I had a login problem after the latest update, which was released on December 7, 2022.
When I try to log in as a user, it throws me literally for a second on the system boot screen (which refers to GRUB as I understand it), and then back to the authorization window. No errors are thrown with this.
And if you enter an incorrect password, the system will display an authorization error. That is, the problem is clearly not with authorization, I can’t enter the session.
They say it might be a window manager problem, but I’m having a hard time figuring out how to fix it.
Thank you for your attention!
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Yes, the version is correct. But at the same time, an error is generated that there is no library bluez-qt-5.100.0-1 and fraemworkintegration-5.100.0-1
