5 posts were split to a new topic: PHP segmentation fault
All stable mirrors are down ???
Update went ok, system is still working. But after the update VRR is no longer working on my monitor…
I’m using Gnome with X11 and this statement in xorg.conf
Option “VariableRefresh” “true”
I have been running it like that, for getting VRR to work. And it has worked fine up until now.
I was thinking it was a Gnome issue, and it propably shiftet over to wayland but that was not the case. Still thinking it was gnome I ran my cinnamon desktop instead (Cinnamon only uses X11 and is using it’s own compositor (muffin). But VRR still does not work.
I’m wonderring what package update broke VRR and would just like to downgrade it. I also have a system backup but would like to try something else before i pull that trigger.
I would suspekt it to be an xorg or mesa update that is the problem.
Thise where the only xorg pakages updated:
xorg-setxkbmap 1.3.3-2 1.3.4-1
xorg-xcalc 1.1.1-1 1.1.2-1
xorg-xdpyinfo 1.3.3-4 1.3.4-1
xorg-xinput 1.6.3-3 1.6.4-1
And thise the only mesa pakages:
lib32-mesa-demos 8.5.0-1 9.0.0-1
lib32-mesa-utils 8.5.0-1 9.0.0-1
My specs:
Running stable Manjaro
AMD CPU Ryzen 5 1600AF
AMD GPU RX6650XT
Driver: Mesa
Kernel: 6.3.5
Desktop Gnome and also have cinnamon.
Any solution or suggestion is highly appreciated.
I’ve opened a separate topic for this issue, as it’s very severe and messages in here seem to flood in: 2023-06-05 update broke gnome-shell
If you still have the issue, please check in in 2023-06-05 update broke gnome-shell. I’ve opened a separate topic for this issue.
I deleted the /var/temp/openrazer folder and it did a clean rebuild.
I found myself in the same position.
Disabling gpu acceleration worked as a quick workaround.
But i found another post about the same issue in the arch forum: https://bbs.archlinux.org/viewtopic.php?pid=2098015#p2098015
Doing an:
# rm -rf ~/.config/google-chrome/Default/GPUCache
fixed the problem for me. Now chrome start as usual without any graphics glitches
i’m using plasma and i noticed that the last stable update affected mouse cursor movement speed - this update restored it to what it should be, but i first had to adjust the speed in system settings (no need to enable adaptive speed)
After the update VLC and Smplayer stutter with fullscreen videos.
Same here for Xfce, Monospace Font Selection got reset to “empty”
Why didn’t the new Lutris version make it into this update? I know it landed on testing a few weeks ago.
Its kind of important because of this issue.
Although python311 has not been in the AUR for a few weeks (since Arch upgraded to python 3.11) you can still uninstall it, using you AUR helper or pacman.
You need to uninstall it before starting this system update.
Always read the wiki post at the start of these announcements, before upgrading.
AUR python311 is mentioned in [HowTo] Python upgrade: reinstall AUR and pip packages
Thank you very much, this fixed too my issue with Brave.
Best regards!!
What is the current situation with KiCad?
According to the mirrors, kicad will be updated to 7.0.3-1 but according to the manjaro packages, there is currently no such version for the stable release kicad manjaro package
KiCad 7.0.3 and 7.0.4 have also never been officially launched because they had critical bugs, which were fixed with KiCad 7.0.5.
Like most of our packages, we inherit kicad from Arch. They updated to 7.0.3 > 7.0.4 > 7.0.5. There should be a testing update before the next stable update, so both testing and stable should receive 7.0.5 next.
Got a problem with Evolution after applying this update - Evbolution doesn’t display mail content or header. Neither in preview, nor when opening a mail. Just a blank window.
Packages shows that stable has an older version of evolution. Commits · main · Arch Linux / Packaging / Packages / evolution · GitLab. so maybe that version has known bugs like yours @leftbit
Does starting evolution from the command line print out any info?
There are some folders that can be cleaned / renamed to check if there is an issue with settings or cache.
The user’s data files
$HOME/.local/share/evolution
Various configuration and state files
$HOME/.config/evolution
Account settings
$HOME/.config/evolution/sources
Disposable data caches
$HOME/.cache/evolution
I did the update few minutes ago, everything is OK, no issue at all with dkms modules nor with firefox or with AUR python based app.
Thank you! ![]()
A post was split to a new topic: Curl 8.1.0-1 is not working with github
