If the DE was Gnome, icon and other themes could no longer be compatible due to the recent update to Gnome 45, which requires new themes, addons, widgets, etc, to be 100% compatible going forward; no more gtk-3.0/gtk-4.0 themes.
Sure, a different problem could result in the same symptoms. Donāt see how thatās relevant given that Iāve already debugged it and provided the solution.
When installing or updating a new version of sudo or some packages, a problem would occur that new files are not allowed to be written to /etc/sudoers.d/, because this directory is fully read-only.
If you did, please donāt blame Arch based distros when a new update fails in the future.
Thanks Philm. Great. I am running on the 5 LTS kernel but have 2 6 LTS kernels on the machine. Going to be an updated kernel issued, a patch or?? Machine is in a production environment with a Mediatek MT 7921 wireless card. Both the 6 kernels are broken. Hanging shutdown.
Thanks
The proposed patch seems to work for at least one user. However, upstream decided to revert that offending patch with 6.6.6 and 6.1.67. You can check if the updated kernel already fixes it or wait for the upstream solution ā¦
So regarding this update, should I wait until there is a fix? Did nothing until now, reading this thread first to see potential issues people are havingā¦
@ARSManiac a fix is applied to 6.1 and 6.6 kernel series. You can install 5.15 series on your system, to be sure to have a backup kernel and do the update and test. This would help to find a solution faster.
I have Kernel 5.15 LTS and 6.1 LTS installed, thanks!
So regarding those issues a fix was already applied, thanks for the info, I will update later then!
Iāve just download and install Kernel 6.6.5-3 from āāāRelease 6.6.5-3 Ā· manjaro-kernels/linux66 Ā· GitHubāāā and seems to work fine, I can switch on and off wifi, connect to a vpn vĆa openvpn without problem, no hangs, no freezes, shutdown ok, reboot okā¦
Simply illustrating that your previous assumption was incorrect. Consider it an informational note as a courtesy, which in response to your comment, was relevant. Cheers.
