Sorry for the inconvenience, I’ve been using Linux and Manjaro for quite a while and have been able to solve superficial problems myself by googling, but with this problem here I didn’t get any further with googling and the troubleshooting process in the Manjaro forum is therefore still a bit new to me.
Output of inxi -zv8:
Kernel: 6.15.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64
root=UUID=7855555d-0a93-4424-b16e-369377dc824d rw quiet apparmor=1
security=apparmor resume=UUID=9741a237-6f5f-4b60-aca6-67430dbb7d5f
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.15.0
Type: Desktop Mobo: ASRock model: X570 Taichi serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: P4.60
date: 08/03/2021
System RAM: total: 32 GiB available: 31.26 GiB used: 15.2 GiB (48.6%)
(unregistered) size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3600C16-8GVK serial: N/A
Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 2
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 4198 min/max: 563/4674 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4198 2: 4198 3: 4198
4: 4198 5: 4198 6: 4198 7: 4198 8: 4198 9: 4198 10: 4198 11: 4198 12: 4198
13: 4198 14: 4198 15: 4198 16: 4198 17: 4198 18: 4198 19: 4198 20: 4198
21: 4198 22: 4198 23: 4198 24: 4198 bogomips: 182390
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [RX 9070/9070 XT]
vendor: ASUSTeK driver: amdgpu v: kernel pcie: gen: 5 speed: 32 GT/s
lanes: 16 ports: active: DP-1,DP-2,HDMI-A-1 empty: DP-3,Writeback-1
bus-ID: 10:00.0 chip-ID: 1002:7550 class-ID: 0300
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu d-rect: 9600x3240
display-ID: 0
Monitor-1: DP-1 pos: top-center model: LG (GoldStar) Ultra HD
serial: <filter> built: 2017 res: mode: 3840x2160 hz: 60 scale: 125% (1.25)
to: 3072x1728 dpi: 163 gamma: 1.2 chroma: red: x: 0.655 y: 0.333 green:
x: 0.306 y: 0.639 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 600x340mm (23.62x13.39") diag: 690mm (27.2") ratio: 16:9
modes: 3840x2160, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
800x600, 720x480, 640x480
Monitor-2: DP-2 pos: top-right model: LG (GoldStar) Ultra HD
serial: <filter> built: 2019 res: mode: 3840x2160 hz: 60 scale: 125% (1.25)
Monitor-3: HDMI-A-1 pos: bottom-l model: Idek Iiyama PLX2783H
serial: <filter> built: 2013 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 82 gamma: 1.2 chroma: red: x: 0.647 y: 0.329 green: x: 0.314 y: 0.620
blue: x: 0.153 y: 0.063 white: x: 0.314 y: 0.329
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
modes: 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x960,
1280x800, 1280x720, 1152x720, 1024x768, 800x600, 720x576, 720x480,
640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
gfx1201 LLVM 20.1.6 DRM 3.63 6.15.3-1-MANJARO) device-ID: 1002:7550
memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 15 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.1.4-arch1.1
device-ID: 1002:7550 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: lact wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Creative Labs EMU20k2 [Sound Blaster X-Fi Titanium Series]
driver: snd_ctxfi v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 09:00.0 chip-ID: 1102:000b class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel
pcie: gen: 5 speed: 32 GT/s lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:ab40
class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 12:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: ABC MIC_TEST driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 3142:0001
class-ID: 0300
API: ALSA v: k6.15.3-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.5 status: active with: 1: pipewire-media-session
status: active 2: pipewire-alsa type: plugin tools: pw-cat,pw-cli
Server-4: PulseAudio v: 17.0-43-g3e2bb status: active with:
tools: pacat,pactl,pamixer,pavucontrol
Device-1: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Intel I211 Gigabit Network vendor: ASRock driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 8087:0029
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 11.37 TiB used: 3.84 TiB (33.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 67.8 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD30EFRX-68AX9N0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD30EURS-63SPKY0 size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT500MX500SSD1
tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 020 scheme: GPT
ID-6: /dev/sde maj-min: 8:64 vendor: Crucial model: CT2000MX500SSD1
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 033 scheme: GPT
ID-7: /dev/sdf maj-min: 8:80 vendor: Samsung model: ST1000LM024 HN-M101MBB
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> scheme: GPT
ID-1: / raw-size: 247.72 GiB size: 243.53 GiB (98.31%)
used: 149.96 GiB (61.6%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
label: Manjaro OS uuid: 7855555d-0a93-4424-b16e-369377dc824d
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
label: NO_LABEL uuid: 4148-1A1C
ID-3: /home raw-size: 1.56 TiB size: 1.53 TiB (98.36%)
used: 991.32 GiB (63.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: Home uuid: 79dfb248-3e66-47a6-b718-732bd89492d7
ID-4: /run/media/fye/Backup raw-size: 2.73 TiB size: 2.69 TiB (98.39%)
used: 5.14 GiB (0.2%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: Backup
uuid: 74172308-6968-487b-b454-2e62d451af7e
ID-5: /run/media/fye/Daten_Backup raw-size: 2.73 TiB
size: 2.69 TiB (98.39%) used: 1.16 TiB (43.2%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17 label: Daten_Backup
uuid: 29a19eac-3e7e-4042-866c-bf8b21b01242
ID-6: /run/media/fye/Development-SSD raw-size: 931.51 GiB
size: 915.82 GiB (98.31%) used: 591.85 GiB (64.6%) fs: ext4 dev: /dev/sdd1
maj-min: 8:49 label: Development-SSD
uuid: 11a4923a-9057-49cc-a75f-e1d2b3ea6bd9
ID-7: /run/media/fye/Spiele_2TB raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1009.15 GiB (55.1%) fs: ext4 dev: /dev/sde1 maj-min: 8:65
label: Spiele_2TB uuid: 8ff8a1cd-a686-4c3e-ac2f-c9200a97d0ec
ID-1: swap-1 type: partition size: 17.5 GiB used: 597.1 MiB (3.3%)
priority: -2 dev: /dev/nvme0n1p4 maj-min: 259:4 label: Swap
uuid: 9741a237-6f5f-4b60-aca6-67430dbb7d5f
ID-1: /dev/sdc1 maj-min: 8:33 size: 465.14 GiB fs: ntfs label: N/A
uuid: 68B03161B0313742
ID-2: /dev/sdc2 maj-min: 8:34 size: 100 MiB fs: vfat label: N/A
uuid: 2C65-47BA
ID-3: /dev/sdc3 maj-min: 8:35 size: 531 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/sdf1 maj-min: 8:81 size: 931.51 GiB fs: btrfs
label: Btrfs_1TB_HDD uuid: bcba95e2-e197-466d-bce0-0f0ef78e6e63
Hub-2: 1-2:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-3: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Device-1: 2-2:2 info: ASMedia Ugreen Storage Device type: mass storage
driver: uas interfaces: 1 rev: 3.1 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
mode: 3.2 gen-1x1 chip-ID: 174c:235c class-ID: 0806 serial: <filter>
Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-2:2 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-2: 3-4:3 info: ABC MIC_TEST type: audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
chip-ID: 3142:0001 class-ID: 0300
Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 5-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 05e3:0610
Device-1: 5-1.1:5 info: Razer USA DeathAdder V2 Pro type: mouse,keyboard
driver: razermouse,usbhid interfaces: 5 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1532:007d class-ID: 0300
serial: <filter>
Device-2: 5-1.2:4 info: Razer USA RC30-030502 Mouse Dock
type: mouse,keyboard driver: razeraccessory,usbhid interfaces: 3 rev: 2.0
chip-ID: 1532:007e class-ID: 0300
Device-3: 5-4:3 info: Razer USA BlackWidow Classic type: keyboard,mouse
driver: razerkbd,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1532:011b class-ID: 0300
Hub-8: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 42.5 C mobo: 41.0 C gpu: amdgpu temp: 55.0 C
mem: 72.0 C
Fan Speeds (rpm): fan-1: 1028 fan-2: 2036 fan-3: 4078 fan-4: 953 fan-5: 0
fan-6: 0 fan-7: 0 gpu: amdgpu fan: 46
Packages: 2395 pm: pacman pkgs: 2303 libs: 534 tools: pamac pm: flatpak
pkgs: 82 pm: snap pkgs: 10
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
2: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
3: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
4: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
5: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
6: https://muug.ca/mirror/manjaro/stable/$repo/$arch
7: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
8: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 575
1: cpu: 202% command: VirtualBoxVM pid: 4333 mem: 4718.7 MiB (14.7%)
2: cpu: 84.0% command: baloo_file_extractor pid: 4416
mem: 188.4 MiB (0.5%)
3: cpu: 42.1% command: floorp pid: 4448 mem: 653.0 MiB (2.0%)
4: cpu: 25.2% command: baloo_file pid: 2448 mem: 74.1 MiB (0.2%)
5: cpu: 12.0% command: floorp pid: 4749 mem: 229.1 MiB (0.7%)
Memory top: 5 of 575
1: mem: 4718.7 MiB (14.7%) command: VirtualBoxVM pid: 4333 cpu: 202%
2: mem: 675.2 MiB (2.1%) command: plasmashell pid: 2744 cpu: 2.9%
3: mem: 653.0 MiB (2.0%) command: floorp pid: 4448 cpu: 42.1%
4: mem: 435.8 MiB (1.3%) command: exe pid: 3845 cpu: 2.6%
5: mem: 415.5 MiB (1.2%) command: floorp pid: 5143 cpu: 8.7%
Processes: 575 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,upowerd
Compilers: clang: 20.1.6 gcc: 15.1.1 alt: 11/13/14 Shell: Zsh v: 5.9
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
Had a crash a few Minuts ago, output of journalctl --boot=-1 --priority=3 --catalog --no-pager
Jun 29 11:25:42 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000008 SMN_C2PMSG_82:0x00000400
Jun 29 11:25:42 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Failed to enable GFXCLK DS!
Jun 29 11:25:47 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000008 SMN_C2PMSG_82:0x00000400
Jun 29 11:25:47 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Failed to set workload mask 0x00000001
Jun 29 11:25:47 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:25:52 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000008 SMN_C2PMSG_82:0x00000400
Jun 29 11:25:52 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Failed to disable gfxoff!
Jun 29 11:25:56 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000008 SMN_C2PMSG_82:0x00000400
Jun 29 11:25:56 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Failed to disable gfxoff!
Jun 29 11:26:01 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000008 SMN_C2PMSG_82:0x00000400
Jun 29 11:26:01 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Failed to disable gfxoff!
Jun 29 11:26:05 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000008 SMN_C2PMSG_82:0x00000400
Jun 29 11:26:05 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Failed to disable gfxoff!
Jun 29 11:26:05 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: ring gfx_0.0.0 timeout, signaled seq=4554323, emitted seq=4554325
Jun 29 11:26:05 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Process information: process Xwayland pid 2506 thread Xwayland:cs0 pid 2510
Jun 29 11:26:05 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Starting gfx_0.0.0 ring reset
Jun 29 11:26:08 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: MES(1) failed to respond to msg=RESET
Jun 29 11:26:08 fye-linux kernel: [drm:amdgpu_mes_reset_legacy_queue [amdgpu]] *ERROR* failed to reset legacy queue
Jun 29 11:26:08 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: reset via MES failed -110
Jun 29 11:26:08 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Ring gfx_0.0.0 reset failure
Jun 29 11:26:09 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:26:10 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:26:11 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:26:12 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:26:13 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:26:16 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000008 SMN_C2PMSG_82:0x00000400
Jun 29 11:26:16 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Failed to disable gfxoff!
Jun 29 11:26:18 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:26:19 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:26:20 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:26:21 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000008 SMN_C2PMSG_82:0x00000400
Jun 29 11:26:21 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Failed to enable GFXCLK DS!
Jun 29 11:26:21 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:26:25 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000008 SMN_C2PMSG_82:0x00000400
Jun 29 11:26:25 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: Failed to set workload mask 0x00000001
Jun 29 11:26:29 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: SMU: I'm not done with your previous command: SMN_C2PMSG_66:0x00000008 SMN_C2PMSG_82:0x00000400
Jun 29 11:26:29 fye-linux kernel: amdgpu 0000:10:00.0: amdgpu: [SetDfCstate] failed!
Jun 29 11:26:29 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:26:30 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:27:06 fye-linux kernel: amdgpu 0000:10:00.0: [drm] *ERROR* dc_dmub_srv_log_diagnostic_data: DMCUB error - collecting diagnostic data
Jun 29 11:27:06 fye-linux systemd[1]: Failed to start CUPS Scheduler.
Jun 29 11:27:06 fye-linux systemd[1]: Failed to start Rule-based Manager for Device Events and Files.
Jun 29 11:27:06 fye-linux systemd[1]: Failed to start Journal Service.
Jun 29 11:26:32 fye-linux pulseaudio[2557]: Failed to release transport /org/bluez/hci0/dev_AC_12_2F_CC_FA_70/fd0: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Jun 29 11:26:32 fye-linux systemd-coredump[17616]: [🡕] Process 1714 (bluetoothd) of user 0 dumped core.
Stack trace of thread 1714:
#0 0x00007f044441574c n/a (libc.so.6 + 0x9774c)
#1 0x00007f04443bbdc0 raise (libc.so.6 + 0x3ddc0)
#2 0x00007f04443a357a abort (libc.so.6 + 0x2557a)
#3 0x00007f04446aa064 n/a (libdbus-1.so.3 + 0xe064)
#4 0x00007f04446d3e50 _dbus_warn_check_failed (libdbus-1.so.3 + 0x37e50)
#5 0x00007f04446c1a42 dbus_message_new_method_call (libdbus-1.so.3 + 0x25a42)
#6 0x000055cf32996723 n/a (/usr/lib/bluetooth/bluetoothd + 0xf723)
#7 0x000055cf3299cccc n/a (/usr/lib/bluetooth/bluetoothd + 0x15ccc)
#8 0x000055cf32a4c496 n/a (/usr/lib/bluetooth/bluetoothd + 0xc5496)
#9 0x000055cf32a4cba0 n/a (/usr/lib/bluetooth/bluetoothd + 0xc5ba0)
#10 0x000055cf32a1710f n/a (/usr/lib/bluetooth/bluetoothd + 0x9010f)
#11 0x00007f0444770be0 g_slist_foreach (libglib-2.0.so.0 + 0x81be0)
#12 0x000055cf329aaa7e n/a (/usr/lib/bluetooth/bluetoothd + 0x23a7e)
#13 0x000055cf32991353 n/a (/usr/lib/bluetooth/bluetoothd + 0xa353)
#14 0x00007f04443a56b5 n/a (libc.so.6 + 0x276b5)
#15 0x00007f04443a5769 __libc_start_main (libc.so.6 + 0x27769)
#16 0x000055cf32992565 n/a (/usr/lib/bluetooth/bluetoothd + 0xb565)
░░ Subject: Memory image generated for process 1714 (bluetoothd)
░░ Defined-By: systemd
░░ Documentation: man:core(5)
░░ Process 1714 (bluetoothd) has been aborted and
░░ a memory image has been generated.
░░ This is usually an indication of a program error and should
░░ be reported as an error to the respective manufacturer.
Jun 29 11:26:34 fye-linux systemd-coredump[17617]: [🡕] Process 3249 (ferdium) of user 1000 dumped core.
Stack trace of thread 22:
#0 0x000055d78e4b0aae n/a (/app/Ferdium/ferdium + 0x6c95aae)
#1 0x000055d78e4b058b n/a (/app/Ferdium/ferdium + 0x6c9558b)
#2 0x000055d78e4b0b19 n/a (/app/Ferdium/ferdium + 0x6c95b19)
#3 0x000055d78f28f030 n/a (/app/Ferdium/ferdium + 0x7a74030)
#4 0x00007f17d8a91b51 n/a (/usr/lib/x86_64-linux-gnu/libdbus-1.so.3.32.4 + 0x1bb51)
#5 0x000055d78f28fdda n/a (/app/Ferdium/ferdium + 0x7a74dda)
#6 0x000055d78e4ffcff n/a (/app/Ferdium/ferdium + 0x6ce4cff)
#7 0x000055d78e52e17e n/a (/app/Ferdium/ferdium + 0x6d1317e)
#8 0x000055d78e52d825 n/a (/app/Ferdium/ferdium + 0x6d12825)
#9 0x000055d78e52d420 n/a (/app/Ferdium/ferdium + 0x6d12420)
#10 0x000055d78e541ef5 n/a (/app/Ferdium/ferdium + 0x6d26ef5)
#11 0x000055d78e541ccd n/a (/app/Ferdium/ferdium + 0x6d26ccd)
#12 0x000055d78e541bc7 n/a (/app/Ferdium/ferdium + 0x6d26bc7)
#13 0x000055d78e55e4cc n/a (/app/Ferdium/ferdium + 0x6d434cc)
#14 0x00007f17d79c3eda n/a (/usr/lib/x86_64-linux-gnu/libc.so.6 + 0x8eeda)
#15 0x00007f17d7a4bac4 n/a (/usr/lib/x86_64-linux-gnu/libc.so.6 + 0x116ac4)
░░ Subject: Memory image generated for process 3249 (ferdium)
░░ Process 3249 (ferdium) has been aborted and
Jun 29 11:26:38 fye-linux pulseaudio[2557]: org.bluez.BatteryProviderManager1.UnregisterBatteryProvider() Failed: org.freedesktop.DBus.Error.Disconnected:Connection is closed
Jun 29 11:26:39 fye-linux systemd-coredump[17650]: [🡕] Process 9706 (steamwebhelper) of user 1000 dumped core.
Module /run/host/usr/lib/libicudata.so.76.1 without build-id.
Module /run/host/usr/lib/libicuuc.so.76.1 without build-id.
Stack trace of thread 9722:
#0 0x00007f75c7ccb0af n/a (/home/fye/.local/share/Steam/ubuntu12_64/libcef.so + 0x66cb0af)
#1 0x00007f75c7ccab7b n/a (/home/fye/.local/share/Steam/ubuntu12_64/libcef.so + 0x66cab7b)
#2 0x00007f75c7ccb129 n/a (/home/fye/.local/share/Steam/ubuntu12_64/libcef.so + 0x66cb129)
#3 0x00007f75c8c748e0 n/a (/home/fye/.local/share/Steam/ubuntu12_64/libcef.so + 0x76748e0)
#4 0x00007f75c042aa41 n/a (/usr/lib/x86_64-linux-gnu/libdbus-1.so.3.19.17 + 0x17a41)
░░ Subject: Memory image generated for process 9706 (steamwebhelper)
░░ Process 9706 (steamwebhelper) has been terminated and
What I could observe during the latest crash was that the mouse started to hang or stutter and the 3 screens then went off. It is noticeable that they keep trying to wake up from “standby mode” (no idea what else to call it), but fail and the keyboard also hangs.
REISUB was able to restart the PC in this case, but unfortunately REISUB did not work during the crash yesterday.
As I said, the problems have only existed since the last Manjaro stable update, before that everything was absolutely stable and problem-free.
If further information is required, I will be happy to provide it.
