no im back in the live i can run the installation but it will almost exactly shutdown after 1:30 uptime.
hwd-kernel -li
Currently running: 5.15.12-1-MANJARO (linux515)
* linux515
* linux54
hwd-kernel -li
* linux515
* linux54
so you have it installed … just to be sure install also the 5.10 with this:
mhwd-kernel -i linux510
then run this command:
nano /etc/mkinitcpio.conf
and in the HOOKS= section remove the shutdown, then press ctrl+x to save the file and run these commands:
update-grub
mkinitcpio -P
exit
systemctl reboot
then select in the grub menu in advanced options the 5.10 kernel and boot with it and see if you still get shutdown…
so far installation went fine but last step:
(6/6) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.4-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
Found initrd fallback image: /boot/initramfs-5.4-x86_64-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdj1. Check your device.map.
error: syntax error.
error: Incorrect command.
Syntax error at line 272
Syntax errors are detected in generated GRUB config file.
Ensure that there are no errors in /etc/default/grub
and /etc/grub.d/* files or please file a bug report with
/boot/grub/grub.cfg.new file attached.
error: command failed to execute correctly
i will do the mkinitcpio stuff tho
cat /etc/grub.d/40_custom
and copy the lfollowing lines here:
270-275
dont reboot yet from live usb
i made the mkinitcpio stuff.
i updated grub again that worked. but there was no 5.10 listing
however i have to go to work so i have to get back to it the day after tomorrow i appreciate your time and effort so much thank you.
well your update-grub doesnt work because of the error on the 272 line, thats why the kernels are not listed… ok, so when you have the time do this from chroot:
run this command:
and copy the following lines here:
270-275
well i have time to give you that.
#!/bin/sh
exec tail -n +3 $0
# This file provides an easy way to add custom menu entries. Simply type the
# menu entries you want to add after this comment. Be careful not to change
# the 'exec tail' line above.
yes the conf is:
cat -n /boot/grub/grub.cfg
edit:
the best would be to post output from these commands:
cat -n /usr/sbin/grub-mkconfig
cat -n /etc/default/grub
you cant use a kernel 5.4 lts on this config ( Zen2 )
minimum version required is 5.10 LTS kernel
sudo manjaro chroot -a
pacman -Syyu
mhwd -r linux54
pacman -S xorg-xdpyinfo mesa-utils
pacman -S linux510 linux510-headers linux510-nvidia-470xx
pacman -S linux515 linux515-headers linux515-nvidia-470xx
pacman -S linux517 linux517-headers linux517-nvidia-470xx
mkinitcpio -P
update-grub
sync
exit ( end chroot )
Manjaro != Windows
Ensure your system is fully updated - you may need to use TTY
As you are using Plasma - custom themes may cause such behaviour
Okay I had time to look at it and i start get really disoriented. I don’t think i ever had a 5.4 kernel installed. so i don’t know where the grub listing comes from. im not using a 5.4 kernel though and I don’t think i have used it. However I did install 5.10, 5.15, 5.17 as per @stephane . the grub error mentioned by @brahma still exits though. so Here is the desired output.
I can not test @linux-aarhus theory until the grub issue is resolved as the current grub won’t find the required kernel. Altough `update-grub´ didn’t break anything when i tried to install 5.10 the first time.
grub.cfg
1 #
2 # DO NOT EDIT THIS FILE
3 #
4 # It is automatically generated by grub-mkconfig using templates
5 # from /etc/grub.d and settings from /etc/default/grub
6 #
7
8 ### BEGIN /etc/grub.d/00_header ###
9 insmod part_gpt
10 insmod part_msdos
11 if [ -s $prefix/grubenv ]; then
12 load_env
13 fi
14 if [ "${next_entry}" ] ; then
15 set default="${next_entry}"
16 set next_entry=
17 save_env next_entry
18 set boot_once=true
19 else
20 set default="${saved_entry}"
21 fi
22
23 if [ x"${feature_menuentry_id}" = xy ]; then
24 menuentry_id_option="--id"
25 else
26 menuentry_id_option=""
27 fi
28
29 export menuentry_id_option
30
31 if [ "${prev_saved_entry}" ]; then
32 set saved_entry="${prev_saved_entry}"
33 save_env saved_entry
34 set prev_saved_entry=
35 save_env prev_saved_entry
36 set boot_once=true
37 fi
38
39 function savedefault {
40 if [ -z "${boot_once}" ]; then
41 saved_entry="${chosen}"
42 save_env saved_entry
43 fi
44 }
45
46 function load_video {
47 if [ x$feature_all_video_module = xy ]; then
48 insmod all_video
49 else
50 insmod efi_gop
51 insmod efi_uga
52 insmod ieee1275_fb
53 insmod vbe
54 insmod vga
55 insmod video_bochs
56 insmod video_cirrus
57 fi
58 }
59
60 set menu_color_normal=light-gray/black
61 set menu_color_highlight=green/black
62
63 insmod part_msdos
64 insmod ext2
65 set root='hd2,msdos3'
66 if [ x$feature_platform_search_hint = xy ]; then
67 search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,msdos3' --hint-bios=hd2,msdos3 --hint-efi=hd2,msdos3 --hint-baremetal=ahci2,msdos3 bb7ffb9c-67ce-4002-b16b-05b7607979c4
68 else
69 search --no-floppy --fs-uuid --set=root bb7ffb9c-67ce-4002-b16b-05b7607979c4
70 fi
71 if loadfont /boot/grub/unicode.pf2 ; then
72 set gfxmode=auto
73 load_video
74 insmod gfxterm
75 set locale_dir=$prefix/locale
76 set lang=de_DE
77 insmod gettext
78 fi
79 terminal_input console
80 terminal_output gfxterm
81 insmod part_msdos
82 insmod ext2
83 set root='hd2,msdos3'
84 if [ x$feature_platform_search_hint = xy ]; then
85 search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,msdos3' --hint-bios=hd2,msdos3 --hint-efi=hd2,msdos3 --hint-baremetal=ahci2,msdos3 bb7ffb9c-67ce-4002-b16b-05b7607979c4
86 else
87 search --no-floppy --fs-uuid --set=root bb7ffb9c-67ce-4002-b16b-05b7607979c4
88 fi
89 insmod gfxmenu
90 loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_12.pf2
91 loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_14.pf2
92 loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_16.pf2
93 loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_24.pf2
94 loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_48.pf2
95 loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_bold_16.pf2
96 loadfont ($root)/usr/share/grub/themes/manjaro/dejavu_sans_mono_12.pf2
97 loadfont ($root)/usr/share/grub/themes/manjaro/terminus-12.pf2
98 loadfont ($root)/usr/share/grub/themes/manjaro/terminus-14.pf2
99 loadfont ($root)/usr/share/grub/themes/manjaro/terminus-16.pf2
100 loadfont ($root)/usr/share/grub/themes/manjaro/terminus-18.pf2
101 loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b12.pf2
102 loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b14.pf2
103 loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b16.pf2
104 loadfont ($root)/usr/share/grub/themes/manjaro/terminus-b18.pf2
105 insmod png
106 set theme=($root)/usr/share/grub/themes/manjaro/theme.txt
107 export theme
108 if [ x$feature_timeout_style = xy ] ; then
109 set timeout_style=hidden
110 set timeout=10
111 # Fallback hidden-timeout code in case the timeout_style feature is
112 # unavailable.
113 elif sleep --interruptible 10 ; then
114 set timeout=0
115 fi
116 ### END /etc/grub.d/00_header ###
117
118 ### BEGIN /etc/grub.d/06_grub-customizer_menu_color_helper ###
119 set color_normal=light-gray/black
120 set color_highlight=green/black
121 ### END /etc/grub.d/06_grub-customizer_menu_color_helper ###
122
123 ### BEGIN /etc/grub.d/10_linux ###
124 menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-bb7ffb9c-67ce-4002-b16b-05b7607979c4' {
125 savedefault
126 load_video
127 set gfxpayload=keep
128 insmod gzio
129 insmod part_msdos
130 insmod ext2
131 set root='hd2,msdos3'
132 if [ x$feature_platform_search_hint = xy ]; then
133 search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,msdos3' --hint-bios=hd2,msdos3 --hint-efi=hd2,msdos3 --hint-baremetal=ahci2,msdos3 bb7ffb9c-67ce-4002-b16b-05b7607979c4
134 else
135 search --no-floppy --fs-uuid --set=root bb7ffb9c-67ce-4002-b16b-05b7607979c4
136 fi
137 linux /boot/vmlinuz-5.4-x86_64 root=UUID=bb7ffb9c-67ce-4002-b16b-05b7607979c4 rw quiet apparmor=1 security=apparmor udev.log_priority=3
138 initrd /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
139 }
140 submenu 'Advanced options for Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-bb7ffb9c-67ce-4002-b16b-05b7607979c4' {
141 menuentry 'Manjaro Linux (Kernel: 5.4.64-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.64-1-MANJARO x64-advanced-bb7ffb9c-67ce-4002-b16b-05b7607979c4' {
142 savedefault
143 load_video
144 set gfxpayload=keep
145 insmod gzio
146 insmod part_msdos
147 insmod ext2
148 set root='hd2,msdos3'
149 if [ x$feature_platform_search_hint = xy ]; then
150 search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,msdos3' --hint-bios=hd2,msdos3 --hint-efi=hd2,msdos3 --hint-baremetal=ahci2,msdos3 bb7ffb9c-67ce-4002-b16b-05b7607979c4
151 else
152 search --no-floppy --fs-uuid --set=root bb7ffb9c-67ce-4002-b16b-05b7607979c4
153 fi
154 linux /boot/vmlinuz-5.4-x86_64 root=UUID=bb7ffb9c-67ce-4002-b16b-05b7607979c4 rw quiet apparmor=1 security=apparmor udev.log_priority=3
155 initrd /boot/amd-ucode.img /boot/initramfs-5.4-x86_64.img
156 }
157 menuentry 'Manjaro Linux (Kernel: 5.4.64-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-5.4.64-1-MANJARO x64-fallback-bb7ffb9c-67ce-4002-b16b-05b7607979c4' {
158 load_video
159 set gfxpayload=keep
160 insmod gzio
161 insmod part_msdos
162 insmod ext2
163 set root='hd2,msdos3'
164 if [ x$feature_platform_search_hint = xy ]; then
165 search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,msdos3' --hint-bios=hd2,msdos3 --hint-efi=hd2,msdos3 --hint-baremetal=ahci2,msdos3 bb7ffb9c-67ce-4002-b16b-05b7607979c4
166 else
167 search --no-floppy --fs-uuid --set=root bb7ffb9c-67ce-4002-b16b-05b7607979c4
168 fi
169 linux /boot/vmlinuz-5.4-x86_64 root=UUID=bb7ffb9c-67ce-4002-b16b-05b7607979c4 rw quiet apparmor=1 security=apparmor udev.log_priority=3
170 initrd /boot/initramfs-5.4-x86_64-fallback.img
171 }
172 }
173
174 ### END /etc/grub.d/10_linux ###
175
176 ### BEGIN /etc/grub.d/20_linux_xen ###
177 ### END /etc/grub.d/20_linux_xen ###
178
179 ### BEGIN /etc/grub.d/30_os-prober ###
180 menuentry 'Windows Boot Manager (on /dev/sdd3)' --class windows --class os $menuentry_id_option 'osprober-efi-A8C5-3E26' {
181 savedefault
182 insmod part_gpt
183 insmod fat
184 set root='hd3,gpt3'
185 if [ x$feature_platform_search_hint = xy ]; then
186 search --no-floppy --fs-uuid --set=root --hint-ieee1275='ieee1275//disk@0,gpt3' --hint-bios=hd3,gpt3 --hint-efi=hd3,gpt3 --hint-baremetal=ahci3,gpt3 A8C5-3E26
187 else
188 search --no-floppy --fs-uuid --set=root A8C5-3E26
189 fi
190 chainloader /EFI/Microsoft/Boot/bootmgfw.efi
191 }
192 set timeout_style=menu
193 if [ "${timeout}" = 0 ]; then
194 set timeout=10
195 fi
196 ### END /etc/grub.d/30_os-prober ###
197
198 ### BEGIN /etc/grub.d/30_uefi-firmware ###
199 menuentry 'UEFI Firmware Settings' $menuentry_id_option 'uefi-firmware' {
200 fwsetup
201 }
202 ### END /etc/grub.d/30_uefi-firmware ###
203
204 ### BEGIN /etc/grub.d/40_custom ###
205 # This file provides an easy way to add custom menu entries. Simply type the
206 # menu entries you want to add after this comment. Be careful not to change
207 # the 'exec tail' line above.
208 ### END /etc/grub.d/40_custom ###
209
210 ### BEGIN /etc/grub.d/41_custom ###
211 if [ -f ${config_directory}/custom.cfg ]; then
212 source ${config_directory}/custom.cfg
213 elif [ -z "${config_directory}" -a -f $prefix/custom.cfg ]; then
214 source $prefix/custom.cfg;
215 fi
216 ### END /etc/grub.d/41_custom ###
217
218 ### BEGIN /etc/grub.d/60_memtest86+ ###
219 if [ "${grub_platform}" == "pc" ]; then
220 menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
221 search --fs-uuid --no-floppy --set=root --hint-ieee1275='ieee1275//disk@0,msdos3' --hint-bios=hd2,msdos3 --hint-efi=hd2,msdos3 --hint-baremetal=ahci2,msdos3 bb7ffb9c-67ce-4002-b16b-05b7607979c4
222 linux16 /boot/memtest86+/memtest.bin
223 }
224 fi
225 ### END /etc/grub.d/60_memtest86+ ###
/etc/default/grub
1 GRUB_DEFAULT="saved"
2 GRUB_TIMEOUT="10"
3 GRUB_TIMEOUT_STYLE="hidden"
4 GRUB_DISTRIBUTOR="Manjaro"
5 GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
6 GRUB_CMDLINE_LINUX=""
7
8 # If you want to enable the save default function, uncomment the following
9 # line, and set GRUB_DEFAULT to saved.
10 GRUB_SAVEDEFAULT="true"
11
12 # Preload both GPT and MBR modules so that they are not missed
13 GRUB_PRELOAD_MODULES="part_gpt part_msdos"
14
15 # Uncomment to enable booting from LUKS encrypted devices
16 #GRUB_ENABLE_CRYPTODISK="y"
17
18 # Uncomment to use basic console
19 GRUB_TERMINAL_INPUT="console"
20
21 # Uncomment to disable graphical terminal
22 #GRUB_TERMINAL_OUTPUT="console"
23
24 # The resolution used on graphical terminal
25 # note that you can use only modes which your graphic card supports via VBE
26 # you can see them in real GRUB with the command 'videoinfo'
27 GRUB_GFXMODE=auto
28
29 # Uncomment to allow the kernel use the same resolution used by grub
30 GRUB_GFXPAYLOAD_LINUX="keep"
31
32 # Uncomment if you want GRUB to pass to the Linux kernel the old parameter
33 # format "root=/dev/xxx" instead of "root=/dev/disk/by-uuid/xxx"
34 #GRUB_DISABLE_LINUX_UUID="true"
35
36 # Uncomment to disable generation of recovery mode menu entries
37 GRUB_DISABLE_RECOVERY="true"
38
39 # Uncomment and set to the desired menu colors. Used by normal and wallpaper
40 # modes only. Entries specified as foreground/background.
41 export GRUB_COLOR_NORMAL="light-gray/black"
42 export GRUB_COLOR_HIGHLIGHT="green/black"
43
44 # Uncomment one of them for the gfx desired, a image background or a gfxtheme
45 GRUB_BACKGROUND="/home/bastian/Bilder/Bluuuuurrrry/vadim-sadovski-n36.jpg"
46 GRUB_THEME="/usr/share/grub/themes/manjaro/theme.txt"
47
48 # Uncomment to get a beep at GRUB start
49 #GRUB_INIT_TUNE="480 440 1"
50
51 GRUB_FONT="/boot/grub/unicode.pf2"
52 # Uncomment this option to enable os-prober execution in the grub-mkconfig command
53 GRUB_DISABLE_OS_PROBER=false
grub_mkconfig
1 #! /bin/sh
2 set -e
3
4 # Generate grub.cfg by inspecting /boot contents.
5 # Copyright (C) 2006,2007,2008,2009,2010 Free Software Foundation, Inc.
6 #
7 # GRUB is free software: you can redistribute it and/or modify
8 # it under the terms of the GNU General Public License as published by
9 # the Free Software Foundation, either version 3 of the License, or
10 # (at your option) any later version.
11 #
12 # GRUB is distributed in the hope that it will be useful,
13 # but WITHOUT ANY WARRANTY; without even the implied warranty of
14 # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
15 # GNU General Public License for more details.
16 #
17 # You should have received a copy of the GNU General Public License
18 # along with GRUB. If not, see <http://www.gnu.org/licenses/>.
19
20 prefix="/usr"
21 exec_prefix="/usr"
22 datarootdir="/usr/share"
23
24 prefix="/usr"
25 exec_prefix="/usr"
26 sbindir="/usr/bin"
27 bindir="/usr/bin"
28 sysconfdir="/etc"
29 PACKAGE_NAME=GRUB
30 PACKAGE_VERSION=2.06~6~manjaro
31 host_os=linux-gnu
32 datadir="${datarootdir}"
33 if [ "x$pkgdatadir" = x ]; then
34 pkgdatadir="${datadir}/grub"
35 fi
36 # export it for scripts
37 export pkgdatadir
38
39 grub_cfg=""
40 grub_mkconfig_dir="${sysconfdir}"/grub.d
41
42 self=`basename $0`
43
44 grub_probe="${sbindir}/grub-probe"
45 grub_file="${bindir}/grub-file"
46 grub_editenv="${bindir}/grub-editenv"
47 grub_script_check="${bindir}/grub-script-check"
48
49 export TEXTDOMAIN=grub
50 export TEXTDOMAINDIR="${datarootdir}/locale"
51
52 . "${pkgdatadir}/grub-mkconfig_lib"
53
54 # Usage: usage
55 # Print the usage.
56 usage () {
57 gettext_printf "Usage: %s [OPTION]\n" "$self"
58 gettext "Generate a grub config file"; echo
59 echo
60 print_option_help "-o, --output=$(gettext FILE)" "$(gettext "output generated config to FILE [default=stdout]")"
61 print_option_help "-h, --help" "$(gettext "print this message and exit")"
62 print_option_help "-V, --version" "$(gettext "print the version information and exit")"
63 echo
64 gettext "Report bugs to <bug-grub@gnu.org>."; echo
65 }
66
67 argument () {
68 opt=$1
69 shift
70
71 if test $# -eq 0; then
72 gettext_printf "%s: option requires an argument -- \`%s'\n" "$self" "$opt" 1>&2
73 exit 1
74 fi
75 echo $1
76 }
77
78 # Check the arguments.
79 while test $# -gt 0
80 do
81 option=$1
82 shift
83
84 case "$option" in
85 -h | --help)
86 usage
87 exit 0 ;;
88 -V | --version)
89 echo "$self (${PACKAGE_NAME}) ${PACKAGE_VERSION}"
90 exit 0 ;;
91 -o | --output)
92 grub_cfg=`argument $option "$@"`; shift;;
93 --output=*)
94 grub_cfg=`echo "$option" | sed 's/--output=//'`
95 ;;
96 -*)
97 gettext_printf "Unrecognized option \`%s'\n" "$option" 1>&2
98 usage
99 exit 1
100 ;;
101 # Explicitly ignore non-option arguments, for compatibility.
102 esac
103 done
104
105 if [ "x$EUID" = "x" ] ; then
106 EUID=`id -u`
107 fi
108
109 if [ "$EUID" != 0 ] ; then
110 root=f
111 case "`uname 2>/dev/null`" in
112 CYGWIN*)
113 # Cygwin: Assume root if member of admin group
114 for g in `id -G 2>/dev/null` ; do
115 case $g in
116 0|544) root=t ;;
117 esac
118 done ;;
119 esac
120 if [ $root != t ] ; then
121 gettext_printf "%s: You must run this as root\n" "$self" >&2
122 exit 1
123 fi
124 fi
125
126 set $grub_probe dummy
127 if test -f "$1"; then
128 :
129 else
130 gettext_printf "%s: Not found.\n" "$1" 1>&2
131 exit 1
132 fi
133
134 # Device containing our userland. Typically used for root= parameter.
135 GRUB_DEVICE="`${grub_probe} --target=device /`"
136 GRUB_DEVICE_UUID="`${grub_probe} --device ${GRUB_DEVICE} --target=fs_uuid 2> /dev/null`" || true
137 GRUB_DEVICE_PARTUUID="`${grub_probe} --device ${GRUB_DEVICE} --target=partuuid 2> /dev/null`" || true
138
139 # Device containing our /boot partition. Usually the same as GRUB_DEVICE.
140 GRUB_DEVICE_BOOT="`${grub_probe} --target=device /boot`"
141 GRUB_DEVICE_BOOT_UUID="`${grub_probe} --device ${GRUB_DEVICE_BOOT} --target=fs_uuid 2> /dev/null`" || true
142
143 # Disable os-prober by default due to security reasons.
144 GRUB_DISABLE_OS_PROBER="true"
145
146 # Filesystem for the device containing our userland. Used for stuff like
147 # choosing Hurd filesystem module.
148 GRUB_FS="`${grub_probe} --device ${GRUB_DEVICE} --target=fs 2> /dev/null || echo unknown`"
149
150 if [ x"$GRUB_FS" = xunknown ]; then
151 GRUB_FS="$(stat -f -c %T / || echo unknown)"
152 fi
153
154 # Provide a default set of stock linux early initrd images.
155 # Define here so the list can be modified in the sourced config file.
156 if [ "x${GRUB_EARLY_INITRD_LINUX_STOCK}" = "x" ]; then
157 GRUB_EARLY_INITRD_LINUX_STOCK="intel-uc.img intel-ucode.img amd-uc.img amd-ucode.img early_ucode.cpio microcode.cpio"
158 fi
159
160 if test -f ${sysconfdir}/default/grub ; then
161 . ${sysconfdir}/default/grub
162 fi
163
164 if [ "x${GRUB_DISABLE_UUID}" = "xtrue" ]; then
165 if [ -z "${GRUB_DISABLE_LINUX_UUID}" ]; then
166 GRUB_DISABLE_LINUX_UUID="true"
167 fi
168 if [ -z "${GRUB_DISABLE_LINUX_PARTUUID}" ]; then
169 GRUB_DISABLE_LINUX_PARTUUID="true"
170 fi
171 fi
172
173 # XXX: should this be deprecated at some point?
174 if [ "x${GRUB_TERMINAL}" != "x" ] ; then
175 GRUB_TERMINAL_INPUT="${GRUB_TERMINAL}"
176 GRUB_TERMINAL_OUTPUT="${GRUB_TERMINAL}"
177 fi
178
179 termoutdefault=0
180 if [ "x${GRUB_TERMINAL_OUTPUT}" = "x" ]; then
181 GRUB_TERMINAL_OUTPUT=gfxterm;
182 termoutdefault=1;
183 fi
184
185 for x in ${GRUB_TERMINAL_OUTPUT}; do
186 case "x${x}" in
187 xgfxterm) ;;
188 xconsole | xserial | xofconsole | xvga_text)
189 # make sure all our children behave in conformance with ascii..
190 export LANG=C;;
191 *) echo "Invalid output terminal \"${GRUB_TERMINAL_OUTPUT}\"" >&2 ; exit 1 ;;
192 esac
193 done
194
195 GRUB_ACTUAL_DEFAULT="$GRUB_DEFAULT"
196
197 if [ "x${GRUB_ACTUAL_DEFAULT}" = "xsaved" ] ; then GRUB_ACTUAL_DEFAULT="`"${grub_editenv}" - list | sed -n '/^saved_entry=/ s,^saved_entry=,,p'`" ; fi
198
199
200 # These are defined in this script, export them here so that user can
201 # override them.
202 export GRUB_DEVICE \
203 GRUB_DEVICE_UUID \
204 GRUB_DEVICE_PARTUUID \
205 GRUB_DEVICE_BOOT \
206 GRUB_DEVICE_BOOT_UUID \
207 GRUB_DISABLE_OS_PROBER \
208 GRUB_FS \
209 GRUB_FONT \
210 GRUB_PRELOAD_MODULES \
211 GRUB_ACTUAL_DEFAULT
212
213 # These are optional, user-defined variables.
214 export GRUB_DEFAULT \
215 GRUB_HIDDEN_TIMEOUT \
216 GRUB_HIDDEN_TIMEOUT_QUIET \
217 GRUB_TIMEOUT \
218 GRUB_TIMEOUT_STYLE \
219 GRUB_DEFAULT_BUTTON \
220 GRUB_HIDDEN_TIMEOUT_BUTTON \
221 GRUB_TIMEOUT_BUTTON \
222 GRUB_TIMEOUT_STYLE_BUTTON \
223 GRUB_BUTTON_CMOS_ADDRESS \
224 GRUB_BUTTON_CMOS_CLEAN \
225 GRUB_DISTRIBUTOR \
226 GRUB_CMDLINE_LINUX \
227 GRUB_CMDLINE_LINUX_DEFAULT \
228 GRUB_CMDLINE_XEN \
229 GRUB_CMDLINE_XEN_DEFAULT \
230 GRUB_CMDLINE_LINUX_XEN_REPLACE \
231 GRUB_CMDLINE_LINUX_XEN_REPLACE_DEFAULT \
232 GRUB_CMDLINE_NETBSD \
233 GRUB_CMDLINE_NETBSD_DEFAULT \
234 GRUB_CMDLINE_GNUMACH \
235 GRUB_EARLY_INITRD_LINUX_CUSTOM \
236 GRUB_EARLY_INITRD_LINUX_STOCK \
237 GRUB_TERMINAL_INPUT \
238 GRUB_TERMINAL_OUTPUT \
239 GRUB_SERIAL_COMMAND \
240 GRUB_DISABLE_UUID \
241 GRUB_DISABLE_LINUX_UUID \
242 GRUB_DISABLE_LINUX_PARTUUID \
243 GRUB_DISABLE_RECOVERY \
244 GRUB_VIDEO_BACKEND \
245 GRUB_GFXMODE \
246 GRUB_BACKGROUND \
247 GRUB_THEME \
248 GRUB_GFXPAYLOAD_LINUX \
249 GRUB_COLOR_NORMAL \
250 GRUB_COLOR_HIGHLIGHT \
251 GRUB_INIT_TUNE \
252 GRUB_SAVEDEFAULT \
253 GRUB_ENABLE_CRYPTODISK \
254 GRUB_BADRAM \
255 GRUB_OS_PROBER_SKIP_LIST \
256 GRUB_DISABLE_SUBMENU \
257 GRUB_ROOT_FS_RO
258
259 if test "x${grub_cfg}" != "x"; then
260 rm -f "${grub_cfg}.new"
261 oldumask=$(umask); umask 077
262 exec > "${grub_cfg}.new"
263 umask $oldumask
264 fi
265 gettext "Generating grub configuration file ..." >&2
266 echo >&2
267
268 cat << EOF
269 #
270 # DO NOT EDIT THIS FILE
271 #
272 # It is automatically generated by $self using templates
273 # from ${grub_mkconfig_dir} and settings from ${sysconfdir}/default/grub
274 #
275 EOF
276
277
278 for i in "${grub_mkconfig_dir}"/* ; do
279 case "$i" in
280 # emacsen backup files. FIXME: support other editors
281 *~) ;;
282 # emacsen autosave files. FIXME: support other editors
283 */\#*\#) ;;
284 *)
285 if grub_file_is_not_garbage "$i" && test -x "$i" ; then
286 echo
287 echo "### BEGIN $i ###"
288 "$i"
289 echo "### END $i ###"
290 fi
291 ;;
292 esac
293 done
294
295 if test "x${grub_cfg}" != "x" ; then
296 if ! ${grub_script_check} ${grub_cfg}.new; then
297 # TRANSLATORS: %s is replaced by filename
298 gettext_printf "Syntax errors are detected in generated GRUB config file.
299 Ensure that there are no errors in /etc/default/grub
300 and /etc/grub.d/* files or please file a bug report with
301 %s file attached." "${grub_cfg}.new" >&2
302 echo >&2
303 exit 1
304 else
305 # none of the children aborted with error, install the new grub.cfg
306 cat ${grub_cfg}.new > ${grub_cfg}
307 rm -f ${grub_cfg}.new
308 fi
309 fi
310
311 gettext "done" >&2
312 echo >&2
Do you mean that Zen 2 CPU’s are incompatible with 5.4 ?
run again update-grub, and post the output here
it says line 272 so it can only be in mkconfig but i dont see an error in that file on that line.
update-grub
Found linux image: /boot/vmlinuz-5.17-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-5.17-x86_64.img
Found initrd fallback image: /boot/initramfs-5.17-x86_64-fallback.img
so reinstall grub:
pacman -S grub
and then run again update-grub and post output here
output is the same.
exactly.
remove & reinstall ?
the same error? … i dont know, ive never done that, dont want to mess that up even more…
are you efi or bios?
you mean the live boot ? it should be efi but let me double check.
run this:
test -d /sys/firmware/efi && echo efi || echo bios
motherboard is set to only boot uefi so it should be uefi and i know that i reinstalled because i first installed in BIOS
command tells the same
