Hello,
I have read and tried a lot of fixes now. After an update some time ago, my X broke and I can’t get graphics anymore. Every help is appreciated (also how do I copy code from tty to the forum?)
Best regards
Hello,
Best regards
Select the text with a mouse and press Ctrl Shift C to copy the highlighted text. Not sure how much help I can be with the other part. Good luck!
Well, I have only access to the TTYs with CTRL-ALT-F3 to F7
There is no mouse, and I have to connect to the WIFI via nmtui
startx says: no display found
I reinstalled all nvidia drivers, updated to latest kernel, any help would be greatly appreciated
Perfect, exactly what I needed, here is my system info:
Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=db4b7c7e-3676-4dd7-a17d-b14b220cc184 rw apparmor=1
security=apparmor resume=UUID=5e39f5a4-8662-49d7-b2ec-6e0d508edd78
udev.log_priority=3
bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash acpi_osi=!
"acpi_osi=Windows 2009"
Console: tty 3 DM: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Micro-Star product: GS65 Stealth Thin 8RF v: REV:1.0
Mobo: Micro-Star model: MS-16Q2 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16Q2IMS.10E date: 08/27/2018
ID-1: BAT1 charge: 60.5 Wh (90.8%) condition: 66.6/80.3 Wh (83.0%)
volts: 16.8 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
RAM: total: 31.19 GiB used: 1.04 GiB (3.3%)
Info: model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 9 MiB desc: 1x9 MiB
Speed (MHz): avg: 2083 high: 2200 min/max: 800/4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 2200 2: 2200 3: 2200
4: 2200 5: 2200 6: 2200 7: 2200 8: 2200 9: 2200 10: 800 11: 2200 12: 2200
bogomips: 52815
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: DP-1,eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA GP104M [GeForce GTX 1070 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-03) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1ba1 class-ID: 0300
Display: server: X.org v: 1.21.1.7 driver: X: loaded: nvidia gpu: i915
tty: 240x67
Monitor-1: DP-1 model: LG (GoldStar) HDR 4K serial: <filter> built: 2021
res: 3840x2160 dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39")
diag: 690mm (27.2") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 model: BOE Display 0x07af built: 2018 res: 1920x1080
dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: GL data unavailable in console. Try -G --display
Device-1: Intel Cannon Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
API: ALSA v: k6.1.19-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.65 status: off with: pipewire-media-session
status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: off with: pulseaudio-jack type: module
tools: pacat,pactl
Device-1: Intel Cannon Lake PCH CNVi WiFi vendor: Rivet Networks Killer
Wireless-AC 1550i Wireless driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Qualcomm Atheros Killer E2500 Gigabit Ethernet
vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 3d:00.0 chip-ID: 1969:e0b1 class-ID: 0200
IF: enp61s0 state: down mac: <filter>
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 1-14:5 chip-ID: 8087:0aaa class-ID: e001
Local Storage: total: 1.38 TiB used: 312.76 GiB (22.2%)
ID-1: /dev/nvme0n1 maj-min: 259:4 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 47.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital
model: PC SN720 SDAPNTW-512G size: 476.94 GiB block-size: physical: 512 B
rev: 10123000 temp: 44.9 C scheme: GPT
ID-1: / raw-size: 442.31 GiB size: 434.3 GiB (98.19%)
used: 312.73 GiB (72.0%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:2
label: Home uuid: db4b7c7e-3676-4dd7-a17d-b14b220cc184
used: 25.8 MiB (8.6%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1 label: N/A
uuid: C07B-C900
ID-1: swap-1 type: partition size: 34.33 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:3 label: N/A
uuid: 5e39f5a4-8662-49d7-b2ec-6e0d508edd78
ID-1: /dev/nvme0n1p1 maj-min: 259:5 size: 465.76 GiB fs: ntfs label: N/A
uuid: 967EC0727EC04CA5
ID-2: /dev/nvme0n1p2 maj-min: 259:6 size: 600 MiB fs: vfat label: N/A
uuid: CEF7-20F0
ID-3: /dev/nvme0n1p3 maj-min: 259:7 size: 1024 MiB fs: ext4 label: N/A
uuid: c6d2a54b-9244-40ed-bb34-6aa51f243c8a
ID-4: /dev/nvme0n1p4 maj-min: 259:8 size: 464.17 GiB fs: btrfs
label: fedora_localhost-live uuid: 165394b4-5265-46fb-8051-1dc5b53ed958
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-5:2 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-7:3 info: SteelSeries ApS KLC type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 300mA
chip-ID: 1038:1122 class-ID: 0300
Device-3: 1-14:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 3-1:4 info: Texas Instruments TUSB8041 4-Port Hub ports: 4 rev: 2.1
speed: 480 Mb/s chip-ID: 0451:8142 class-ID: 0900
Device-1: 3-1.3:5 info: SINO WEALTH Mechanical Keyboard type: Keyboard
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 500mA
chip-ID: 258a:0090 class-ID: 0301
Device-2: 3-1.4:6 info: LG USA USB Controls
type: HID,Abstract (modem),CDC-Data driver: cdc_acm,hid-generic,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip-ID: 043e:9a39 class-ID: 0a00
serial: <filter>
Hub-5: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.0 C pch: 59.0 C mobo: N/A gpu: nvidia temp: 47 C
Processes: 246 Uptime: 3m wakeups: 5 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1698
pm: pacman pkgs: 1680 libs: 459 tools: pamac,yay pm: flatpak pkgs: 0 pm: snap
pkgs: 18 Shell: Bash (login) v: 5.1.16 running-in: tty 3 inxi: 3.3.26
Post the log from X server to see if X has a problem
cat /var/log/Xorg.0.log
Alright, here it is:
[ 5.840] (--) Log file renamed from "/var/log/Xorg.pid-1143.log" to "/var/log/Xorg.0.log"
[ 5.841]
X.Org X Server 1.21.1.7
[ 5.841] Current Operating System: Linux ManjoTox 6.1.19-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon Mar 13 12:59:35 UTC 2023 x86_64
[ 5.841] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=db4b7c7e-3676-4dd7-a17d-b14b220cc184 rw apparmor=1 security=apparmor resume=UUID=5e39f5a4-8662-49d7-b2ec-6e0d508edd78 udev.log_priority=3 bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash acpi_osi=! "acpi_osi=Windows 2009"
[ 5.841]
[ 5.841] Current version of pixman: 0.42.2
[ 5.841] Before reporting problems, check http://wiki.x.org
[ 5.841] Markers: (--) probed, (**) from config file, (==) default setting,
[ 5.842] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Apr 12 22:06:25 2023
[ 5.843] (==) Using config file: "/etc/X11/xorg.conf"
[ 5.843] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 5.843] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 5.845] (==) ServerLayout "layout"
[ 5.845] (**) |-->Screen "Screen0" (0)
[ 5.845] (**) | |-->Monitor "Monitor0"
[ 5.845] (**) | |-->Device "Device0"
[ 5.845] (==) Automatically adding devices
[ 5.845] (==) Automatically enabling devices
[ 5.845] (==) Automatically adding GPU devices
[ 5.845] (==) Automatically binding GPU devices
[ 5.845] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 5.846] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 5.846] Entry deleted from font path.
[ 5.846] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 5.846] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 5.846] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 5.846] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 5.846] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 5.846] (II) The server relies on udev to provide the list of input devices.
[ 5.846] (II) Module ABI versions:
[ 5.846] X.Org ANSI C Emulation: 0.4
[ 5.846] X.Org Video Driver: 25.2
[ 5.846] X.Org XInput driver : 24.4
[ 5.846] X.Org Server Extension : 10.0
[ 5.847] (++) using VT number 1
[ 5.847] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 5.848] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 5.848] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[ 5.848] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 5.848] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 5.856] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 5.856] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 7.000] (--) PCI:*(0@0:2:0) 8086:3e9b:1462:1227 rev 0, Mem @ 0xab000000/16777216, 0x40000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 7.000] (--) PCI: (1@0:0:0) 10de:1ba1:1462:1227 rev 161, Mem @ 0xac000000/16777216, 0x80000000/268435456, 0x90000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[ 7.000] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 7.000] (II) LoadModule: "glx"
[ 7.002] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 7.006] (II) Module glx: vendor="X.Org Foundation"
[ 7.006] compiled for 1.21.1.7, module version = 1.0.0
[ 7.006] ABI class: X.Org Server Extension, version 10.0
[ 7.006] (II) LoadModule: "nvidia"
[ 7.006] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 7.009] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 7.009] compiled for 1.6.99.901, module version = 1.0.0
[ 7.009] Module class: X.Org Video Driver
[ 7.009] (II) NVIDIA dlloader X Driver 525.89.02 Wed Feb 1 23:14:37 UTC 2023
[ 7.009] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 7.010] (II) Loading sub module "fb"
[ 7.010] (II) LoadModule: "fb"
[ 7.010] (II) Module "fb" already built-in
[ 7.010] (II) Loading sub module "wfb"
[ 7.010] (II) LoadModule: "wfb"
[ 7.010] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 7.011] (II) Module wfb: vendor="X.Org Foundation"
[ 7.011] compiled for 1.21.1.7, module version = 1.0.0
[ 7.011] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.011] (II) Loading sub module "ramdac"
[ 7.011] (II) LoadModule: "ramdac"
[ 7.011] (II) Module "ramdac" already built-in
[ 7.011] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 7.011] (==) NVIDIA(0): RGB weight 888
[ 7.011] (==) NVIDIA(0): Default visual is TrueColor
[ 7.011] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.011] (**) Option "AllowNVIDIAGpuScreens"
[ 7.011] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 7.011] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 7.011] (**) NVIDIA(0): Enabling 2D acceleration
[ 7.011] (II) Loading sub module "glxserver_nvidia"
[ 7.011] (II) LoadModule: "glxserver_nvidia"
[ 7.011] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 7.042] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 7.042] compiled for 1.6.99.901, module version = 1.0.0
[ 7.042] Module class: X.Org Server Extension
[ 7.042] (II) NVIDIA GLX Module 525.89.02 Wed Feb 1 23:13:01 UTC 2023
[ 7.043] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 8.349] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 8.349] (--) NVIDIA(0): DFP-0
[ 8.349] (--) NVIDIA(0): DFP-1
[ 8.349] (--) NVIDIA(0): DFP-2
[ 8.350] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 1070 with Max-Q Design (GP104-A)
[ 8.350] (II) NVIDIA(0): at PCI:1:0:0 (GPU-0)
[ 8.350] (--) NVIDIA(0): Memory: 8388608 kBytes
[ 8.350] (--) NVIDIA(0): VideoBIOS: 86.04.8a.00.88
[ 8.350] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 8.350] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 8.350] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 8.350] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 8.350] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 8.350] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 8.350] (--) NVIDIA(GPU-0): DFP-1: 1440.0 MHz maximum pixel clock
[ 8.350] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 8.350] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 8.350] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 8.350] (==) NVIDIA(0):
[ 8.350] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 8.350] (==) NVIDIA(0): will be used as the requested mode.
[ 8.350] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[ 8.350] (--) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 8.350] (II) NVIDIA(0): Validated MetaModes:
[ 8.350] (II) NVIDIA(0): "NULL"
[ 8.350] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 8.350] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 8.350] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 8.350] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 8.350] (II) NVIDIA: access.
[ 8.354] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 8.354] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 8.354] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 8.354] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 8.354] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 8.354] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 8.354] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 8.354] (II) NVIDIA(0): Config Options in the README.
[ 8.369] (II) NVIDIA(0): Setting mode "NULL"
[ 8.375] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 8.375] (==) NVIDIA(0): Backing store enabled
[ 8.375] (==) NVIDIA(0): Silken mouse enabled
[ 8.375] (**) NVIDIA(0): DPMS enabled
[ 8.375] (II) Loading sub module "dri2"
[ 8.375] (II) LoadModule: "dri2"
[ 8.375] (II) Module "dri2" already built-in
[ 8.375] (II) NVIDIA(0): [DRI2] Setup complete
[ 8.375] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 8.375] (II) Initializing extension Generic Event Extension
[ 8.375] (II) Initializing extension SHAPE
[ 8.375] (II) Initializing extension MIT-SHM
[ 8.375] (II) Initializing extension XInputExtension
[ 8.375] (II) Initializing extension XTEST
[ 8.375] (II) Initializing extension BIG-REQUESTS
[ 8.375] (II) Initializing extension SYNC
[ 8.375] (II) Initializing extension XKEYBOARD
[ 8.376] (II) Initializing extension XC-MISC
[ 8.376] (II) Initializing extension SECURITY
[ 8.376] (II) Initializing extension XFIXES
[ 8.376] (II) Initializing extension RENDER
[ 8.376] (II) Initializing extension RANDR
[ 8.376] (II) Initializing extension COMPOSITE
[ 8.376] (II) Initializing extension DAMAGE
[ 8.376] (II) Initializing extension MIT-SCREEN-SAVER
[ 8.376] (II) Initializing extension DOUBLE-BUFFER
[ 8.376] (II) Initializing extension RECORD
[ 8.376] (II) Initializing extension DPMS
[ 8.376] (II) Initializing extension Present
[ 8.376] (II) Initializing extension DRI3
[ 8.376] (II) Initializing extension X-Resource
[ 8.376] (II) Initializing extension XVideo
[ 8.376] (II) Initializing extension XVideo-MotionCompensation
[ 8.376] (II) Initializing extension GLX
[ 8.377] (II) Initializing extension GLX
[ 8.377] (II) Indirect GLX disabled.
[ 8.377] (II) GLX: Another vendor is already registered for screen 0
[ 8.377] (II) Initializing extension XFree86-VidModeExtension
[ 8.377] (II) Initializing extension XFree86-DGA
[ 8.377] (II) Initializing extension XFree86-DRI
[ 8.377] (II) Initializing extension DRI2
[ 8.377] (II) Initializing extension NV-GLX
[ 8.377] (II) Initializing extension NV-CONTROL
[ 8.428] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 8.428] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 8.428] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 8.428] (**) Power Button: Applying InputClass "system-keyboard"
[ 8.428] (II) LoadModule: "libinput"
[ 8.428] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 8.430] (II) Module libinput: vendor="X.Org Foundation"
[ 8.430] compiled for 1.21.1.3, module version = 1.2.1
[ 8.430] Module class: X.Org XInput Driver
[ 8.430] ABI class: X.Org XInput driver, version 24.4
[ 8.430] (II) Using input driver 'libinput' for 'Power Button'
[ 8.430] (**) Power Button: always reports core events
[ 8.430] (**) Option "Device" "/dev/input/event3"
[ 8.437] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 8.437] (II) event3 - Power Button: device is a keyboard
[ 8.437] (II) event3 - Power Button: device removed
[ 8.466] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 8.466] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 8.466] (**) Option "xkb_layout" "us"
[ 8.467] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 8.467] (II) event3 - Power Button: device is a keyboard
[ 8.467] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[ 8.467] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 8.467] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 8.467] (**) Video Bus: Applying InputClass "system-keyboard"
[ 8.467] (II) Using input driver 'libinput' for 'Video Bus'
[ 8.467] (**) Video Bus: always reports core events
[ 8.467] (**) Option "Device" "/dev/input/event11"
[ 8.468] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[ 8.468] (II) event11 - Video Bus: device is a keyboard
[ 8.468] (II) event11 - Video Bus: device removed
[ 8.499] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13/event11"
[ 8.499] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 8.499] (**) Option "xkb_layout" "us"
[ 8.501] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[ 8.501] (II) event11 - Video Bus: device is a keyboard
[ 8.503] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[ 8.503] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 8.503] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 8.503] (**) Video Bus: Applying InputClass "system-keyboard"
[ 8.503] (II) Using input driver 'libinput' for 'Video Bus'
[ 8.503] (**) Video Bus: always reports core events
[ 8.503] (**) Option "Device" "/dev/input/event12"
[ 8.505] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 8.505] (II) event12 - Video Bus: device is a keyboard
[ 8.505] (II) event12 - Video Bus: device removed
[ 8.543] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input14/event12"
[ 8.543] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 8.543] (**) Option "xkb_layout" "us"
[ 8.546] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 8.546] (II) event12 - Video Bus: device is a keyboard
[ 8.548] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 8.548] (II) No input driver specified, ignoring this device.
[ 8.548] (II) This device may have been added with another device file.
[ 8.549] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 8.549] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 8.549] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 8.549] (**) Power Button: Applying InputClass "system-keyboard"
[ 8.549] (II) Using input driver 'libinput' for 'Power Button'
[ 8.549] (**) Power Button: always reports core events
[ 8.549] (**) Option "Device" "/dev/input/event2"
[ 8.551] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 8.551] (II) event2 - Power Button: device is a keyboard
[ 8.552] (II) event2 - Power Button: device removed
[ 8.570] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[ 8.570] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 8.570] (**) Option "xkb_layout" "us"
[ 8.572] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 8.572] (II) event2 - Power Button: device is a keyboard
[ 8.574] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 8.574] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 8.574] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 8.574] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 8.574] (II) Using input driver 'libinput' for 'Sleep Button'
[ 8.574] (**) Sleep Button: always reports core events
[ 8.574] (**) Option "Device" "/dev/input/event1"
[ 8.576] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 8.576] (II) event1 - Sleep Button: device is a keyboard
[ 8.576] (II) event1 - Sleep Button: device removed
[ 8.599] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 8.600] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 8.600] (**) Option "xkb_layout" "us"
[ 8.602] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 8.602] (II) event1 - Sleep Button: device is a keyboard
[ 8.604] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event8)
[ 8.604] (II) No input driver specified, ignoring this device.
[ 8.604] (II) This device may have been added with another device file.
[ 8.605] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event9)
[ 8.605] (II) No input driver specified, ignoring this device.
[ 8.605] (II) This device may have been added with another device file.
[ 8.606] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event10)
[ 8.606] (II) No input driver specified, ignoring this device.
[ 8.606] (II) This device may have been added with another device file.
[ 8.607] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event7)
[ 8.607] (II) No input driver specified, ignoring this device.
[ 8.607] (II) This device may have been added with another device file.
[ 8.610] (II) config/udev: Adding input device Logitech MX Master 3 (/dev/input/event18)
[ 8.610] (**) Logitech MX Master 3: Applying InputClass "evdev pointer catchall"
[ 8.610] (**) Logitech MX Master 3: Applying InputClass "evdev keyboard catchall"
[ 8.610] (**) Logitech MX Master 3: Applying InputClass "libinput pointer catchall"
[ 8.610] (**) Logitech MX Master 3: Applying InputClass "libinput keyboard catchall"
[ 8.610] (**) Logitech MX Master 3: Applying InputClass "system-keyboard"
[ 8.610] (II) Using input driver 'libinput' for 'Logitech MX Master 3'
[ 8.610] (**) Logitech MX Master 3: always reports core events
[ 8.610] (**) Option "Device" "/dev/input/event18"
[ 8.614] (II) event18 - Logitech MX Master 3: is tagged by udev as: Keyboard Mouse
[ 8.615] (II) event18 - Logitech MX Master 3: device is a pointer
[ 8.615] (II) event18 - Logitech MX Master 3: device is a keyboard
[ 8.615] (II) event18 - Logitech MX Master 3: device removed
[ 8.636] (II) libinput: Logitech MX Master 3: needs a virtual subdevice
[ 8.636] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.2/0003:046D:C52B.0003/0003:046D:4082.0006/input/input30/event18"
[ 8.636] (II) XINPUT: Adding extended input device "Logitech MX Master 3" (type: MOUSE, id 11)
[ 8.637] (**) Option "AccelerationScheme" "none"
[ 8.637] (**) Logitech MX Master 3: (accel) selected scheme none/0
[ 8.637] (**) Logitech MX Master 3: (accel) acceleration factor: 2.000
[ 8.637] (**) Logitech MX Master 3: (accel) acceleration threshold: 4
[ 8.640] (II) event18 - Logitech MX Master 3: is tagged by udev as: Keyboard Mouse
[ 8.641] (II) event18 - Logitech MX Master 3: device is a pointer
[ 8.641] (II) event18 - Logitech MX Master 3: device is a keyboard
[ 8.644] (II) config/udev: Adding input device Logitech MX Master 3 (/dev/input/mouse1)
[ 8.644] (**) Logitech MX Master 3: Applying InputClass "system-keyboard"
[ 8.644] (II) No input driver specified, ignoring this device.
[ 8.644] (II) This device may have been added with another device file.
[ 8.646] (II) config/udev: Adding input device SteelSeries SteelSeries KLC (/dev/input/event22)
[ 8.646] (**) SteelSeries SteelSeries KLC: Applying InputClass "evdev keyboard catchall"
[ 8.646] (**) SteelSeries SteelSeries KLC: Applying InputClass "libinput keyboard catchall"
[ 8.646] (**) SteelSeries SteelSeries KLC: Applying InputClass "system-keyboard"
[ 8.646] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries KLC'
[ 8.646] (**) SteelSeries SteelSeries KLC: always reports core events
[ 8.646] (**) Option "Device" "/dev/input/event22"
[ 8.649] (II) event22 - SteelSeries SteelSeries KLC: is tagged by udev as: Keyboard
[ 8.649] (II) event22 - SteelSeries SteelSeries KLC: device is a keyboard
[ 8.650] (II) event22 - SteelSeries SteelSeries KLC: device removed
[ 8.673] (II) libinput: SteelSeries SteelSeries KLC: needs a virtual subdevice
[ 8.673] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1038:1122.0005/input/input24/event22"
[ 8.673] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries KLC" (type: MOUSE, id 12)
[ 8.673] (**) Option "AccelerationScheme" "none"
[ 8.673] (**) SteelSeries SteelSeries KLC: (accel) selected scheme none/0
[ 8.673] (**) SteelSeries SteelSeries KLC: (accel) acceleration factor: 2.000
[ 8.673] (**) SteelSeries SteelSeries KLC: (accel) acceleration threshold: 4
[ 8.677] (II) event22 - SteelSeries SteelSeries KLC: is tagged by udev as: Keyboard
[ 8.677] (II) event22 - SteelSeries SteelSeries KLC: device is a keyboard
[ 8.679] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event13)
[ 8.679] (II) No input driver specified, ignoring this device.
[ 8.679] (II) This device may have been added with another device file.
[ 8.680] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event14)
[ 8.680] (II) No input driver specified, ignoring this device.
[ 8.680] (II) This device may have been added with another device file.
[ 8.681] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event15)
[ 8.681] (II) No input driver specified, ignoring this device.
[ 8.681] (II) This device may have been added with another device file.
[ 8.682] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event16)
[ 8.682] (II) No input driver specified, ignoring this device.
[ 8.682] (II) This device may have been added with another device file.
[ 8.683] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 8.683] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 8.683] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.683] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 8.683] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 8.683] (**) AT Translated Set 2 keyboard: always reports core events
[ 8.683] (**) Option "Device" "/dev/input/event4"
[ 8.685] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 8.685] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 8.687] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 8.709] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 8.709] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 13)
[ 8.710] (**) Option "xkb_layout" "us"
[ 8.712] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 8.712] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 8.715] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event17)
[ 8.715] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 8.715] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 8.716] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad"
[ 8.716] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 8.716] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 8.716] (**) Option "Device" "/dev/input/event17"
[ 8.718] (II) event17 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 8.721] (II) event17 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 8.721] (II) event17 - SynPS/2 Synaptics TouchPad: device removed
[ 8.773] (**) Option "Tapping" "on"
[ 8.774] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event17"
[ 8.774] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 14)
[ 8.777] (**) Option "AccelerationScheme" "none"
[ 8.777] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 8.777] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 8.777] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 8.779] (II) event17 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 8.783] (II) event17 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 8.785] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 8.785] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad"
[ 8.785] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 8.785] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 8.785] (**) Option "Device" "/dev/input/mouse0"
[ 8.816] (II) mouse0 - not using input device '/dev/input/mouse0'.
[ 8.816] (EE) libinput: SynPS/2 Synaptics TouchPad: Failed to create a device for /dev/input/mouse0
[ 8.816] (EE) PreInit returned 2 for "SynPS/2 Synaptics TouchPad"
[ 8.816] (II) UnloadModule: "libinput"
[ 8.817] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 8.817] (II) No input driver specified, ignoring this device.
[ 8.817] (II) This device may have been added with another device file.
[ 8.824] (II) config/udev: Adding input device MSI WMI hotkeys (/dev/input/event6)
[ 8.824] (**) MSI WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 8.824] (**) MSI WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 8.824] (**) MSI WMI hotkeys: Applying InputClass "system-keyboard"
[ 8.824] (II) Using input driver 'libinput' for 'MSI WMI hotkeys'
[ 8.824] (**) MSI WMI hotkeys: always reports core events
[ 8.825] (**) Option "Device" "/dev/input/event6"
[ 8.826] (II) event6 - MSI WMI hotkeys: is tagged by udev as: Keyboard
[ 8.826] (II) event6 - MSI WMI hotkeys: device is a keyboard
[ 8.827] (II) event6 - MSI WMI hotkeys: device removed
[ 8.869] (**) Option "config_info" "udev:/sys/devices/virtual/input/input8/event6"
[ 8.869] (II) XINPUT: Adding extended input device "MSI WMI hotkeys" (type: KEYBOARD, id 15)
[ 8.869] (**) Option "xkb_layout" "us"
[ 8.872] (II) event6 - MSI WMI hotkeys: is tagged by udev as: Keyboard
[ 8.872] (II) event6 - MSI WMI hotkeys: device is a keyboard
[ 8.884] (**) Logitech MX Master 3: Applying InputClass "evdev pointer catchall"
[ 8.884] (**) Logitech MX Master 3: Applying InputClass "evdev keyboard catchall"
[ 8.884] (**) Logitech MX Master 3: Applying InputClass "libinput pointer catchall"
[ 8.884] (**) Logitech MX Master 3: Applying InputClass "libinput keyboard catchall"
[ 8.884] (**) Logitech MX Master 3: Applying InputClass "system-keyboard"
[ 8.884] (II) Using input driver 'libinput' for 'Logitech MX Master 3'
[ 8.884] (**) Logitech MX Master 3: always reports core events
[ 8.884] (**) Option "Device" "/dev/input/event18"
[ 8.884] (II) libinput: Logitech MX Master 3: is a virtual subdevice
[ 8.884] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.2/0003:046D:C52B.0003/0003:046D:4082.0006/input/input30/event18"
[ 8.884] (II) XINPUT: Adding extended input device "Logitech MX Master 3" (type: KEYBOARD, id 16)
[ 8.884] (**) Option "xkb_layout" "us"
[ 8.885] (**) SteelSeries SteelSeries KLC: Applying InputClass "evdev keyboard catchall"
[ 8.885] (**) SteelSeries SteelSeries KLC: Applying InputClass "libinput keyboard catchall"
[ 8.885] (**) SteelSeries SteelSeries KLC: Applying InputClass "system-keyboard"
[ 8.885] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries KLC'
[ 8.885] (**) SteelSeries SteelSeries KLC: always reports core events
[ 8.885] (**) Option "Device" "/dev/input/event22"
[ 8.885] (II) libinput: SteelSeries SteelSeries KLC: is a virtual subdevice
[ 8.885] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1038:1122.0005/input/input24/event22"
[ 8.885] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries KLC" (type: KEYBOARD, id 17)
[ 8.885] (**) Option "xkb_layout" "us"
[ 13.421] (II) config/udev: Adding input device SINO WEALTH Mechanical Keyboard (/dev/input/event20)
[ 13.421] (**) SINO WEALTH Mechanical Keyboard: Applying InputClass "evdev keyboard catchall"
[ 13.421] (**) SINO WEALTH Mechanical Keyboard: Applying InputClass "libinput keyboard catchall"
[ 13.421] (**) SINO WEALTH Mechanical Keyboard: Applying InputClass "system-keyboard"
[ 13.421] (II) Using input driver 'libinput' for 'SINO WEALTH Mechanical Keyboard'
[ 13.421] (**) SINO WEALTH Mechanical Keyboard: always reports core events
[ 13.421] (**) Option "Device" "/dev/input/event20"
[ 13.423] (II) event20 - SINO WEALTH Mechanical Keyboard: is tagged by udev as: Keyboard
[ 13.423] (II) event20 - SINO WEALTH Mechanical Keyboard: device is a keyboard
[ 13.423] (II) event20 - SINO WEALTH Mechanical Keyboard: device removed
[ 13.450] (II) libinput: SINO WEALTH Mechanical Keyboard: needs a virtual subdevice
[ 13.450] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1b.0/0000:02:00.0/0000:03:02.0/0000:3a:00.0/usb3/3-1/3-1.3/3-1.3:1.1/0003:258A:0090.0008/input/input32/event20"
[ 13.450] (II) XINPUT: Adding extended input device "SINO WEALTH Mechanical Keyboard" (type: MOUSE, id 18)
[ 13.450] (**) Option "AccelerationScheme" "none"
[ 13.450] (**) SINO WEALTH Mechanical Keyboard: (accel) selected scheme none/0
[ 13.450] (**) SINO WEALTH Mechanical Keyboard: (accel) acceleration factor: 2.000
[ 13.450] (**) SINO WEALTH Mechanical Keyboard: (accel) acceleration threshold: 4
[ 13.454] (II) event20 - SINO WEALTH Mechanical Keyboard: is tagged by udev as: Keyboard
[ 13.454] (II) event20 - SINO WEALTH Mechanical Keyboard: device is a keyboard
[ 13.455] (**) SINO WEALTH Mechanical Keyboard: Applying InputClass "evdev keyboard catchall"
[ 13.455] (**) SINO WEALTH Mechanical Keyboard: Applying InputClass "libinput keyboard catchall"
[ 13.455] (**) SINO WEALTH Mechanical Keyboard: Applying InputClass "system-keyboard"
[ 13.455] (II) Using input driver 'libinput' for 'SINO WEALTH Mechanical Keyboard'
[ 13.455] (**) SINO WEALTH Mechanical Keyboard: always reports core events
[ 13.455] (**) Option "Device" "/dev/input/event20"
[ 13.455] (II) libinput: SINO WEALTH Mechanical Keyboard: is a virtual subdevice
[ 13.455] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1b.0/0000:02:00.0/0000:03:02.0/0000:3a:00.0/usb3/3-1/3-1.3/3-1.3:1.1/0003:258A:0090.0008/input/input32/event20"
[ 13.455] (II) XINPUT: Adding extended input device "SINO WEALTH Mechanical Keyboard" (type: KEYBOARD, id 19)
[ 13.455] (**) Option "xkb_layout" "us"
[ 13.457] (II) config/udev: Adding input device SINO WEALTH Mechanical Keyboard (/dev/input/event19)
[ 13.457] (**) SINO WEALTH Mechanical Keyboard: Applying InputClass "evdev keyboard catchall"
[ 13.457] (**) SINO WEALTH Mechanical Keyboard: Applying InputClass "libinput keyboard catchall"
[ 13.457] (**) SINO WEALTH Mechanical Keyboard: Applying InputClass "system-keyboard"
[ 13.457] (II) Using input driver 'libinput' for 'SINO WEALTH Mechanical Keyboard'
[ 13.457] (**) SINO WEALTH Mechanical Keyboard: always reports core events
[ 13.457] (**) Option "Device" "/dev/input/event19"
[ 13.462] (II) event19 - SINO WEALTH Mechanical Keyboard: is tagged by udev as: Keyboard
[ 13.462] (II) event19 - SINO WEALTH Mechanical Keyboard: device is a keyboard
[ 13.463] (II) event19 - SINO WEALTH Mechanical Keyboard: device removed
[ 13.503] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1b.0/0000:02:00.0/0000:03:02.0/0000:3a:00.0/usb3/3-1/3-1.3/3-1.3:1.0/0003:258A:0090.0007/input/input31/event19"
[ 13.503] (II) XINPUT: Adding extended input device "SINO WEALTH Mechanical Keyboard" (type: KEYBOARD, id 20)
[ 13.503] (**) Option "xkb_layout" "us"
[ 13.509] (II) event19 - SINO WEALTH Mechanical Keyboard: is tagged by udev as: Keyboard
[ 13.510] (II) event19 - SINO WEALTH Mechanical Keyboard: device is a keyboard
[ 38.022] (II) event3 - Power Button: device removed
[ 38.036] (II) event11 - Video Bus: device removed
[ 38.070] (II) event12 - Video Bus: device removed
[ 38.103] (II) event2 - Power Button: device removed
[ 38.120] (II) event1 - Sleep Button: device removed
[ 38.140] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 38.156] (II) event17 - SynPS/2 Synaptics TouchPad: device removed
[ 38.203] (II) event6 - MSI WMI hotkeys: device removed
[ 38.249] (II) event18 - Logitech MX Master 3: device removed
[ 38.269] (II) event22 - SteelSeries SteelSeries KLC: device removed
[ 38.306] (II) event20 - SINO WEALTH Mechanical Keyboard: device removed
[ 38.343] (II) event19 - SINO WEALTH Mechanical Keyboard: device removed
It seems you have a dual-graphics setup … but the display driver is defaulting to nvidia which is also pumping out some ACPI errors.
In whatever case this is not the normal configuration. Did you set it up like this on purpose?
Please also share the output of
mhwd -l -d
(PS going by your kernel version you are certainly out-of-date. Please perform a full system upgrade, before querying mhwd, if possible. sudo pacman -Syu)
Actually, I updated everything yesterday, and then I changed to a newer Kernel, 6.1 (I read that’s the LTS version). I was on kernel 5.15 I think. I thought I could magically fix it by updating all, changing kernel and reinstalling nvidia drivers.
By dual-graphics, do you mean, dual screen? I just use dual screen, and for that, NVidia needs to work I think, I am not sure anymore.
However, I would be happy to have any graphics at all …
This is the output from mhwd -l -d
e[1me[31m> e[mPCI Device: /devices/pci0000:00/0000:00:01.0/0000:01:00.0 (0300:10de:1ba1)
Display controller nVidia Corporation GP104M [GeForce GTX 1070 Mobile]
> INSTALLED:
ATTACHED: PCI
VERSION: 2021.11.04
INFO: Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 8
FREEDRIVER: false
DEPENDS: video-modesetting
CONFLICTS: video*nvidia*
CLASSIDS: 0300 0302 0300
VENDORIDS: 10de 8086
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.26
INFO: Hybrid bumblebee solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2021.11.04
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2021.11.26
PRIORITY: 3
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
e[1me[31m> e[mPCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:3e9b)
Display controller Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
> INSTALLED:
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.26
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
e[1me[31mWarning: e[mno configs for USB devices found!
To take a stab …
You want to use the hybrid profile … which relies on video-modesetting.
So you want those.
But there shouldnt be a reason for video-linux.
So lets try to remove that and reinstall the hybrid profile for just in case.
sudo mhwd -r pci video-linux
sudo mhwd -f -i pci video-hybrid-intel-nvidia-prime
Hello, thank you for your effort and the answer, unfortunately I am out of luck :‘(
Mhwd -l -d
> INSTALLED:
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.26
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2021.11.26
PRIORITY: 3
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> INSTALLED:
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.04
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2021.11.26
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
Cat /var/log/Xorg.0.log
[ 6.017] (--) Log file renamed from "/var/log/Xorg.pid-1046.log" to "/var/log/Xorg.0.log"
[ 6.019]
[ 6.019] Current Operating System: Linux ManjoTox 6.1.19-1-MANJARO #1 SMP PREEMPT_DYNAMIC Mon Mar 13 12:59:35 UTC 2023 x86_64
[ 6.019] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=db4b7c7e-3676-4dd7-a17d-b14b220cc184 rw apparmor=1 security=apparmor resume=UUID=5e39f5a4-8662-49d7-b2ec-6e0d508edd78 udev.log_priority=3 bootsplash.bootfile=bootsplash-themes/manjaro/bootsplash acpi_osi=! "acpi_osi=Windows 2009"
[ 6.019]
[ 6.019] Current version of pixman: 0.42.2
[ 6.019] Before reporting problems, check http://wiki.x.org
[ 6.019] Markers: (--) probed, (**) from config file, (==) default setting,
[ 6.019] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 14 09:43:33 2023
[ 6.020] (==) Using config file: "/etc/X11/xorg.conf"
[ 6.020] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 6.020] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 6.021] (==) ServerLayout "layout"
[ 6.021] (**) |-->Screen "Screen0" (0)
[ 6.021] (**) | |-->Monitor "Monitor0"
[ 6.022] (**) | |-->Device "Device0"
[ 6.022] (==) Automatically adding devices
[ 6.022] (==) Automatically enabling devices
[ 6.022] (==) Automatically adding GPU devices
[ 6.022] (==) Automatically binding GPU devices
[ 6.022] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.023] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 6.023] Entry deleted from font path.
[ 6.023] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 6.023] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 6.023] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 6.023] (==) FontPath set to:
[ 6.023] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 6.023] (II) The server relies on udev to provide the list of input devices.
[ 6.023] (II) Module ABI versions:
[ 6.023] X.Org ANSI C Emulation: 0.4
[ 6.023] X.Org Video Driver: 25.2
[ 6.023] X.Org XInput driver : 24.4
[ 6.023] X.Org Server Extension : 10.0
[ 6.023] (++) using VT number 1
[ 6.023] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.024] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 6.024] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[ 6.024] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.024] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 6.026] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 6.026] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 7.184] (--) PCI:*(0@0:2:0) 8086:3e9b:1462:1227 rev 0, Mem @ 0xab000000/16777216, 0x40000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 7.184] (--) PCI: (1@0:0:0) 10de:1ba1:1462:1227 rev 161, Mem @ 0xac000000/16777216, 0x80000000/268435456, 0x90000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[ 7.184] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 7.184] (II) LoadModule: "glx"
[ 7.186] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 7.190] (II) Module glx: vendor="X.Org Foundation"
[ 7.191] compiled for 1.21.1.7, module version = 1.0.0
[ 7.191] ABI class: X.Org Server Extension, version 10.0
[ 7.191] (II) LoadModule: "nvidia"
[ 7.191] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 7.193] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 7.193] compiled for 1.6.99.901, module version = 1.0.0
[ 7.193] Module class: X.Org Video Driver
[ 7.194] (II) NVIDIA dlloader X Driver 525.89.02 Wed Feb 1 23:14:37 UTC 2023
[ 7.194] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 7.194] (II) Loading sub module "fb"
[ 7.194] (II) LoadModule: "fb"
[ 7.194] (II) Module "fb" already built-in
[ 7.194] (II) Loading sub module "wfb"
[ 7.194] (II) LoadModule: "wfb"
[ 7.194] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 7.195] (II) Module wfb: vendor="X.Org Foundation"
[ 7.195] compiled for 1.21.1.7, module version = 1.0.0
[ 7.195] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.195] (II) Loading sub module "ramdac"
[ 7.195] (II) LoadModule: "ramdac"
[ 7.195] (II) Module "ramdac" already built-in
[ 7.195] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[ 7.195] (==) NVIDIA(0): RGB weight 888
[ 7.195] (==) NVIDIA(0): Default visual is TrueColor
[ 7.195] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.196] (**) Option "AllowNVIDIAGpuScreens"
[ 7.196] (II) Applying OutputClass "nvidia" options to /dev/dri/card1
[ 7.196] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[ 7.196] (**) NVIDIA(0): Enabling 2D acceleration
[ 7.196] (II) Loading sub module "glxserver_nvidia"
[ 7.196] (II) LoadModule: "glxserver_nvidia"
[ 7.196] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 7.224] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 7.224] compiled for 1.6.99.901, module version = 1.0.0
[ 7.224] Module class: X.Org Server Extension
[ 7.224] (II) NVIDIA GLX Module 525.89.02 Wed Feb 1 23:13:01 UTC 2023
[ 7.225] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 8.526] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[ 8.526] (--) NVIDIA(0): DFP-0
[ 8.526] (--) NVIDIA(0): DFP-1
[ 8.526] (--) NVIDIA(0): DFP-2
[ 8.527] (II) NVIDIA(0): NVIDIA GPU NVIDIA GeForce GTX 1070 with Max-Q Design (GP104-A)
[ 8.527] (II) NVIDIA(0): at PCI:1:0:0 (GPU-0)
[ 8.527] (--) NVIDIA(0): Memory: 8388608 kBytes
[ 8.527] (--) NVIDIA(0): VideoBIOS: 86.04.8a.00.88
[ 8.527] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 8.527] (--) NVIDIA(GPU-0): DFP-0: disconnected
[ 8.527] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[ 8.527] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[ 8.527] (--) NVIDIA(GPU-0): DFP-1: disconnected
[ 8.527] (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
[ 8.527] (--) NVIDIA(GPU-0): DFP-1: 1440.0 MHz maximum pixel clock
[ 8.527] (--) NVIDIA(GPU-0): DFP-2: disconnected
[ 8.527] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[ 8.527] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[ 8.527] (==) NVIDIA(0):
[ 8.527] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 8.527] (==) NVIDIA(0): will be used as the requested mode.
[ 8.527] (--) NVIDIA(0): No enabled display devices found; starting anyway because
[ 8.527] (--) NVIDIA(0): AllowEmptyInitialConfiguration is enabled
[ 8.527] (II) NVIDIA(0): Validated MetaModes:
[ 8.527] (II) NVIDIA(0): "NULL"
[ 8.527] (II) NVIDIA(0): Virtual screen size determined to be 640 x 480
[ 8.527] (WW) NVIDIA(0): Unable to get display device for DPI computation.
[ 8.527] (==) NVIDIA(0): DPI set to (75, 75); computed from built-in default
[ 8.527] (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
[ 8.527] (II) NVIDIA: access.
[ 8.535] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 8.535] (II) NVIDIA(0): may not be running or the "AcpidSocketPath" X
[ 8.535] (II) NVIDIA(0): configuration option may not be set correctly. When the
[ 8.535] (II) NVIDIA(0): ACPI event daemon is available, the NVIDIA X driver will
[ 8.535] (II) NVIDIA(0): try to use it to receive ACPI event notifications. For
[ 8.535] (II) NVIDIA(0): details, please see the "ConnectToAcpid" and
[ 8.535] (II) NVIDIA(0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 8.535] (II) NVIDIA(0): Config Options in the README.
[ 8.549] (II) NVIDIA(0): Setting mode "NULL"
[ 8.555] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 8.555] (==) NVIDIA(0): Backing store enabled
[ 8.555] (==) NVIDIA(0): Silken mouse enabled
[ 8.555] (**) NVIDIA(0): DPMS enabled
[ 8.555] (II) Loading sub module "dri2"
[ 8.555] (II) LoadModule: "dri2"
[ 8.555] (II) Module "dri2" already built-in
[ 8.555] (II) NVIDIA(0): [DRI2] Setup complete
[ 8.555] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 8.555] (II) Initializing extension Generic Event Extension
[ 8.555] (II) Initializing extension SHAPE
[ 8.555] (II) Initializing extension MIT-SHM
[ 8.555] (II) Initializing extension XInputExtension
[ 8.555] (II) Initializing extension XTEST
[ 8.555] (II) Initializing extension BIG-REQUESTS
[ 8.555] (II) Initializing extension SYNC
[ 8.555] (II) Initializing extension XKEYBOARD
[ 8.556] (II) Initializing extension XC-MISC
[ 8.556] (II) Initializing extension SECURITY
[ 8.556] (II) Initializing extension XFIXES
[ 8.556] (II) Initializing extension RENDER
[ 8.556] (II) Initializing extension RANDR
[ 8.556] (II) Initializing extension COMPOSITE
[ 8.556] (II) Initializing extension DAMAGE
[ 8.556] (II) Initializing extension MIT-SCREEN-SAVER
[ 8.556] (II) Initializing extension DOUBLE-BUFFER
[ 8.556] (II) Initializing extension RECORD
[ 8.556] (II) Initializing extension DPMS
[ 8.556] (II) Initializing extension Present
[ 8.556] (II) Initializing extension DRI3
[ 8.556] (II) Initializing extension X-Resource
[ 8.556] (II) Initializing extension XVideo
[ 8.556] (II) Initializing extension XVideo-MotionCompensation
[ 8.556] (II) Initializing extension GLX
[ 8.557] (II) Initializing extension GLX
[ 8.557] (II) Indirect GLX disabled.
[ 8.557] (II) GLX: Another vendor is already registered for screen 0
[ 8.557] (II) Initializing extension XFree86-VidModeExtension
[ 8.557] (II) Initializing extension XFree86-DGA
[ 8.557] (II) Initializing extension XFree86-DRI
[ 8.557] (II) Initializing extension DRI2
[ 8.557] (II) Initializing extension NV-GLX
[ 8.557] (II) Initializing extension NV-CONTROL
[ 8.607] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 8.607] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 8.607] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 8.607] (**) Power Button: Applying InputClass "system-keyboard"
[ 8.607] (II) LoadModule: "libinput"
[ 8.607] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 8.609] (II) Module libinput: vendor="X.Org Foundation"
[ 8.609] compiled for 1.21.1.3, module version = 1.2.1
[ 8.609] Module class: X.Org XInput Driver
[ 8.610] ABI class: X.Org XInput driver, version 24.4
[ 8.610] (II) Using input driver 'libinput' for 'Power Button'
[ 8.610] (**) Power Button: always reports core events
[ 8.610] (**) Option "Device" "/dev/input/event3"
[ 8.616] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 8.616] (II) event3 - Power Button: device is a keyboard
[ 8.616] (II) event3 - Power Button: device removed
[ 8.641] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 8.641] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 8.641] (**) Option "xkb_layout" "us"
[ 8.642] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 8.642] (II) event3 - Power Button: device is a keyboard
[ 8.642] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[ 8.642] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 8.642] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 8.642] (**) Video Bus: Applying InputClass "system-keyboard"
[ 8.642] (II) Using input driver 'libinput' for 'Video Bus'
[ 8.642] (**) Video Bus: always reports core events
[ 8.642] (**) Option "Device" "/dev/input/event11"
[ 8.643] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[ 8.643] (II) event11 - Video Bus: device is a keyboard
[ 8.643] (II) event11 - Video Bus: device removed
[ 8.681] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input13/event11"
[ 8.681] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 8.681] (**) Option "xkb_layout" "us"
[ 8.682] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[ 8.682] (II) event11 - Video Bus: device is a keyboard
[ 8.683] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[ 8.683] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 8.683] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 8.683] (**) Video Bus: Applying InputClass "system-keyboard"
[ 8.683] (II) Using input driver 'libinput' for 'Video Bus'
[ 8.683] (**) Video Bus: always reports core events
[ 8.683] (**) Option "Device" "/dev/input/event12"
[ 8.685] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 8.685] (II) event12 - Video Bus: device is a keyboard
[ 8.685] (II) event12 - Video Bus: device removed
[ 8.724] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input14/event12"
[ 8.724] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 8.724] (**) Option "xkb_layout" "us"
[ 8.727] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 8.727] (II) event12 - Video Bus: device is a keyboard
[ 8.729] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 8.730] (II) No input driver specified, ignoring this device.
[ 8.730] (II) This device may have been added with another device file.
[ 8.731] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 8.731] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 8.731] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 8.731] (**) Power Button: Applying InputClass "system-keyboard"
[ 8.731] (II) Using input driver 'libinput' for 'Power Button'
[ 8.731] (**) Power Button: always reports core events
[ 8.731] (**) Option "Device" "/dev/input/event2"
[ 8.733] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 8.733] (II) event2 - Power Button: device is a keyboard
[ 8.733] (II) event2 - Power Button: device removed
[ 8.751] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
[ 8.751] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 9)
[ 8.751] (**) Option "xkb_layout" "us"
[ 8.753] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 8.754] (II) event2 - Power Button: device is a keyboard
[ 8.755] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 8.755] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 8.755] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 8.755] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 8.755] (II) Using input driver 'libinput' for 'Sleep Button'
[ 8.755] (**) Sleep Button: always reports core events
[ 8.755] (**) Option "Device" "/dev/input/event1"
[ 8.757] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 8.757] (II) event1 - Sleep Button: device is a keyboard
[ 8.758] (II) event1 - Sleep Button: device removed
[ 8.781] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 8.781] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 8.781] (**) Option "xkb_layout" "us"
[ 8.783] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 8.784] (II) event1 - Sleep Button: device is a keyboard
[ 8.785] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event8)
[ 8.785] (II) No input driver specified, ignoring this device.
[ 8.785] (II) This device may have been added with another device file.
[ 8.786] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event9)
[ 8.786] (II) No input driver specified, ignoring this device.
[ 8.786] (II) This device may have been added with another device file.
[ 8.787] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event10)
[ 8.787] (II) No input driver specified, ignoring this device.
[ 8.787] (II) This device may have been added with another device file.
[ 8.788] (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event7)
[ 8.788] (II) No input driver specified, ignoring this device.
[ 8.788] (II) This device may have been added with another device file.
[ 8.791] (II) config/udev: Adding input device SteelSeries SteelSeries KLC (/dev/input/event18)
[ 8.791] (**) SteelSeries SteelSeries KLC: Applying InputClass "evdev keyboard catchall"
[ 8.791] (**) SteelSeries SteelSeries KLC: Applying InputClass "libinput keyboard catchall"
[ 8.791] (**) SteelSeries SteelSeries KLC: Applying InputClass "system-keyboard"
[ 8.791] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries KLC'
[ 8.791] (**) SteelSeries SteelSeries KLC: always reports core events
[ 8.791] (**) Option "Device" "/dev/input/event18"
[ 8.794] (II) event18 - SteelSeries SteelSeries KLC: is tagged by udev as: Keyboard
[ 8.795] (II) event18 - SteelSeries SteelSeries KLC: device is a keyboard
[ 8.795] (II) event18 - SteelSeries SteelSeries KLC: device removed
[ 8.818] (II) libinput: SteelSeries SteelSeries KLC: needs a virtual subdevice
[ 8.818] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1038:1122.0002/input/input19/event18"
[ 8.818] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries KLC" (type: MOUSE, id 11)
[ 8.818] (**) Option "AccelerationScheme" "none"
[ 8.818] (**) SteelSeries SteelSeries KLC: (accel) selected scheme none/0
[ 8.818] (**) SteelSeries SteelSeries KLC: (accel) acceleration factor: 2.000
[ 8.818] (**) SteelSeries SteelSeries KLC: (accel) acceleration threshold: 4
[ 8.822] (II) event18 - SteelSeries SteelSeries KLC: is tagged by udev as: Keyboard
[ 8.822] (II) event18 - SteelSeries SteelSeries KLC: device is a keyboard
[ 8.823] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event13)
[ 8.823] (II) No input driver specified, ignoring this device.
[ 8.823] (II) This device may have been added with another device file.
[ 8.824] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event14)
[ 8.824] (II) No input driver specified, ignoring this device.
[ 8.824] (II) This device may have been added with another device file.
[ 8.825] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event15)
[ 8.825] (II) No input driver specified, ignoring this device.
[ 8.825] (II) This device may have been added with another device file.
[ 8.826] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event16)
[ 8.826] (II) No input driver specified, ignoring this device.
[ 8.826] (II) This device may have been added with another device file.
[ 8.827] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 8.827] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 8.828] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 8.828] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 8.828] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 8.828] (**) AT Translated Set 2 keyboard: always reports core events
[ 8.828] (**) Option "Device" "/dev/input/event4"
[ 8.830] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 8.830] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 8.832] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 8.854] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 8.854] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[ 8.854] (**) Option "xkb_layout" "us"
[ 8.857] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 8.857] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 8.860] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/event17)
[ 8.860] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "evdev touchpad catchall"
[ 8.860] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "libinput touchpad catchall"
[ 8.860] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad"
[ 8.860] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 8.860] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 8.860] (**) Option "Device" "/dev/input/event17"
[ 8.862] (II) event17 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 8.866] (II) event17 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 8.866] (II) event17 - SynPS/2 Synaptics TouchPad: device removed
[ 8.908] (**) Option "Tapping" "on"
[ 8.908] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio1/input/input7/event17"
[ 8.909] (II) XINPUT: Adding extended input device "SynPS/2 Synaptics TouchPad" (type: TOUCHPAD, id 13)
[ 8.911] (**) Option "AccelerationScheme" "none"
[ 8.911] (**) SynPS/2 Synaptics TouchPad: (accel) selected scheme none/0
[ 8.912] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration factor: 2.000
[ 8.912] (**) SynPS/2 Synaptics TouchPad: (accel) acceleration threshold: 4
[ 8.914] (II) event17 - SynPS/2 Synaptics TouchPad: is tagged by udev as: Touchpad
[ 8.917] (II) event17 - SynPS/2 Synaptics TouchPad: device is a touchpad
[ 8.919] (II) config/udev: Adding input device SynPS/2 Synaptics TouchPad (/dev/input/mouse0)
[ 8.919] (**) SynPS/2 Synaptics TouchPad: Applying InputClass "touchpad"
[ 8.919] (II) Using input driver 'libinput' for 'SynPS/2 Synaptics TouchPad'
[ 8.919] (**) SynPS/2 Synaptics TouchPad: always reports core events
[ 8.919] (**) Option "Device" "/dev/input/mouse0"
[ 8.961] (II) mouse0 - not using input device '/dev/input/mouse0'.
[ 8.961] (EE) libinput: SynPS/2 Synaptics TouchPad: Failed to create a device for /dev/input/mouse0
[ 8.961] (EE) PreInit returned 2 for "SynPS/2 Synaptics TouchPad"
[ 8.961] (II) UnloadModule: "libinput"
[ 8.962] (II) config/udev: Adding input device PC Speaker (/dev/input/event5)
[ 8.962] (II) No input driver specified, ignoring this device.
[ 8.962] (II) This device may have been added with another device file.
[ 8.969] (II) config/udev: Adding input device MSI WMI hotkeys (/dev/input/event6)
[ 8.969] (**) MSI WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 8.969] (**) MSI WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 8.969] (**) MSI WMI hotkeys: Applying InputClass "system-keyboard"
[ 8.969] (II) Using input driver 'libinput' for 'MSI WMI hotkeys'
[ 8.969] (**) MSI WMI hotkeys: always reports core events
[ 8.969] (**) Option "Device" "/dev/input/event6"
[ 8.970] (II) event6 - MSI WMI hotkeys: is tagged by udev as: Keyboard
[ 8.970] (II) event6 - MSI WMI hotkeys: device is a keyboard
[ 8.971] (II) event6 - MSI WMI hotkeys: device removed
[ 9.018] (**) Option "config_info" "udev:/sys/devices/virtual/input/input8/event6"
[ 9.018] (II) XINPUT: Adding extended input device "MSI WMI hotkeys" (type: KEYBOARD, id 14)
[ 9.018] (**) Option "xkb_layout" "us"
[ 9.020] (II) event6 - MSI WMI hotkeys: is tagged by udev as: Keyboard
[ 9.020] (II) event6 - MSI WMI hotkeys: device is a keyboard
[ 9.031] (**) SteelSeries SteelSeries KLC: Applying InputClass "evdev keyboard catchall"
[ 9.031] (**) SteelSeries SteelSeries KLC: Applying InputClass "libinput keyboard catchall"
[ 9.031] (**) SteelSeries SteelSeries KLC: Applying InputClass "system-keyboard"
[ 9.031] (II) Using input driver 'libinput' for 'SteelSeries SteelSeries KLC'
[ 9.031] (**) SteelSeries SteelSeries KLC: always reports core events
[ 9.031] (**) Option "Device" "/dev/input/event18"
[ 9.031] (II) libinput: SteelSeries SteelSeries KLC: is a virtual subdevice
[ 9.031] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.1/0003:1038:1122.0002/input/input19/event18"
[ 9.031] (II) XINPUT: Adding extended input device "SteelSeries SteelSeries KLC" (type: KEYBOARD, id 15)
[ 9.031] (**) Option "xkb_layout" "us"
[ 17.975] (II) event3 - Power Button: device removed
[ 17.991] (II) event11 - Video Bus: device removed
[ 18.024] (II) event12 - Video Bus: device removed
[ 18.058] (II) event2 - Power Button: device removed
[ 18.074] (II) event1 - Sleep Button: device removed
[ 18.091] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 18.108] (II) event17 - SynPS/2 Synaptics TouchPad: device removed
[ 18.141] (II) event6 - MSI WMI hotkeys: device removed
[ 18.191] (II) event18 - SteelSeries SteelSeries KLC: device removed
I wonder whats in /etc/X11/xorg.conf.d
Looks like nothing special/suspicious… ![]()
this point can stop Xorg
can you
cat / etc/X11/xorg.conf.d/30-touchpad.conf
Sure
Should I delete it? ![]()
