Grub won't update
Since yesterday, I have this set of updates/downgrades that pamac wants to do (I’m on the testing branch):
To upgrade (2):
  gnome-shell-extension-gtk4-desktop-icons-ng  1:44-2                  (1:44-1)              extra
  spectre-meltdown-checker                     0.46-1                  (0.45+10+g9bb79a1-1)  extra
To downgrade (10):
  mesa                                         23.0.4-3                (23.1.4-3)            extra
  grub                                         2.06.r499.ge67a551a4-4  (2.12rc1-1)           core
  lib32-mesa                                   23.0.4-3                (23.1.4-2)            multilib
  lib32-mesa-vdpau                             23.0.4-3                (23.1.4-2)            multilib
  lib32-vulkan-intel                           23.0.4-3                (23.1.4-2)            multilib
  vulkan-radeon                                23.0.4-3                (23.1.4-3)            extra
  lib32-vulkan-radeon                          23.0.4-3                (23.1.4-2)            multilib
  libva-mesa-driver                            23.0.4-3                (23.1.4-3)            extra
  mesa-vdpau                                   23.0.4-3                (23.1.4-3)            extra
  vulkan-intel                                 23.0.4-3                (23.1.4-3)            extra
However, the transition fails here:
Checking keyring...        [12/12]
Checking integrity...        [12/12]
Loading packages files...        [12/12]
Checking file conflicts...        [12/12]
Error: Failed to commit transaction:
conflicting files:
- grub: /usr/bin/update-grub already exists in filesystem (owned by grub-update)
I’m very cautious when it comes to messing up with grub, of course. I appreciate any guidance. Thanks.
I am on unstable and have the relevant packages installed already.
I wonder about your package … maybe you replaced it with the AUR one?
pacman -Qi grub-update
I also wonder how things would go using a … more tested … package manager:
sudo pacman -Syu
pacman -Qi grub-update returns:
Version         : 2.12rc1-1
Description     : GNU Grub (2) Update Menu Script
Architecture    : x86_64
URL             : https://www.gnu.org/software/grub/
Licenses        : GPL3
Groups          : None
Provides        : None
Depends On      : grub
Optional Deps   : None
Required By     : grub
Optional For    : None
Conflicts With  : None
Replaces        : None
Installed Size  : 324.00 B
Packager        : Philip Müller <philm@manjaro.org>
Build Date      : Wed 12 Jul 2023 09:57:16
Install Date    : Mon 24 Jul 2023 16:32:28
Install Reason  : Installed as a dependency for another package
Install Script  : Yes
Validated By    : Signature
sudo pacman -Syu returns:
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
warning: grub: local (2.12rc1-1) is newer than core (2.06.r499.ge67a551a4-4)
warning: lib32-mesa: local (23.1.4-2) is newer than multilib (23.0.4-3)
warning: lib32-mesa-vdpau: local (23.1.4-2) is newer than multilib (23.0.4-3)
warning: lib32-vulkan-intel: local (23.1.4-2) is newer than multilib (23.0.4-3)
warning: lib32-vulkan-radeon: local (23.1.4-2) is newer than multilib (23.0.4-3)
warning: libva-mesa-driver: local (23.1.4-3) is newer than extra (23.0.4-3)
warning: mesa: local (23.1.4-3) is newer than extra (23.0.4-3)
warning: mesa-vdpau: local (23.1.4-3) is newer than extra (23.0.4-3)
warning: vulkan-intel: local (23.1.4-3) is newer than extra (23.0.4-3)
warning: vulkan-radeon: local (23.1.4-3) is newer than extra (23.0.4-3)
 there is nothing to do
Ah. It appears your mirrors arent fully synced.
sudo pacman-mirrors -f && sudo pacman -Syuu
Though the grub is oddly truly newer than it should be.
(the extra u allows downgrades)
https://packages.manjaro.org/?query=mesa
sudo pacman -Rdd grub-update
sudo pacman -Suu grub
or simply disable downgrades in pamac
