for future problem reports I suggest you take a quick look at
For this particular problem, I’ve seen several posts mentioning a similar problem, e.g. here
I suggest you post any follow ups in this thread. In addition to that you should search https://bugs.kde.org/ for this problem and report it there if it hasn’t already been done.
I tested it and I have the same problem too UPDATE:
It just happens when you open the dolphin recently! once it shows the information, there is no problem!
I guess it happens because the dolphin tries to calculate the space at first times and when it calculated, there is no problem. So I think this is not a bug but it is a delay which is caused by doing space calculations.
Also, keep in mind the dolphin calculates the space of the device and not folder and that’s why it takes time to show it.
you can test this suggestion by just opening dolphin and wait until you see the correct information then change the directory and you see always the correct space information.
Something went wrong during the update and after the reboot plasmashell didn’t load. I have reinstalled all packages through tty, then also checked the plasma packages (for -git version, which had happened before), reinstalled all plasma completely- still didn’t work.
I got tired of KDE instability at this point, so by the end of this update I am using XFCE. No regrets. I should’ve done this earlier as with KDE there always were some issues to solve and time to loose.
Hey there, FYI I didn’t see anyone else respond to this issue you had. I had the same issue where X was crashing, and basically I was stuck at bios splash screen like you reported, but I was able to crtl+F2 to get to a tty and found the issue. I was on Kernel 5.11 and its no longer supported, so I booted into kernel 5.10 (or any other supported kernel that you have installed for that matter) and then installed kernel 5.12, switched on next boot and that resolved my issue. Hope that helps you if you are still stuck like I was.
Thought I would like the new gnome 40 but for some reason I don’t like it that much. I really liked the previous Manjaro theme and layout with gnome 3.38. Just my honest opinion.
Using Xfce more than gnome now.
Well, I made a test. I installed Manjaro 21.0.7 and then made the last stable updates. Everything is all right. Gnome 40.3 working well, but the dash-to-dock extension (69+14+g302c693-3) version doesn’t work very well. I see in the topic that a new version is available (-5). I will make the update. If that last version will not working very well, I will go back to 69+13+ga081e41-0 version by downgrade. I remember that that version worked correctly.
I’m running gnome with an nvidia card using the proprietary driver and experience the same pink tint since this update, but only on GDM. Once I’ve logged in, the colours are fine.
Ps.: Looks like there is an ongoing issue on the gnome side:
What I did to resolve this on my side was to turn off the colour profile management in the system settings for my monitor entirely. Now everything is back to normal.
Uninstalled yaourt, updated pamac, the system automatically uninstalled package-query and all gone at its place, aside a 45 minutes of rebuilding qt4 and an another couple of programs, but the system is working fine.
Thanks for your reply, I tried this but it didn’t work, the message Error: resume: no device specified for hibernation still appears when I boot my computer.
And I diffed the /etc/default/grub file with the one I backed up before the update, there is no difference between them, so it may be caused by something other.
The gnome-shell-extension-dash-to-dock-69+14+g302c693-5 works for me. A new version is available (6), I will install it.
News: Version 6 of Dash-to-dock extension works too. Only two or three options don’t work (Opacity, Maximum size panel/dock slider). Otherwise, it is good and Gnome 40 works very well.
You have both KDE and Xfce installed? I have both, but I created another user for KDE, I usually use Xfce and I leave KDE for when I have some time to deal with it. It’s been quite a long time. Could be that the configurations in the home directory between Xfce and KDE entered in conflicts, don’t know I am right.
Try to remove Plasma caches in ~/.cache/plasmashell and ~/.cache/kwin* and restart. I had similar issue once or twice and just destroying all ~/.cache directory helped each time.
