+1 - I got this too.
thank you, that do the trick.
A post was split to a new topic: After 2023-12-01 I can not get in to a timed out session
A post was merged into an existing topic: WiFi problems after 2032.12.10 Stable Update
Iāve solved mine with this one too. Thank you:)
How did you switch the kernel⦠Iām not able to boot into the desktop.
Here are the changes of 6.6.4 and 6.6.5. 6.6.5 introduced those patches:
-rw-rārā | r8169-fix-deadlock-on-rtl8125-in-jumbo-mtu-mode.patch | 2011 | logstatsplain |
-rw-rārā | r8169-prevent-potential-deadlock-in-rtl8169_close.patch |
check if 6.7 series works.
Upcoming 6.6.6 may have those additional patches:
-rw-rārā | r8152-add-rtl8152_inaccessible-checks-to-more-loops.patch | 2545 | logstatsplain |
-rw-rārā | r8152-add-rtl8152_inaccessible-to-r8153_aldps_en.patch | 1414 | logstatsplain |
-rw-rārā | r8152-add-rtl8152_inaccessible-to-r8153_pre_firmware.patch | 1397 | logstatsplain |
-rw-rārā | r8152-add-rtl8152_inaccessible-to-r8156b_wait_loadin.patch | 1378 | logstatsplain |
-rw-rārā | r8152-hold-the-rtnl_lock-for-all-of-reset.patch | 3467 | logstatsplain |
-rw-rārā | r8169-fix-rtl8125b-pause-frames-blasting-when-suspended.patch | 2889 | logstatsplain |
All kernels of 6.6 series can also been found on our github project: Releases Ā· manjaro-kernels/linux66 Ā· GitHub
I also got this errorā¦
error: tensorflow-opt-cuda: signature from "Sven-Hendrik Haase <sh@lutzhaase.com>" is invalid
:: File /var/cache/pacman/pkg/tensorflow-opt-cuda-2.15.0-4-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] ^C
Interrupt signal received
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
Are the shutdown problems with the LTS kernels >515 also on suspend/hibernate/resume actions?
postgresql seems to have been updated - the database needs upgradingā¦
I just deleted mine and recreated it.
Iām testing 6.7.0rc4-6 now and everything seems to work fine, wifi can be switched on-off over and over without freezes.
Looks like the āWifi causing hangupā problem is more generic than specific to a particular chipset:
- RTL8192EE PCIe Wireless Network Adapter - [Stable Update] 2023-12-10 - Kernels, Plasma, Phosh, Systemd, Cinnamon, Gnome, libpamac - #46 by Arrababiski
- TPLINK Archer T4U RTL8822BU - Several problems after 2023.12.10 Stable Update
- Broadcom BCM4331 (Macbook Pro) - Wifi not working and system freezes after 2032.12.10 Stable Update (MBP)
- Broadcom BCM4360 - WiFi problems after 2032.12.10 Stable Update
- and even me with MEDIATEK MT7922
But it looks like the problem is currently mitigated in 6.7 branch ⦠more tests needed.
Kernel 6.1.66-1 is also affected. Any tree that back-ported 7e7efdda6adb wifi: cfg80211: fix CQM for non-range use that does not contain 076fc8775daf wifi: cfg80211: remove wdev mutex (which does not apply cleanly to 6.6.y or 6.6.1) will be affected. Upstream solution so far: [PATCH] wifi: nl80211: fix deadlock in nl80211_set_cqm_rssi (6.6.x) ā Linux Stable Kernel Updates
If anyone other than me is using rtl-sdr dongles (quite possibly not, as theyāre fairly niche), the latest update introduces a change which seems to cause problems in some circumstances. Thereās a new group ārtlsdrā and it seems this causes problems unless a user accessing the dongles has been added to that group.
I need to do a little more testing to confirm adding the user to rtlsdr is the final fix (I have to wait until some radio timeshifting jobs release my dongles). Iāll come back with my answer in a few hours.
[Edit]: this does seem to solve the problem.
Not so. Dolphin, Gwenview, Kate etc are still at 23.08.3.
Upstream released new kernels as we speak with the offending patch reverted. I simply triggered those: [Regression] 6.1.66, 6.6.5 - wifi: cfg80211: fix CQM for non-range use
After the update my DE used a completely different icon set. Turns out the ePapirus icon theme got split into its own package and since the files for it disappeared my DE used a fallback theme.
To fix it, you can either select the papirus
icon theme, which you should still have installed and is very similar, or you can install the epapirus-icon-theme
package to get the exact icons previously in use back.
And what DE ? is with the failing the ePapirus icons?
Iād assume something similar happens regardless of the specific DE as itās about the icon theme you have selected. But to answer your question: Cinnamon.
