: resource 0 [io  0x4000-0x4fff]
[    0.229635] pci_bus 0000:02: resource 1 [mem 0xc1100000-0xc11fffff]
[    0.229637] pci_bus 0000:03: resource 0 [io  0x3000-0x3fff]
[    0.229639] pci_bus 0000:03: resource 1 [mem 0xc1000000-0xc10fffff]
[    0.229892] pci 0000:00:14.0: can't derive routing for PCI INT A
[    0.229894] pci 0000:00:14.0: PCI INT A: no GSI
[    0.245364] pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x7d0 took 13760 usecs
[    0.245390] PCI: CLS 64 bytes, default 64
[    0.245404] DMAR: Failed to find handle for ACPI object \_SB.PCI0.SDMA
[    0.245407] DMAR: Failed to find handle for ACPI object \_SB.PCI0.SDHC
[    0.245420] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.245421] software IO TLB: mapped [mem 0x000000009870e000-0x000000009c70e000] (64MB)
[    0.245459] Trying to unpack rootfs image as initramfs...
[    0.246299] Initialise system trusted keyrings
[    0.246311] Key type blacklist registered
[    0.246381] workingset: timestamp_bits=41 max_order=20 bucket_order=0
[    0.246401] zbud: loaded
[    0.246621] integrity: Platform Keyring initialized
[    0.246625] integrity: Machine keyring initialized
[    0.258548] Key type asymmetric registered
[    0.258551] Asymmetric key parser 'x509' registered
[    0.258584] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.258660] io scheduler mq-deadline registered
[    0.258663] io scheduler kyber registered
[    0.258680] io scheduler bfq registered
[    0.259104] pcieport 0000:00:1c.0: PME: Signaling with IRQ 42
[    0.259133] pcieport 0000:00:1c.0: pciehp: Slot #0 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[    0.259436] pcieport 0000:00:1c.2: PME: Signaling with IRQ 43
[    0.259646] pcieport 0000:00:1c.3: PME: Signaling with IRQ 44
[    0.259732] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    0.260846] ACPI: AC: AC Adapter [ADP0] (off-line)
[    0.260923] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[    0.271971] ACPI: button: Lid Switch [LID0]
[    0.272018] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[    0.275316] ACPI: button: Power Button [PWRB]
[    0.275373] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[    0.275480] ACPI: button: Power Button [PWRF]
[    0.276104] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    0.283182] hpet_acpi_add: no address or irqs in _CRS
[    0.283240] Non-volatile memory driver v1.3
[    0.283242] Linux agpgart interface v0.103
[    0.295290] AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
[    0.295328] ACPI: bus type drm_connector registered
[    0.295732] [drm] Initialized simpledrm 1.0.0 20200625 for simple-framebuffer.0 on minor 0
[    0.296393] fbcon: Deferring console take-over
[    0.296396] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[    0.296888] ahci 0000:00:1f.2: version 3.0
[    0.307153] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    0.307159] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[    0.307485] scsi host0: ahci
[    0.307663] scsi host1: ahci
[    0.307737] ata1: SATA max UDMA/133 abar m2048@0xc1218000 port 0xc1218100 irq 45
[    0.307742] ata2: SATA max UDMA/133 abar m2048@0xc1218000 port 0xc1218180 irq 45
[    0.307898] usbcore: registered new interface driver usbserial_generic
[    0.307908] usbserial: USB Serial support registered for generic
[    0.308054] ehci-pci 0000:00:1d.0: EHCI Host Controller
[    0.308067] rtc_cmos 00:01: RTC can wake from S4
[    0.308068] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 1
[    0.308081] ehci-pci 0000:00:1d.0: debug port 2
[    0.308439] rtc_cmos 00:01: registered as rtc0
[    0.308487] rtc_cmos 00:01: setting system clock to 2023-09-24T15:27:36 UTC (1695569256)
[    0.308528] rtc_cmos 00:01: alarms up to one month, 242 bytes nvram
[    0.308632] intel_pstate: Intel P-state driver initializing
[    0.308939] ledtrig-cpu: registered to indicate activity on CPUs
[    0.309385] hid: raw HID events driver (C) Jiri Kosina
[    0.309608] drop_monitor: Initializing network drop monitor service
[    0.312010] ehci-pci 0000:00:1d.0: irq 23, io mem 0xc1219000
[    0.325278] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    0.325370] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
[    0.325378] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.325382] usb usb1: Product: EHCI Host Controller
[    0.325384] usb usb1: Manufacturer: Linux 6.5.3-1-MANJARO ehci_hcd
[    0.325387] usb usb1: SerialNumber: 0000:00:1d.0
[    0.325620] hub 1-0:1.0: USB hub found
[    0.325631] hub 1-0:1.0: 2 ports detected
[    0.327883] Initializing XFRM netlink socket
[    0.327930] NET: Registered PF_INET6 protocol family
[    0.386273] ACPI: battery: Slot [BAT0] (battery present)
[    0.546284] Freeing initrd memory: 22212K
[    0.554591] Segment Routing with IPv6
[    0.554595] RPL Segment Routing with IPv6
[    0.554610] In-situ OAM (IOAM) with IPv6
[    0.554647] NET: Registered PF_PACKET protocol family
[    0.555016] microcode: Microcode Update Driver: v2.2.
[    0.555025] IPI shorthand broadcast: enabled
[    0.557301] sched_clock: Marking stable (553337245, 1906053)->(584091474, -28848176)
[    0.557491] registered taskstats version 1
[    0.557789] Loading compiled-in X.509 certificates
[    0.562112] Loaded X.509 cert 'Build time autogenerated kernel key: b678539ac47544d6e6a423cd159eb7544d97d454'
[    0.563136] zswap: loaded using pool zstd/zsmalloc
[    0.565677] Key type .fscrypt registered
[    0.565680] Key type fscrypt-provisioning registered
[    0.566088] PM:   Magic number: 7:340:488
[    0.566155] regulator regulator.0: hash matches
[    0.569862] RAS: Correctable Errors collector initialized.
[    0.569942] clk: Disabling unused clocks
[    0.575311] usb 1-1: new high-speed USB device number 2 using ehci-pci
[    0.621977] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    0.621998] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    0.625542] ata2.00: ATAPI: PLDS    DVD-RW DA8AESH, XL61, max UDMA/133
[    0.626706] ata2.00: configured for UDMA/133
[    0.628069] ata1.00: LPM support broken, forcing max_power
[    0.628209] ata1.00: ATA-8: ST1000LM024 HN-M101MBB, 2BA30001, max UDMA/100
[    0.628214] ata1.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 32)
[    0.634361] ata1.00: LPM support broken, forcing max_power
[    0.634494] ata1.00: configured for UDMA/100
[    0.644997] scsi 0:0:0:0: Direct-Access     ATA      ST1000LM024 HN-M 0001 PQ: 0 ANSI: 5
[    0.646025] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    0.646035] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    0.646070] sd 0:0:0:0: [sda] Write Protect is off
[    0.646077] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    0.646130] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    0.646203] sd 0:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[    0.649333] scsi 1:0:0:0: CD-ROM            PLDS     DVD-RW DA8AESH   XL61 PQ: 0 ANSI: 5
[    0.698921]  sda: sda1 sda2 sda3 sda4 sda5
[    0.699378] sd 0:0:0:0: [sda] Attached SCSI disk
[    0.722517] usb 1-1: New USB device found, idVendor=8087, idProduct=8001, bcdDevice= 0.03
[    0.722523] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    0.723237] hub 1-1:1.0: USB hub found
[    0.723438] hub 1-1:1.0: 8 ports detected
[    0.768138] Freeing unused decrypted memory: 2036K
[    0.769565] Freeing unused kernel image (initmem) memory: 3400K
[    0.769656] Write protecting the kernel read-only data: 30720k
[    0.770978] Freeing unused kernel image (rodata/data gap) memory: 1308K
[    0.888161] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.888168] rodata_test: all tests were successful
[    0.888170] x86/mm: Checking user space page tables
[    0.958848] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    0.958854] Run /init as init process
[    0.958856]   with arguments:
[    0.958858]     /init
[    0.958859]     splash
[    0.958860]   with environment:
[    0.958861]     HOME=/
[    0.958862]     TERM=linux
[    0.958863]     BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
[    1.271933] tsc: Refined TSC clocksource calibration: 1995.381 MHz
[    1.271947] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x398645f40a8, max_idle_ns: 881590586805 ns
[    1.271977] clocksource: Switched to clocksource tsc
[    1.287116] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[    1.305893] serio: i8042 KBD port at 0x60,0x64 irq 1
[    1.306591] serio: i8042 AUX port at 0x60,0x64 irq 12
[    1.316026] xhci_hcd 0000:00:14.0: can't derive routing for PCI INT A
[    1.316033] xhci_hcd 0000:00:14.0: PCI INT A: no GSI
[    1.316072] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.316084] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    1.317252] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x000000000004b810
[    1.317838] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    1.317848] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[    1.317855] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    1.318067] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.05
[    1.318073] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.318076] usb usb2: Product: xHCI Host Controller
[    1.318079] usb usb2: Manufacturer: Linux 6.5.3-1-MANJARO xhci-hcd
[    1.318082] usb usb2: SerialNumber: 0000:00:14.0
[    1.318448] hub 2-0:1.0: USB hub found
[    1.318467] hub 2-0:1.0: 11 ports detected
[    1.329922] usb usb3: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.05
[    1.329931] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.329935] usb usb3: Product: xHCI Host Controller
[    1.329938] usb usb3: Manufacturer: Linux 6.5.3-1-MANJARO xhci-hcd
[    1.329941] usb usb3: SerialNumber: 0000:00:14.0
[    1.330273] hub 3-0:1.0: USB hub found
[    1.330289] hub 3-0:1.0: 4 ports detected
[    1.355706] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[    1.396729] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[    1.396735] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.439473] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    1.578620] usb 2-2: new full-speed USB device number 2 using xhci_hcd
[    1.724169] usb 2-2: New USB device found, idVendor=062a, idProduct=4101, bcdDevice= 1.01
[    1.724176] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.724178] usb 2-2: Product: 2.4G Keyboard Mouse
[    1.724180] usb 2-2: Manufacturer: MOSART Semi.
[    1.736028] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/0003:062A:4101.0001/input/input5
[    1.792186] hid-generic 0003:062A:4101.0001: input,hidraw0: USB HID v1.10 Keyboard [MOSART Semi. 2.4G Keyboard Mouse] on usb-0000:00:14.0-2/input0
[    1.795087] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.1/0003:062A:4101.0002/input/input6
[    1.795217] input: MOSART Semi. 2.4G Keyboard Mouse Consumer Control as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.1/0003:062A:4101.0002/input/input7
[    1.848647] usb 2-4: new high-speed USB device number 3 using xhci_hcd
[    1.848866] input: MOSART Semi. 2.4G Keyboard Mouse System Control as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.1/0003:062A:4101.0002/input/input8
[    1.849034] input: MOSART Semi. 2.4G Keyboard Mouse as /devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.1/0003:062A:4101.0002/input/input9
[    1.849319] hid-generic 0003:062A:4101.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [MOSART Semi. 2.4G Keyboard Mouse] on usb-0000:00:14.0-2/input1
[    1.849421] usbcore: registered new interface driver usbhid
[    1.849426] usbhid: USB HID core driver
[    1.989021] usb 2-4: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
[    1.989028] usb 2-4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    1.989030] usb 2-4: Product: USB2.0-CRW
[    1.989032] usb 2-4: Manufacturer: Generic
[    1.989034] usb 2-4: SerialNumber: 20100201396000000
[    2.002392] usbcore: registered new interface driver rtsx_usb
[    2.111981] usb 2-6: new high-speed USB device number 4 using xhci_hcd
[    2.276912] usb 2-6: New USB device found, idVendor=04f2, idProduct=b572, bcdDevice=95.60
[    2.276919] usb 2-6: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    2.276921] usb 2-6: Product: Lenovo EasyCamera
[    2.276923] usb 2-6: Manufacturer: Chicony Electronics Co.,Ltd.
[    2.276925] usb 2-6: SerialNumber: 0x0001
[    2.401982] usb 2-7: new full-speed USB device number 5 using xhci_hcd
[    2.431376] EXT4-fs (sda3): mounted filesystem a58ccd07-1439-4d19-834b-cfdb281916a2 r/w with ordered data mode. Quota mode: none.
[    2.550335] usb 2-7: New USB device found, idVendor=0bda, idProduct=b728, bcdDevice= 2.00
[    2.550342] usb 2-7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.550344] usb 2-7: Product: Bluetooth Radio
[    2.550346] usb 2-7: Manufacturer: Realtek
[    2.550348] usb 2-7: SerialNumber: 00e04c000001
[    3.391336] fbcon: Taking over console
[    3.395876] Console: switching to colour frame buffer device 170x48
[    4.033809] systemd[1]: systemd 254.3-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[    4.033834] systemd[1]: Detected architecture x86-64.
[    4.101779] systemd[1]: Hostname set to <preiwer-80qq>.
[    4.960537] systemd[1]: bpf-lsm: LSM BPF program attached
[    9.947790] zram: Added device: zram0
[   10.810891] systemd[1]: Queued start job for default target Graphical Interface.
[   10.836837] systemd[1]: Created slice Slice /system/getty.
[   10.837320] systemd[1]: Created slice Slice /system/modprobe.
[   10.837718] systemd[1]: Created slice Slice /system/systemd-zram-setup.
[   10.838027] systemd[1]: Created slice User and Session Slice.
[   10.838132] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   10.838395] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   10.838454] systemd[1]: Reached target Login Prompts.
[   10.838478] systemd[1]: Reached target Local Integrity Protected Volumes.
[   10.838511] systemd[1]: Reached target Remote File Systems.
[   10.838528] systemd[1]: Reached target Slice Units.
[   10.838566] systemd[1]: Reached target Local Verity Protected Volumes.
[   10.838693] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   10.838874] systemd[1]: Listening on LVM2 poll daemon socket.
[   10.840493] systemd[1]: Listening on Process Core Dump Socket.
[   10.840688] systemd[1]: Listening on Journal Socket (/dev/log).
[   10.840874] systemd[1]: Listening on Journal Socket.
[   10.853284] systemd[1]: Listening on udev Control Socket.
[   10.853471] systemd[1]: Listening on udev Kernel Socket.
[   10.854807] systemd[1]: Mounting Huge Pages File System...
[   10.856066] systemd[1]: Mounting POSIX Message Queue File System...
[   10.857336] systemd[1]: Mounting Kernel Debug File System...
[   10.858602] systemd[1]: Mounting Kernel Trace File System...
[   10.860337] systemd[1]: Starting Create List of Static Device Nodes...
[   10.861748] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   10.864088] systemd[1]: Starting Load Kernel Module configfs...
[   10.865926] systemd[1]: Starting Load Kernel Module dm_mod...
[   10.868108] systemd[1]: Starting Load Kernel Module drm...
[   10.870242] systemd[1]: Starting Load Kernel Module fuse...
[   10.871962] systemd[1]: Starting Load Kernel Module loop...
[   10.872198] systemd[1]: File System Check on Root Device was skipped because of an unmet condition check (ConditionPathIsReadWrite=!/).
[   10.978844] systemd[1]: Starting Load Kernel Modules...
[   10.978888] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/StubPcrKernelImage-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[   10.980228] systemd[1]: Starting Remount Root and Kernel File Systems...
[   10.981530] systemd[1]: Starting Coldplug All udev Devices...
[   10.982843] systemd[1]: Starting Virtual Console Setup...
[   10.985019] systemd[1]: Mounted Huge Pages File System.
[   10.985367] systemd[1]: Mounted POSIX Message Queue File System.
[   10.985604] systemd[1]: Mounted Kernel Debug File System.
[   10.985833] systemd[1]: Mounted Kernel Trace File System.
[   10.986284] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   10.992130] loop: module loaded
[   11.029838] systemd[1]: Finished Load Kernel Module configfs.
[   11.060311] EXT4-fs (sda3): re-mounted a58ccd07-1439-4d19-834b-cfdb281916a2 r/w. Quota mode: none.
[   11.065538] systemd[1]: Finished Create List of Static Device Nodes.
[   11.066973] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   11.108890] systemd[1]: Finished Load Kernel Module drm.
[   11.109368] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   11.145553] systemd[1]: Finished Load Kernel Module loop.
[   11.168886] systemd[1]: Finished Remount Root and Kernel File Systems.
[   11.193705] device-mapper: uevent: version 1.0.3
[   11.193816] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[   11.205516] systemd[1]: Mounting Kernel Configuration File System...
[   11.249085] fuse: init (API version 7.38)
[   11.382899] systemd[1]: Rebuild Hardware Database was skipped because no trigger condition checks were met.
[   11.398903] systemd[1]: Starting Load/Save OS Random Seed...
[   11.400253] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[   11.401577] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   11.418849] systemd[1]: Finished Load Kernel Module dm_mod.
[   11.419369] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   11.435601] systemd[1]: Finished Load Kernel Module fuse.
[   11.435898] systemd[1]: Mounted Kernel Configuration File System.
[   11.455530] systemd[1]: Mounting FUSE Control File System...
[   11.455678] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[   11.458238] systemd[1]: Mounted FUSE Control File System.
[   11.485521] systemd[1]: Finished Load Kernel Modules.
[   11.488090] systemd[1]: Starting Apply Kernel Variables...
[   11.752165] systemd[1]: Finished Coldplug All udev Devices.
[   11.808817] systemd[1]: Finished Apply Kernel Variables.
[   11.948837] systemd[1]: Finished Load/Save OS Random Seed.
[   12.318814] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[   12.412166] systemd[1]: Finished Virtual Console Setup.
[   12.482170] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[   12.505636] systemd[1]: Starting Create System Users...
[   12.988844] systemd[1]: Finished Create System Users.
[   13.012301] systemd[1]: Starting Create Static Device Nodes in /dev...
[   13.065619] systemd[1]: Finished Create Static Device Nodes in /dev.
[   13.065991] systemd[1]: Reached target Preparation for Local File Systems.
[   13.066171] systemd[1]: Set up automount EFI System Partition Automount.
[   13.066220] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of an unmet condition check (ConditionPathExists=/var/lib/machines.raw).
[   13.066291] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of an unmet condition check (ConditionKernelVersion=<5.6).
[   13.068343] systemd[1]: Starting Journal Service...
[   13.069848] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   13.145894] systemd-journald[225]: Collecting audit messages is disabled.
[   13.200989] systemd[1]: Started Journal Service.
[   13.275168] systemd-journald[225]: Received client request to flush runtime journal.
[   13.778531] systemd-journald[225]: /var/log/journal/d3de3fba32e141cf9e0e13980ee49b85/system.journal: Journal file uses a different sequence number ID, rotating.
[   13.778544] systemd-journald[225]: Rotating system journal.
[   15.887094] zram0: detected capacity change from 0 to 20480000
[   16.441588] input: PC Speaker as /devices/platform/pcspkr/input/input10
[   16.912364] i801_smbus 0000:00:1f.3: SPD Write Disable is set
[   16.912401] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[   16.913546] i2c i2c-0: 1/2 memory slots populated (from DMI)
[   16.913879] i2c i2c-0: Successfully instantiated SPD at 0x50
[   16.977933] Adding 10239996k swap on /dev/zram0.  Priority:100 extents:1 across:10239996k SSDscFS
[   17.896532] input: Ideapad extra buttons as /devices/pci0000:00/0000:00:1f.0/PNP0C09:00/VPC2004:00/input/input12
[   17.907543] ideapad_acpi VPC2004:00: Keyboard backlight control not available
[   17.941464] RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer
[   17.941470] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   17.941472] RAPL PMU: hw unit of domain package 2^-14 Joules
[   17.941473] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   17.941474] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   17.956230] ideapad_acpi VPC2004:00: DYTC interface is not available
[   18.033681] cryptd: max_cpu_qlen set to 1000
[   18.141427] mousedev: PS/2 mouse device common for all mice
[   18.177890] at24 0-0050: supply vcc not found, using dummy regulator
[   18.178465] at24 0-0050: 256 byte spd EEPROM, read-only
[   18.202520] iTCO_vendor_support: vendor-support=0
[   18.316203] psmouse serio1: elantech: assuming hardware version 4 (with firmware version 0x5e0f01)
[   18.322514] Bluetooth: Core ver 2.22
[   18.322542] NET: Registered PF_BLUETOOTH protocol family
[   18.322544] Bluetooth: HCI device and connection manager initialized
[   18.322550] Bluetooth: HCI socket layer initialized
[   18.322552] Bluetooth: L2CAP socket layer initialized
[   18.322559] Bluetooth: SCO socket layer initialized
[   18.333060] psmouse serio1: elantech: Synaptics capabilities query result 0x71, 0x12, 0x09.
[   18.350204] psmouse serio1: elantech: Elan sample query result 05, 12, 97
[   18.443987] iTCO_wdt iTCO_wdt.3.auto: Found a Wildcat Point_LP TCO device (Version=2, TCOBASE=0x1860)
[   18.444169] iTCO_wdt iTCO_wdt.3.auto: initialized. heartbeat=30 sec (nowayout=0)
[   18.446112] input: ETPS/2 Elantech Touchpad as /devices/platform/i8042/serio1/input/input11
[   18.511304] AVX2 version of gcm_enc/dec engaged.
[   18.511360] AES CTR mode by8 optimization enabled
[   18.673345] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   18.673876] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   18.859534] mc: Linux media interface: v0.10
[   19.071361] usbcore: registered new interface driver btusb
[   19.076509] Bluetooth: hci0: RTL: examining hci_ver=06 hci_rev=000b lmp_ver=06 lmp_subver=8723
[   19.077490] Bluetooth: hci0: RTL: rom_version status=0 version=1
[   19.077494] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_fw.bin
[   19.202840] videodev: Linux video capture interface: v2.00
[   19.202905] Bluetooth: hci0: RTL: loading rtl_bt/rtl8723b_config.bin
[   19.203006] bluetooth hci0: Direct firmware load for rtl_bt/rtl8723b_config.bin failed with error -2
[   19.203022] Bluetooth: hci0: RTL: cfg_sz -2, total sz 22496
[   19.292729] spi-nor spi0.0: s25fl064k (8192 Kbytes)
[   19.304976] Creating 1 MTD partitions on "intel-spi":
[   19.304983] 0x000000000000-0x000000800000 : "BIOS"
[   19.687716] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[   19.704824] r8169 0000:02:00.0 eth0: RTL8106eus, c8:5b:76:63:87:77, XID 509, IRQ 48
[   19.745165] usb 2-6: Found UVC 1.00 device Lenovo EasyCamera (04f2:b572)
[   19.747739] usbcore: registered new interface driver uvcvideo
[   19.866276] rtl8723be: Using firmware rtlwifi/rtl8723befw_36.bin
[   19.872183] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[   19.873473] rtlwifi: rtlwifi: wireless switch is on
[   19.977999] r8169 0000:02:00.0 enp2s0: renamed from eth0
[   20.006507] Bluetooth: hci0: RTL: fw version 0x0e2f9f73
[   20.111448] rtl8723be 0000:03:00.0 wlp3s0: renamed from wlan0
[   20.805369] Console: switching to colour dummy device 80x25
[   20.822285] i915 0000:00:02.0: vgaarb: deactivate vga console
[   20.823928] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   20.882978] [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 1
[   20.886098] ACPI: video: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   20.886357] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13
[   20.886600] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   20.892687] fbcon: i915drmfb (fb0) is primary device
[   20.904536] snd_hda_codec_conexant hdaudioC1D0: CX20751/2: BIOS auto-probing.
[   20.908916] snd_hda_codec_conexant hdaudioC1D0: autoconfig for CX20751/2: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[   20.908924] snd_hda_codec_conexant hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   20.908929] snd_hda_codec_conexant hdaudioC1D0:    hp_outs=1 (0x16/0x0/0x0/0x0/0x0)
[   20.908934] snd_hda_codec_conexant hdaudioC1D0:    mono: mono_out=0x0
[   20.908936] snd_hda_codec_conexant hdaudioC1D0:    inputs:
[   20.908939] snd_hda_codec_conexant hdaudioC1D0:      Internal Mic=0x1a
[   20.908943] snd_hda_codec_conexant hdaudioC1D0:      Mic=0x19
[   22.008861] Console: switching to colour frame buffer device 170x48
[   22.028265] i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device
[   22.045418] input: HDA Intel PCH Mic as /devices/pci0000:00/0000:00:1b.0/sound/card1/input14
[   22.045651] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card1/input15
[   22.552761] input: HDA Intel HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.0/sound/card0/input16
[   22.552852] input: HDA Intel HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.0/sound/card0/input17
[   22.552930] input: HDA Intel HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.0/sound/card0/input18
[   22.688620] intel_rapl_common: Found RAPL domain package
[   22.688625] intel_rapl_common: Found RAPL domain core
[   22.688627] intel_rapl_common: Found RAPL domain uncore
[   22.688628] intel_rapl_common: Found RAPL domain dram
[   22.688635] intel_rapl_common: package-0:package:long_term locked by BIOS
[   22.688638] intel_rapl_common: package-0:package:short_term locked by BIOS
[   25.646507] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   25.646512] Bluetooth: BNEP filters: protocol multicast
[   25.646519] Bluetooth: BNEP socket layer initialized
[   25.649343] Bluetooth: MGMT ver 1.22
[   25.724579] NET: Registered PF_ALG protocol family
[   28.705309] Generic FE-GE Realtek PHY r8169-0-200:00: attached PHY driver (mii_bus:phy_addr=r8169-0-200:00, irq=MAC)
[   28.761205] NET: Registered PF_QIPCRTR protocol family
[   28.885410] r8169 0000:02:00.0 enp2s0: Link is Down
[   33.210792] wlp3s0: authenticate with 1c:3d:2f:35:1a:78
[   33.210835] wlp3s0: 80 MHz not supported, disabling VHT
[   33.716342] wlp3s0: send auth to 1c:3d:2f:35:1a:78 (try 1/3)
[   33.717809] wlp3s0: authenticated
[   33.718779] wlp3s0: associate with 1c:3d:2f:35:1a:78 (try 1/3)
[   33.724963] wlp3s0: RX AssocResp from 1c:3d:2f:35:1a:78 (capab=0x1431 status=0 aid=15)
[   33.725228] wlp3s0: associated
[   33.885500] wlp3s0: Limiting TX power to 20 (20 - 0) dBm as advertised by 1c:3d:2f:35:1a:78
[   42.117007] sddm-greeter[513]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[   68.312640] systemd-journald[225]: /var/log/journal/d3de3fba32e141cf9e0e13980ee49b85/user-1000.journal: Journal file uses a different sequence number ID, rotating.
[   86.599277] warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[   99.907320] Bluetooth: RFCOMM TTY layer initialized
[   99.907333] Bluetooth: RFCOMM socket layer initialized
[   99.907337] Bluetooth: RFCOMM ver 1.11
[ 1975.808497] perf: interrupt took too long (2605 > 2500), lowering kernel.perf_event_max_sample_rate to 76500
[ 2630.771486] perf: interrupt took too long (3312 > 3256), lowering kernel.perf_event_max_sample_rate to 60300
[ 3218.188929] perf: interrupt took too long (4195 > 4140), lowering kernel.perf_event_max_sample_rate to 47400
[ 4103.788232] perf: interrupt took too long (5382 > 5243), lowering kernel.perf_event_max_sample_rate to 36900
[ 4246.977974] rtlwifi: AP off, try to reconnect now
[ 4246.977991] wlp3s0: Connection to AP 1c:3d:2f:35:1a:78 lost
[ 4257.644636] rtlwifi: AP off, try to reconnect now
[ 4285.929176] rtl8723be: Init MAC failed
the log of the error is in the last
I think, first try it without the antenna selection:
First, remove the current file:
sudo rm sudo nano /etc/modprobe.d/rtl8723be.conf
Then create a new one without the antenna selection:
echo "options rtl8723be fwlps=0" | sudo tee /etc/modprobe.d/rtl8723be.conf
And try rebooting.
If that still doesn’t work, there’s one last thing we can try, which I don’t know if it’ll make a difference, but it might. It won’t.
:thinking:
My (very) bad. Fixed now, thank you!
Can you explain, why this error happens???
I’m unsure, but according to what I understand from the Arch wiki, it’s because the NIC goes into power-saving mode. Or something like that anyway.
Thank you for your eagerness. I’ve been trying to solve this problem for 3-4 months now.
But I haven’t found any clues. But you could find this clue in a day :slight_smile:
The Arch wiki is your friend!
