Since major Update a few days ago: blackscreen after entering password
Hi together , noob here!
Hope you can help: after the last update a few days ago my system boots normally to the point where I enter my password. Then the screen gets dark and enters powersaving-mode. System seems to run in the background, while I can restart it with CTL-Alt_DEL.
Thanks to Timeshift I managed to restore my system but any new attempt to update fails into the same result.
I’m running a Ryzen PC with AMD-GPU and two different HDD’s (one with Win11, one with Manjaro) between which i can select in the GRUB-menue at startup.
Please take the time to read through the links below in order to help us help you. :wink:
Tips and Tricks
How to Request Support
Resources
Tip:
As a new member, you may want to subscribe to notifications for the Announcements > Stable Updates category. Every bundled update, whether it’s for Manjaro Testing or Manjaro Stable, always comes accompanied by a dedicated announcement thread.
  • The first post of the thread contains the changes with regard to the previous bundled update.
  • The second post of the thread details the potential problems, and how to deal with them.
  • The announcement thread also always contains a poll (in the first post), and a summary of past issues (in the second post), for those who’ve skipped an update — which is not advised with a rolling-release distribution, but it does happen. :wink:
You mean you see the greeter with the password prompt or you do not see it?
I see it and i can enter my password. THEN the screen turns black and enters powersaving-mode and says “no signal”.
Looks like something video or wayland related…but i will let the more experienced be the judge of that. In the meantime you can post your inxi (see the links above) from a live usb session.
Maybe wayland is not working in your config and as x11 got removed from plasma and gnome that is why you are stuck. But this should not switch the monitor to standby so i don’t know.
You can also try to select another type of session from the greeter screen - x11 or wayland, if you see a choice.
Hi, If i understand you right, you need an inxi from the broken system?
This would mean, that i have to run the update again to “destroy" my OS, because,like i wrote, i saved it via Timeshift into a functioning state before the update..
Ist there something i can do prior running the update to increase chances to perform a successfull update?
Reinstalling manjaro would bei my last choice, since i then would not learn anything new.. :grinning_face:
Btw. X11 and wayland are terms i did not encounter as by now, i need to read more about these..
You do not need to run an update, inxi is build in in a default install.
Boot from live session, manjaro-chroot -a (if you are on ext4 filesystem, otherwise manually), inxi -zv8, and post between 3 ticks (the </> posting button)
12System:
  12Kernel 6.12.48-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 15.2.1
    12clocksource tsc 12avail hpet,acpi_pm 12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64
    lang=en_US keytable=us tz=UTC misobasedir=manjaro
    misolabel=MANJARO_KDE_25010 quiet systemd.show_status=1 splash driver=free
    nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
  12Desktop KDE Plasma 12v 6 12tk Qt 12v N/A 12wm kwin_x11 12vt 2 12dm N/A 12Distro Manjaro
    12base Arch Linux
12Machine:
  12Type Desktop 12Mobo Micro-Star 12model MEG X570 UNIFY (MS-7C35) 12v 2.0 12serial N/A
    12Firmware UEFI 12vendor American Megatrends LLC. 12v A.J0 12date 03/29/2024
12Battery:
  12Message No system battery data found. Is one present?
12Memory:
  12System RAM 12total 32 GiB 12available 31.26 GiB 12used 2.22 GiB (7.1%)
  12Array-1 12capacity 128 GiB 12slots 4 12modules 2 12EC None 12max-module-size 32 GiB
    12note est.
  12Device-1 Channel-A DIMM 0 12type no module installed
  12Device-2 Channel-A DIMM 1 12type DDR4 12detail synchronous unbuffered
    (unregistered) 12size 16 GiB 12speed 3200 MT/s 12volts 12curr 1.2 12min 1.2 12max 1.2
    12width (bits) 12data 64 12total 64 12manufacturer Crucial
    12part-no BLS16G4D32AESE.M16FE 12serial <filter>
  12Device-3 Channel-B DIMM 0 12type no module installed
  12Device-4 Channel-B DIMM 1 12type DDR4 12detail synchronous unbuffered
12PCI Slots:
  12Slot 0 12type PCIe 12status in use 12info J6B2 12length long 12volts 3.3 12bus-ID 00:01.0
  12Slot 1 12type PCIe 12status in use 12info J6B1 12length short 12volts 3.3
    12bus-ID 00:1c.3
  12Slot 2 12type PCIe 12status in use 12info J6D1 12length short 12volts 3.3
    12bus-ID 00:1c.4
  12Slot 3 12type PCIe 12status in use 12info J7B1 12length short 12volts 3.3
    12bus-ID 00:1c.5
  12Slot 4 12type PCIe 12status in use 12info J8B4 12length short 12volts 3.3
    12bus-ID 00:1c.6
  12Slot 5 12type PCIe 12status in use 12info J8D1 12length short 12volts 3.3
    12bus-ID 00:1c.7
  12Slot 6 12type PCI 12status in use 12info J8B3 12length short 12volts 3.3
    12bus-ID 00:1e.0
  12Slot 12 12type PCIe 12status in use 12info J10 12length short 12volts 3.3
    12bus-ID 00:03.1 12children 121 2d:00.0 12class-ID 0604 12type bridge 12children
    121 2e:00.0 12class-ID 0604 12type bridge 12children 121 2f:00.0 12class-ID 0300
    12type display 122 2f:00.1 12class-ID 0403 12type audio
  12Slot 13 12type PCIe 12status available 12info J3600 12length short 12volts 3.3
    12bus-ID 00:1f.7
  12Slot 2 12type PCIe 12status available 12info J3708 12length short 12volts 3.3
    12bus-ID 00:1f.7
  12Slot 3 12type PCIe 12status available 12info J3702 12length short 12volts 3.3
    12bus-ID 00:1f.7
  12Slot 4 12type PCIe 12status available 12info J3703 12length short 12volts 3.3
    12bus-ID 00:1f.7
  12Slot 5 12type PCIe 12status in use 12info J3701, M.2 12length short 12volts 3.3
    12bus-ID 21:05.0
  12Slot 14 12type PCIe 12status in use 12info M.2 12length short 12volts 3.3
    12bus-ID 00:01.1 12children 121 01:00.0 12class-ID 0108 12type mass-storage
12CPU:
  12Info 12model AMD Ryzen 7 5800X3D 12socket AM4 12bits 64 12type MT MCP 12arch Zen 3+
    12gen 3 12level v3 12note check 12built 2022 12process TSMC n6 (7nm) 12family 0x19 (25)
    12model-id 0x21 (33) 12stepping 2 12microcode 0xA201211
  12Topology 12cpus 1x 12dies 1 12clusters 1 12cores 8 12threads 16 12tpc 2 12smt enabled
    12cache 12L1 512 KiB 12desc d-8x32 KiB; i-8x32 KiB 12L2 4 MiB 12desc 8x512 KiB
    12L3 96 MiB 12desc 1x96 MiB
  12Speed (MHz) 12avg 1753 12min/max 550/4550 12boost enabled 12base/boost 3400/3400
    12scaling 12driver amd-pstate-epp 12governor powersave 12volts 1.1 V
    12ext-clock 100 MHz 12cores 121 1753 122 1753 123 1753 124 1753 125 1753 126 1753 127 1753
    128 1753 129 1753 1210 1753 1211 1753 1212 1753 1213 1753 1214 1753 1215 1753 1216 1753
    12bogomips 108839
  12Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
  12Vulnerabilities
  12Type gather_data_sampling 12status Not affected
  12Type indirect_target_selection 12status Not affected
  12Type itlb_multihit 12status Not affected
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type mmio_stale_data 12status Not affected
  12Type reg_file_data_sampling 12status Not affected
  12Type retbleed 12status Not affected
  12Type spec_rstack_overflow 12mitigation Safe RET
  12Type spec_store_bypass 12mitigation Speculative Store Bypass disabled via
  12Type spectre_v1 12mitigation usercopy/swapgs barriers and __user pointer
  12Type spectre_v2 12mitigation Retpolines; IBPB: conditional; IBRS_FW; STIBP:
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  12Type srbds 12status Not affected
  12Type tsa 12mitigation Clear CPU buffers
  12Type tsx_async_abort 12status Not affected
  12Type vmscape 12mitigation IBPB before exit to userspace
12Graphics:
  12Device-1 Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
    XTX/7900 GRE/7900M] 12vendor Sapphire PULSE 12driver amdgpu 12v kernel
    12arch RDNA-3 12code Navi-3x 12process TSMC n5 (5nm) 12built 2022+ 12pcie 12gen 4
    12speed 16 GT/s 12lanes 16 12ports 12active DP-2 12empty DP-1, HDMI-A-1, HDMI-A-2,
    Writeback-1 12bus-ID 2f:00.0 12chip-ID 1002:744c 12class-ID 0300
  12Display x11 12server X.org 12v 1.21.1.18 12with Xwayland 12v 24.1.8
    12compositor kwin_x11 12driver 12X 12loaded amdgpu 12unloaded modesetting,radeon
    12alternate fbdev,vesa 12dri radeonsi 12gpu amdgpu 12display-ID :0
  12Monitor-1 DP-2 12model Dell S3220DGF 12serial <filter> 12built 2020 12res 2560x1440
    12dpi 93 12gamma 1.2 12chroma 12red 12x 0.678 12y 0.314 12green 12x 0.271 12y 0.659 12blue
    12x 0.149 12y 0.067 12white 12x 0.314 12y 0.329 12size 697x392mm (27.44x15.43")
    12diag 806mm (31.7") 12ratio 16:9 12modes 2560x1440, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480, 720x400
  12API EGL 12v 1.5 12hw 12drv amd radeonsi 12platforms 12device 0 12drv radeonsi 12device 1
    12drv swrast 12gbm 12drv radeonsi 12surfaceless 12drv radeonsi 12inactive wayland,x11
  12API OpenGL 12v 4.6 12compat-v 4.5 12vendor mesa 12v 25.2.3-arch1.2 12note incomplete
    (EGL sourced) 12renderer AMD Radeon RX 7900 GRE (radeonsi navi31 LLVM 20.1.8
    DRM 3.61 6.12.48-1-MANJARO), llvmpipe (LLVM 20.1.8 256 bits)
  12API Vulkan 12Message No Vulkan data available.
  12Info 12Tools 12api clinfo, eglinfo, glxinfo, vulkaninfo
    12de kscreen-console,kscreen-doctor 12wl wayland-info 12x11 xdpyinfo, xprop, xrandr
12Audio:
  12Device-1 Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    12driver snd_hda_intel 12v kernel 12pcie 12gen 4 12speed 16 GT/s 12lanes 16
    12bus-ID 2f:00.1 12chip-ID 1002:ab30 12class-ID 0403
  12Device-2 Advanced Micro Devices [AMD] Starship/Matisse HD Audio
    12vendor Micro-Star MSI 12driver snd_hda_intel 12v kernel 12pcie 12gen 4 12speed 16 GT/s
    12lanes 16 12bus-ID 31:00.4 12chip-ID 1022:1487 12class-ID 0403
  12Device-3 beyerdynamic GmbH & KG LL Adapter
    12driver hid-generic,snd-usb-audio,usbhid 12type USB 12rev 2.0 12speed 12 Mb/s
    12lanes 1 12mode 1.1 12bus-ID 5-3.1.2:6 12chip-ID 2e50:002f 12class-ID 0102
    12serial <filter>
  12API ALSA 12v k6.12.48-1-MANJARO 12status kernel-api 12with aoss 12type oss-emulator
    12tools alsactl,alsamixer,amixer
  12Server-1 sndiod 12v N/A 12status off 12tools aucat,midicat,sndioctl
  12Server-2 JACK 12v 1.9.22 12status off 12tools N/A
  12Server-3 PipeWire 12v 1.4.8 12status n/a (root, process) 12with 121 pipewire-pulse
    12status active 122 wireplumber 12status active 123 pipewire-alsa 12type plugin
    12tools pactl,pw-cat,pw-cli,wpctl
12Network:
  12Device-1 Realtek RTL8125 2.5GbE 12vendor Micro-Star MSI 12driver r8169 12v kernel
    12pcie 12gen 2 12speed 5 GT/s 12lanes 1 12port f000 12bus-ID 27:00.0 12chip-ID 10ec:8125
    12class-ID 0200
  12IF enp39s0 12state up 12speed 2500 Mbps 12duplex full 12mac <filter>
  12IP v4 <filter> 12type dynamic noprefixroute 12scope global 12broadcast <filter>
  12IP v6 <filter> 12type dynamic noprefixroute 12scope global
  12IP v6 <filter> 12type noprefixroute 12scope link
  12Device-2 Intel Wi-Fi 6 AX200 12driver iwlwifi 12v kernel 12pcie 12gen 2
    12speed 5 GT/s 12lanes 1 12bus-ID 28:00.0 12chip-ID 8086:2723 12class-ID 0280
  12IF wlo1 12state down 12mac <filter>
  12Info 12services NetworkManager, systemd-timesyncd, wpa_supplicant
  12WAN IP <filter>
12Bluetooth:
  12Device-1 Intel AX200 Bluetooth 12driver btusb 12v 0.8 12type USB 12rev 2.0
    12speed 12 Mb/s 12lanes 1 12mode 1.1 12bus-ID 1-4:2 12chip-ID 8087:0029 12class-ID e001
  12Report rfkill 12ID hci0 12rfk-id 0 12state up 12address see --recommends
12Logical:
  12Message No logical block device data found.
12RAID:
  12Message No RAID data found.
12Drives:
  12Local Storage 12total 5.58 TiB 12used 338.66 GiB (5.9%)
  12ID-1 /dev/nvme0n1 12maj-min 259:0 12vendor Crucial 12model CT1000P1SSD8
    12size 931.51 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 31.6 Gb/s
    12lanes 4 12tech SSD 12serial <filter> 12fw-rev P3CR013 12temp 31.9 C
  12SMART yes 12health PASSED 12on 1y 127d 20h 12cycles 3,783
    12read-units 35,235,645 [18.0 TB] 12written-units 29,869,635 [15.2 TB]
  12ID-2 /dev/nvme1n1 12maj-min 259:6 12vendor Western Digital
    12model WD BLACK SN850X 2000GB 12size 1.82 TiB 12block-size 12physical 512 B
    12logical 512 B 12speed 63.2 Gb/s 12lanes 4 12tech SSD 12serial <filter>
    12fw-rev 620361WD 12temp 45.9 C
  12SMART yes 12health PASSED 12on 130d 4h 12cycles 957
    12read-units 20,195,567 [10.3 TB] 12written-units 8,460,759 [4.33 TB]
  12ID-3 /dev/sda 12maj-min 8:0 12vendor Samsung 12model SSD 850 EVO 500GB
    12family based SSDs 12size 465.76 GiB 12block-size 12physical 512 B 12logical 512 B
    12sata 3.1 12speed 6.0 Gb/s 12tech SSD 12serial <filter> 12fw-rev 2B6Q 12temp 19 C
  12SMART yes 12state enabled 12health PASSED 12on 1y 190d 7h 12cycles 4422
    12written 12.72 TiB
  12ID-4 /dev/sdb 12maj-min 8:16 12vendor Crucial 12model M4-CT512M4SSD2
    12family Micron RealSSD m4/C400 12size 476.94 GiB 12block-size 12physical 512 B
    12logical 512 B 12sata 3.0 12speed 6.0 Gb/s 12tech SSD 12serial <filter> 12fw-rev 000F
  12SMART yes 12state enabled 12health PASSED 12on 1y 287d 8h 12cycles 5422 12Pre-Fail
    12reallocated sector 100 12threshold 10
  12ID-5 /dev/sdc 12maj-min 8:32 12vendor Seagate 12model Portable 12size 1.82 TiB
    12block-size 12physical 4096 B 12logical 512 B 12type USB 12rev 3.0 12spd 5 Gb/s 12lanes 1
    12mode 3.2 gen-1x1 12tech N/A 12serial <filter> 12fw-rev 9300
  12SMART Message A mandatory SMART command failed. Various possible causes.
  12ID-6 /dev/sdd 12maj-min 8:48 12vendor Transcend 12model JetFlash 128GB
    12size 112.64 GiB 12block-size 12physical 512 B 12logical 512 B 12type USB 12rev 2.1
    12spd 480 Mb/s 12lanes 1 12mode 2.0 12tech SSD 12serial <filter> 12fw-rev 1100
  12SMART Message Unknown USB bridge. Flash drive/Unsupported enclosure?
  12Optical-1 /dev/sr0 12vendor TSSTcorp 12model CD/DVDW SH-S183A 12rev SB02
    12dev-links cdrom
  12Features 12speed 48 12multisession yes 12audio yes 12dvd yes
    12rw cd-r,cd-rw,dvd-r,dvd-ram 12state running
12Partition:
  12ID-1 / 12raw-size 1.82 TiB 12size 1.79 TiB (98.37%) 12used 338.66 GiB (18.5%)
    12fs ext4 12block-size 4096 B 12dev /dev/nvme1n1p2 12maj-min 259:8 12label N/A
    12uuid 5b5b32e9-8e78-455c-8b04-44049c35ca04
12Swap:
  12Alert No swap data was found.
12Unmounted:
  12ID-1 /dev/nvme0n1p1 12maj-min 259:1 12size 529 MiB 12fs ntfs 12label N/A
    12uuid 349A0CF19A0CB202
  12ID-2 /dev/nvme0n1p2 12maj-min 259:2 12size 100 MiB 12fs fat (32 bit) 12label N/A
    12uuid 3A24-81DA
  12ID-3 /dev/nvme0n1p3 12maj-min 259:3 12size 16 MiB 12fs N/A 12label N/A 12uuid N/A
  12ID-4 /dev/nvme0n1p4 12maj-min 259:4 12size 930.09 GiB 12fs ntfs 12label NVME
    12uuid AC7633D176339AD2
  12ID-5 /dev/nvme0n1p5 12maj-min 259:5 12size 808 MiB 12fs ntfs 12label N/A
    12uuid 60701F1F701EFC0A
  12ID-6 /dev/nvme1n1p1 12maj-min 259:7 12size 300 MiB 12fs fat (32 bit) 12label N/A
    12uuid 0ED0-BD87
  12ID-7 /dev/sda1 12maj-min 8:1 12size 465.76 GiB 12fs ext4 12label Samsung500GB
    12uuid 74b67f60-0bb1-4518-97a4-7c3e244e7936
  12ID-8 /dev/sdb1 12maj-min 8:17 12size 476.94 GiB 12fs ntfs 12label Transfer-SSD
    12uuid 5C9AF0AC9AF08434
  12ID-9 /dev/sdc1 12maj-min 8:33 12size 1.82 TiB 12fs btrfs 12label N/A
    12uuid 3eb34b44-3ce5-4dbe-919d-fa427de82bc3
  12ID-10 /dev/sdd1 12maj-min 8:49 12size 5.1 GiB 12fs N/A 12label MANJARO_KDE_25010
    12uuid 2025-10-13-14-44-52-00
  12ID-11 /dev/sdd2 12maj-min 8:50 12size 4 MiB 12fs N/A 12label MISO_EFI
    12uuid CA66-EF73
12USB:
  12Hub-1 1-0:1 12info hi-speed hub with single TT 12ports 6 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12chip-ID 1d6b:0002 12class-ID 0900
  12Device-1 1-4:2 12info Intel AX200 Bluetooth 12type bluetooth 12driver btusb
    12interfaces 2 12rev 2.0 12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 100mA
  12Hub-2 2-0:1 12info super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
    12lanes 1 12mode 3.2 gen-2x1 12chip-ID 1d6b:0003 12class-ID 0900
  12Device-1 2-2:2 12info Seagate RSS LLC Portable 12type mass storage 12driver uas
    12interfaces 1 12rev 3.0 12speed 5 Gb/s (596.0 MiB/s) 12lanes 1 12mode 3.2 gen-1x1
    12power 144mA 12chip-ID 0bc2:2343 12class-ID 0806 12serial <filter>
  12Hub-3 3-0:1 12info hi-speed hub with single TT 12ports 6 12rev 2.0
  12Device-1 3-5:2 12info Micro Star MYSTIC LIGHT 12type HID
    12driver hid-generic,usbhid 12interfaces 1 12rev 1.1 12speed 12 Mb/s (1.4 MiB/s)
    12lanes 1 12mode 1.1 12power 500mA 12chip-ID 1462:7c35 12class-ID 0300
    12serial <filter>
  12Hub-4 3-6:3 12info Genesys Logic Hub 12ports 4 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 100mA 12chip-ID 05e3:0608
    12class-ID 0900
  12Device-1 3-6.1:4 12info Transcend Information JetFlash 12type mass storage
    12driver usb-storage 12interfaces 1 12rev 2.1 12speed 480 Mb/s (57.2 MiB/s) 12lanes 1
    12mode 2.0 12power 300mA 12chip-ID 8564:1000 12class-ID 0806 12serial <filter>
  12Hub-5 4-0:1 12info super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
  12Hub-6 5-0:1 12info hi-speed hub with single TT 12ports 4 12rev 2.0
  12Hub-7 5-3:2 12info Genesys Logic Hub 12ports 4 12rev 2.0
    12speed 480 Mb/s (57.2 MiB/s) 12lanes 1 12mode 2.0 12power 100mA 12chip-ID 05e3:0610
    12class-ID 0900
  12Hub-8 5-3.1:3 12info Genesys Logic Hub 12ports 4 12rev 2.0
    12class-ID 0900
  12Device-1 5-3.1.1:5 12info MosArt 2.4G Keyboard Mouse 12type keyboard,mouse
    12driver hid-generic,usbhid 12interfaces 2 12rev 1.1 12speed 12 Mb/s (1.4 MiB/s)
    12lanes 1 12mode 1.1 12power 100mA 12chip-ID 062a:261c 12class-ID 0301
  12Device-2 5-3.1.2:6 12info beyerdynamic GmbH & KG LL Adapter 12type HID,audio
    12driver hid-generic,snd-usb-audio,usbhid 12interfaces 4 12rev 2.0
    12speed 12 Mb/s (1.4 MiB/s) 12lanes 1 12mode 1.1 12power 100mA 12chip-ID 2e50:002f
    12class-ID 0102 12serial <filter>
  12Device-3 5-3.2:4 12info MosArt Wireless Mouse 12type mouse
    12lanes 1 12mode 1.1 12power 100mA 12chip-ID 062a:4102 12class-ID 0301
  12Hub-9 6-0:1 12info super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s (1.16 GiB/s)
12Sensors:
  12System Temperatures 12cpu 31.4 C 12mobo N/A 12gpu amdgpu 12temp 34.0 C 12mem 51.0 C
  12Fan Speeds (rpm) N/A 12gpu amdgpu 12fan 2
12Repos:
  12Packages 1714 12pm pacman 12pkgs 1705 12libs 498 12tools pamac 12pm flatpak 12pkgs 9
  12Active pacman repo servers in /etc/pacman.d/mirrorlist
    121 https: //mirror.koddos.net/manjaro/stable/$repo/$arch
    122 https: //www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    123 https: //mirror.telepoint.bg/manjaro/stable/$repo/$arch
    124 https: //ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    125 https: //cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    126 https: //southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    127 https: //nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    128 https: //kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
12Processes:
  12CPU top 5 of 351
  121 12cpu 0.9% 12command zsh 12pid 2614 12mem 8.55 MiB (0.0%)
  122 12cpu 0.3% 12command konsole 12pid 2590 12mem 132.6 MiB (0.4%)
  123 12cpu 0.2% 12command Xorg 12pid 1749 12mem 179.8 MiB (0.5%)
  124 12cpu 0.2% 12command plasmashell 12pid 1929 12mem 375.4 MiB (1.1%)
  125 12cpu 0.1% 12command init 12pid 1 12mem 13.7 MiB (0.0%)
  12Memory top 5 of 351
  121 12mem 375.4 MiB (1.1%) 12command plasmashell 12pid 1929 12cpu 0.2%
  122 12mem 238.6 MiB (0.7%) 12command kwin_x11 12pid 1888 12cpu 0.1%
  123 12mem 179.8 MiB (0.5%) 12command Xorg 12pid 1749 12cpu 0.2%
  124 12mem 132.6 MiB (0.4%) 12command konsole 12pid 2590 12cpu 0.3%
  125 12mem 127.5 MiB (0.3%) 12command yakuake 12pid 2253 12cpu 0.0%
12Info:
  12Processes 351 12Power 12uptime 13m 12states freeze,mem,disk 12suspend deep
    12avail s2idle 12wakeups 0 12hibernate platform 12avail shutdown, reboot, suspend,
    test_resume 12image 12.46 GiB 12services org_kde_powerdevil,
    power-profiles-daemon, upowerd 12Init systemd 12v 257 12default graphical
    12tool systemctl
  12Compilers 12clang 20.1.8 12gcc 15.2.1 12Client systemd 12inxi 3.3.40
I am not sure which variant you using - but 7900 XTX run flawless on Manjaro. I know - because I have been running it for years.
I suggest you reboot to the display manager
  • do not enter your password
  • switch to a TTY Ctrl+Alt+F4
  • login with your username - then remove the content of the ~/.cache folder
    rm -rf ~/.cache/*
Logout and switch back to the display manager Ctrl+Alt+F2 - perhaps F1
Check in lower left corner - the session type… select Wayland
Then enter your password to login and see what happen…
Many thanks!
In the left corner you mentioned i had “KODi on GBM”, don’t know why and if this was my major problem, but it works now! :+1:
@Jagermo
System Information
inxi -zv8 (short-form)
inxi man pages (manual)
:point_down: :point_down:
Running `inxi` within a `chroot` environment
:point_up: :point_up:
Your privacy is respected
A post was split to a new topic: User with old Nvidia GPU
A post was merged into an existing topic: User with old Nvidia GPU
Possibly the 6.3 to 6.5 where the x11 session no longer exist and therefore the known sessions are listed alphabetically.
