Hey, I’m also struggling with a similar problem. I can confirm that it’s an OS issue on my side as windows works fine for gaming the whole day. Since all of my RAM was used i doubt it’s a RAM issue either. Where should I start troubleshooting ?
Note: Although I don’t think my hardware RAM is faulty I see a “can not access initramfs” error during boot could that be related ? I ask because I used the computer with this issue for a few hours before the boot looping started. After I get to desktop about 1:30 minute until reboot.
We’d need more information about your system.
Detail prior actions leading to the issue.
List solutions and guides you already tried , with links whenever possible.
[HowTo] post screenshots and links
Provide any related error messages.
[HowTo] Find error logs
Provide your system information , whenever relevant or when in doubt.
[HowTo] Find system information
Provide text information as preformatted text , unless you really don’t have the option.
[HowTo] Use preformatting in a forum post
Do not hijack an existing thread
If the solution provided in that thread does not work for you, or if it is doesn’t provide a solution yet, do not add your issue your issue to it, as they might have different causes and thus may require different solutions.
You can though link that thread from yours, as one you checked in order to fix your issue.
please check your bios-settings for any manual xmp-profil and confirm that it is set to defaults. we had a similar issue some weeks ago, lasting useless weeks in a thread until the member came up that he had a bad xmp-profil that he used. ms-windows seems to be more flexible in this case than linux.
Okay I’m sorry for Hijacking.
Prior to the Problem I used DD to write a ISO to an SSD that is not otherwise used in the system. and watched some YT.
system information:
Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=de_DE keytable=de
tz=Europe/Berlin misobasedir=manjaro misolabel=MANJARO_KDE_2121 quiet
systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree
nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: B450 AORUS M v: x.x
serial: <superuser required> UEFI: American Megatrends v: F41
date: 07/22/2019
RAM: total: 15.63 GiB used: 3.62 GiB (23.2%)
RAM Report:
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+
family: 0x17 (23) model-id: 8 stepping: 2 microcode: 0x800820D
L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2369 high: 4142 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2792 2: 2070
3: 2182 4: 4142 5: 2061 6: 2072 7: 2694 8: 1718 9: 1712 10: 2800 11: 2070
12: 2116 bogomips: 86267
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
disabled, RSB filling
Device-1: NVIDIA GK104 [GeForce GTX 770] vendor: Micro-Star MSI
driver: nvidia v: 470.94 alternate: nouveau,nvidia_drm bus-ID: 07:00.0
chip-ID: 10de:1184 class-ID: 0300
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: nvidia resolution: <missing: xdpyinfo>
Device-1: Creative Labs Sound Core3D [Sound Blaster Recon3D / Z-Series]
driver: snd_hda_intel v: kernel bus-ID: 06:00.0 chip-ID: 1102:0012
class-ID: 0403
Device-2: NVIDIA GK104 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 07:00.1 chip-ID: 10de:0e0a
class-ID: 0403
Device-3: AMD Family 17h HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-4: Nam Tai E&E Products or OmniVision Sony Playstation Eye
type: USB driver: ov534,snd-usb-audio bus-ID: 3-4:2 chip-ID: 1415:2000
class-ID: 0102
Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: f000 bus-ID: 04:00.0
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth type: USB driver: btusb
v: 0.8 bus-ID: 1-10:5 chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Local Storage: total: 5.25 TiB used: 142.96 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 type: SSD serial: <filter> rev: 3B2QGXA7 temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
type: SSD serial: <filter> rev: 3B6Q scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1ER162
type: HDD rpm: 7200 serial: <filter> rev: CC43 scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: TR150 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 12.3 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD20EZAZ-00GGJB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 0A80 scheme: GPT
ID-6: /dev/sdg maj-min: 8:96 type: USB vendor: Kingston model: FCR-HS3 -2
size: 1.88 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: MBR
ID-7: /dev/sdi maj-min: 8:128 type: USB vendor: Toshiba
model: External USB 3.0 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 5438 scheme: MBR
ID-8: /dev/sdj maj-min: 8:144 type: USB vendor: SMI (STMicroelectronics)
model: USB size: 29.3 GiB block-size: physical: 512 B logical: 512 B
type: N/A serial: <filter> rev: 1100 scheme: MBR
ID-1: /mnt raw-size: 72.01 GiB size: 70.75 GiB (98.26%)
used: 38.49 GiB (54.4%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: /
uuid: bb7ffb9c-67ce-4002-b16b-05b7607979c4
ID-2: /mnt/boot/efi raw-size: 100 MiB size: 96 MiB (96.00%)
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/sdc4 maj-min: 8:36 label: N/A
uuid: A8C5-3E26
ID-3: /mnt/home raw-size: 115.3 GiB size: 112.99 GiB (98.00%)
used: 104.44 GiB (92.4%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: /home
uuid: 65ec6d4c-3dee-4eb2-b633-12b3c902652f
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 488.28 GiB fs: ntfs label: Pluto
uuid: E6E20C7FE20C5669
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 197.67 GiB fs: btrfs label: bfs
uuid: 58303e57-0470-4fb5-9d2b-8c3e0d0750e6
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 48.83 GiB fs: ext4 label: games
uuid: cba344dc-677f-447f-8bf4-c00f37c0f967
ID-5: /dev/sda1 maj-min: 8:1 size: 736.2 GiB fs: ntfs label: Io - 1000
uuid: 50928AE1928ACAC4
ID-6: /dev/sda4 maj-min: 8:4 size: 8 GiB fs: swap label: N/A
uuid: ed73241d-bb18-46b5-967b-2c0b672a42ee
ID-7: /dev/sdb1 maj-min: 8:17 size: 931.51 GiB fs: ntfs label: Titan
uuid: DE3C1D463C1D1B5B
ID-8: /dev/sdc1 maj-min: 8:33 size: 579 MiB fs: vfat label: BOOT
uuid: D014-D0A3
ID-9: /dev/sdc2 maj-min: 8:34 size: 222.36 GiB fs: ntfs label: N/A
uuid: 00E8E957E8E94C0A
ID-10: /dev/sdc3 maj-min: 8:35 size: 554 MiB fs: ntfs label: N/A
uuid: 5AE83A26E83A00B5
ID-11: /dev/sdd1 maj-min: 8:49 size: 16 MiB fs: <superuser required>
ID-12: /dev/sdd2 maj-min: 8:50 size: 1.16 TiB fs: ntfs label: Jupiter
uuid: D44AF9D64AF9B4F8
ID-13: /dev/sdg1 maj-min: 8:97 size: 1.88 GiB fs: vfat label: M2 uuid: N/A
ID-14: /dev/sdi1 maj-min: 8:129 size: 465.76 GiB fs: ntfs label: Atlas
uuid: 41113748679FA2A1
ID-15: /dev/sdj1 maj-min: 8:145 size: 3.58 GiB fs: iso9660
ID-16: /dev/sdj2 maj-min: 8:146 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 8078-6038
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: ROCCAT Ryos MK Glow Keyboard type: Keyboard,HID
driver: ryos,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 1e7d:31ce class-ID: 0300
Device-2: 1-6:3 info: ROCCAT Tyon White Mouse type: Mouse,HID
driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1e7d:2e4b class-ID: 0300 serial: <filter>
Device-3: 1-8:4
info: Silicon Motion - Taiwan (formerly Feiya ) Flash Drive
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.1
speed: 480 Mb/s power: 500mA chip-ID: 090c:1000 class-ID: 0806
Device-4: 1-10:5 info: ASUSTek Broadcom BCM20702A0 Bluetooth
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-4:2
info: Nam Tai E&E Products or OmniVision Sony Playstation Eye type: Audio
driver: ov534,snd-usb-audio interfaces: 3 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 1415:2000 class-ID: 0102
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 4-1:2 info: ATECH FLASH USB3.0 Media Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
chip-ID: 11b0:6348 class-ID: 0806 serial: <filter>
Device-2: 4-3:3 info: Toshiba America External USB 3.0 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 0480:a108 class-ID: 0806 serial: <filter>
System Temperatures: cpu: N/A mobo: N/A gpu: nvidia temp: 33 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 37%
Processes: 349 Uptime: 19m wakeups: 0 Init: systemd v: 250 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1223 lib: 329 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
drivers
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia-470xx 2021.12.18 false PCI
and release
ManjaroLinux 21.2.6 Qonos
The following is the output of your How to find logs guide.
Live system is running fine so far.
so im using manjaro-chroot -a.
journalctl
Jun 04 17:32:46 manjaro kernel: cgroup2: Unknown parameter 'memory_recursiveprot'
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:2: [sdh] No Caching mode page found
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:2: [sdh] Assuming drive cache: write through
Jun 04 17:32:50 manjaro kernel: proc: Bad value for 'hidepid'
Jun 04 17:32:50 manjaro kernel: usb 3-4: 3:1: cannot get min/max values for control 2 (id 3)
Jun 04 17:32:51 manjaro bluetoothd[1294]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Unknown Command (0x01)
Jun 04 17:32:51 manjaro kernel: proc: Bad value for 'hidepid'
Jun 04 17:32:53 manjaro kernel: watchdog: watchdog0: watchdog did not stop!
Jun 04 17:32:54 manjaro libvirtd[1387]: cannot open directory '/run/media/bastian/Phobos - 250/Iso & utility/Linux/ISO/Arch - Manjaro': Datei oder Verzeichnis nicht gefunden
Jun 04 17:32:54 manjaro libvirtd[1387]: Interner Fehler: Autostart von Speicherpool »Arch_-_Manjaro« fehlgeschlagen: cannot open directory '/run/media/bastian/Phobos - 250/Iso & utility/Linux/ISO/Arch - Manjaro': Datei oder Verzeichnis nicht gefunden
Jun 04 17:33:33 manjaro systemd-coredump[2121]: Process 2062 (appimagelaunche) of user 1000 dumped core.
Module linux-vdso.so.1 without build-id.
Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
Module libgpg-error.so.0 with build-id f9aaa96d5ddf6f6872051ed7abcdfe6bdaff9b1c
Module libXdmcp.so.6 with build-id 8ca0792d23c8b8b4c0864297512349292bea5955
Module libXau.so.6 with build-id 1c67764663e07bec24d8951e5fd93f4d165979ff
Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
Module libpangoft2-1.0.so.0 with build-id c2c09f789578900f61b7fca4a4311d8b94d9a750
Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
Module libtiff.so.5 with build-id 9e8868622f8b7144fd82dabfa8ac2fcaf6d45a34
Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
Module libgmodule-2.0.so.0 with build-id c6df28882f153ee03d0fb33bb8aac2b219ebaacc
Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
Module libresolv.so.2 with build-id 89a368a6ad1b392d126a2a5beb9c2f61ade00279
Module libkeyutils.so.1 with build-id ac405ddd17be10ce538da3211415ee50c8f8df79
Module libkrb5support.so.0 with build-id 36db7c21bc57a9b934ad2d3463782db9fef4af07
Module libcom_err.so.2 with build-id 358b783c9b3d12ba8248519ea2e7f3da4c4e0297
Module libk5crypto.so.3 with build-id f1c113fea46023cdf62c7e51cb643c45831abdd5
Module libkrb5.so.3 with build-id 9350783c946d77aec8ee8fd9c6bc12f4f7b72be9
Module libunistring.so.2 with build-id 617dbf3d3d6f85d6556a7a036e23845e95490158
Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
Module libcap.so.2 with build-id 21b00ab76bb16fde56fd741f07233c78069f0579
Module libpixman-1.so.0 with build-id 341f793dcada3a48a306a793d265a517e3f2e7d6
Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
Module libXrender.so.1 with build-id 97e0b9ab6ba96ebc86527cc2b3c3078aad8616b3
Module libXext.so.6 with build-id d70f24beb4fad748d6becffdcc13e51be0a2ebfa
Module libX11.so.6 with build-id d8e0be8e0323aa421366f19065ecd1c76405c130
Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
Module libpango-1.0.so.0 with build-id 7e27c1e46a1d958f6b16e1ba199f8bdb3f100566
Module libpangocairo-1.0.so.0 with build-id b65f507d9e33adfbd19369acef5e5a0a2422c6d1
Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
Module libgio-2.0.so.0 with build-id 8c411770513e0bc758a1bbe661af14c972e2a3c4
Module libgdk_pixbuf-2.0.so.0 with build-id 5b8422ab971b1a8a8e1c43b88738d4ee217f609e
Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
Module libacl.so.1 with build-id 27869ed0219ade5d2ffd50eaee11f967187faa8b
Module libboost_atomic.so.1.78.0 with build-id 194f88dfc556fa19a886a23cd9ff3051d7725c08
Module libgraphite2.so.3 with build-id 47761dc11e553f519cde97ed9ee985be12ccdae2
Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
Module libgssapi_krb5.so.2 with build-id 1813217c8baf82a1078772eed0d868310cd59f8b
Module libcrypto.so.1.1 with build-id d54a7ee1e288aeae436d073277ff986e03994b15
Module libssl.so.1.1 with build-id 25a55106cb13dec5d495c34ca1caf2c2f3114f11
Module libpsl.so.5 with build-id 0229a201aaf5652186c9fdc192ebe52baf19d7f1
Module libssh2.so.1 with build-id a4adfe44cc7ebd295b3b783361acc3dcfcea1d50
Module libidn2.so.0 with build-id 1ce2b50ad9f9821c2c629b521cf5a3c99593d332
Module libnghttp2.so.14 with build-id f2738fead8e6593084b4fb8756f460aa8cf5535a
Module ld-linux-x86-64.so.2 with build-id fc93487393eea02b5bc6e76e48976fc325294c24
Module libzstd.so.1 with build-id 3bccb8fe08e48d5ea135b1d0f99de0d771dd752f
Module libpcre2-16.so.0 with build-id 68a5c2d52b45bfa6b1e93d2766e80094f52d9ebf
Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
Module libdouble-conversion.so.3 with build-id d162eb67b00f523a3f146b1077ae00fe04d5fb85
Module libsystemd.so.0 with build-id cdfc45d8f96e3af51b3d041c32f7899a93b86706
Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
Module libgobject-2.0.so.0 with build-id 4337ec84b2f33ec39a95863d47bfca0a28afd488
Module librsvg-2.so.2 with build-id 8c033bf594f51f48c7b2ee078fa4586ddb70513a
Module libsquashfuse.so.0 with build-id 450212c2ecbebc35d1bd40b0c3d26c540c482218
Module libarchive.so.13 with build-id 79dc2cbd51eb8ff72ee83974b3244027bd970ea4
Module libboost_filesystem.so.1.78.0 with build-id 1d5e5d4cc25f6c44a946e4b5652265018108443b
Module libmd4c.so.0 with build-id 2151dba72cdc9960097e6e960a58a2f03c8bb96e
Module libharfbuzz.so.0 with build-id a11faa61f71b258fb92b717723757fc7dd141c01
Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
Module libm.so.6 with build-id 210ec9905e41825671210f8f7d0b24d6c371196a
Module libcurl.so.4 with build-id 8ab1352b26fc2bb50933b8caa480e032b0b7d6b3
Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
Module libc.so.6 with build-id 388993b6ef62f964bc7bf473c069fbfe957b9e44
Module libgcc_s.so.1 with build-id 0e3de903950e35ae59a5de8c00b1817a4a71ca01
Module libstdc++.so.6 with build-id b3eaebcb5369487562e52dd8d016c9cd77f80c54
Module libQt5Core.so.5 with build-id c38b617c7f758f3327a3cf4d1b4168ec8e4db842
Module libglib-2.0.so.0 with build-id e268e80e668ce871312cf50e9969f88b086e33f2
Module libpthread.so.0 with build-id 95ae4f30a6f12ccbff645d30f8e1a3ee23ec7d36
Module libappimage.so.1.0 with build-id d67ce2a7aa8dd4b46166cf517820f31cfbca1930
Module libQt5Gui.so.5 with build-id f2aced11623934e05c00514f8e891a65700fca20
Module libQt5Widgets.so.5 with build-id 4718220524507280b1711f967e97d6017eaa0d6c
Module libappimageupdate.so with build-id e102343adacf6676d8481a521db2482e6c6b8b3e
Module libQt5DBus.so.5 with build-id 9095840053834c1683ba54020b63d7e545cd0f47
Module appimagelauncherd with build-id 2fafbe9e86541032ce92120998276a7dda1b22c3
Stack trace of thread 2062:
#0 0x00007faa8b1543d4 local_Rb_tree_increment (libstdc++.so.6 + 0xbf3d4)
#1 0x000055b4cd19c5b9 n/a (appimagelauncherd + 0x215b9)
#2 0x000055b4cd189a4f n/a (appimagelauncherd + 0xea4f)
#3 0x00007faa8b58a791 n/a (libQt5Core.so.5 + 0x2be791)
#4 0x00007faa8b58cb4f _ZN6QTimer7timeoutENS_14QPrivateSignalE (libQt5Core.so.5 + 0x2c0b4f)
#5 0x00007faa8b57d8b6 _ZN7QObject5eventEP6QEvent (libQt5Core.so.5 + 0x2b18b6)
#6 0x00007faa8b559fdc _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt5Core.so.5 + 0x28dfdc)
#7 0x00007faa8b5a4003 _ZN14QTimerInfoList14activateTimersEv (libQt5Core.so.5 + 0x2d8003)
#8 0x00007faa8b5a4642 n/a (libQt5Core.so.5 + 0x2d8642)
#9 0x00007faa8b842163 g_main_context_dispatch (libglib-2.0.so.0 + 0x55163)
#10 0x00007faa8b8989e9 n/a (libglib-2.0.so.0 + 0xab9e9)
#11 0x00007faa8b83f6c5 g_main_context_iteration (libglib-2.0.so.0 + 0x526c5)
#12 0x00007faa8b5a47bc _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2d87bc)
#13 0x00007faa8b55279c _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x28679c)
#14 0x00007faa8b55d2a9 _ZN16QCoreApplication4execEv (libQt5Core.so.5 + 0x2912a9)
#15 0x000055b4cd188189 n/a (appimagelauncherd + 0xd189)
#16 0x00007faa8ae91290 n/a (libc.so.6 + 0x29290)
#17 0x00007faa8ae9134a __libc_start_main (libc.so.6 + 0x2934a)
#18 0x000055b4cd18869e n/a (appimagelauncherd + 0xd69e)
-- Subject: Process 2062 (appimagelaunche) dumped core
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/support
-- Documentation: man:core(5)
-- Process 2062 (appimagelaunche) crashed and dumped core.
-- This usually indicates a programming error in the crashing program and
-- should be reported to its vendor as a bug.
you can find the dmesg output here: https://pastebin.com/BS3RRFuf
i dont see anything that screams error to me so im kinda stuck on where to look.
so you are now in the live usb chrooted into the installation?
yes and live boot is stable.
so if this is 5.15.12-1-MANJARO from the installation, then youre running a old kernel, so you didnt updated for some time… so update your system with:
pacman-mirrors -f5 && pamac update
now that you’ve mentioned it it should have updated the kernel 1 week ago.
just to confirm
manjaro-chroot -a and then uname -r will give me the kernel of the installation NOT of the live system ?
Beware, usually the kernel version read from a chroot is always the one running the liveUSB.
@Langeundweile The journalctl log seems rather short. Don’t you have another error in that boot journal?
Alternatively, you can add the --no-pager option to output the whole log.
i didnt know that… so why is the command mhwd-kernel -li in chroot showing actual kernels?
It shows the installed kernels on the chrooted system, but the running one is from the liveUSB.
so manjaro-chroot -> uname -r reports 5.15 and the live usb is a bit older so this makes sense.
mhwd-kernel -li also reports 5.15
the journalctl --boot=-1 --priority=3 --catalog --no-pager > journal.txt the output is the same. maybe because i redirect it to a txt ?
try runnnig this in chroot for more logs
journalctl --boot=0 --priority=5 --no-pager
boot=0 yields no entries
boot=-1 yields this
journalctl --boot=-1 --priority=5 --no-pager
Jun 04 17:32:46 manjaro kernel: Linux version 5.4.195-1-MANJARO (builduser@fv-az41-259) (gcc version 12.1.0 (GCC)) #1 SMP PREEMPT Wed May 18 09:23:31 UTC 2022
Jun 04 17:32:46 manjaro kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=bb7ffb9c-67ce-4002-b16b-05b7607979c4 rw 3 quiet apparmor=1 security=apparmor udev.log_priority=3
Jun 04 17:32:46 manjaro kernel: random: get_random_u64 called from __kmem_cache_create+0x3e/0x5d0 with crng_init=0
Jun 04 17:32:46 manjaro kernel: *** VALIDATE tmpfs ***
Jun 04 17:32:46 manjaro kernel: *** VALIDATE proc ***
Jun 04 17:32:46 manjaro kernel: *** VALIDATE cgroup1 ***
Jun 04 17:32:46 manjaro kernel: *** VALIDATE cgroup2 ***
Jun 04 17:32:46 manjaro kernel: audit: type=2000 audit(1654356763.166:1): state=initialized audit_enabled=0 res=1
Jun 04 17:32:46 manjaro kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Jun 04 17:32:46 manjaro kernel: pci 0000:00:03.1: ASPM: current common clock configuration is broken, reconfiguring
Jun 04 17:32:46 manjaro kernel: *** VALIDATE bpf ***
Jun 04 17:32:46 manjaro kernel: VFS: Disk quotas dquot_6.6.0
Jun 04 17:32:46 manjaro kernel: *** VALIDATE ramfs ***
Jun 04 17:32:46 manjaro kernel: *** VALIDATE hugetlbfs ***
Jun 04 17:32:46 manjaro kernel: PPR NX GT IA GA PC GA_vAPIC
Jun 04 17:32:46 manjaro kernel: Initialise system trusted keyrings
Jun 04 17:32:46 manjaro kernel: Key type blacklist registered
Jun 04 17:32:46 manjaro kernel: Key type asymmetric registered
Jun 04 17:32:46 manjaro kernel: Asymmetric key parser 'x509' registered
Jun 04 17:32:46 manjaro kernel: Loading compiled-in X.509 certificates
Jun 04 17:32:46 manjaro kernel: Loaded X.509 cert 'Build time autogenerated kernel key: b4017d77bdb75a4df315fa0b90e02ec0036aaba0'
Jun 04 17:32:46 manjaro kernel: Key type ._fscrypt registered
Jun 04 17:32:46 manjaro kernel: Key type .fscrypt registered
Jun 04 17:32:46 manjaro kernel: Key type big_key registered
Jun 04 17:32:46 manjaro kernel: SCSI subsystem initialized
Jun 04 17:32:46 manjaro kernel: usb: port power management may be unreliable
Jun 04 17:32:46 manjaro kernel: ata1.00: supports DRM functions and may not be fully accessible
Jun 04 17:32:46 manjaro kernel: scsi 0:0:0:0: Direct-Access ATA Samsung SSD 860 3B6Q PQ: 0 ANSI: 5
Jun 04 17:32:46 manjaro kernel: ata2.00: supports DRM functions and may not be fully accessible
Jun 04 17:32:46 manjaro kernel: scsi 1:0:0:0: Direct-Access ATA ST1000DM003-1ER1 CC43 PQ: 0 ANSI: 5
Jun 04 17:32:46 manjaro kernel: random: fast init done
Jun 04 17:32:46 manjaro kernel: scsi 4:0:0:0: Direct-Access ATA TOSHIBA-TR150 12.3 PQ: 0 ANSI: 5
Jun 04 17:32:46 manjaro kernel: scsi 5:0:0:0: Direct-Access ATA WDC WD20EZAZ-00G 0A80 PQ: 0 ANSI: 5
Jun 04 17:32:46 manjaro kernel: sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Jun 04 17:32:46 manjaro kernel: sd 0:0:0:0: [sdb] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
Jun 04 17:32:46 manjaro kernel: sd 1:0:0:0: [sda] 4096-byte physical blocks
Jun 04 17:32:46 manjaro kernel: sd 0:0:0:0: [sdb] Write Protect is off
Jun 04 17:32:46 manjaro kernel: sd 1:0:0:0: [sda] Write Protect is off
Jun 04 17:32:46 manjaro kernel: sd 0:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 04 17:32:46 manjaro kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 04 17:32:46 manjaro kernel: sd 5:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
Jun 04 17:32:46 manjaro kernel: sd 5:0:0:0: [sdc] 4096-byte physical blocks
Jun 04 17:32:46 manjaro kernel: sd 4:0:0:0: [sdd] 468862128 512-byte logical blocks: (240 GB/224 GiB)
Jun 04 17:32:46 manjaro kernel: sd 4:0:0:0: [sdd] Write Protect is off
Jun 04 17:32:46 manjaro kernel: sd 5:0:0:0: [sdc] Write Protect is off
Jun 04 17:32:46 manjaro kernel: sd 4:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 04 17:32:46 manjaro kernel: sd 5:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 04 17:32:46 manjaro kernel: sd 1:0:0:0: [sda] Attached SCSI disk
Jun 04 17:32:46 manjaro kernel: sd 0:0:0:0: [sdb] supports TCG Opal
Jun 04 17:32:46 manjaro kernel: sd 0:0:0:0: [sdb] Attached SCSI disk
Jun 04 17:32:46 manjaro kernel: sd 4:0:0:0: [sdd] Attached SCSI disk
Jun 04 17:32:46 manjaro kernel: sd 5:0:0:0: [sdc] Attached SCSI disk
Jun 04 17:32:46 manjaro kernel: scsi 10:0:0:0: Direct-Access TOSHIBA External USB 3.0 5438 PQ: 0 ANSI: 6
Jun 04 17:32:46 manjaro kernel: sd 10:0:0:0: [sde] 976773164 512-byte logical blocks: (500 GB/466 GiB)
Jun 04 17:32:46 manjaro kernel: sd 10:0:0:0: [sde] Write Protect is off
Jun 04 17:32:46 manjaro kernel: sd 10:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Jun 04 17:32:46 manjaro kernel: scsi 9:0:0:0: Direct-Access FCR-HS3 -0 1.00 PQ: 0 ANSI: 6
Jun 04 17:32:46 manjaro kernel: scsi 9:0:0:1: Direct-Access FCR-HS3 -1 1.00 PQ: 0 ANSI: 6
Jun 04 17:32:46 manjaro kernel: scsi 9:0:0:2: Direct-Access FCR-HS3 -2 1.00 PQ: 0 ANSI: 6
Jun 04 17:32:46 manjaro kernel: scsi 9:0:0:3: Direct-Access FCR-HS3 -3 1.00 PQ: 0 ANSI: 6
Jun 04 17:32:46 manjaro systemd[1]: Configuration file /etc/systemd/system/kill_kwin.service is marked executable. Please remove executable permission bits. Proceeding anyway.
Jun 04 17:32:46 manjaro kernel: *** VALIDATE fuse ***
Jun 04 17:32:46 manjaro kernel: random: lvm: uninitialized urandom read (4 bytes read)
Jun 04 17:32:46 manjaro kernel: audit: type=1130 audit(1654356766.953:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup-dev comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:46 manjaro kernel: audit: type=1400 audit(1654356766.953:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/lxc-start" pid=382 comm="apparmor_parser"
Jun 04 17:32:46 manjaro systemd-random-seed[373]: Kernel entropy pool is not initialized yet, waiting until it is.
Jun 04 17:32:46 manjaro kernel: audit: type=1130 audit(1654356766.979:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:47 manjaro systemd-journald[364]: File /var/log/journal/6b8604cf705b4b16a8c6657ac841012d/system.journal corrupted or uncleanly shut down, renaming and replacing.
Jun 04 17:32:47 manjaro kernel: audit: type=1130 audit(1654356766.996:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udev-trigger comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:47 manjaro kernel: audit: type=1400 audit(1654356767.003:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=377 comm="apparmor_parser"
Jun 04 17:32:47 manjaro kernel: audit: type=1400 audit(1654356767.003:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=379 comm="apparmor_parser"
Jun 04 17:32:47 manjaro kernel: audit: type=1400 audit(1654356767.003:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=379 comm="apparmor_parser"
Jun 04 17:32:47 manjaro kernel: audit: type=1130 audit(1654356767.036:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:47 manjaro kernel: audit: type=1400 audit(1654356767.049:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=383 comm="apparmor_parser"
Jun 04 17:32:47 manjaro kernel: crng init done
Jun 04 17:32:47 manjaro kernel: ACPI Warning: SystemIO range 0x0000000000000B00-0x0000000000000B08 conflicts with OpRegion 0x0000000000000B00-0x0000000000000B0F (\GSA1.SMBI) (20190816/utaddress-204)
Jun 04 17:32:47 manjaro kernel: sd 10:0:0:0: [sde] Attached SCSI disk
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:2: [sdh] 3938304 512-byte logical blocks: (2.02 GB/1.88 GiB)
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:2: [sdh] Write Protect is off
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:1: [sdg] Attached SCSI removable disk
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:3: [sdi] Attached SCSI removable disk
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:0: [sdf] Attached SCSI removable disk
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:2: [sdh] Attached SCSI removable disk
Jun 04 17:32:47 manjaro kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jun 04 17:32:47 manjaro kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
Jun 04 17:32:47 manjaro kernel: sd 4:0:0:0: Attached scsi generic sg2 type 0
Jun 04 17:32:47 manjaro kernel: sd 5:0:0:0: Attached scsi generic sg3 type 0
Jun 04 17:32:47 manjaro kernel: sd 10:0:0:0: Attached scsi generic sg4 type 0
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:0: Attached scsi generic sg5 type 0
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:1: Attached scsi generic sg6 type 0
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:2: Attached scsi generic sg7 type 0
Jun 04 17:32:47 manjaro kernel: sd 9:0:0:3: Attached scsi generic sg8 type 0
Jun 04 17:32:47 manjaro kernel: ccp 0000:08:00.2: ccp enabled
Jun 04 17:32:48 manjaro kernel: v4l2loopback_dc: loading out-of-tree module taints kernel.
Jun 04 17:32:48 manjaro kernel: v4l2loopback_dc: module verification failed: signature and/or required key missing - tainting kernel
Jun 04 17:32:48 manjaro kernel: VBoxNetAdp: Successfully started.
Jun 04 17:32:48 manjaro kernel: VBoxNetFlt: Successfully started.
Jun 04 17:32:48 manjaro kernel: kauditd_printk_skb: 27 callbacks suppressed
Jun 04 17:32:48 manjaro kernel: audit: type=1130 audit(1654356768.716:36): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:49 manjaro kernel: nvidia: module license 'NVIDIA' taints kernel.
Jun 04 17:32:49 manjaro kernel: Disabling lock debugging due to kernel taint
Jun 04 17:32:50 manjaro kernel: audit: type=1130 audit(1654356770.076:37): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-binfmt comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:50 manjaro kernel: audit: type=1130 audit(1654356770.083:38): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:50 manjaro kernel: audit: type=1127 audit(1654356770.086:39): pid=1233 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:50 manjaro kernel: audit: type=1130 audit(1654356770.089:40): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-update-utmp comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:50 manjaro kernel: audit: type=1130 audit(1654356770.163:41): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timesyncd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:50 manjaro kernel: usb 3-4: current rate 802123 is different from the runtime rate 16000
Jun 04 17:32:50 manjaro kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.129.06 Thu May 12 22:52:02 UTC 2022
Jun 04 17:32:51 manjaro kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Jun 04 17:32:51 manjaro kernel: audit: type=1130 audit(1654356771.229:42): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:51 manjaro kernel: audit: type=1130 audit(1654356771.249:43): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:51 manjaro kernel: audit: type=1130 audit(1654356771.259:44): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ufw comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:51 manjaro kernel: audit: type=1130 audit(1654356771.273:45): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cronie comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:51 manjaro polkitd[1300]: Loading rules from directory /etc/polkit-1/rules.d
Jun 04 17:32:51 manjaro polkitd[1300]: Loading rules from directory /usr/share/polkit-1/rules.d
Jun 04 17:32:51 manjaro polkitd[1300]: Finished loading, compiling and executing 9 rules
Jun 04 17:32:51 manjaro polkitd[1300]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jun 04 17:32:51 manjaro kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000c0000-0x000dffff window]
Jun 04 17:32:51 manjaro kernel: caller _nv000720rm+0x1ad/0x200 [nvidia] mapping multiple BARs
Jun 04 17:32:53 manjaro kernel: kauditd_printk_skb: 74 callbacks suppressed
Jun 04 17:32:53 manjaro kernel: audit: type=1131 audit(1654356773.719:120): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:54 manjaro libvirtd[1387]: ignoring missing fifo '/dev/log'
Jun 04 17:32:54 manjaro libvirtd[1387]: ignoring missing fifo '/dev/stderr'
Jun 04 17:32:54 manjaro libvirtd[1387]: ignoring missing fifo '/dev/stdout'
Jun 04 17:32:54 manjaro libvirtd[1387]: ignoring missing fifo '/dev/tty'
Jun 04 17:32:55 manjaro kernel: audit: type=1130 audit(1654356775.813:121): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:32:56 manjaro kernel: audit: type=1400 audit(1654356776.319:122): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=1613 comm="apparmor_parser"
Jun 04 17:32:56 manjaro kernel: Bridge firewalling registered
Jun 04 17:32:56 manjaro kernel: audit: type=1325 audit(1654356776.409:123): table=nat family=2 entries=13
Jun 04 17:32:56 manjaro kernel: audit: type=1325 audit(1654356776.409:124): table=filter family=2 entries=32
Jun 04 17:32:56 manjaro kernel: audit: type=1325 audit(1654356776.409:125): table=filter family=2 entries=34
Jun 04 17:32:56 manjaro kernel: audit: type=1325 audit(1654356776.413:126): table=filter family=2 entries=36
Jun 04 17:32:56 manjaro kernel: audit: type=1325 audit(1654356776.416:127): table=filter family=2 entries=38
Jun 04 17:32:56 manjaro kernel: audit: type=1325 audit(1654356776.416:128): table=filter family=2 entries=39
Jun 04 17:32:56 manjaro kernel: audit: type=1325 audit(1654356776.443:129): table=nat family=2 entries=15
Jun 04 17:33:01 manjaro kernel: kauditd_printk_skb: 82 callbacks suppressed
Jun 04 17:33:01 manjaro kernel: audit: type=1131 audit(1654356781.469:212): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:33:02 manjaro kernel: audit: type=1100 audit(1654356782.383:213): pid=1390 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="bastian" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
Jun 04 17:33:02 manjaro kernel: audit: type=1101 audit(1654356782.386:214): pid=1390 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="bastian" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
Jun 04 17:33:02 manjaro kernel: audit: type=1103 audit(1654356782.386:215): pid=1390 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="bastian" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
Jun 04 17:33:02 manjaro kernel: audit: type=1006 audit(1654356782.386:216): pid=1390 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty1 old-ses=4294967295 ses=1 res=1
Jun 04 17:33:02 manjaro kernel: audit: type=1130 audit(1654356782.433:217): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:33:02 manjaro systemd[2054]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[bastian] ruser=[<unknown>] rhost=[<unknown>]
Jun 04 17:33:02 manjaro kernel: audit: type=1101 audit(1654356782.439:218): pid=2054 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="bastian" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:33:02 manjaro kernel: audit: type=1103 audit(1654356782.439:219): pid=2054 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="bastian" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Jun 04 17:33:02 manjaro kernel: audit: type=1006 audit(1654356782.439:220): pid=2054 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Jun 04 17:33:02 manjaro kernel: audit: type=1105 audit(1654356782.443:221): pid=2054 uid=0 auid=1000 ses=2 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_loginuid,pam_keyinit,pam_systemd_home,pam_limits,pam_unix,pam_permit,pam_mail,pam_systemd,pam_env acct="bastian" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:33:02 manjaro systemd-xdg-autostart-generator[2060]: Configuration file /home/bastian/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Jun 04 17:33:02 manjaro systemd-journald[364]: File /var/log/journal/6b8604cf705b4b16a8c6657ac841012d/user-1000.journal corrupted or uncleanly shut down, renaming and replacing.
Jun 04 17:33:22 manjaro kernel: kauditd_printk_skb: 3 callbacks suppressed
Jun 04 17:33:22 manjaro kernel: audit: type=1131 audit(1654356802.028:225): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:33:22 manjaro kernel: audit: type=1131 audit(1654356802.655:226): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:33:33 manjaro kernel: audit: type=1701 audit(1654356813.688:227): auid=1000 uid=1000 gid=1001 ses=2 subj==unconfined pid=2062 comm="appimagelaunche" exe="/usr/bin/appimagelauncherd" sig=11 res=1
Jun 04 17:33:33 manjaro kernel: audit: type=1130 audit(1654356813.725:228): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-2120-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Jun 04 17:33:33 manjaro systemd-coredump[2121]: [LNK] Process 2062 (appimagelaunche) of user 1000 dumped core.
Jun 04 17:33:33 manjaro kernel: audit: type=1131 audit(1654356813.878:229): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-coredump@0-2120-0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
except the appimage dumped core, nothing there really… and these logs show that youre running the 5.4 kernel… post output from:
mhwd-kernel -li
Currently running: 5.15.12-1-MANJARO (linux515)
* linux54
should i give your previous idea a go of updating the kernel through chroot ?
the logs shows that you have installed the latest kernel: Linux version 5.4.195-1
and the 5.15 is from the live usb… so you could try installing the 5.15 kernel, since you running it without problems in the live usb:
mhwd-kernel -i linux515
then run these commands:
update-grub
mkinitcpio -P
exit
systemctl reboot
and try running your installation with the 5.15 kernel and see if you still have instability…
mhwd tells me i cant install my currently running kernel
i booted the installtion and ran the command there but i didnt think the installation completed before reboot. it is listed under mhwd-kernel -li but i cant find in in grub and mkinitcpio -P s out put lists 5.4 for vmlinuz and initramfs
is still see a cp err. cannot create /run/initramfs no such file or directroy error when booting the installation is that related ?
post output again from mhwd-kernel -li
are you now back in your installation?
