I got a message on pamac saying “WARNING: The wheel package is not available.” whilst attempting at building a package (athenaeum).
You can have this fixed it with:
pamac install python-wheel
python packages installed with pip are not tracked by pacman FYI
https://archlinux.org/packages/community/any/python-wheel/
with pacman we add “python-”
if we not install in home with pip : it’s always very bad to install in system with pip
in arch page, read Required by … if installed by pip, you can’t install these 61 packages
…as it is internal infrastructure of pip, it’s user actions, user configs, files, etc.
Just the same as for npm packages.
~/Desktop ❯ pacman -Qo $(which touch)
/usr/bin/touch is owned by coreutils 9.0-2
The same as to expect tracking the files created by user using the touch.
System packages manager VS project package manager of local user.
Oh sheet, I actually ran a bit later:
I was under the impression “pip install wheel” should work, but don’t mind me, I was updating a bunch of stuff.
