[Testing Update] 2022-07-25 - Kernels, Cinnamon, Haskell, Python, Virtualbox
Hello community,
Another testing branch update with some usual updates for you.
Cinnamon 5.4 brings a new version of the Mutter window manager
  • Most of our Kernels got updated
  • Some more Cinnamon updates got added
  • Virtualbox is now at 6.1.36
  • Regular KDE-git, Haskell and Python updates
Additional Info
Info about AUR packages
:warning: AUR (Arch User Repository) packages are neither supported by Arch nor Manjaro. Posts about them in Announcement topics are off-topic and will be flagged, moved or removed without warning.
:information_source: You may need to rebuild any AUR packages that install files to site-packages …
Get our latest daily developer images now from Github: Plasma, GNOME, XFCE. You get the latest stable releases of Manjaro from CDN77.
Our current supported kernels
  • linux419 4.19.253
  • linux54 5.4.207
  • linux510 5.10.132
  • linux515 5.15.57
  • linux517 5.17.15 (EOL)
  • linux518 5.18.14
  • linux519 5.19-rc7
  • linux515-rt 5.15.55_rt48
  • linux518-rt 5.18.0_rt11
Package Changes (Mon Jul 25 17:06:10 CEST 2022)
See here for all package changes.
0 voters
Known issues and solutions
:arrow_right: 2022-07-25
2022-07-16
wxWidgets 3.2 update may need manual intervention
Packages have been renamed from wxgtk- to wxwidgets-. The GTK2 frontend is no longer provided. If you have wxgtk2 installed, the upgrade will fail with:
In such case, uninstall wxgtk2 first and then proceed with the upgrade.
2022-07-13
Linux518: could not insert 'amd_pstate': No such device
With Kernel 5.18.11 there was added a regression to AMD P-State driver preventing it from loading.
2022-07-08
Wireplumber 0.4.11 may crash for GDM users
Currently there is an issue with 0.4.11 and GDM crashing on boot-up. More in the upstream bugtracker issue: Making sure you're not a bot!
2022-06-07
Locale file changes
C.UTF8 locale is now included in glibc:
Credits @diabonas for this change. Systemd wants us to include C.UTF8 by default and it seems the locale may be in included by glibc upstream in the future. To fix building and avoid nasty fixing in devtools, we include the locale in the package. See systemd/systemd#23252 (comment) FS#74864 : [systemd] >= 251 breaks devtools' locale
There is a pacsave for /etc/locale.conf as it has been removed from the filesystem package.
UPDATE: With filesystem 2022.06.08-2, it will automatically restore /etc/locale.conf if it did not already exist.
There is a pacnew for /etc/locale.gen. Please review it and regenerate your locale if necessary.
2022-05-10
QEMU >= 7.0.0 changes split package setup
2022-05-09 - David Runge
With the update to qemu 7.0.0 the package has been turned into a more fine grained split package utilizing meta packages.
  • The qemu package is now virtually provided by the meta packages qemu-base, qemu-desktop and qemu-full.
  • The functionality of qemu prior to 7.0.0 is replaced by qemu-desktop
  • The functionality of qemu-headless is replaced by qemu-base
  • The functionality of qemu-arch-extra and qemu-headless-arch-extra is replaced by qemu-emulators-full
  • The meta package qemu-full provides all QEMU related packages (excluding qemu-guest-agent)
2022-03-12
Cannot mix incompatible Qt library (5.15.2) with this library (5.15.3)
  • Check the mirror you use is up to date:
sudo pacman-mirrors -f 5 && sudo pacman -Syyu
  • If you use qt5-styleplugins (AUR), rebuild it:
pamac build qt5-styleplugins
FIXED? VPN via L2TP might not work anymore
See FS#74089 - networkmanager 1.36 breaks vpn with networkmanager-l2tp
You may need to downgrade to 1.34.0:
sudo pacman -U https://archive.archlinux.org/packages/l/libnm/libnm-1.34.0-1-x86_64.pkg.tar.zst https://archive.archlinux.org/packages/n/networkmanager/networkmanager-1.34.0-1-x86_64.pkg.tar.zst
FIXED? DSL/PPPoE may require downgrading 2 packages
See my-internet-connection-is-no-longer-working and FS#73948 - networkmanager 1.36.0 breaks DSL connection
Please check if 1.36.2-1.0 of NetworkManager improve things, else downgrade to 1.34.0:
2022-01-03
New warnings when building the fallback initcpio - Possibly missing firmware for module: bfa, qed, qla1280, qla2xxx
That’s due to the recent changes to the linux-firmware package. Note these are warnings, not errors. You only need those firmwares if you have Mellanox Spectrum switches, Marvell devices, Qualcomm SoCs, Cavium LiquidIO server adapters, QLogic devices and Broadcom NetXtreme II 10Gb ethernet adapters. if you have that hardware you can install linux-firmware-qlogic to get rid of those warnings. If you do not have that hardware you can safely ignore those warnings.
pamac install linux-firmware-qlogic
Noticed some key issues.
sudo rm -rf /etc/pacman.d/gnupg
sudo pacman-key --init
sudo pacman-key --populate archlinux manjaro
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring
sudo pacman-key --refresh-keys
sudo pacman -Syu
Now the update went fine.
The list of changed files [Testing Update] 2022-07-25 - Kernels, Cinnamon, Haskell, Python, Virtualbox ($774) · Snippets · Snippets · GitLab
shows a.o:
                  virtualbox-ext-vnc             6.1.34-4             6.1.36-1
                virtualbox-guest-iso             6.1.34-1             6.1.36-1
              virtualbox-guest-utils             6.1.34-4             6.1.36-1
          virtualbox-guest-utils-nox             6.1.34-4             6.1.36-1
                virtualbox-host-dkms             6.1.34-4             6.1.36-1
                      virtualbox-sdk             6.1.34-4             6.1.36-1
2nd column is date 22-07-23 and 3rd 22-07-25. There must be something wrong here since the virtualbox versions were already 6.1.36 in the testing update of 22-07-23?
A post was split to a new topic: Issues with gdal and arrow after update
Latest Firefox update 103.0-1 brought a problem on browser start:
juil. 27 02:26:49 omano-nvme systemd-coredump[1720]: [🡕] Process 1714 (firefox) of user 1000 dumped core.
                                                     Module /usr/lib/firefox/liblgpllibs.so with build-id 081553b68087ea2aaaeff0f256cd9e46d7edf667
                                                     Module linux-vdso.so.1 with build-id e742ac296f3e928fcdf6c0077898e22444472659
                                                     Module libGLX.so.0 with build-id 02bd4ac6acc4da9288c543ea1a0cdaa70c5e151a
                                                     Module libGLdispatch.so.0 with build-id de981c020bd9dbdc159b11f4a2a541310cc3b8d5
                                                     Module libvdpau.so.1 with build-id fccd021ff13c37ebf7144d184a3250624e086f52
                                                     Module libGL.so.1 with build-id b915a2e48be6c9fd3cc6f9f4c7aab1f7aeed8a4c
                                                     Module nvidia_drv_video.so with build-id 8976d88c463676c8a7a27a4fa06ab51a4f428200
                                                     Module libdrm.so.2 with build-id 39847bc84bc769f632f8f599a62fdcc98c9270cd
                                                     Module libva.so.2 with build-id 86d5ae6b358ba79962131649d99e42e1ba669501
                                                     Module libva-drm.so.2 with build-id 58df7fa92e899fee0c784db7a9fc68bb107156b6
                                                     Module libxcb-glx.so.0 with build-id 71d5b6691f53a235696da49ffa2178d643ecc228
                                                     Module librt.so.1 with build-id f696f0167950c759f9ea43d46167fae35d43dded
                                                     Module libplds4.so with build-id 2b49ec2f43d2e5fc2e56f35bcd094968f9bf36e6
                                                     Module libX11-xcb.so.1 with build-id f92352eae0a30aea89d11beb22367fa985288925
                                                     Module libdbus-glib-1.so.2 with build-id 9b483ffff76251ff057e007a0b960bff84ce34a8
                                                     Module libnssutil3.so with build-id 36c34a5ab8de68047e7886fe56da7ccf6722f465
                                                     Module libnss3.so with build-id 87abb242025e6e243d6974b3a9da26166884533a
                                                     Module libsmime3.so with build-id e80b1eacbb0979a1355fd008847c6eef060e83e3
                                                     Module libssl3.so with build-id 94040772bf0029a13562ab6314237dc26ea29a60
                                                     Module libplc4.so with build-id 2f3f90e73b1f4fc3424689615d6d32f7427bb783
                                                     Module libasound.so.2 with build-id aefb908044b1b408df406f1a9bab9bba486c0e94
                                                     Module libxul.so with build-id df5df7cca77bbb20d8d023735d6a2e3007704f96
                                                     Module libmozwayland.so with build-id 3f89e1e6b103635baf1a3f7616088efc0a6cde48
                                                     Module libgpg-error.so.0 with build-id 4738b8a9478177c202cccd64e0eb65d3dea2bfae
                                                     Module liblz4.so.1 with build-id e63600ab23b2f6997f42fac2fa56e1f02ce159a1
                                                     Module libgcrypt.so.20 with build-id 8bf3cb884124273640de797a3e77d86c98434ea4
                                                     Module libcap.so.2 with build-id 21b00ab76bb16fde56fd741f07233c78069f0579
                                                     Module libbrotlicommon.so.1 with build-id acfd597a977c8087bb6184383daae2e828a9ce42
                                                     Module libicudata.so.71 with build-id 4fef196388e678deb881978139e125e20ee2d94d
                                                     Module libsystemd.so.0 with build-id 761a39da56f185d6f1ef6f7bb95a3299789eb3e2
                                                     Module liblzma.so.5 with build-id 28b40c7af8098a66af6ee093b6986b91cad7694d
                                                     Module libzstd.so.1 with build-id ab54c2881f53ab314e134f3e08c76d504376dd5d
                                                     Module libXdmcp.so.6 with build-id d864159ab0008415667db8d5f251696d75c90df2
                                                     Module libXau.so.6 with build-id 60db1eac70f819bea9d4c366603c1583067510b4
                                                     Module libbrotlidec.so.1 with build-id 66c54e9301f7e102ecc1d88547e5f0e8a056fe22
                                                     Module libbz2.so.1.0 with build-id 919597c477c9b2cb9cdbb7745ed6494ac0e6da60
                                                     Module libdatrie.so.1 with build-id 6fe3b6ece2c8e7d11869fa051375128d8f808f58
                                                     Module libblkid.so.1 with build-id 140694a62d8d4d07c6c320a501f948dd1b389d73
                                                     Module libpthread.so.0 with build-id 95ae4f30a6f12ccbff645d30f8e1a3ee23ec7d36
                                                     Module libxml2.so.2 with build-id 8cdf00fa954d9a27f2f184c4d354cb14677446ac
                                                     Module libjson-glib-1.0.so.0 with build-id 58decebd2c409d59b07f926ae4c513281918bc4d
                                                     Module libsqlite3.so.0 with build-id 90fb9a043b4a51db25530e16cd543c4b2a9319a9
                                                     Module libicui18n.so.71 with build-id 6fd5c97fd2808ee29958bf809656d5885e7e8963
                                                     Module libicuuc.so.71 with build-id 633fdc0c5385d916571f6140e7a978ad0630ef55
                                                     Module libstemmer.so.0 with build-id 013b48e71279a5ec55e3021fc0bd8fb10a08bae5
                                                     Module libatspi.so.0 with build-id 87bca381f073faea3b0ffd1ab06f5f8f204e24cf
                                                     Module libdbus-1.so.3 with build-id 7f4b16b4b407cbae2d7118d6f99610e29a18a56a
                                                     Module libtiff.so.5 with build-id 31895d2bd133f34f0cdc2d4ac855ed838ec927b6
                                                     Module libjpeg.so.8 with build-id 8e6d3f3e8f438912b561c43b6e7f66e6e5e097d0
                                                     Module libexpat.so.1 with build-id 113bb5a3e9ad856801bfcfc029102c9bdc13d67e
                                                     Module libpixman-1.so.0 with build-id d2170a3ac106c2a68597bf7910ab04b1cdd69c14
                                                     Module libxcb-shm.so.0 with build-id 828fec4d856e2710e732ea8d92c3f250c807b1c2
                                                     Module libxcb-render.so.0 with build-id b1ca498d665807ab0ccdafbe8070853efd058173
                                                     Module libxcb.so.1 with build-id 13d677412a71468381b11092915d231f664d18d3
                                                     Module libXrender.so.1 with build-id 42e386d2acf3cde61081959d9671ca74acfb3edc
                                                     Module libpng16.so.16 with build-id 2dc0bce07f199bf983c07a05fb95a6f4af83a9b3
                                                     Module libgraphite2.so.3 with build-id ce58945ebb55b86d3a4e717b6eae29efc4720d8e
                                                     Module libfreetype.so.6 with build-id f89dd5502e75aca28fb5c3ccd0dbd26fe822bfef
                                                     Module libthai.so.0 with build-id a7ac5010b4275c49308021200d23690533952702
                                                     Module libmount.so.1 with build-id 4436aeea0cd8c01b5a77969e0531184f8b3513ce
                                                     Module libz.so.1 with build-id fefe3219a96d682ec98fcfb78866b8594298b5a2
                                                     Module libffi.so.8 with build-id f0a9586cf0f42d2b9971bd1065ca3a6b19f4a2c2
                                                     Module libpcre.so.1 with build-id 845483dd0acba86de9f0313102bebbaf3ce52767
                                                     Module libXinerama.so.1 with build-id 8198240259261b612189e89c9fcfc902b025b382
                                                     Module libXrandr.so.2 with build-id 154e55f082ee9e685d0794c98c5b76ffe9c8868e
                                                     Module libXcomposite.so.1 with build-id 13228d108b290268d88510db494daefd5521cda0
                                                     Module libXdamage.so.1 with build-id a99dbe3fc2b01da9fbdd90d5ad00621f9022379f
                                                     Module libXcursor.so.1 with build-id f0525ae3715ac95f96a8cdb44795b03f831334b0
                                                     Module libXext.so.6 with build-id 17beadf1cb40d41ab36629db3b4eed74110678a7
                                                     Module libwayland-egl.so.1 with build-id dd02a2af320297e68308cc698f75828529271a57
                                                     Module libwayland-cursor.so.0 with build-id 46a637dbcbb02d6712a201f177377b66598b9121
                                                     Module libwayland-client.so.0 with build-id 515c72111400d7bdbfbdfcec78d597e4986a5943
                                                     Module libxkbcommon.so.0 with build-id 6cf66eead3fcc20fe5df10162bfbcdcdc8b2a183
                                                     Module libXfixes.so.3 with build-id 0a05c7e8714522bfbdd7c0027c3e2a94965664b0
                                                     Module libtracker-sparql-3.0.so.0 with build-id eb5972c9f0b0292b8a7053255db5245c07669a88
                                                     Module libcloudproviders.so.0 with build-id ed1d9c9e60be4e858ad148484767249be1edf95f
                                                     Module libatk-bridge-2.0.so.0 with build-id 1161ebbcc5aa791075dfa026671875e5417287bd
                                                     Module libX11.so.6 with build-id 21e886e968772b7964d646f54c1faecc56734de9
                                                     Module libXi.so.6 with build-id 16603be937a02a7e61b0b0395d064be7efd86f49
                                                     Module libepoxy.so.0 with build-id edc178a150c4255d124e1e1ecbdbecebd1a388cd
                                                     Module libatk-1.0.so.0 with build-id c2de8b4fcbd9681cef225fe3956a9608a2a664bb
                                                     Module libgdk_pixbuf-2.0.so.0 with build-id 5b8422ab971b1a8a8e1c43b88738d4ee217f609e
                                                     Module libcairo-gobject.so.2 with build-id 9927090dddfb180365695a8f37d1cac89463f109
                                                     Module libfribidi.so.0 with build-id fe9f35ac2a0074108c8306c517793f7279bd9b37
                                                     Module libfontconfig.so.1 with build-id 36be6951b8c1e42a7dd05684a37400fc8ef9147c
                                                     Module libpangoft2-1.0.so.0 with build-id 1d293edcbaefc8c1b024f83d0935e88e6f09dfcb
                                                     Module libcairo.so.2 with build-id a222d042e56108d2786ece7bf291b56ba2069591
                                                     Module libharfbuzz.so.0 with build-id aad49fa51ffb89551ebb021336f56cfa28334823
                                                     Module libpango-1.0.so.0 with build-id b358a862a5ca8b1e4e69235edce1780e9f860a0a
                                                     Module libpangocairo-1.0.so.0 with build-id e7a2a9e56f2e2f6121d9c5741b3e93871b673cfa
                                                     Module libgio-2.0.so.0 with build-id 7a769ec24a9a705d04ee0297730032f70ed0835b
                                                     Module libgobject-2.0.so.0 with build-id a7515bd8cd51064d187953c0f506a43958de31a6
                                                     Module libglib-2.0.so.0 with build-id 1340f3a762b2293ebf6d725edf0eb14839f85317
                                                     Module libgmodule-2.0.so.0 with build-id abd986222e2cf12fc7324cb0182dfc2c8f2269c0
                                                     Module libgdk-3.so.0 with build-id 4a9a6d5ddd18f22c56c05773208f8808cefacab6
                                                     Module libgtk-3.so.0 with build-id 48baf44dfd4d51f8c2b81d852eb44de692c16b19
                                                     Module libmozgtk.so with build-id 3556db01b713cbc87af838233f58c16a8ceb0079
                                                     Module libmozsqlite3.so with build-id ac4e88133b28442d673acfa7640814c404fde869
                                                     Module libnspr4.so with build-id e54087b0e38cf8936f6c458e922589406343b05d
                                                     Module libmozsandbox.so with build-id 737b4f94dc082641ef04e3e3ed05fc254e66b6ca
                                                     Module ld-linux-x86-64.so.2 with build-id 0effd0e43efa4468d3c31871c93af0b7f3005673
                                                     Module libc.so.6 with build-id 60df1df31f02a7b23da83e8ef923359885b81492
                                                     Module libgcc_s.so.1 with build-id 0e3de903950e35ae59a5de8c00b1817a4a71ca01
                                                     Module libm.so.6 with build-id 1b7296ef9fd806e47060788389293c824b09ad72
                                                     Module libstdc++.so.6 with build-id a24b312bb5881ceae0ffbed599201690f2a1747b
                                                     Module firefox with build-id e6b65d95282c4101fec6f3871fc5d7d213918a7c
                                                     Stack trace of thread 1714:
                                                     #0  0x00007f36f5ccc814 XDisplayString (libX11.so.6 + 0x2b814)
                                                     #1  0x00007f36f2bf7a1d __vaDriverInit_1_13 (nvidia_drv_video.so + 0xda1d)
                                                     #2  0x00007f36e8c75c8a n/a (libva.so.2 + 0x3c8a)
                                                     #3  0x00007f36e8c7bbe1 vaInitialize (libva.so.2 + 0x9be1)
                                                     #4  0x00007f36f13369f7 n/a (libxul.so + 0x85369f7)
                                                     #5  0x00007f36f1337609 n/a (libxul.so + 0x8537609)
                                                     #6  0x00007f36ed2b73de n/a (libxul.so + 0x44b73de)
                                                     #7  0x00007f36ed2b51e5 n/a (libxul.so + 0x44b51e5)
                                                     #8  0x00007f36ed2a8125 n/a (libxul.so + 0x44a8125)
                                                     #9  0x00007f36ed2a73ed n/a (libxul.so + 0x44a73ed)
                                                     #10 0x000055e639121912 n/a (firefox + 0x49912)
                                                     #11 0x00007f36f7829290 n/a (libc.so.6 + 0x29290)
                                                     #12 0x00007f36f782934a __libc_start_main (libc.so.6 + 0x2934a)
                                                     #13 0x000055e6391355b5 _start (firefox + 0x5d5b5)
Firefox starts, and works, but this is generated on every Firefox start.
Yep, someone pushed Firefox to that branch which shouldn’t be done that way.
But it shows no error in Journalctl on my two devices.
The problem is probably related to hardware acceleration with Nvidia driver
maybe …
