Hello.
When I try to launch steam it just shows the updating screen for a split second then closes.
When I run steam in my terminal it gives me this output:
steam.sh[8613]: Running Steam on manjarolinux 23.0.0 64-bit
steam.sh[8613]: STEAM_RUNTIME is enabled automatically
setup.sh[8686]: Steam runtime environment up-to-date!
steam.sh[8613]: Steam client's requirements are satisfied
[2023-07-07 16:56:28] Startup - updater built Jun 21 2023 21:17:38
[2023-07-07 16:56:28] Startup - Steam Client launched with: '/home/samc/.local/share/Steam/ubuntu12_32/steam'
07/07 16:56:28 Init: Installing breakpad exception handler for appid(steam)/version(1687386907)/tid(8761)
Looks like steam didn't shutdown cleanly, scheduling immediate update check
[2023-07-07 16:56:28] Loading cached metrics from disk (/home/samc/.local/share/Steam/package/steam_client_metrics.bin)
[2023-07-07 16:56:28] Using the following download hosts for Public, Realm steamglobal
[2023-07-07 16:56:28] 1. https://client-update.akamai.steamstatic.com, /, Realm 'steamglobal', weight was 1000, source = 'update_hosts_cached.vdf'
[2023-07-07 16:56:28] 2. https://cdn.cloudflare.steamstatic.com, /client/, Realm 'steamglobal', weight was 1, source = 'update_hosts_cached.vdf'
[2023-07-07 16:56:28] 3. http://media.steampowered.com, /client/, Realm 'steamglobal', weight was 1, source = 'baked in'
[2023-07-07 16:56:28] Checking for update on startup
[2023-07-07 16:56:28] Checking for available updates...
[2023-07-07 16:56:28] Downloading manifest: https://client-update.akamai.steamstatic.com/steam_client_ubuntu12
[2023-07-07 16:56:28] Manifest download: send request
[2023-07-07 16:56:28] Manifest download: waiting for download to finish
[2023-07-07 16:56:28] Manifest download: finished
[2023-07-07 16:56:28] Download skipped: /steam_client_ubuntu12 version 1687386907, installed version 1687386907, existing pending version 0
[2023-07-07 16:56:28] Nothing to do
[2023-07-07 16:56:28] Verifying installation...
[2023-07-07 16:56:28] Performing checksum verification of executable files
[2023-07-07 16:56:29] Verification complete
(process:8761): GLib-GObject-CRITICAL **: 16:56:29.579: g_object_ref: assertion 'G_IS_OBJECT (object)' failed
(process:8761): GLib-GObject-CRITICAL **: 16:56:29.579: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Loaded SDL version 3.0.0-1782-g214d5daa3
XRRGetOutputInfo Workaround: initialized with override: 0 real: 0xec613db0
XRRGetCrtcInfo Workaround: initialized with override: 0 real: 0xec612500
Gtk-Message: 16:56:29.631: Failed to load module "appmenu-gtk-module"
/usr/share/themes/Breeze/gtk-2.0/widgets/entry:70: error: unexpected identifier 'direction', expected character '}'
(steam:8761): Gtk-WARNING **: 16:56:29.636: Unable to locate theme engine in module_path: "adwaita",
/usr/share/themes/Breeze/gtk-2.0/widgets/styles:36: error: invalid string constant "combobox_entry", expected valid string constant
GetWin32Stats: display was not open yet, good
ComputeStartupMode: found registry default startup mode: 0
Switching to desktopui, since -vgui was not specified
steamwebhelper.sh[8788]: Runtime for steamwebhelper: defaulting to /home/samc/.local/share/Steam/ubuntu12_64/steam-runtime-heavy
steamwebhelper.sh[8788]: glibc >= 2.34, partially disabling sandbox until CEF supports clone3()
CAppInfoCacheReadFromDiskThread took 25 milliseconds to initialize
Failed to init SteamVR because it isn't installed
Assertion 'device' failed at src/libsystemd/sd-device/device-private.c:103, function device_get_tags_generation(). Aborting.
crash_20230707165630_27.dmp[8970]: Uploading dump (out-of-process)
/tmp/dumps/crash_20230707165630_27.dmp
crash_20230707165630_27.dmp[8970]: Finished uploading minidump (out-of-process): success = yes
crash_20230707165630_27.dmp[8970]: response: CrashID=bp-e919952d-82f8-4dd7-8a2a-3412d2230707
crash_20230707165630_27.dmp[8970]: file ''/tmp/dumps/crash_20230707165630_27.dmp'', upload yes: ''CrashID=bp-e919952d-82f8-4dd7-8a2a-3412d2230707''
/home/samc/.local/share/Steam/steam.sh: line 798: 8761 Aborted (core dumped) "$STEAMROOT/$STEAMEXEPATH" "$@"
Manjaro Unstable
System info:
Kernel: 6.1.38-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=b5089fca-1558-4628-b8ce-be93a4357c01 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.6 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DT_FX505DT v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: FX505DT v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: FX505DT.316 date: 01/28/2021
ID-1: BAT0 charge: 35.8 Wh (100.0%) condition: 35.8/48.1 Wh (74.5%)
volts: 12.0 min: 11.7 model: FX50442 type: Li-ion serial: N/A status: full
System RAM: available: 15.06 GiB used: 3.45 GiB (22.9%)
Info: model: AMD Ryzen 7 3750H with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108102
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2042 high: 2945 min/max: 1400/2300 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1571 2: 1738
3: 1400 4: 1400 5: 1400 6: 2945 7: 2944 8: 2942 bogomips: 36750
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2
sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 535.54.03 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1f91
class-ID: 0300
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: eDP-1 empty: none bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
temp: 67.0 C
Device-3: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 13d3:56a2
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: amdgpu,nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: Najing CEC Panda 0x0036 built: 2018
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: AMD Radeon Vega 10 Graphics
(raven LLVM 15.0.7 DRM 3.49 6.1.38-1-MANJARO) direct-render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.6
chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.1.38-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.72 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: AzureWave driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
chip-ID: 10ec:c822 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-1: IMC Networks Bluetooth Radio driver: btusb v: 0.8 type: USB
rev: 1.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 13d3:3548
Local Storage: total: 596.18 GiB used: 99.15 GiB (16.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200V MTFDHBA512TCK
lanes: 4 tech: SSD serial: <filter> fw-rev: P1MA0V4 temp: 41.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: A-Data model: SX900 size: 119.24 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 2a scheme: GPT
ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
used: 99.15 GiB (85.1%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: b5089fca-1558-4628-b8ce-be93a4357c01
used: 316 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: F58C-AECD
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 260 MiB fs: vfat label: SYSTEM
uuid: AAEA-60E5
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 476.03 GiB fs: ntfs label: OS
uuid: F4ECEC87ECEC4588
ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 650 MiB fs: ntfs label: RECOVERY
uuid: D26E88386E88177F
Device-1: 1-4:2 info: IMC Networks Bluetooth Radio type: bluetooth
driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
mode: 1.1 power: 500mA chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
Device-1: 3-1:2 info: IMC Networks USB2.0 HD UVC WebCam type: video
driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Device-2: 3-2:3 info: Logitech Mouse type: mouse driver: hid-generic,usbhid
interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 66.0 C mobo: N/A gpu: amdgpu temp: 66.0 C
Fan Speeds (RPM): cpu: 2700
Processes: 278 Uptime: 11m wakeups: 1 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 alt: 11 clang: 15.0.7 Packages: 1931
pm: pacman pkgs: 1923 libs: 470 tools: pamac,paru pm: flatpak pkgs: 8
Shell: Zsh v: 5.9 default: Bash v: 5.2.0 running-in: konsole inxi: 3.3.27
I hope you can help. ![]()
