Issues with gdal and arrow after update
After update:
gdalinfo
ERROR 1: libarrow.so.800: cannot open shared object file: No such file or directory
When I install arrow package I got this:
Job 1, 'gdalinfo' terminated by signal SIGILL
You did reboot the system, right?
Yes, I’ve rebooted system
Maybe try again with:
sudo pacman-mirrors -f5 && sudo pacman -Syyu gdal arrow
I’ve investigated that and removing -DARROW_SIMD_LEVEL=AVX2 option from PKGBUILD fixes arrow.
I have the same error
How can we remove this option…
Instructions please
Andriu
looks like you’d need to rebuild a repository package (arrow)
like with all others:
get the PKGBUILD
svntogit-community/trunk at packages/arrow · archlinux/svntogit-community · GitHub
svntogit-community/trunk/PKGBUILD at packages/arrow · archlinux/svntogit-community · GitHub
edit it (to remove the line in question)
and (re)build it using
makepkg
Related Arch bug report: FS#75749 - [gdal] ERROR 1: libarrow.so.800: cannot open shared object file: No such file or directory
