Despite the amount of packages and their total size I only had a couple of minor issues, one was infamous “signature … is marginal trust” and another one with python-language-server which I should have removed long ago.
Thanks, this was a flawless experience!
4 posts were split to a new topic: qBittorrent lost it’s system tray’s monochome icons
Got the `Changing NetworkManager Connectivity-Ping to manjaro.org` notification, but afterwards the app actually connects to ping.manjaro.org (was caught by firewall)
I found odd that by updating
To upgrade (3):
networkmanager 1.32.12-2 (1.32.12-1) extra 3.5 MB
Reloading system bus configuration... [6/7]
Changing NetworkManager Connectivity-Ping to manjaro.org [7/7]
and after manual turn off and on the network connection I found that the network manager still connects to ping.manjaro.org:80
If I found exact config file, then it’s content is:
~/Desktop ❯ cat /usr/lib/NetworkManager/conf.d/20-connectivity.conf
[connectivity]
uri=http://ping.manjaro.org/check_network_status.txt
~/Desktop ❯ ls -A1 /usr/lib/NetworkManager/conf.d/
~/Desktop ❯
~/Desktop ❯ ls -A1 /etc/NetworkManager/conf.d
~/Desktop ❯
@philm, i have following packages not updated to latest revision of 32-bit mesa drivers;
lib32-libva-mesa-driver 21.3.1-0.1
lib32-mesa 21.3.1-0.1
lib32-mesa-vdpau 21.3.1-0.1
lib32-vulkan-intel 21.3.1-0.1
lib32-vulkan-radeon 21.3.1-0.1
i’ve also seen the above packages residing in both “community” and “multilib” repos. mine are from community repo, the ones in multilib repo are updated to the latest.
Summary
$ pacman -Si lib32-libva-mesa-driver
Repository : community
Version : 21.3.1-0.1
Description : VA-API implementation for gallium (32-bit)
Architecture : x86_64
URL : https://www.mesa3d.org/
Licenses : custom
Groups : None
Provides : None
Depends On : lib32-libdrm lib32-libx11 lib32-llvm-libs lib32-expat lib32-libelf lib32-libxshmfence lib32-zstd
Optional Deps : None
Conflicts With : None
Replaces : None
Download Size : 3.95 MiB
Installed Size : 11.87 MiB
Packager : Philip Mueller philm@manjaro.org
Build Date : Monday 06 December 2021 03:33:18 PM
Validated By : MD5 Sum SHA-256 Sum Signature
Repository : multilib
Version : 21.3.1-1
Licenses : custom
Groups : None
Provides : None
Replaces : None
Download Size : 3.21 MiB
Installed Size : 11.81 MiB
Packager : Laurent Carlier lordheavym@gmail.com
Build Date : Monday 06 December 2021 02:37:24 PM
This is how it looks btw:
lib32-vulkan-intel and lib32-vulkan-radeon are still present in community.
Your mirror is out of date then. I removed them right after @koshikas posted.
[2021-12-15T03:38:02+0300] [ALPM] upgraded linux515 (5.15.7-1 -> 5.15.8-1)
[2021-12-17T04:52:26+0300] [ALPM] upgraded linux515 (5.15.8-1 -> 5.15.9-1)
[2021-12-18T12:30:53+0300] [ALPM] upgraded linux515 (5.15.9-1 -> 5.15.10-1)
What’s up with 5.15 kernel gen? Why so frequent updates?
Usually 1 update per week, now 3 updates per 3 days already, so another 2 are… urgent? What happen?
Constant need for PC reboots…
If they are urgent, then why 5.15.7 in stable and 5.15.8 in testing still? (Manjaro - Branch Compare)
I get this error of loading Kernel Modul acpi_call (Old ThinkPad T60):
Dez 17 18:50:26 memepad kernel: acpi_call: version magic '5.16.0-1-MANJARO SMP preempt mod_unload ' should be '5.15.10-1-MANJARO SMP preempt mod_unload '
Dez 17 18:50:26 memepad systemd-modules-load[269]: Failed to insert module 'acpi_call': Exec format error
Dez 17 18:50:27 memepad systemd[1]: Failed to start Load Kernel Modules.
@oberon it’s happen because of the patch removal?
they were released as frequently as well. surely must be for obvious reasons, than when its not. no reasons to complain if its that serious anyway.
and we are in unstable branch afterall, sooner we have nothing to alarm functionally, the other branches can get them as well (the last changelog is lenghthy)
I guess you’re talking about this?
@Yochanan Has libreswan been removed? I went to install networkmanager-l2tp which has libreswan as a recommended dependency, but such package is missing in the repo.
libreswan has always been in the AUR and so was networkmanager-l2tp until last February. I’ll let the Arch package maintainer know he forgot to import libreswan along with it.
EDIT: The maintainer decided to drop libreswan from optional dependencies instead of importing it.
Perhaps, GRUB update involved.
PC boot up directly after grub menu: `error: sparse file not allowed`
After
the update
~/Desktop ❯ tail -n18 /var/log/pacman.log
[2021-12-26T08:17:41+0300] [PAMAC] synchronizing package lists
[2021-12-26T08:18:32+0300] [ALPM] transaction started
[2021-12-26T08:18:33+0300] [ALPM] upgraded opencv (4.5.4-11 -> 4.5.5-1)
[2021-12-26T08:18:33+0300] [ALPM] upgraded gmic (3.0.0-2 -> 3.0.0-3)
[2021-12-26T08:18:33+0300] [ALPM] warning: /etc/default/grub installed as /etc/default/grub.pacnew
[2021-12-26T08:18:33+0300] [ALPM] upgraded grub (2.06-1 -> 2.06-2)
[2021-12-26T08:18:33+0300] [ALPM-SCRIPTLET] :: Grub does no longer support side-loading modules when secure boot is
[2021-12-26T08:18:33+0300] [ALPM-SCRIPTLET] enabled. Thus booting will fail, unless you have an efi executable
[2021-12-26T08:18:33+0300] [ALPM-SCRIPTLET] 'grubx64.efi' with bundled modules.
[2021-12-26T08:18:33+0300] [ALPM] upgraded gst-plugins-bad-libs (1.18.5-3 -> 1.18.5-4)
[2021-12-26T08:18:33+0300] [ALPM] upgraded gst-plugins-bad (1.18.5-3 -> 1.18.5-4)
[2021-12-26T08:18:33+0300] [ALPM] upgraded mlt (7.4.0-1 -> 7.4.0-2)
[2021-12-26T08:18:33+0300] [ALPM] upgraded mlt6 (6.26.1-7 -> 6.26.1-8)
[2021-12-26T08:18:34+0300] [ALPM] transaction completed
[2021-12-26T08:18:34+0300] [ALPM] running '30-systemd-update.hook'...
[2021-12-26T08:18:34+0300] [ALPM] running '90-packagekit-refresh.hook'...
[2021-12-26T08:18:34+0300] [ALPM] running 'texinfo-install.hook'...
[2021-12-26T08:29:31+0300] [PAMAC] synchronizing package lists
I got ordinary
but immediately after it the
If to press any key, booting proceeds fine (sddm, user session, etc.).
The message is absent in
~/Desktop ❯ journalctl -b | grep -i "sparse"
~/Desktop ❯ journalctl -b | grep -i "not allowed"
~/Desktop ❯
cat /etc/default/grub
~/Desktop ❯ cat /etc/default/grub
# If you want to enable the save default function, uncomment the following
# line, and set GRUB_DEFAULT to saved.
GRUB_SAVEDEFAULT=true
I have btrfs encrypted setup.
GRUB version in boot menu does not match grub package version
Compare
with the
~/Desktop ❯ pamac info grub | grep "Ver"
Version : 2.06-2
Going back to the issue above, it appears to happen only with kernel series 5.15 every time my system boots up from a restart. If I previously power off my system and then I boot it up again with kernel 5.15, then I will be able to manage Bluetooth devices from Gnome Settings. This odd behaviour was introduced for me after this major update, although it never happens with kernel series 5.10.
No big deal, but still I think it’s worth reporting this in case someone else experiences the same in future releases for the other branches.
Updated inxi output below (truncated) for further reference ![]()
Kernel: 5.15.11-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: root=UUID=59c46027-8f73-4e0e-a52e-825f3df72c29 rootfstype=xfs
add_efi_memmap acpi_osi='Windows 2020' lsm=lockdown,yama,apparmor,bpf
audit=1 initrd=\initramfs-5.15-x86_64.img
Desktop: GNOME 41.2 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.0
Type: Laptop System: Dell product: Inspiron 7559 v: 1.3.1
Mobo: Dell model: 0H0CC0 v: A00 serial: <superuser required> UEFI: Dell
v: 1.3.1 date: 12/02/2018
RAM: total: 15.5 GiB used: 6.86 GiB (44.3%)
RAM Report:
Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xCC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2911 high: 2995 min/max: 800/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 2995 2: 2918 3: 2900
4: 2900 5: 2900 6: 2900 7: 2900 8: 2877 bogomips: 41621
Device-1: Intel HD Graphics 530 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Dell driver: nouveau
v: kernel bus-ID: 02:00.0 chip-ID: 10de:139b class-ID: 0302
Device-3: Sunplus Innovation Integrated_Webcam_HD type: USB
driver: uvcvideo bus-ID: 1-4:2 chip-ID: 1bcf:28b0 class-ID: 0e02
Display: wayland server: X.org 1.21.1.2 compositor: gnome-shell driver:
loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
display-ID: 0 resolution: <missing: xdpyinfo>
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Sound Server-1: ALSA v: k5.15.11-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.42 running: yes
bus-ID: 1-5:3 chip-ID: 8087:0a2a class-ID: e001
Processes: 406 Uptime: 26m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1263 lib: 343
flatpak: 0 Shell: Zsh v: 5.8 running-in: kitty inxi: 3.3.11
EDIT: I found a very similar issue on the arch forum. Still not resolved there though.
This is due to using a filesystem grub cannot write e.g. f2fs and btrfs.
Remove the save last entry from /etc/default/grub - and the message is gone.
The `error: sparse file not allowed` issue was fixed
Changed the line to
# GRUB_SAVEDEFAULT=true
ran
sudo update-grub
and rebooted PC: the message was not shown.
So I unveiled the issue while merging .pacnew and in the same time “improving” my “/etc/default/grub” settings.
Thank you, Frede!
The report of version mismatch in the GRUB menu vs grub package remains.
You need to reinstall grub: not the package but the boot loader (from currently installed package).
lib32-systemd didn’t get updated to 250 like the other systemd packages @Yochanan
It was fixed. My lib32-systemd package was updated this morning.
Systemd (250-2)Problem (?) while copying (using Nemo) some >1 GiB files to USB-drive:
Dez 27 13:21:08 kernel: INFO: task kworker/u64:5:233 blocked for more than 122 seconds.
Dez 27 13:21:08 kernel: Not tainted 5.15.11-1-MANJARO #1
Dez 27 13:21:08 kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
Dez 27 13:23:11 kernel: INFO: task kworker/u64:5:233 blocked for more than 245 seconds.
Dez 27 13:23:11 kernel: Not tainted 5.15.11-1-MANJARO #1
Dez 27 13:23:11 kernel: "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
