[Testing Update] 2023-08-08 - Kernels, Firmwares, Plasma, Pamac, Firefox, Pipewire
Hello community,
Another testing branch update with some usual package updates for you.
Get the lastest SoftMaker Office with ChatGPT buillt-in. You will find our Special Offer here!
Recent News:
  • Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
  • As you might have seen some of our team were able to attend FOSDEM 2023 and the conference proved to be incredibly productive for us. See our blog post for more.
Previous News
Notable Package Updates:
  • Some Kernels got updated
    • We updated the linux-firmware packages again
  • Small fixes to Plasma 5.27.7
  • Firefox is at 116.0.2
  • With Pamac 10.6.0 and 11.6.0 we hope to have fixed most of the issues we had due to a mitigation. Both UIs use libpamac 11.6.0 now.
    • Please report any issues you may still have with it.
  • Pipewire is now at 0.3.77
  • Usual KDE-git, Perl and Python updates
Additional Info
Python 3.11 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.10.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.10/ :
pacman -Qoq /usr/lib/python3.10/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.10)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
Our current supported kernels
  • linux419 4.19.289
  • linux54 5.4.251
  • linux510 5.10.188
  • linux515 5.15.124
  • linux61 6.1.43
  • linux64 6.4.8
  • linux65 6.5.0-rc5
  • linux61-rt 6.1.38_rt12
  • linux64-rt 6.4.6_rt8
Package Changes (Tue Aug 8 00:04:42 CEST 2023)
  • testing core x86_64: 3 new and 3 removed package(s)
  • testing extra x86_64: 1062 new and 1049 removed package(s)
  • testing multilib x86_64: 7 new and 7 removed package(s)
Overlay Changes
  • testing core x86_64: 14 new and 14 removed package(s)
  • testing extra x86_64: 37 new and 35 removed package(s)
  • testing kde-unstable x86_64: 133 new and 133 removed package(s)
A full list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2023-08-08
2023-08-04
Possible glibc 2.38 posix_memalign regression
There seems a performance regression of posix_memalign in Glibc-2.38. More info here: Making sure you're not a bot!
Workarounds:
You can try another malloc like mimalloc or jemalloc as workaround. Install mimalloc and start mpv with:
LD_PRELOAD=/usr/lib/libmimalloc.so mpv
or
LD_PRELOAD=/usr/lib/libjemalloc.so mpv
For folks that dont want to change things too much .. an apparent workaround is to set a lowish cache size:
mkdir -p ~/.config/mpv && printf '\ndemuxer-max-bytes=50MiB\ndemuxer-max-back-bytes=25MiB\n' | tee -a ~/.config/mpv/mpv.conf
budgie-desktop >= 10.7.2-6 update requires manual intervention
When upgrading from budgie-desktop 10.7.2-5 to 10.7.2-6, the package mutter43 must be replaced with magpie-wm, which currently depends on mutter. As mutter43 conflicts with mutter, manual intervention is required to complete the upgrade.
First remove mutter43, then immediately perform the upgrade. Do not relog or reboot between these steps.
pacman -Rdd mutter43
pacman -Syu
2023-07-28
Grub conflicting files
Error: Failed to commit transaction:
conflicting files:
grub: /usr/bin/update-grub already exists in filesystem (owned by grub-update)
sudo pacman -Rdd grub-update
sudo pacman -Suu grub
[1] [2] [3]
2023-07-24
One core of CPU has high IO-wait operation at 100%
[Unstable Update] 2023-05-21 - Repository changes - #199 by Zesko
Kernel 6.4.4, 6.4.5 and 6.1.39 LTS are affected:
The known issue and report:
2023-07-15
Steam crashes on startup with lib32-libgudev installed
The latest lib32-libgudev update does not cooperate with the version of the same package provided by steam, and steam seems to attempt making calls to both leading to the crash.
Details: bug report, arch task, arch forum thread.
  • Workaround #1 (causes steam to avoid making any calls to lib32-libgudev by using a different library altogether)
    • sudo pacman -S lib32-libnm
  • Workaround #2 (forces steam and any other application to always use the new lib32-libgudev)
    • sudo pacman -S lib32-libudev0-shim
  • Workaround #3 (use steam-native-runtime, which doesn’t have the issue)
    • sudo pacman -S steam-native-runtime
2023-06-27
possible kernel bug for amdgpu users
[Testing Update] 2023-06-27 - Kernels, Linux-Firmware, Mesa, Wine, Nvidia, KDE-git - #4 by xvin
2023-06-24
Pamac GUI theme does not match theme for Xfce
pamac-gtk 11.0.1 uses Gtk 4 that is not supported by Xfce
user can replace pamac-gtk with pamac-gtk3
pamac install pamac-gtk3
TeX Live package reorganization
2023-06-18 - Antonio Rojas
Starting from version 2023.66594-9, TeX Live packages have been reorganized to mirror upstream collections. Even though the new texlive-basic replaces the old texlive-core, many of the texlive-core contents (including language specific files) are now split between different packages. To find out which Arch package contains a specific CTAN package, you can use the tlmgr utility, eg.
$ tlmgr info euler | grep collection
collection:  collection-latexrecommended
which means the euler CTAN package is contained in texlive-latexrecommended. You may also use pacman -F to query for specific files.
A new metapackage texlive-meta is available to install all subpackages (except for language specific ones), and the new texlive-doc package provides the full documentation for offline use.
Arch Linux - News: TeX Live package reorganization
2023-06-15
[details=“The “community” repository has been merged into “extra” and is now empty”]
The [community] repository has been merged into [extra] and is now empty. It may take a bit of time for mirrors to catch up.
:point_right: Update your system and merge the pacman pacnew /etc/pacman.conf.pacnew file.
sudo pacman -Syu "pacman>=6.0.2-11"
[/details]
OpenBLAS >= 0.3.23-2 update requires manual intervention
2023-06-14 - Felix Yan
The openblas package prior to version 0.3.23-2 doesn’t ship optimized LAPACK routine and CBLAS/LAPACKE interfaces for compatibility. This decision has been reverted now, and the ability to choose a different default system BLAS/LAPACK implementation while keeping openblas installed is now provided to allow future co-installation of BLIS, ATLAS, etc.
The default BLAS implementation will be used for most packages like NumPy or R. Please install blas-openblas and blas64-openblas to make OpenBLAS the default BLAS implementation, just like the old behavior.
Unfortunately you will get errors on updating if you currently have OpenBLAS installed as the default BLAS implementation:
:: installing openblas (0.3.23-2) breaks dependency 'blas' required by cblas
:: installing openblas (0.3.23-2) breaks dependency 'blas' required by lapack
Please append your preferred default BLAS implementation to the regular -Syu command line to get around it. For example:
sudo pacman -Syu blas-openblas
or
Arch Linux - News: OpenBLAS >= 0.3.23-2 update requires manual intervention
2023-05-11
Python 3.11 upgrade tip
Python packages built against python 3.10 can be rebuilt with the following:
Pip package upgrade guide
If you have a lot of pip/AUR packages to upgrade to Python 3.11, read this.
If you installed python311 from the AUR, you need to uninstall it before running this update.
Many applications (firefox, thunderbird, etc) slow to start on desktops other than Gnome
There is a bug with xdg-desktop-portal-gnome (more details here).
Workaround for gtk-based desktops (including Xfce)
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
Workaround for KDE
sudo pacman -S xdg-desktop-portal-kde
Workaround for Lxqt
sudo pacman -S xdg-desktop-portal-lxqt
Workaround for desktops using hyprland
sudo pacman -S xdg-desktop-portal-hyprland
Workaround for desktops using wlroots
sudo pacman -S xdg-desktop-portal-wlr
GDM slow to start after at-spi2-core 2.48.1-1 upgrade
  • Fixed with at-spi2-core 2.48.2-1 (no action required)
2023-03-28
Info about recent GRUB changes
[Unstable Update] 2023-02-17 - Plasma 5.27 LTS, GNOME, Python - #51 by philm
Info about recent NVIDIA packaging changes
[Testing Update] 2023-03-25 - Kernels, Firefox, Deepin, GNOME, NVIDIA, Wine - #42 by philm
2023-03-11
Possible kernel fs block code regression in 6.2.3 umounting usb drives
With kernel 6.2.3 when you simply plug in a usb external drive, mount it and umount it, then the journal has a kernel Oops. A bug report, that includes the journal output was submitted at. Making sure you're not a bot! Discussion can be found here: https://www.spinics.net/lists/stable/msg637035.html
kernel 5.15.99+ Black/empty screen during boot with i915 Intel gfx. No ways to do anything
Seems there is a regression introduced with 5.15.99 kernel update: Making sure you're not a bot!. My thoughts here: [Testing Update] 2023-03-11 - Kernels, Mesa 22.3.7, Phosh, LibreOffice 7.4.6 - #31 by philm
2023-02-10
Switch to the base-devel meta package requires manual intervention
2023-02-12 - Robin Candau
On February 2nd, the base-devel package group has been replaced by a meta package of the same name.
If you installed the base-devel package group prior to this date, explicitly re-install it to get the new base-devel package installed on the system:
pacman -Syu base-devel
Arch Linux - News: Switch to the base-devel meta package requires manual intervention
2023-01-17
Very slow shutdown when using KDE Plasma Wayland
The issue is sddm that can not be finished until the default timeout 90 sec.
The solution: Install sddm-git
The known bug reports:
PHP 8.2 update and introduction of legacy branch
2023-01-13 - Pierre Schmitz
The php packages have been updated to the latest version 8.2. In addition to this, a new set of php-legacy packages have been introduced. These will follow the oldest but still actively supported PHP branch. This enables users to install the latest version but also introduces the option to use third party applications that might rely on an older version. Both branches will be kept up to date following our rolling release model. php and php-legacy can be installed at the same time as the latter uses a -legacy suffix for its binaries and configuration files.
In addition to this, the php7 packages have been removed as they reached end of life. The imap extension will no longer be provided as it relies on the c-client library which has been abandoned for many years.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
2023-01-04
Some games like Dota 2 are freezing
The issue is caused by update libx11 1.8.3-4
The solution: Upgrade to libx11 1.8.3-5
VLC crashes when playing a video file
It looks like there has been a regression introduced with the new version of libva (2.17.0), which is used by VLC media player. If you get the following error when executing vlc in a terminal:
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
you may try to change the Output option in Preferences > Video to VDPAU output instead of Automatic (or whatever value it had been set to before).
Downgrading the libva package from 2.17.0-1 to 2.16.0-1 may also work, but it is a more short-term workaround that should not be kept for too long, as sooner or later, the older package won’t be compatible with the other packages. Consider to do the solution above first.
Previous testing threads
Problems with MPV and ffmpeg should be fixed now. Atleast my encoding speed is back to where it should be.
After updating & rebooting I found the lines below in the journal:
kernel: pamac-manager[3657]: segfault at 7fe8f7de0070 ip 00007fe8f7de0070 sp 00007ffe7ca61ae8 error 14 in libgvfscommon.so[7fe8f7de8000+13000] likely on CPU 5 (core 6, socket 0)
systemd-coredump[4032]: Process 3657 (pamac-manager) of user 1000 dumped core.
gvfs was updated in this set of updates.
Pamac cli & gui work fine, if I run into issues with pamac I’ll update this post.
A post was split to a new topic: Asbru-cm does not start
:point_up:
Since last update …
(though it is odd to me … as this never happened in Unstable [where I still have grub-update installed] … I suppose grub was downgraded on other branches? … :person_shrugging: )
Yes, testing was downgraded in regard of grub. Also we may not need to split out update-grub, but lets see.
