[HowTo] Manual rollback with btrfs
Difficulty: ★★☆☆☆ :de: :uk:
Why roll back?
  • If Manjaro doesn’t want to boot into the graphical user interface.
  • If an update managed to break an application you need
Now btrfs pays off! With a good layout and snapper. Please read all of the instructions through to the end before you begin.
Only a few steps are necessary for a rollback:
Boot a rescue Manjaro
Either from CD or from a live USB stick or somewhere else. Under no circumstances use the btrfs volume that you want to repair. If the necessary programs are not there, install with:
pamac install btrfs-progs mc gparted
  • gparted: To get an overview of the device names of the drives
  • btrfs-progs: For creating and listing snapshots
  • mc: To control what is happening on the volume
:warning: The following is not a playground for experimentation.
All the following commands require you to be root, and not without reason. Please remember to check each command 3 times for typing errors. It’s all very easy. But it intervenes deeply in the system. No fear. Errors can be repaired. But that costs time and nerves unnecessarily.
So open 2 (!) terminals and become root in each one
sudo su
[details=“Where is the “good” snapshot?”]
First look at the disks with gparted and search for the device with the btrfs file system that should get the rollback. Then mount this volume in the 1st terminal:
mkdir /mnt/ROOT; cd /mnt/ROOT
My btrfs volume is /dev/nvme0n1p3 Please insert your device in the following command!
mount -t btrfs -o subvol=/ /dev/nvme0n1p3/ mnt/ROOT
From now on you can start mc in the 2nd terminal and see everything we do. The layout of the btrfs volume can also be seen there.
cd /mnt/ROOT; mc
In my layout, the system is at @ and the snapshots are under @snapshots. We are looking for the snapshot whose timestamp is so that the system was still OK at this point in time. Don’t worry, the data afterwards won’t be lost. For me this seems to be @snapshots/18330/snapshot
[/details]
Save the broken system state
My booting system is under @ , and my snapshots are under @snapshots. The @ is broken and must be cleared away. (rw-snapshots can be moved, and @ is an rw-snapshot) I switch in mc into the right window with TAB then into “directory” @snapshots , then TAB in the left window with F6 move the “@” and rename it to “kaputt1” . Or do this in the 1st terminal:
mv /mnt/ROOT/@ /mnt/ROOT/@snapshots/kaputt1
mc is a great way to control how this works.
Prepare the selected snapshot for booting
The system needs an rw snapshot to boot. But the snapshots that snapper takes are read-only for a reason. So we have to create a new rw-snapshot from the existing snapshot.
btrfs subvolume snapshot /mnt/ROOT/@snapshots/18330/snapshot /mnt/ROOT/@
We now make this snapshot the default
btrfs subvolume set-default @
Check again with mc! Then quit mc.
umount /mnt/ROOT
DONE
If you have selected the good snapshot the system will boot. I had to repeat the whole thing again with snapshot 18347 :wink:
clean up
A few days after the rollback you have to remove the now unnecessary snapshot with the broken file system. It’s called @ snapshots / kaputt1 This can be done from within the running system. (btrfs is great)
These instructions assume that the directory (/ boot) with the kernel (which can be changed during the update) is on the btrfs volume. This ensures that matching kernels, initramfs and modules are available for each snapshot. With a disconnected /boot drive (as was the case in the past), rolling back can be extremely difficult.
When this fails, follow this link to rescue your data
How did it go
  • i did roll back successfully
  • i only could rescue my data
  • i gave up
  • I’m in the middle of it
0 voters
[HowTo]Rollback mit btrfs von Hand
Recovering BTRFS snapshots
Need a little btrfs subvolumes advice
Installation with btrfs subvolume and snapper
Manjaro KDE (btrfs) Dual Boot, HDD & SSD, recommended partition setup
For remote backup of the home folder, is it better to use syncthing for backup or btrbk?
BTRFS Problem read-only / free space
Unable to login | Failed to Start | Dependency Failed
I had really bad experiences last month using grub-btrfs and timeshift
Timeshift snapshots are taking a very big amount of space on my SSD
Secondary HDD stopped mounting. No mount point
Can Manjaro replicate the utility of Knoppix persistent?
Error: you need to load the kernel first (timeshift file is missing)
Btrfs system wont boot from the default subvolume?
Which permissions do I need to give an enrypted partition and encrypted root
BTRFS - How to convert single disk into RAID 1 (with LUKS)?
How to Install Manjaro on an empty BRTFS (or to be) partition with an existing /home directory and existing GRUB?
System (versatilely) bricked - after recovery of failed system update
Update ended in readonly filesystem
[HowTo] UEFI boot -> GPT, FAT32, GRUB to manjaro
Find right configuration of BTRFS and Snapper to be able to rollback the system without live system
Missing modules/5.10.xxx-MANJARO, suspect .old
"emergency mode" after Timeshift snapshot recovery
Random SSD usage spikes at idle
Where can I find docs/tutorials on BTRFS?
Boot failed (efibootmgr, luks, btrfs, sway) after updating
Can't load kernel after Timeshift restore / broken installation
Timeshift (ext4/rsync) - miss(?)-conception, wrong configuration?
[Stable Update] 2021-09-24 - Kernels, LibreOffice, Browsers, Pipewire, RHVoice, KDE Frameworks, Mesa
BTRFS ran out of space during update, now I can't boot, GRUB does not find kernel
Is BTRFS unstable? (Update: It's not unstable, the problem is probably something else)
How to restore snapshot using the default layout of snapper
Boot issue after luks encryption removal
Stuck at boot after first restart with only mouse pointer for the 3rd time, TTY is glitched out
How do I use Timeshift/btrfs to permanently restore to a previous snapshot?
No, this is only needed for subvolume @, so this gets the default subvolume when mounting without specifying any subvolume
You may also have a look at:
Btrfs - Wiki
6 posts were split to a new topic: How to restore snapshot using the default layout of snapper
FastTrack (only for the brave, as root)
:warning: You may need to adapt ALL commands/paths to your Btrfs layout
1) Mount BTRFS volume
mount -o subvol=/ /dev/sdy2 /mnt/
2) Save current state (optional)
mv /mnt/@ /mnt/@snapshots/broken_230513
3) Restore snapshot 7569
btrfs subvolume snapshot /mnt/@snapshots/7569/snapshot /mnt/@
4) Declare as default (to boot)
btrfs subvolume set-default /mnt/@
boot (for the brave)
reboot
5) cleanup (optional later)
btrfs subvolume delete /.snapshots/broken_230513
This works via ssh in a running system while @ was mounted as filesystem-root (/) without live-manjaro
:smiling_face_with_three_hearts:
This may be the same as:
snapper --print-number rollback 7569
mount -t btrfs -o subvol=/ /dev/sda2/ mnt/ROOT                                                  mount: mnt/ROOT: mount point is not a directory.
       dmesg(1) may have more information after failed mount system call.
:frowning: So confusing…
Ready to give up now.
I guess it must be that:
mount -m -t btrfs -o subvol=/ /dev/sda2 /mnt/ROOT
