Support for R8125 Realtek 2.5 gbe Ethernet Adapter
KDE Plasma Version: 6.2.4
KDE Frameworks Version: 6.8.0
Qt Version: 6.8.1
Kernel Version: 6.12.4-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 24 × AMD Ryzen 9 7900X 12-Core Processor
Memory: 30.5 GiB of RAM
Graphics Processor: NVIDIA GeForce RTX 4060 Ti/PCIe/SSE2
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: X870 AORUS ELITE WIFI7 ICE
System Version: Default string-CF-WCP-ADO
Hi @RaymondTheBrave, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: https://wiki.manjaro.org/index.php/Forum_Rules
Hope you manage!
:bangbang: Tip for legibility: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Note that the above text is partially pre-prepared as a general introduction for new forum users. Please take the time to follow links given and learn how to create effective support requests and encourage quality responses.
Additionally, there is a driver/kernel module in the AUR:
$ pamac search 8125
r8125-dkms  9.014.01-1                                                       AUR
    Kernel module for RTL8125
So you could try installing that:
pamac build r8125-dkms
rebooting and seeing if it works.
a Reminder: While use of the AUR is possible, it’s neither recommended nor supported. See:
The following topic on Arch is marked solved
→ [SOLVED] Hardware issues with new MOBO - Gigabyte X870E / Kernel & Hardware / Arch Linux Forums
A similar topic on Manjaro forum - marked solved by using r8125-dkms from AUR - be sure to have the correct kernel headers synced
→ [root tip] [How To] Kernel - Headers - DKMS
→ Unable to use Ethernet (Realtek RTL8125 rev 0c)
sudo pacman-mirrors --api --set-branch unstable
sudo pacman -Syu base-devel linux612-headers
inxi --admin --verbosity=8 --filter --no-host --width                                          ✔
  Kernel: 6.12.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=9fb3e1d9-3b14-40d0-a8d1-7907cafe2031 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
    wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: X870 AORUS ELITE WIFI7 ICE v: x.x
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: F3i date: 12/03/2024
  System RAM: total: 32 GiB available: 30.46 GiB used: 3.06 GiB (10.0%)
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: 6000 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK32GX5M2E6000C36 serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 4
    level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
    model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
  Topology: cpus: 1x dies: 2 clusters: 2x1 cores: 12 threads: 24 tpc: 2
    smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB
    desc: 12x1024 KiB L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3006 min/max: 545/5733 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3006 2: 3006 3: 3006
    4: 3006 5: 3006 6: 3006 7: 3006 8: 3006 9: 3006 10: 3006 11: 3006 12: 3006
    13: 3006 14: 3006 15: 3006 16: 3006 17: 3006 18: 3006 19: 3006 20: 3006
    21: 3006 22: 3006 23: 3006 24: 3006 bogomips: 225273
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni
    avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
    avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    affected
  Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti] vendor: Gigabyte driver: nvidia
    v: 550.144.03 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
    status: current (as of 2025-01) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.0 chip-ID: 10de:2803 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
    empty: DP-1, DP-2, DP-3, DP-4, DP-5, Writeback-1 bus-ID: 73:00.0
    chip-ID: 1002:164e class-ID: 0300 temp: 41.0 C
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: amdgpu,nouveau unloaded: modesetting
    failed: nvidia alternate: fbdev,nv,vesa dri: radeonsi gpu: nvidia,amdgpu
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 107 s-size: 608x342mm (23.94x13.46")
    s-diag: 698mm (27.46") monitors: <missing: xrandr>
  Monitor-1: Unknown-1 size-res: N/A modes: 1024x768
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 1 drv: radeonsi device: 3 drv: swrast gbm:
    drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.144.03
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Ti/PCIe/SSE2
    memory: 15.62 GiB
  API: Vulkan v: 1.4.303 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4060 Ti driver: N/A device-ID: 10de:2803 surfaces: xcb,xlib
    device: 1 type: integrated-gpu name: AMD Radeon Graphics (RADV
    RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e surfaces: xcb,xlib
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: NVIDIA AD106M High Definition Audio vendor: Gigabyte
    driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 8
    bus-ID: 01:00.1 chip-ID: 10de:22bd class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
    Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 73:00.1 chip-ID: 1002:1640 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 73:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.4-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: N/A modules: r8169
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 06:00.0
  Device-2: MEDIATEK vendor: Foxconn driver: mt7925e v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 07:00.0 chip-ID: 14c3:7925
    class-ID: 0280
  IF: wlp7s0 state: up mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:3 chip-ID: 0489:e124
  Local Storage: total: 5 TiB used: 11.69 GiB (0.2%)
    model: SSD 970 EVO Plus 1TB size: 931.51 GiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 38.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500BX500SSD1
    tech: SSD serial: <filter> fw-rev: 072 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST4000VN006-3CW104
    size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: SC60 scheme: GPT
  ID-1: / raw-size: 136.72 GiB size: 133.51 GiB (97.66%) used: 11.6 GiB (8.7%)
    fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
    uuid: 9fb3e1d9-3b14-40d0-a8d1-7907cafe2031
  ID-2: /boot/efi raw-size: 406.9 MiB size: 403.7 MiB (99.22%)
    used: 86.6 MiB (21.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 8648-3914
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 303.75 GiB fs: ntfs
    label: Windows11 uuid: A4765FDEF32BC15E
  ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 219.07 GiB fs: ntfs label: Data1
    uuid: 7A5C1D4884A8A8FB
  ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 269.36 GiB fs: ext4
    label: LinuxMint uuid: 880b6f31-ff0f-4682-9ca9-4d67a23705f7
  ID-5: /dev/sdb1 maj-min: 8:17 size: 16 MiB fs: <superuser required>
  ID-6: /dev/sdb2 maj-min: 8:18 size: 976.56 GiB fs: ntfs label: HDDBackups
    uuid: F64CBC1A4CBBD419
  ID-7: /dev/sdb3 maj-min: 8:19 size: 465.66 GiB fs: ext4 label: timeshift
    uuid: c69df89f-166d-4e20-85a1-40729bef8e76
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 1-6:2 info: Integrated Express GIGABYTE Device type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5711 class-ID: 0300
  Device-2: 1-9:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e124 class-ID: e001 serial: <filter>
  Device-3: 1-12:4 info: Corsair Lighting Node CORE type: HID
    lanes: 1 mode: 1.1 power: 50mA chip-ID: 1b1c:0c1a class-ID: 0300
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 7-2:2 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
  Hub-9: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-10: 8-2:2 info: Realtek Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
  Hub-11: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-12: 9-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 9-1.2:3 info: Logitech Comfort Keyboard K290 type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
    lanes: 1 mode: 1.0 power: 98mA chip-ID: 046d:c31f class-ID: 0300
  Device-2: 9-1.4:4 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
    type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1bcf:08a0 class-ID: 0301
  Hub-13: 10-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 46.4 C mobo: 42.0 C
  Fan Speeds (rpm): N/A
  GPU: device: nvidia screen: :0.0 temp: 41 C fan: 0% device: amdgpu
    temp: 42.0 C
  Packages: pm: pacman pkgs: 1223 libs: 352 tools: pamac pm: flatpak pkgs: 0
    1: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    2: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    3: https://mirrors.aliyun.com/manjaro/stable/$repo/$arch
    4: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    5: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    6: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    7: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    8: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    9: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    10: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    11: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    13: https://manjaro.ynh.ovh/stable/$repo/$arch
    14: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    15: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    17: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    19: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    20: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    21: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    22: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    23: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    24: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    25: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    26: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    27: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    28: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    29: https://linorg.usp.br/manjaro/stable/$repo/$arch
    30: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    31: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    32: https://manjaro.kurdy.org/stable/$repo/$arch
    33: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    34: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    36: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    37: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    38: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    39: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    40: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    41: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    42: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    43: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    44: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    45: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    46: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    47: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    48: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    49: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    50: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    51: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    52: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    53: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    54: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    55: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    56: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    57: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    58: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    59: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    60: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    61: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    62: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    63: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    64: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    65: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    66: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    67: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    68: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    69: https://repos.silknet.com/manjaro/stable/$repo/$arch
    70: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    71: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    72: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    73: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    74: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    75: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    76: https://mirrors2.manjaro.org/stable/$repo/$arch
    77: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    78: http://manjaro.mirror.ac.za/stable/$repo/$arch
    79: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    80: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    81: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    82: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    83: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    84: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    85: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    86: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    87: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    88: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    89: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    90: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    91: https://mirror.23m.com/manjaro/stable/$repo/$arch
    92: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    93: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    94: http://manjaro.grena.ge/stable/$repo/$arch
    95: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    96: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    97: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    98: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    99: https://mirror.bardia.tech/manjaro/stable/$repo/$arch
    100: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    101: https://mirrors.piconets.webwerks.in/manjaro-mirror/stable/$repo/$arch
    102: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    103: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    104: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    105: https://mirror.nju.edu.cn/manjaro/stable/$repo/$arch
    106: https://mirror.init7.net/manjaro/stable/$repo/$arch
    107: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    108: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    109: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    110: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    111: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    112: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    113: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    114: https://mirrors.netix.net/manjaro/stable/$repo/$arch
    115: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    116: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    117: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    118: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    119: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    120: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    121: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    122: https://mirror.seahost.de/manjaro/stable/$repo/$arch
    123: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    124: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    125: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    126: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    127: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    128: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    129: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    130: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    131: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    132: https://mirror.zetup.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 417
  1: cpu: 30.0% command: [kworker/7:3-events] pid: 2927 mem: 0.00 MiB (0.0%)
  2: cpu: 14.6% command: firefox pid: 2413 mem: 704.7 MiB (2.2%)
  3: cpu: 5.4% command: firefox pid: 2640 mem: 266.1 MiB (0.8%)
  4: cpu: 5.2% command: firefox pid: 2560 mem: 316.9 MiB (1.0%)
  5: cpu: 3.8% command: plasmashell pid: 978 mem: 670.2 MiB (2.1%)
  Memory top: 5 of 417
  1: mem: 704.7 MiB (2.2%) command: firefox pid: 2413 cpu: 14.6%
  2: mem: 670.2 MiB (2.1%) command: plasmashell pid: 978 cpu: 3.8%
  3: mem: 316.9 MiB (1.0%) command: firefox pid: 2560 cpu: 5.2%
  4: mem: 266.1 MiB (0.8%) command: firefox pid: 2640 cpu: 5.4%
  5: mem: 255.4 MiB (0.8%) command: kwin_x11 pid: 966 cpu: 2.1%
  Processes: 417 Power: uptime: 9m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.15 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
I dont know how to install AUR modules etc.
What commands do I need to run from the terminal to install support for RTL8125?
I updated previously what my environment looks looks like.
I am very new to Manjaro!
Hi All,
I managed to work out how to allow software to be installed from the AUR repository and have installed and built the R8125.dkms.
Ethernet 2.5GBE is now working fine. So I have Wifi 7 and Ethernet networks
