[Testing Update] 2023-08-09 - Kernels, Gamescope-Plus, NVIDIA, KDE-git, Haskell, Perl, Python
Hello community,
Another testing branch update with some usual package updates for you.
Get the lastest SoftMaker Office with ChatGPT buillt-in. You will find our Special Offer here!
Recent News:
  • Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
  • As you might have seen some of our team were able to attend FOSDEM 2023 and the conference proved to be incredibly productive for us. See our blog post for more.
Previous News
Notable Package Updates:
  • Some Kernels got updated
    • This also includes security fixes for Intel and AMD
    • We may also update linux-firmware to reflect additional changes made by upstream
  • gamescope-plus got updated to 3.12.0
    • you may want to consider donating to get a better Linux Gaming experience!
  • NVIDIA driver is now at 535.98
  • Usual KDE-git, Haskell, Perl and Python updates
Additional Info
Python 3.11 info
:information_source: You will need to rebuild any AUR Python packages that install files to site-packages or link to libpython3.10.so. :information_source:
Print a list of of packages that have files in /usr/lib/python3.10/ :
pacman -Qoq /usr/lib/python3.10/
Rebuild them all at once:*
pamac build $(pacman -Qoq /usr/lib/python3.10)
* Note that if any fail to build, you’ll have to rebuild what’s remaining one or a few at a time.
checkrebuild
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
Our current supported kernels
  • linux419 4.19.290
  • linux54 5.4.252
  • linux510 5.10.189
  • linux515 5.15.125
  • linux61 6.1.44
  • linux64 6.4.9
  • linux65 6.5.0-rc5
  • linux61-rt 6.1.38_rt12
  • linux64-rt 6.4.6_rt8
Package Changes (Wed Aug 9 17:50:19 CEST 2023)
  • testing extra x86_64: 327 new and 328 removed package(s)
Overlay Changes
  • testing core x86_64: 12 new and 12 removed package(s)
  • testing extra x86_64: 85 new and 85 removed package(s)
  • testing kde-unstable x86_64: 32 new and 32 removed package(s)
  • testing multilib x86_64: 3 new and 3 removed package(s)
A full list of all package changes can be found here.
0 voters
Known issues and solutions
:arrow_right: 2023-08-09
2023-08-04
Possible glibc 2.38 posix_memalign regression
There seems a performance regression of posix_memalign in Glibc-2.38. More info here: Making sure you're not a bot!
Workarounds:
You can try another malloc like mimalloc or jemalloc as workaround. Install mimalloc and start mpv with:
LD_PRELOAD=/usr/lib/libmimalloc.so mpv
or
LD_PRELOAD=/usr/lib/libjemalloc.so mpv
For folks that dont want to change things too much .. an apparent workaround is to set a lowish cache size:
mkdir -p ~/.config/mpv && printf '\ndemuxer-max-bytes=50MiB\ndemuxer-max-back-bytes=25MiB\n' | tee -a ~/.config/mpv/mpv.conf
budgie-desktop >= 10.7.2-6 update requires manual intervention
When upgrading from budgie-desktop 10.7.2-5 to 10.7.2-6, the package mutter43 must be replaced with magpie-wm, which currently depends on mutter. As mutter43 conflicts with mutter, manual intervention is required to complete the upgrade.
First remove mutter43, then immediately perform the upgrade. Do not relog or reboot between these steps.
pacman -Rdd mutter43
pacman -Syu
2023-07-28
Grub conflicting files
Error: Failed to commit transaction:
conflicting files:
grub: /usr/bin/update-grub already exists in filesystem (owned by grub-update)
sudo pacman -Rdd grub-update
sudo pacman -Suu grub
[1] [2] [3]
2023-07-24
One core of CPU has high IO-wait operation at 100%
[Unstable Update] 2023-05-21 - Repository changes - #199 by Zesko
Kernel 6.4.4, 6.4.5 and 6.1.39 LTS are affected:
The known issue and report:
2023-07-15
Steam crashes on startup with lib32-libgudev installed
The latest lib32-libgudev update does not cooperate with the version of the same package provided by steam, and steam seems to attempt making calls to both leading to the crash.
Details: bug report, arch task, arch forum thread.
  • Workaround #1 (causes steam to avoid making any calls to lib32-libgudev by using a different library altogether)
    • sudo pacman -S lib32-libnm
  • Workaround #2 (forces steam and any other application to always use the new lib32-libgudev)
    • sudo pacman -S lib32-libudev0-shim
  • Workaround #3 (use steam-native-runtime, which doesn’t have the issue)
    • sudo pacman -S steam-native-runtime
2023-06-27
possible kernel bug for amdgpu users
[Testing Update] 2023-06-27 - Kernels, Linux-Firmware, Mesa, Wine, Nvidia, KDE-git - #4 by xvin
2023-06-24
Pamac GUI theme does not match theme for Xfce
pamac-gtk 11.0.1 uses Gtk 4 that is not supported by Xfce
user can replace pamac-gtk with pamac-gtk3
pamac install pamac-gtk3
TeX Live package reorganization
2023-06-18 - Antonio Rojas
Starting from version 2023.66594-9, TeX Live packages have been reorganized to mirror upstream collections. Even though the new texlive-basic replaces the old texlive-core, many of the texlive-core contents (including language specific files) are now split between different packages. To find out which Arch package contains a specific CTAN package, you can use the tlmgr utility, eg.
$ tlmgr info euler | grep collection
collection:  collection-latexrecommended
which means the euler CTAN package is contained in texlive-latexrecommended. You may also use pacman -F to query for specific files.
A new metapackage texlive-meta is available to install all subpackages (except for language specific ones), and the new texlive-doc package provides the full documentation for offline use.
Arch Linux - News: TeX Live package reorganization
2023-06-15
[details=“The “community” repository has been merged into “extra” and is now empty”]
The [community] repository has been merged into [extra] and is now empty. It may take a bit of time for mirrors to catch up.
:point_right: Update your system and merge the pacman pacnew /etc/pacman.conf.pacnew file.
sudo pacman -Syu "pacman>=6.0.2-11"
[/details]
OpenBLAS >= 0.3.23-2 update requires manual intervention
2023-06-14 - Felix Yan
The openblas package prior to version 0.3.23-2 doesn’t ship optimized LAPACK routine and CBLAS/LAPACKE interfaces for compatibility. This decision has been reverted now, and the ability to choose a different default system BLAS/LAPACK implementation while keeping openblas installed is now provided to allow future co-installation of BLIS, ATLAS, etc.
The default BLAS implementation will be used for most packages like NumPy or R. Please install blas-openblas and blas64-openblas to make OpenBLAS the default BLAS implementation, just like the old behavior.
Unfortunately you will get errors on updating if you currently have OpenBLAS installed as the default BLAS implementation:
:: installing openblas (0.3.23-2) breaks dependency 'blas' required by cblas
:: installing openblas (0.3.23-2) breaks dependency 'blas' required by lapack
Please append your preferred default BLAS implementation to the regular -Syu command line to get around it. For example:
sudo pacman -Syu blas-openblas
or
Arch Linux - News: OpenBLAS >= 0.3.23-2 update requires manual intervention
2023-05-11
Python 3.11 upgrade tip
Python packages built against python 3.10 can be rebuilt with the following:
Pip package upgrade guide
If you have a lot of pip/AUR packages to upgrade to Python 3.11, read this.
If you installed python311 from the AUR, you need to uninstall it before running this update.
Many applications (firefox, thunderbird, etc) slow to start on desktops other than Gnome
There is a bug with xdg-desktop-portal-gnome (more details here).
Workaround for gtk-based desktops (including Xfce)
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
Workaround for KDE
sudo pacman -S xdg-desktop-portal-kde
Workaround for Lxqt
sudo pacman -S xdg-desktop-portal-lxqt
Workaround for desktops using hyprland
sudo pacman -S xdg-desktop-portal-hyprland
Workaround for desktops using wlroots
sudo pacman -S xdg-desktop-portal-wlr
GDM slow to start after at-spi2-core 2.48.1-1 upgrade
  • Fixed with at-spi2-core 2.48.2-1 (no action required)
2023-03-28
Info about recent GRUB changes
[Unstable Update] 2023-02-17 - Plasma 5.27 LTS, GNOME, Python - #51 by philm
Info about recent NVIDIA packaging changes
[Testing Update] 2023-03-25 - Kernels, Firefox, Deepin, GNOME, NVIDIA, Wine - #42 by philm
2023-03-11
Possible kernel fs block code regression in 6.2.3 umounting usb drives
With kernel 6.2.3 when you simply plug in a usb external drive, mount it and umount it, then the journal has a kernel Oops. A bug report, that includes the journal output was submitted at. Making sure you're not a bot! Discussion can be found here: https://www.spinics.net/lists/stable/msg637035.html
kernel 5.15.99+ Black/empty screen during boot with i915 Intel gfx. No ways to do anything
Seems there is a regression introduced with 5.15.99 kernel update: Making sure you're not a bot!. My thoughts here: [Testing Update] 2023-03-11 - Kernels, Mesa 22.3.7, Phosh, LibreOffice 7.4.6 - #31 by philm
2023-02-10
Switch to the base-devel meta package requires manual intervention
2023-02-12 - Robin Candau
On February 2nd, the base-devel package group has been replaced by a meta package of the same name.
If you installed the base-devel package group prior to this date, explicitly re-install it to get the new base-devel package installed on the system:
pacman -Syu base-devel
Arch Linux - News: Switch to the base-devel meta package requires manual intervention
Previous testing threads:
i have this result with amd-ucode
août 09 19:55:35 kernel: Speculative Return Stack Overflow: IBPB-extending microcode not applied!
août 09 19:55:35 kernel: Speculative Return Stack Overflow: WARNING: See https://kernel.org/doc/html/latest/admin-guide/hw-vuln/srso.html for mitigation options.
août 09 19:55:35 kernel: microcode: CPU1: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: CPU0: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: CPU6: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: CPU4: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: CPU5: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: CPU3: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: CPU10: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: CPU9: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: CPU11: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: CPU8: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: CPU2: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: CPU7: patch_level=0x0a201016
août 09 19:55:35 kernel: microcode: Microcode Update Driver: v2.2.
and this error from nvidia-settings , windows appears
nvidia-settings
(nvidia-settings:1287): GLib-GObject-CRITICAL **: 19:55:58.034: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Thank you for the update. The new linux-firmware* 20230809 produces a booting hang in Linux kernel 6.1.x. Rolling back to 20230804 solves the issue.
This always has been there.
Hmm, what CPU do you have? These are the changes made upstream.
Something else regarding glibc: glibc 2.38 with patch from https://inbox.sourceware.org/libc-alpha/877cq4yrpg.fsf%40oldenburg.str.redhat.com applied
https://drive.google.com/file/d/1tAi0w_lvb_mMrhlsaYhplmqBS2Goc3Zw/view?usp=sharing glibc-2.38-2.1-x86_64.pkg.tar.zst
https://drive.google.com/file/d/16pXFwdKLbwjowsuTjl98jYv7JRAJ0mmo/view?usp=sharing lib32-glibc-2.38-2.1-x86_64.pkg.tar.zst
Just updated with Linux firmware, etc about a half hour ago… my computer’s not making it to the login screen. After last BIOS logo flash screen, the screen turns black (with backlight), then turns off/goes to sleep due to ‘no input detected.’
I’m at a loss. :roll_eyes:
7800X3D, 7900XTX, 6.5rc5… I hope to update with any troubleshooting
Can’t get to Grub (holding Esc after BIOS logos)
tried reseating RAM sticks and changing their positions
loading ‘optimized defaults’ BIOS settings
tried downgrading BIOS
There were two firmware releases yesterday: 20230809.f2eb058a-1 and 20230809.789aa815-1. The later includes kernel/git/firmware/linux-firmware.git - Repository of firmware blobs for use with the Linux kernel. However this commit might have added issues also to other AMDGPU hardware. I can try to do the similar way as Arch did and only update the microcodes of AMD and keep the other older firmwares. So check with an USB-Stick which of yesterdays firmware got installed on your end.
Also try a different kernel than 6.5 series … but your issue can also be something else. Check with a live-media if you can boot.
I am also experiencing a similar issue, I have a 7900XTX and an AMD cpu, although I have been able to boot into grub and I have tried kernels 6.4 and 6.1 so far. After seeing this post I booted into a live environment and it appears I have the later linux-firmware installed. Although the only way I know how to check this is by looking at the cached versions pacman makes in var/cache/pacman/pkg/ and I can see that I have both the 20230809.f2eb058a-1 and 20230809.789aa815-1 versions downloaded.
FIXED:
Booting into command line through grub allowed me to update that fixed the issue.
I do recall installing both throughout the day. The failure happened immediately after the second. I’ll try your other recommendation tomorrow, with a live USB. Thanks
UPDATE: I’m finally back in! I’m glad I didn’t go RJ Macready vs Chess Wizard on my comp! I’m glad this CPU features an iGPU, switching to it, I was able to get to a login screen with DisplayPort, it was solid black after logging in. Switched to HDMI, logged in…black screen with a pointer, force shut down again…switched to X11 (had been attempting Wayland), got in! I ran the microcode, firmware updates, shut down and set up hardware as it was, hoping for the best, selected Wayland (I’m on Plasma 5.27.7—sorry my posts were extra useless since I’d no access to my login), got back to my beautiful desktop. Happy tears.
Well lets see if a re-release of 20230804 + AMD microcodes will help here: [pkg-upd] 20230810.7be2766d-1 (f8eaf540) · Commits · Packages / Core / linux-firmware · GitLab
This all started this morning with an update on unstable branch - resulting in graphics failure.
My system was fully up-to-date yesterday at 18.00 when I shutdown for the day.
I didn’t have any rollback available so after some testing and then some more testing, I lost patience and reinstalled the system so I had a clean slate as a starting point.
 $ inxi -SCG
  Host: tiger Kernel: 6.4.6-1-MANJARO arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.27.6 Distro: Manjaro Linux
  Info: 12-core model: AMD Ryzen Threadripper PRO 5945WX s bits: 64
    type: MT MCP cache: L2: 6 MiB
  Speed (MHz): avg: 2066 min/max: 1800/7015 cores: 1: 1800 2: 2172 3: 1800
    4: 1800 5: 1800 6: 1800 7: 1800 8: 2879 9: 2219 10: 1800 11: 1800 12: 1746
    13: 4100 14: 1784 15: 1800 16: 1800 17: 1789 18: 1800 19: 1800 20: 1800
    21: 4100 22: 1800 23: 1800 24: 1800
  Device-1: AMD Navi 31 [Radeon RX 7900 XT/7900 XTX] driver: amdgpu v: kernel
  Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: amdgpu
    unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu s-res: 5120x1440
    resolution: 3840x1080
  API: OpenGL v: 4.6 Mesa 23.0.4 renderer: AMD Radeon RX 7900 XTX (gfx1100
    LLVM 15.0.7 DRM 3.52 6.4.6-1-MANJARO)
On my system I been taking rounds in determining what is preventing it from loadinig the GUI.
I have a working system on stable branch - fully up-to-date - can fully load Plasma - no problems
Switching to testing and running a sync - results in failing graphics - not even SDDM
 sudo pacman-mirrors -aS testing && sudo pacman -Syu
Rolling the system back using timeshift - it works. Before rolling back I secured the logs especially pacman.log to see what could possibly have caused this.
pacman.log
[2023-08-10T14:37:25+0200] [PACMAN] Running 'pacman -Syu'
[2023-08-10T14:37:25+0200] [PACMAN] synchronizing package lists
[2023-08-10T14:37:26+0200] [PACMAN] starting full system upgrade
[2023-08-10T14:37:49+0200] [PACMAN] Running 'pacman -Syu'
[2023-08-10T14:37:49+0200] [PACMAN] synchronizing package lists
[2023-08-10T14:37:50+0200] [PACMAN] starting full system upgrade
[2023-08-10T14:38:01+0200] [ALPM] running '00-timeshift-autosnap.hook'...
[2023-08-10T14:38:01+0200] [ALPM-SCRIPTLET] ==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
[2023-08-10T14:38:01+0200] [ALPM] running '60-mkinitcpio-remove.hook'...
[2023-08-10T14:38:01+0200] [ALPM] running 'firefox-pre.hook'...
[2023-08-10T14:38:01+0200] [ALPM] transaction started
[2023-08-10T14:38:01+0200] [ALPM] upgraded linux-api-headers (6.3-1 -> 6.4-1)
[2023-08-10T14:38:01+0200] [ALPM] upgraded glibc (2.37-3 -> 2.38-2.0)
[2023-08-10T14:38:01+0200] [ALPM-SCRIPTLET] Generating locales...
[2023-08-10T14:38:02+0200] [ALPM-SCRIPTLET]   da_DK.UTF-8... done
[2023-08-10T14:38:02+0200] [ALPM-SCRIPTLET]   en_DK.UTF-8... done
[2023-08-10T14:38:03+0200] [ALPM-SCRIPTLET]   en_US.UTF-8... done
[2023-08-10T14:38:03+0200] [ALPM-SCRIPTLET] Generation complete.
[2023-08-10T14:38:03+0200] [ALPM] upgraded gcc-libs (13.1.1-2 -> 13.2.1-3)
[2023-08-10T14:38:03+0200] [ALPM] upgraded abseil-cpp (20230125.3-1 -> 20230125.3-2)
[2023-08-10T14:38:03+0200] [ALPM] upgraded amd-ucode (20230724.59fbffa9-1 -> 20230809.789aa815-1)
[2023-08-10T14:38:03+0200] [ALPM] upgraded openssl (3.1.1-1 -> 3.1.2-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded xz (5.4.3-1 -> 5.4.4-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded libldap (2.6.4-2 -> 2.6.6-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded gmp (6.2.1-2 -> 6.3.0-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded ca-certificates-mozilla (3.91-1 -> 3.92-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded curl (8.2.0-2 -> 8.2.1-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded libelf (0.189-1 -> 0.189-3)
[2023-08-10T14:38:04+0200] [ALPM] upgraded binutils (2.40-6 -> 2.41-3)
[2023-08-10T14:38:04+0200] [ALPM] upgraded mesa (23.0.4-3 -> 23.1.5-2)
[2023-08-10T14:38:04+0200] [ALPM] upgraded libjpeg-turbo (2.1.5.1-1 -> 3.0.0-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded libsysprof-capture (3.48.0-2 -> 3.48.0-4)
[2023-08-10T14:38:04+0200] [ALPM] upgraded libproxy (0.5.3-1 -> 0.5.3-2)
[2023-08-10T14:38:04+0200] [ALPM] upgraded harfbuzz (8.0.1-1 -> 8.1.1-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded device-mapper (2.03.21-1 -> 2.03.22-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded qt5-base (5.15.10+kde+r135-1 -> 5.15.10+kde+r147-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded lib32-glibc (2.37-3 -> 2.38-2.0)
[2023-08-10T14:38:04+0200] [ALPM] upgraded lib32-gcc-libs (13.1.1-2 -> 13.2.1-3)
[2023-08-10T14:38:04+0200] [ALPM] upgraded lib32-openssl (1:3.1.1-1 -> 1:3.1.2-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded lib32-libldap (2.6.4-1 -> 2.6.6-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded polkit (122-1 -> 123-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded tar (1.34-2 -> 1.35-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded libtool (2.4.7+4+g1ec8fa28-4 -> 2.4.7+4+g1ec8fa28-6)
[2023-08-10T14:38:04+0200] [ALPM] upgraded nss (3.91-1 -> 3.92-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded kwallet (5.108.0-1 -> 5.108.0-2)
[2023-08-10T14:38:04+0200] [ALPM] upgraded mpfr (4.2.0.p12-1 -> 4.2.0.p12-3)
[2023-08-10T14:38:04+0200] [ALPM] upgraded bluedevil (1:5.27.6-1 -> 1:5.27.7-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded kdecoration (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded breeze (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded breeze-gtk (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded btrfs-progs (6.3.2-1 -> 6.3.3-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded cfitsio (1:4.2.0-1 -> 1:4.3.0-1)
[2023-08-10T14:38:04+0200] [ALPM] upgraded cpupower (6.3-2 -> 6.3-4)
[2023-08-10T14:38:04+0200] [ALPM] upgraded dhcpcd (10.0.1-1 -> 10.0.2-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded noto-fonts (1:23.7.1-1 -> 1:23.8.1-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded libmfx (23.2.2-1 -> 23.2.2-2)
[2023-08-10T14:38:05+0200] [ALPM] upgraded sdl2 (2.28.1-1 -> 2.28.2-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded openexr (3.1.9-1 -> 3.1.10-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded gtk-update-icon-cache (1:4.10.4-1 -> 1:4.10.5-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded firefox (116.0-1 -> 116.0.2-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded fuse-common (3.15.1-1 -> 3.16.1-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded fuse3 (3.15.1-1 -> 3.16.1-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded gcc (13.1.1-2 -> 13.2.1-3)
[2023-08-10T14:38:05+0200] [ALPM] upgraded perl (5.36.1-2 -> 5.38.0-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded perl-error (0.17029-4 -> 0.17029-5)
[2023-08-10T14:38:05+0200] [ALPM] upgraded perl-timedate (2.33-4 -> 2.33-5)
[2023-08-10T14:38:05+0200] [ALPM] upgraded perl-mailtools (2.21-6 -> 2.21-7)
[2023-08-10T14:38:05+0200] [ALPM] upgraded git (2.41.0-1 -> 2.41.0-2)
[2023-08-10T14:38:05+0200] [ALPM] upgraded gupnp (1:1.6.4-1 -> 1:1.6.5-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded libarchive (3.7.0-2 -> 3.7.1-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded gvfs (1.50.5-1 -> 1.50.6-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded gvfs-mtp (1.50.5-1 -> 1.50.6-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded gvfs-nfs (1.50.5-1 -> 1.50.6-1)
[2023-08-10T14:38:05+0200] [ALPM] upgraded gvfs-smb (1.50.5-1 -> 1.50.6-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded imagemagick (7.1.1.14-1 -> 7.1.1.15-2)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kactivitymanagerd (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kde-cli-tools (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kde-gtk-config (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded libksysguard (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded ksystemstats (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded milou (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded layer-shell-qt (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded libkscreen (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kscreenlocker (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded libpipewire (1:0.3.75-2 -> 1:0.3.77-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded libcamera-ipa (0.0.5-1 -> 0.1.0-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded libcamera (0.0.5-1 -> 0.1.0-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded pipewire (1:0.3.75-2 -> 1:0.3.77-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kwin (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded plasma-integration (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kpipewire (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded oxygen-sounds (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded plasma-workspace (5.27.6-2 -> 5.27.7-2)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kdeplasma-addons (5.27.6-2 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kdoctools (5.108.0-1 -> 5.108.0-2)
[2023-08-10T14:38:06+0200] [ALPM] upgraded systemsettings (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kgamma5 (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded khotkeys (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kinfocenter (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kmenuedit (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kscreen (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded ksshaskpass (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kwallet-pam (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kwayland-integration (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded kwrited (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded lib32-curl (8.2.0-1 -> 8.2.1-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded lib32-harfbuzz (8.0.1-1 -> 8.1.1-1)
[2023-08-10T14:38:06+0200] [ALPM] upgraded lib32-xz (5.4.3-1 -> 5.4.4-1)
[2023-08-10T14:38:07+0200] [ALPM] upgraded lib32-llvm-libs (15.0.7-1 -> 15.0.7-3)
[2023-08-10T14:38:07+0200] [ALPM] upgraded lib32-mesa (23.0.4-3 -> 23.1.5-2)
[2023-08-10T14:38:07+0200] [ALPM] upgraded lib32-libva (2.18.0-1 -> 2.19.0-1)
[2023-08-10T14:38:07+0200] [ALPM] upgraded lib32-libva-mesa-driver (23.0.4-3 -> 23.1.5-2)
[2023-08-10T14:38:07+0200] [ALPM] upgraded lib32-mesa-vdpau (23.0.4-3 -> 23.1.5-2)
[2023-08-10T14:38:07+0200] [ALPM] upgraded lib32-vulkan-intel (23.0.4-3 -> 23.1.5-2)
[2023-08-10T14:38:07+0200] [ALPM] upgraded vulkan-radeon (23.0.4-3 -> 23.1.5-2)
[2023-08-10T14:38:07+0200] [ALPM] upgraded lib32-vulkan-radeon (23.0.4-3 -> 23.1.5-2)
[2023-08-10T14:38:07+0200] [ALPM] upgraded python-chardet (5.1.0-3 -> 5.2.0-1)
[2023-08-10T14:38:07+0200] [ALPM] upgraded libpamac (11.5.7-2 -> 11.6.0-0.3)
[2023-08-10T14:38:07+0200] [ALPM] upgraded libva-mesa-driver (23.0.4-3 -> 23.1.5-2)
[2023-08-10T14:38:07+0200] [ALPM] upgraded licenses (20220125-2 -> 20230729-1)
[2023-08-10T14:38:07+0200] [ALPM] upgraded linux-firmware-whence (20230724.59fbffa9-1 -> 20230809.789aa815-1)
[2023-08-10T14:38:10+0200] [ALPM] upgraded linux-firmware (20230724.59fbffa9-1 -> 20230809.789aa815-1)
[2023-08-10T14:38:10+0200] [ALPM] upgraded mkinitcpio (36-3 -> 36-4)
[2023-08-10T14:38:11+0200] [ALPM] upgraded linux64 (6.4.6-1 -> 6.4.9-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded lsb-release (2.0.r48.3cf5103-1 -> 2.0.r53.a86f885-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded thin-provisioning-tools (1.0.4-1 -> 1.0.5-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded lvm2 (2.03.21-1 -> 2.03.22-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded mesa-vdpau (23.0.4-3 -> 23.1.5-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-encode-locale (1.05-10 -> 1.05-11)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-uri (5.19-1 -> 5.19-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-http-date (6.05-6 -> 6.06-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-file-listing (6.15-2 -> 6.16-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-html-tagset (3.20-13 -> 3.20-14)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-clone (0.46-1 -> 0.46-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-io-html (1.004-3 -> 1.004-4)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-lwp-mediatypes (6.04-3 -> 6.04-4)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-http-message (6.44-1 -> 6.44-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-html-parser (3.81-1 -> 3.81-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-http-cookies (6.10-3 -> 6.10-4)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-http-daemon (6.16-1 -> 6.16-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-http-negotiate (6.01-11 -> 6.01-12)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-net-http (6.23-1 -> 6.23-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-try-tiny (0.31-2 -> 0.31-3)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-www-robotrules (6.02-11 -> 6.02-12)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-libwww (6.67-1 -> 6.67-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-xml-parser (2.46-4 -> 2.46-5)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-xml-writer (0.900-1 -> 0.900-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded mhwd-nvidia-470xx (470.199.02-2 -> 470.199.02-3)
[2023-08-10T14:38:11+0200] [ALPM] upgraded mhwd-nvidia (535.86.05-1 -> 535.98-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded oxygen (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded pamac-cli (11.0.0-2 -> 11.6.0-0.1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded pamac-gtk3 (10.5.3-4 -> 10.6.0-0.1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-ipc-system-simple (1.30-4 -> 1.30-5)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-file-basedir (0.09-2 -> 0.09-3)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-file-desktopentry (0.22-10 -> 0.22-11)
[2023-08-10T14:38:11+0200] [ALPM] upgraded perl-file-mimeinfo (0.33-1 -> 0.33-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded plasma-browser-integration (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded polkit-kde-agent (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded powerdevil (5.27.6-3 -> 5.27.7-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded plasma-desktop (5.27.6-1 -> 5.27.7.1-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded plasma-nm (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded plasma-pa (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded plasma-systemmonitor (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded plasma-thunderbolt (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded plymouth-kcm (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded shiboken6 (6.5.1.1-4 -> 6.5.2-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded pyside6 (6.5.1.1-4 -> 6.5.2-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded python-filelock (3.12.0-2 -> 3.12.2-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded python-yaml (6.0-3 -> 6.0.1-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded sddm (0.20.0-1 -> 0.20.0-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded sddm-kcm (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded smartmontools (7.3-1 -> 7.4-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded sudo (1.9.14.p2-1 -> 1.9.14.p3-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded xxhash (0.8.1-4 -> 0.8.2-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded telegram-desktop (4.8.7-2 -> 4.8.10-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded timeshift (23.07.1-1 -> 23.07.1-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded vulkan-intel (23.0.4-3 -> 23.1.5-2)
[2023-08-10T14:38:11+0200] [ALPM] upgraded xapian-core (1:1.4.22-1 -> 1:1.4.23-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded xdg-desktop-portal-kde (5.27.6-1 -> 5.27.7-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded xfsprogs (6.3.0-2 -> 6.4.0-1)
[2023-08-10T14:38:11+0200] [ALPM] upgraded zsh-history-substring-search (1.0.2-2 -> 1.1.0-1)
[2023-08-10T14:38:11+0200] [ALPM] transaction completed
[2023-08-10T14:38:12+0200] [ALPM] running '20-systemd-sysusers.hook'...
[2023-08-10T14:38:12+0200] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-08-10T14:38:12+0200] [ALPM] running '30-systemd-tmpfiles.hook'...
[2023-08-10T14:38:12+0200] [ALPM] running '30-systemd-udev-reload.hook'...
[2023-08-10T14:38:13+0200] [ALPM] running '30-systemd-update.hook'...
[2023-08-10T14:38:13+0200] [ALPM] running '30-update-mime-database.hook'...
[2023-08-10T14:38:13+0200] [ALPM] running '40-update-ca-trust.hook'...
[2023-08-10T14:38:13+0200] [ALPM] running '60-depmod.hook'...
[2023-08-10T14:38:14+0200] [ALPM] running '80-cronie.hook'...
[2023-08-10T14:38:14+0200] [ALPM] running '90-mkinitcpio-install.hook'...
[2023-08-10T14:38:14+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux64.preset: 'default'
[2023-08-10T14:38:14+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2023-08-10T14:38:14+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.4-x86_64 -g /boot/initramfs-6.4-x86_64.img --microcode /boot/amd-ucode.img
[2023-08-10T14:38:14+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.4.9-1-MANJARO'
[2023-08-10T14:38:14+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-08-10T14:38:14+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET]   -> Running build hook: [autodetect]
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-08-10T14:38:15+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.4-x86_64.img'
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET] ==> Building image from preset: /etc/mkinitcpio.d/linux64.preset: 'fallback'
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET] ==> Using default configuration file: '/etc/mkinitcpio.conf'
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET]   -> -k /boot/vmlinuz-6.4-x86_64 -g /boot/initramfs-6.4-x86_64-fallback.img -S autodetect --microcode /boot/amd-ucode.img
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET] ==> Starting build: '6.4.9-1-MANJARO'
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET]   -> Running build hook: [base]
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET]   -> Running build hook: [udev]
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET]   -> Running build hook: [modconf]
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET]   -> Running build hook: [block]
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla1280'
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qla2xxx'
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'qed'
[2023-08-10T14:38:16+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'wd719x'
[2023-08-10T14:38:17+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'aic94xx'
[2023-08-10T14:38:17+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'bfa'
[2023-08-10T14:38:17+0200] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: 'xhci_pci'
[2023-08-10T14:38:17+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keyboard]
[2023-08-10T14:38:18+0200] [ALPM-SCRIPTLET]   -> Running build hook: [keymap]
[2023-08-10T14:38:18+0200] [ALPM-SCRIPTLET]   -> Running build hook: [consolefont]
[2023-08-10T14:38:18+0200] [ALPM-SCRIPTLET] ==> WARNING: consolefont: no font found in configuration
[2023-08-10T14:38:18+0200] [ALPM-SCRIPTLET]   -> Running build hook: [filesystems]
[2023-08-10T14:38:18+0200] [ALPM-SCRIPTLET]   -> Running build hook: [fsck]
[2023-08-10T14:38:19+0200] [ALPM-SCRIPTLET] ==> Generating module dependencies
[2023-08-10T14:38:19+0200] [ALPM-SCRIPTLET] ==> Creating gzip-compressed initcpio image: '/boot/initramfs-6.4-x86_64-fallback.img'
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] ==> Image generation successful
[2023-08-10T14:38:23+0200] [ALPM] running '90-packagekit-refresh.hook'...
[2023-08-10T14:38:23+0200] [ALPM] running '99-grub.hook'...
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] Generating grub configuration file ...
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] Found theme: /usr/share/grub/themes/manjaro/theme.txt
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] Found linux image: /boot/vmlinuz-6.4-x86_64
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.4-x86_64.img
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] Found initrd fallback image: /boot/initramfs-6.4-x86_64-fallback.img
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] Warning: os-prober will not be executed to detect other bootable partitions.
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] Systems on them will not be added to the GRUB boot configuration.
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] Check GRUB_DISABLE_OS_PROBER documentation entry.
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] Adding boot menu entry for UEFI Firmware Settings ...
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] Found memtest86+ image: /boot/memtest86+/memtest.bin
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] /usr/bin/grub-probe: warning: unknown device type nvme1n1.
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
[2023-08-10T14:38:23+0200] [ALPM-SCRIPTLET] done
[2023-08-10T14:38:23+0200] [ALPM] running 'dbus-reload.hook'...
[2023-08-10T14:38:24+0200] [ALPM] running 'detect-old-perl-modules.hook'...
[2023-08-10T14:38:24+0200] [ALPM] running 'firefox-post.hook'...
[2023-08-10T14:38:24+0200] [ALPM] running 'fontconfig.hook'...
[2023-08-10T14:38:24+0200] [ALPM] running 'fontconfig-32.hook'...
[2023-08-10T14:38:24+0200] [ALPM] running 'gio-querymodules.hook'...
[2023-08-10T14:38:24+0200] [ALPM] running 'glib-compile-schemas.hook'...
[2023-08-10T14:38:24+0200] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-08-10T14:38:24+0200] [ALPM] running 'gvfsd.hook'...
[2023-08-10T14:38:24+0200] [ALPM] running 'texinfo-install.hook'...
[2023-08-10T14:38:25+0200] [ALPM] running 'update-desktop-database.hook'...
[2023-08-10T14:38:25+0200] [ALPM] running 'xorg-mkfontscale.hook'...
I am fairly certain my system was already on Plasma 5.27.7 so I am excluding plasma from the list.
Other possible culprits …
The list of files on the mirror which has been created after 1800 yesterday
files changed in overlay
[fh@pw1 overlay]
$ find . -maxdepth 1 -name '*.pkg.tar.zst'  -newermt "2023-08-09 18:00"
./ktextaddons-23.04.3.r651.g05217d2-1-x86_64.pkg.tar.zst
./kcolorscheme-5.108.0.r134.gf77d60f-1-x86_64.pkg.tar.zst
./plasma-framework-5.108.0.r16867.g10f56d06e-1-x86_64.pkg.tar.zst
./plasma-workspace-5.27.7.r14179.g51709da62-1-x86_64.pkg.tar.zst
./baloo-5.108.0.r3312.g5cf4b2e0-1-x86_64.pkg.tar.zst
./elisa-23.04.3.r3378.gc8064a86-1-x86_64.pkg.tar.zst
./kolourpaint-23.04.3.r2563.g0a829777-1-x86_64.pkg.tar.zst
./libksysguard-5.27.7.r2705.g75f612e7-1-x86_64.pkg.tar.zst
./kbounce-23.04.3.r946.gdd8bc6b-1-x86_64.pkg.tar.zst
./kasts-23.04.3.r1333.gc0f83da-1-x86_64.pkg.tar.zst
./kirigami-addons-1:0.10.0.r32.g7786c13-1-x86_64.pkg.tar.zst
./libquotient-r3215.g1172a7e0-1-x86_64.pkg.tar.zst
./qqc2-desktop-style-5.108.0.r792.gf3dd8b2-1-x86_64.pkg.tar.zst
./plasma-nano-5.27.7.r299.g28e8313-1-x86_64.pkg.tar.zst
./kiconthemes-5.108.0.r721.g3b55e72-1-x86_64.pkg.tar.zst
./angelfish-23.04.3.r1374.gb8f113f-1-x86_64.pkg.tar.zst
./kio-5.108.0.r6482.gb34e18f10-1-x86_64.pkg.tar.zst
./breeze-icons-5.108.0.r2013.g260d8af9-1-x86_64.pkg.tar.zst
./kamera-23.04.3.r869.g62d9ce1-1-x86_64.pkg.tar.zst
./kxmlgui-5.108.0.r1089.g86d25349-1-x86_64.pkg.tar.zst
./kwidgetsaddons-5.108.0.r1155.g6bf99c95-1-x86_64.pkg.tar.zst
./krdc-23.04.3.r1741.g268d944-1-x86_64.pkg.tar.zst
./kbookmarks-5.108.0.r555.ga155ca3-1-x86_64.pkg.tar.zst
./ksmtp-23.04.3.r542.gf2f9aea-1-x86_64.pkg.tar.zst
./kdav-1:5.108.0.r1416.ga2b6819-1-x86_64.pkg.tar.zst
./ktextaddons-23.04.3.r644.g7ad57e7-1-x86_64.pkg.tar.zst
./calindori-23.04.3.r764.ge181857-1-x86_64.pkg.tar.zst
./xdg-desktop-portal-kde-5.27.7.r812.gcaab584-1-x86_64.pkg.tar.zst
./killbots-23.04.3.r890.g8baa3d0-1-x86_64.pkg.tar.zst
./kdnssd-5.108.0.r417.g64306f1-1-x86_64.pkg.tar.zst
./kwin-5.27.7.r25065.ged8b581dda-1-x86_64.pkg.tar.zst
./elisa-23.04.3.r3379.gc6f581d9-1-x86_64.pkg.tar.zst
./kcmutils-5.108.0.r959.g9b5df87d-1-x86_64.pkg.tar.zst
./kdenlive-23.04.3.r18526.gdd5b19972-1-x86_64.pkg.tar.zst
./kcoreaddons-5.108.0.r1855.g0ff0637b-1-x86_64.pkg.tar.zst
./plasma-mobile-nm-5.27.7.r3741.g33d7c554-1-x86_64.pkg.tar.zst
./kteatime-23.04.3.r849.g8a4a4d0-1-x86_64.pkg.tar.zst
./kglobalaccel-5.108.0.r679.g95da8a5-1-x86_64.pkg.tar.zst
./ktexteditor-5.108.0.r4105.gc7e62626-1-x86_64.pkg.tar.zst
./kirigami-addons-1:0.10.0.r34.ga0562a6-1-x86_64.pkg.tar.zst
./oxygen-5.27.7.r4638.g40721b09-1-x86_64.pkg.tar.zst
./plasma-desktop-5.27.7.r10763.g0f985616e-1-x86_64.pkg.tar.zst
./kconfigwidgets-5.108.0.r944.g102841b9-1-x86_64.pkg.tar.zst
./kfilemetadata-5.108.0.r1011.ga576166-1-x86_64.pkg.tar.zst
./neochat-23.04.3.r3415.g018154f55-1-x86_64.pkg.tar.zst
./kio-5.108.0.r6481.g104339b05-1-x86_64.pkg.tar.zst
./neochat-23.04.3.r3414.g80a5daa1f-1-x86_64.pkg.tar.zst
./kdeplasma-addons-5.27.7.r9660.g5535fab4f-1-x86_64.pkg.tar.zst
./kturtle-23.04.3.r1303.g770f211-1-x86_64.pkg.tar.zst
./kgeography-23.04.3.r1272.g233dd74-1-x86_64.pkg.tar.zst
./bluedevil-1:5.27.7.r2694.gcccf3c98-1-x86_64.pkg.tar.zst
./libkcddb-23.04.3.r870.g43f6029-1-x86_64.pkg.tar.zst
./plasma-pa-5.27.7.r1335.g399acaf-1-x86_64.pkg.tar.zst
./libkscreen-5.27.7.r1830.gd161e05-1-x86_64.pkg.tar.zst
./kbruch-23.04.3.r973.g0136f98-1-x86_64.pkg.tar.zst
./plasma-nm-5.27.7.r3741.g33d7c554-1-x86_64.pkg.tar.zst
./kidentitymanagement-23.04.3.r4020.g54048f93-1-x86_64.pkg.tar.zst
./kolourpaint-23.04.3.r2564.g776b16ba-1-x86_64.pkg.tar.zst
./kirigami2-5.108.0.r3939.gce973ba3-1-x86_64.pkg.tar.zst
./palapeli-23.04.3.r1416.gc780248-1-x86_64.pkg.tar.zst
./kglobalacceld-5.27.7.r241.ge4f72ce-1-x86_64.pkg.tar.zst
./kdebugsettings-23.04.3.r1410.g6c30372-1-x86_64.pkg.tar.zst
./krdc-23.04.3.r1742.g1efeb9d-1-x86_64.pkg.tar.zst
./kdeplasma-addons-5.27.7.r9662.g77533016f-1-x86_64.pkg.tar.zst
./kdenlive-23.04.3.r18525.g1b50da0db-1-x86_64.pkg.tar.zst
./kasts-23.04.3.r1332.g19d0129-1-x86_64.pkg.tar.zst
./kcron-23.04.3.r940.g5286932-1-x86_64.pkg.tar.zst
./plasma5support-5.27.7.r108.g8f48ff9-1-x86_64.pkg.tar.zst
./neochat-23.04.3.r3417.gfbc4611d0-1-x86_64.pkg.tar.zst
./knewstuff-5.108.0.r1656.gec76457a-1-x86_64.pkg.tar.zst
./kwin-5.27.7.r25064.g9ecd378624-1-x86_64.pkg.tar.zst
./plasma-wayland-session-5.27.7.r14175.g206a71dac-1-x86_64.pkg.tar.zst
./kcron-23.04.3.r939.g9c5ead8-1-x86_64.pkg.tar.zst
./angelfish-23.04.3.r1377.g8044d8f-1-x86_64.pkg.tar.zst
./libquotient-r3230.g2ae8d5de-1-x86_64.pkg.tar.zst
./plasma-systemmonitor-5.27.7.r810.g56894bf-1-x86_64.pkg.tar.zst
./plasma-disks-5.27.7.r425.ga47acb0-1-x86_64.pkg.tar.zst
./kcoreaddons-5.108.0.r1856.gebbc1d38-1-x86_64.pkg.tar.zst
./angelfish-23.04.3.r1376.g238fbaa-1-x86_64.pkg.tar.zst
./kirigami2-5.108.0.r3941.gf025c27f-1-x86_64.pkg.tar.zst
./calindori-23.04.3.r763.ga76a894-1-x86_64.pkg.tar.zst
./kcalc-23.04.3.r1753.ga2a2068-1-x86_64.pkg.tar.zst
./kconfig-5.108.0.r1147.g35f5f18e-1-x86_64.pkg.tar.zst
./kglobalacceld-5.27.7.r242.g12394c3-1-x86_64.pkg.tar.zst
./kalgebra-23.04.3.r2189.gfeaa6144-1-x86_64.pkg.tar.zst
./powerdevil-5.27.7.r2874.gb4678685-1-x86_64.pkg.tar.zst
./drkonqi-5.27.7.r1022.g6184d4b0-1-x86_64.pkg.tar.zst
./qqc2-breeze-style-5.27.7.r271.gaa9c825-1-x86_64.pkg.tar.zst
./sonnet-5.108.0.r836.g532403f-1-x86_64.pkg.tar.zst
./syntax-highlighting-5.108.0.r2308.ged287d35-1-x86_64.pkg.tar.zst
./kreversi-23.04.3.r1379.g35df4ca-1-x86_64.pkg.tar.zst
./partitionmanager-23.04.3.r1840.g07327c3-1-x86_64.pkg.tar.zst
./kteatime-23.04.3.r848.g5052fc8-1-x86_64.pkg.tar.zst
./kcalutils-23.04.3.r1098.ge0fe9d75e-1-x86_64.pkg.tar.zst
./plasma-workspace-5.27.7.r14175.g206a71dac-1-x86_64.pkg.tar.zst
./ktuberling-23.04.3.r1194.gf9b23d8-1-x86_64.pkg.tar.zst
./katomic-23.04.3.r1063.g0969b87-1-x86_64.pkg.tar.zst
./kdenlive-23.04.3.r18522.g46ae2a0bb-1-x86_64.pkg.tar.zst
./knewstuff-5.108.0.r1657.g5b38beab-1-x86_64.pkg.tar.zst
./plasma-desktop-5.27.7.r10765.g550aada70-1-x86_64.pkg.tar.zst
./kongress-23.04.3.r381.gd4efac0-1-x86_64.pkg.tar.zst
./sddm-kcm-5.27.7.r852.gff401cb-1-x86_64.pkg.tar.zst
./baloo-widgets-23.04.3.r923.g5d57bad-1-x86_64.pkg.tar.zst
./plasma-wayland-session-5.27.7.r14179.g51709da62-1-x86_64.pkg.tar.zst
./libkexiv2-23.04.3.r845.g75a7c20-1-x86_64.pkg.tar.zst
./krunner-5.108.0.r1008.g84b26ba-1-x86_64.pkg.tar.zst
./ktextaddons-23.04.3.r654.gbb538e1-1-x86_64.pkg.tar.zst
./networkmanager-qt-5.108.0.r1202.gc384d59-1-x86_64.pkg.tar.zst
From sanitizing and comparing the two file sets it seems my issue is cause by plasma?
mirror-changed-files.txt (sanitized)
angelfish
baloo
baloo-widgets
bluedevil
breeze-icons
calindori
drkonqi
elisa
kalgebra
kamera
kasts
katomic
kbookmarks
kbounce
kbruch
kcalc
kcalutils
kcmutils
kcolorscheme
kconfig
kconfigwidgets
kcoreaddons
kcron
kdav
kdebugsettings
kdenlive
kdeplasma
kdeplasma-addons
kdnssd
kfilemetadata
kgeography
kglobalaccel
kglobalacceld
kiconthemes
kidentitymanagement
killbots
kio
kirigami-addons
kirigami2
knewstuff
kolourpaint
kongress
krdc
krdc
kreversi
krunner
ksmtp
kteatime
ktextaddons
ktexteditor
ktuberling
kturtle
kwidgetsaddons
kwin
kxmlgui
libkcddb
libkexiv2
libkscreen
libksysguard
libquotient
neochat
networkmanager-qt
oxygen
palapeli
partitionmanager
plasma-desktop
plasma-disks
plasma-framework
plasma-mobile-nm
plasma-nano
plasma-nm
plasma-pa
plasma-workspace
plasma5support
powerdevil
qqc2-breeze-style
qqc2-desktop-style
sddm-kcm
sonnet
syntax-highlighting
system-changed-files.txt (sanitized)
abseil-cpp
amd-ucode
binutils
bluedevil
breeze
breeze-gtk
btrfs-progs
cfitsio
cpupower
curl
device-mapper
dhcpcd
firefox
fuse-common
fuse3
gcc
gcc-libs
git
glibc
gmp
gupnp
gvfs
gvfs-mtp
gvfs-nfs
gvfs-smb
harfbuzz
imagemagick
kactivitymanagerd
kde-cli-tools
kde-gtk-config
kdecoration
kdeplasma-addons
kdoctools
kgamma5
khotkeys
kinfocenter
kmenuedit
kpipewire
kscreen
kscreenlocker
ksshaskpass
ksystemstats
kwallet
kwallet-pam
kwin
kwrited
layer-shell-qt
lib32-curl
lib32-gcc-libs
lib32-glibc
lib32-harfbuzz
lib32-libldap
lib32-libva
lib32-llvm-libs
lib32-mesa
lib32-mesa-vdpau
lib32-openssl
lib32-vulkan-intel
lib32-vulkan-radeon
lib32-xz
libarchive
libcamera
libcamera-ipa
libelf
libjpeg-turbo
libkscreen
libksysguard
libldap
libmfx
libpamac
libpipewire
libproxy
libsysprof-capture
libtool
libva-mesa-driver
licenses
linux-api-headers
linux-firmware
linux64
lsb-release
lvm2
mesa
mesa-vdpau
mhwd-nvidia
mhwd-nvidia-470xx
milou
mkinitcpio
mpfr
noto-fonts
nss
openexr
openssl
oxygen
oxygen-sounds
pamac-cli
pamac-gtk3
perl
perl-clone
perl-encode-locale
perl-error
perl-file-basedir
perl-file-listing
perl-file-mimeinfo
perl-html-parser
perl-html-tagset
perl-http-cookies
perl-http-daemon
perl-http-date
perl-http-message
perl-http-negotiate
perl-io-html
perl-libwww
perl-lwp-mediatypes
perl-mailtools
perl-net-http
perl-timedate
perl-try-tiny
perl-uri
perl-www-robotrules
perl-xml-parser
perl-xml-writer
pipewire
plasma-desktop
plasma-integration
plasma-nm
plasma-pa
plasma-thunderbolt
plasma-workspace
plymouth-kcm
polkit
polkit-kde-agent
powerdevil
pyside6
python-chardet
python-filelock
python-yaml
qt5-base
sddm
sddm-kcm
sdl2
shiboken6
smartmontools
sudo
systemsettings
tar
telegram-desktop
timeshift
vulkan-intel
vulkan-radeon
xapian-core
xfsprogs
xxhash
xz
Maybe try to boot a Plasma Daily Build
I ran a new installation using an unstable ISO I created on 230729 with linux64.
I created a checklist using
checkupdates > ~/pending-updates.txt
I noted the amd-ucode was newer and matching above
amd-ucode 20230724.59fbffa9-1 -> 20230810.7be2766d-1
I created a snapshot and ran the sync - and my system is back to normal.
@philm It’s an AMD CPU with an integrated GPU. Confirmed firmware 20230810.7be2766d-1 (f8eaf540) solved the hang problem with an AMD CPU and Internal GPU in the previous 20230809.f2eb058a-1 and 20230809.789aa815-1
The one from yesterday also broke my system but this new one works for me.
Hi, just FYI I switched to testing because ungoogled-chromium-bin from AUR required glibc 2.38:
$ chromium
/usr/lib/chromium/chromium: /usr/lib/libm.so.6: version `GLIBC_2.38' not found (required by /usr/lib/chromium/chromium)
/usr/lib/chromium/chromium: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/chromium/chromium)
I know that you don’t support AUR (probably building from source would use glibc 2.37 on stable branch), also there’s an issue conecerning this on the ungoogled-chromium AUR package’s GitHub.
After switching to testing, ungoogled-chromium-bin works just fine. This is on 6.5-rc5 kernel, no issues to report so far. I noticed that 6.1… (LTS) kernel gets a kernel panic sometimes, but this seems to be caused by AUR xmm7360 LTE modem DKMS module and happened on stable branch too.
glibc saga continues. now it seems they are on the same page upstream by disabling a code section they introduced too fast. Some files to test:
Recently, irregularly in operation:
Aug 15 18:11:41 Horizen systemd-coredump[3469]: Process 3375 (python3) of user 1000 dumped core.
                                                Stack trace of thread 3375:
                                                #0  0x00007fdb380a0070 n/a (n/a + 0x0)
Aug 15 18:11:53 Horizen systemd-coredump[3485]: Process 3232 (pamac-manager) of user 1000 dumped core.
                                                Stack trace of thread 3232:
                                                #0  0x00007f5412944070 n/a (n/a + 0x0)
I am investigating the case…
Same entries in log here, does not seem to break anything.
Process 15669 (pamac-manager) of user 1000 dumped core.
                                             Stack trace of thread 15669:
                                             #0  0x00007fa5ab915070 n/a (n/a + 0x0)
