Hello community,
Another unstable branch update with some usual updates for you.
Rumours stating pacman-mirrors is unmaintained has it all wrong. Pacman-mirrors is a core Manjaro package and will not become unmaintained.
With this package sync - pacman-mirrors is v4.23.1 with numereous small cosmetic fixes over the past months.
Find out whats new in Python 3.10
- We pulled 2560 packages from Arch due to Python 3.10 rebuilds.
- We will start to build our overlay packages against that, which might take a while
- Report any issues you may have with this
You will need to rebuild any AUR packages that install files to site-packages. ![]()
You may need to rebuild any Python packages you’ve installed from the AUR. To get a list of them, you can run:
pacman -Qoq /usr/lib/python3.9And to rebuild them all at once with an AUR helper such as
yay, you can do:yay -S $(pacman -Qoq /usr/lib/python3.9) --answerclean AllBut if any of the packages don’t work with Python 3.10 yet, this might fail halfway through and you’ll have to do rebuild the remaining ones one or a few at a time.
Get our latest daily developer images now from Github: Plasma, Gnome, XFCE. You get the latest stable releases of Manjaro from CDN77.
Our current supported kernels
- linux44 4.4.294
- linux49 4.9.292
- linux414 4.14.257
- linux419 4.19.220
- linux54 5.4.164
- linux510 5.10.84
- linux514 5.14.21 [EOL]
- linux515 5.15.7
- linux516 5.16-rc4
- linux510-rt 5.10.83_rt58
- linux515-rt 5.15.5_rt22
Package Updates (Mon Dec 13 01:34:38 CET 2021)
- unstable core x86_64: 29 new and 29 removed package(s)
- unstable multilib x86_64: 1 new and 1 removed package(s)
- unstable extra x86_64: 272 new and 272 removed package(s)
- unstable community x86_64: 2258 new and 2258 removed package(s)
A detailed list of package changes can be found here
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself.(Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
