Hi all
I am using the tuned daemon version 2.16.0-2, but it isn’t able to start anymore.
edit:
I am sorry, I missed this one:
systemctl enable --now tuned.service
Job for tuned.service failed because the control process exited with error code.
See "systemctl status tuned.service" and "journalctl -xeu tuned.service" for details.
systemctl status tuned.service returns:
× tuned.service - Dynamic System Tuning Daemon
Loaded: loaded (/usr/lib/systemd/system/tuned.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Wed 2022-01-05 23:46:09 CET; 44s ago
Docs: man:tuned(8)
man:tuned.conf(5)
man:tuned-adm(8)
Process: 11310 ExecStart=/usr/sbin/tuned -l -P (code=exited, status=1/FAILURE)
Main PID: 11310 (code=exited, status=1/FAILURE)
CPU: 26ms
Jan 05 23:46:09 asus-rog systemd[1]: Starting Dynamic System Tuning Daemon...
Jan 05 23:46:09 asus-rog tuned[11310]: Traceback (most recent call last):
Jan 05 23:46:09 asus-rog tuned[11310]: File "/usr/sbin/tuned", line 27, in <module>
Jan 05 23:46:09 asus-rog tuned[11310]: import tuned.logs
Jan 05 23:46:09 asus-rog tuned[11310]: ModuleNotFoundError: No module named 'tuned'
Jan 05 23:46:09 asus-rog systemd[1]: tuned.service: Main process exited, code=exited, status=1/FAILURE
Jan 05 23:46:09 asus-rog systemd[1]: tuned.service: Failed with result 'exit-code'.
Jan 05 23:46:09 asus-rog systemd[1]: Failed to start Dynamic System Tuning Daemon.
journalctl -xeu tuned.service returns:
░░ Subject: Unit process exited
░░ Defined-By: systemd
░░ An ExecStart= process belonging to unit tuned.service has exited.
░░ The process' exit code is 'exited' and its exit status is 1.
░░ Subject: Unit failed
░░ The unit tuned.service has entered the 'failed' state with result 'exit-code'.
░░ Subject: A start job for unit tuned.service has failed
░░ A start job for unit tuned.service has finished with a failure.
░░ The job identifier is 2942 and the job result is failed.
Thanks!
