[Stable Update] 2021-07-13 - Kernels, Plasma 5.22, Cinnamon 5, Gnome 40, LibreOffice, Mesa, Nvidia, Pamac
Hello community,
Another stable branch update with some usual updates for you.
Only one day left! Don’t miss out on Shells Laptop Giveaway to celebrate 10 years Manjaro!
  • Most of our Kernels got updated
  • Mesa is now at 21.1.4
  • With the latest Nvidia Beta Driver we have the issues with DisplayPort fixed: 470.42.01
  • KDE Framework got upded to 5.84.0
  • KDE Gear is now at 21.04.3
  • KDE Plasma got updated to 5.22.3
  • Gnome got updated to 40.3
  • Wine is now at 6.12
  • ZFS got renewed to 2.1.0
  • Pipewire got updated to 0.3.31
  • Firefox is at 89.0.2
  • We updated Cutefish to 0.3 and provide a new install medium to try it out
  • We updated Pamac to work with Pacman 6.0
  • ALSA got needed updates to work better with Pipewire
  • LibreOffice is now at 7.1.4
  • Some of our Browsers got updated
  • Cinnamon going to get updated to 5.0
  • Deepin got some new updates
  • More KDE-Git and Deepin updates
  • Other regular upstream updates including python and haskell
Get our latest daily developer images now from Github: Plasma, Gnome, XFCE. You get the latest stable releases of Manjaro from CDN77.
Our current supported kernels
  • linux44 4.4.275
  • linux49 4.9.275
  • linux414 4.14.239
  • linux419 4.19.197
  • linux54 5.4.131
  • linux510 5.10.49
  • linux512 5.12.16
  • linux513 5.13.1
  • linux514 5.14-rc1
  • linux510-rt 5.10.35_rt39
  • linux511-rt 5.11.4_rt11
Package Updates (Tue Jul 13 10:17:38 CEST 2021)
  • stable community x86_64: 2330 new and 2251 removed package(s)
  • stable core x86_64: 74 new and 73 removed package(s)
  • stable extra x86_64: 1014 new and 1123 removed package(s)
  • stable kde-unstable x86_64: 398 new and 394 removed package(s)
  • stable multilib x86_64: 42 new and 44 removed package(s)
A detailed list of all changes can be found here.
0 voters
Known issues and solutions
New issues:
  • You might be blocked updating when using pacman due to some libcanberra packages. Simply remove those packages: sudo pacman -Rdd lib32-libcanberra-pulse lib32-libcanberra-gstreamer libcanberra-pulse libcanberra-gstreamer. We recommend to use pamac anyway, which does this automatically: pamac update
  • Compiz packages like compiz-easy-patch got dropped from our repositories. Due to protobuf update you may need to rebuild that package locally on your end. Compiz-easy-patch removed from repos
Older Issues
  • OS prober does not run and add other operating systems
    Please click the ► at the beginning of this line to view this solution
    To restore, please execute: echo GRUB_DISABLE_OS_PROBER=false|sudo tee -a /etc/default/grub && sudo update-grub
    For more information, see opening post in [Stable Update] 2021-03-08.
Nvidia card owners
  • We simplified nVidia driver installation. This means we dropped legacy drivers.
    • We recommend to switch over to Nouveau drivers if your card is mentioned here and the feature you need is not in red TO DO here for your particular card.
    • If you however still need proprietary drivers, you may want to execute the following to ensure all parts of the nVidia drivers get installed properly:
      sudo mhwd -a pci nonfree 0300
      If proprietary drivers don't fix everything, please click the ► at the beginning of this line to view more info
      1. try installing kernel 5.4 LTS (Long Term Support)
      2. If that doesn’t fix it, take a full system backup, go to a console using Ctrl+Alt+F2 and:
      • Backup /etc/X11/mhwd.d/nvidia.conf if you ever edited that manually
      • remove all nVidia related drivers and applications:
        pacman --remove nvidia*
      • Note which applications are being removed and keep them handy in a list
      • Install the driver first:
        mhwd --install video-hybrid-XXX-nvidia-prime
        (Where XXX is amd or intel if you have hybrid graphics or the whole thing is video-nvidia if you’re on an nVidia-only system)
      • reboot and see if you at least get a screen.
      • Install all the other applications from your handy list that you still need one by one.
      • Restore /etc/X11/mhwd.d/nvidia.conf if you ever edited that manually
      • If that wouldn’t solve the issue open a new issue here referring to this update and posting at a minimum the full output of:
      If you however still have issues with your Nvidia card, you may open a new thread in our forum: Graphics & Display - Manjaro Linux Forum or look at our tutorial on compiling old Nvidia drivers.
For AMD GPU users having a black screen with kernel 5.10
Please click the ► at the beginning of this line to view more info
Due to a bug in the AMD drivers, please try the following first:
For GRUB:
  1. Open a terminal or a TTY
  2. Open /etc/default/grub in your favourite CLI editor (nano vi, emacs`)
  3. Find the line: GRUB_CMDLINE_LINUX_DEFAULT="
  4. Add amdgpu.dc=0
  5. Save
  6. Execute sudo update-grub and reboot
For systemd-boot:
  2. Open /boot/loader/entries/manjarolinux5.10.conf in your favourite CLI editor (nano vi, emacs`)
  3. Add amdgpu.dc=0 to the end of the line options
  4. Save & reboot
For rEFInd:
  2. Open /boot/refind_linux.conf in your favourite CLI editor (nano vi, emacs`)
  3. Find the line: "Boot using default options" "root=
  4. Add amdgpu.dc=0
  5. Save & reboot
Possible 2 Min delay on shutdown with Gnome
  • If you got the problem with shutdown delay (about 2min) on Gnome, here is a workaround:
    • Edit /usr/lib/systemd/user/gnome-session-restart-dbus.service in your favourite editor as root and add Slice=-.slice as a line all by itself like this:
      [Service]
      Type=notify
      Slice=-.slice
      ExecStart=/usr/lib/gnome-session-ctl --restart-dbus
    • Click this link For more information
Touchpad on a ThinkPad stops working
  • Restart again, please.
You get [PKGNAME] warning: directory permissions differ on [Directory name]
followed by:
Filesystem: NNN package MMM
  • The solution:
    sudo chmod MMM DirectoryName
Where obviously MMM is the second number you see (the correct one)
  • The explanation:
    Your package expects the security permissions to be MMM but your system is set to NNN. This is just a warning (today) but to ensure you remain up-to-date with the latest and greatest security rules it’s advised to execute the above command.
Systemd error message: .slice: Failed to migrate controller cgroups
If you have a similar error message like this:
systemd[1004]: -.slice: Failed to migrate controller cgroups from /user.slice/user-1000.slice/user@1000.service, ignoring: Permission denied
… you may need to add this Grub parameter to your /etc/default/grub file in line GRUB_CMDLINE_LINUX_DEFAULT: systemd.unified_cgroup_hierarchy=true. To update your grub menu, call: sudo update-grub. For more information on that issue, see also Arch Forum.
Python 3.9 Requires Rebuilds
Instructions for quickly and easily rebuilding affected AUR packages:
# Install yay
sudo pacman -S --needed --noconfirm yay
# Rebuild AUR python packages
yay -S --noconfirm $(pacman -Qqo "/usr/lib/python3.8/site-packages")
libtraceevent>=5.9-1 update requires manual intervention
2020-10-23 - Sébastien Luttringer
The libtraceevent package prior to version 5.9-1 was missing a soname link. This has been fixed in 5.9-1, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
libtraceevent: /usr/lib/libtraceevent.so.1 exists in filesystem
when updating, use
pacman -Syu --overwrite /usr/lib/libtraceevent.so.1
to perform the upgrade.
Arch Linux - News: libtraceevent>=5.9-1 update requires manual intervention
OpenVPN connection times out.
Workaround: donwgrade openvpn (2.5.0-1 => 2.4.9-2).
For a proper solution follow this bug report on Arch Linux: FS#68480 : [openvpn] running unprivileged with iproute no longer working
PAM and PAMBASE got updated, which might prevent you from login
Due to updates from pambase and pam you might take care about any .pacnew files in /etc/pam.d as for example pam_tally, pam_tally2 and pam_cracklib got deprecated. Read in the ArchWiki about managing those files.
Typical issue:
For recovery, it is enough to boot with kernel option “systemd.unit=rescue.target”, then proceed into /etc/pam.d and merge “system-auth” and “system-auth.pacnew”
System takes a long time to boot
If you’ve got errors like Failed to start Network Manager Wait Online. you can try removing systemd from passwd and group in /etc/nsswitch.conf as described here
Update: If you can see the line
dbus-daemon[1453]: [system] Connection has not authenticated soon enough, closing it (auth_timeout=30000ms, elapsed: 45146ms)
in in your dbus log ( journalctl -b -u dbus ), the new/better workaround is to switch cups from service to socket as described here:
systemctl disable cups.service
systemctl enable cups.socket
I think I’ve some font problems
With the update of fontconfig some major rules how fonts get applied changed. Make sure that your system has ttf-dejavu installed. A more in depth explanation can be found here.
Gnome-shell-extension-pop-shell is currently incompatible with wayland
… and causes the system to freeze when the first window is tiled and can render it unbootable. Solution is a hard reset and disabling either pop shell or wayland. If the system becomes unbootable, use a live USB to edit /etc/gdm/custom.conf to disable wayland and reboot.
GDM does not start (black screen when booting gnome edition)
Log into your system via tty and depending on your use of Plymouth or bootsplash-systemd choose a option from this post
@philm: I see Gnome shell 40.3 package in the stable extra repository. Does it means that Gnome 40 is now available and full supported for Manjaro Gnome (stable branch) ? If the answer is “yes”, I’m very happy. Hurray !!! :joy: :clap: :+1:
The wait was very long but you are doing very good work.
I guess in this case Manjaro 21.1 is near to be released ?
Once again, thank to the Manjaro Team and to you for your work. :wink: :+1:
Gnome user here. Everything works as expected. Great transition, everyone. Well done! Happy anniversary :heart:
Another Gnome user here (with Nvidia Graphics on Xorg). The Update itself runs smoothly without any breaks. So great job! :heart_eyes:
The Adwaita-maia theme needs some smaller updates, e.g. the corners of the background of the dock looks weird, but that’s only minor issues.
The only issue I have so far is the performance within non GTK applications. The rendering inside those applications becomes some kind of choppy and laggy, especially when scrolling. For example, the Firefox browser or any electron based app. But maybe this issue is because of the new Nvidia driver (470.42.01).
Edit: Yes, it seems Nvidia is the evil (of course they are :laughing: ): https://forum.manjaro.org/t/opengl-and-opencl-not-working-anymore-after-ugrading-to-nvidia-470-42-01/
The update went smoothly, except for the Plasma panel icons… they became much smaller. Is it a bug, or a feature? :grinning_face_with_smiling_eyes:
Take a look at the difference in Telegram icon, speaker, lock, shutdown…
EDIT: For some reason, the previous 27px height setting is shortened now for 1px (but the setting remained to display 27px, even though the real dimension is 26px now), so I fixed this by increasing the panel’s height to 28px. Now it looks fine again.
I guess this is just another typical glitch with Plasma KDE, when after each update people feel like the interface is doing some uncontrollably crazy dance moves.
Hi, this update failed for me with this warning -
installing pacman (6.0.0-1) breaks dependency ‘pacman<5.3’ required by package-query
Does anyone have a suggestions for a workaround?
KDE user here…encountering the following issues… :unamused:
:: Starte vollständige Systemaktualisierung...
:: pamac-common durch extra/libpamac ersetzen? [J/n] j
:: pamac-flatpak-plugin durch extra/libpamac-flatpak-plugin ersetzen? [J/n] j
:: pamac-snap-plugin durch extra/libpamac-snap-plugin ersetzen? [J/n] j
Löse Abhängigkeiten auf...
Suche nach in Konflikt stehenden Paketen...
Fehler: Konnte den Vorgang nicht vorbereiten (Kann Abhängigkeiten nicht erfüllen)
:: Installation von jre-openjdk (16.0.1.u9-1) verletzt Abhängigkeit 'java-runtime=15', benötigt von mediathekview
:: Installation von pacman (6.0.0-1) verletzt Abhängigkeit 'pacman<5.3', benötigt von package-query
Sorry, is all in German…
Have you tried updating with pamac?
pamac update -a
Yeah, did the job. Thanks a lot :clap: :raised_hands:
Please delete mediathekview - the support for that is a shame.
There are always problems with the Java version.
Better us Linux Installer (Sh) from this link:
https://mediathekview.de/download/
Also delete package-query, that is no longer needed
Hi NGR,
Thanks. It instructs me as follows:
Resolving dependencies…
Checking inter-conflicts…
Error: Failed to prepare transaction:
could not satisfy dependencies:
  • removing package-query breaks dependency ‘package-query>=1.9’ required by yaourt,
  • if possible, remove yaourt and retry
I’m hesitant to remove yaourt - will I be able to update AUR packages from pamac without it?
Okay, will do so. Thank you for your advice.
The command pamac update -a will also update any AUR packages you have installed.
Gnome 40 is finally available, thanks Manjaro Team! :tada:
I have encountered some problems with this update:
  • The Gnome extensions got disabled, I had to re-enable them.
  • I cannot open Dash to Dock settings, and the dock looks ugly (see below).
The Dash to Dock extension is very buggy : there is no margin below, some text overlap the dash when I open activity, the background color is not contrasted enough …
Screenshots
Text overlap and no bottom margin
Background contrast
Settings error
The settings of extension dash-to-dock@micxgx.gmail.com had an error:
Error: GSettings key preview-size-scale not found in schema org.gnome.shell.extensions.dash-to-dock
Stack trace:
_checkKey@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:563:23
createCheckedMethod/<@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:515:30
_bindSettings@/usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/prefs.js:545:81
_init@/usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/prefs.js:219:14
buildPrefsWidget@/usr/share/gnome-shell/extensions/dash-to-dock@micxgx.gmail.com/prefs.js:1013:20
_init@resource:///org/gnome/Shell/Extensions/js/extensionsService.js:209:40
OpenExtensionPrefsAsync/<@resource:///org/gnome/Shell/Extensions/js/extensionsService.js:122:28
asyncCallback@resource:///org/gnome/gjs/modules/core/overrides/Gio.js:115:22
run@resource:///org/gnome/Shell/Extensions/js/dbusService.js:177:20
main@resource:///org/gnome/Shell/Extensions/js/main.js:19:13
run@resource:///org/gnome/gjs/modules/script/package.js:206:19
start@resource:///org/gnome/gjs/modules/script/package.js:190:8
@/usr/share/gnome-shell/org.gnome.Shell.Extensions:1:17
Do you know how to solve this problem? Am I the only one to encounter it? Thank you in advance for your answers! :grinning_face_with_smiling_eyes:
EDIT (07-16-2021) : The last update of the extension (69+14+g302c693-5) from the community repo fixed the issue. Thanks for the quick fix!
KDE User here and I received a long list of conflicting files all owned by plasma-desktop-primex
- plasma-workspace: /usr/lib/qt/plugins/kcm_formats.so already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/lib/qt/plugins/kcms/kcm_autostart.so already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/lib/qt/plugins/kcms/kcm_nightcolor.so already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/lib/qt/plugins/kcms/kcm_notifications.so already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/ca/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/ca/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/ca/kcontrol/formats/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/ca/kcontrol/formats/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/ca/kcontrol/notifications/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/ca/kcontrol/notifications/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/de/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/de/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/de/kcontrol/formats/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/de/kcontrol/formats/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/en/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/en/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/en/kcontrol/formats/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/en/kcontrol/formats/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/en/kcontrol/notifications/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/en/kcontrol/notifications/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/es/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/es/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/id/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/id/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/id/kcontrol/formats/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/id/kcontrol/formats/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/it/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/it/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/it/kcontrol/formats/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/it/kcontrol/formats/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/it/kcontrol/notifications/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/it/kcontrol/notifications/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/nl/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/nl/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/nl/kcontrol/formats/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/nl/kcontrol/formats/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/nl/kcontrol/notifications/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/nl/kcontrol/notifications/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/pt/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/pt/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/pt/kcontrol/formats/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/pt/kcontrol/formats/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/pt_BR/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/pt_BR/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/pt_BR/kcontrol/formats/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/pt_BR/kcontrol/formats/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/ru/kcontrol/formats/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/ru/kcontrol/formats/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/sr/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/sr/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/sr@latin/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/sr@latin/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/sv/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/sv/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/sv/kcontrol/formats/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/sv/kcontrol/formats/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/sv/kcontrol/notifications/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/sv/kcontrol/notifications/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/uk/kcontrol/autostart/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/uk/kcontrol/autostart/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/uk/kcontrol/formats/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/uk/kcontrol/formats/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/uk/kcontrol/notifications/index.cache.bz2 already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/doc/HTML/uk/kcontrol/notifications/index.docbook already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_autostart/contents/ui/main.qml already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_autostart/metadata.desktop already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_autostart/metadata.json already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/LocationsFixedView.qml already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/NumberField.qml already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/TimeField.qml already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/TimingsView.qml already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_nightcolor/contents/ui/main.qml already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_nightcolor/metadata.desktop already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_nightcolor/metadata.json already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_notifications/contents/ui/ApplicationConfiguration.qml already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_notifications/contents/ui/PopupPositionPage.qml already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_notifications/contents/ui/ScreenPositionSelector.qml already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_notifications/contents/ui/SourcesPage.qml already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_notifications/contents/ui/main.qml already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_notifications/metadata.desktop already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kpackage/kcms/kcm_notifications/metadata.json already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kservices5/autostart.desktop already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kservices5/formats.desktop already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kservices5/kcm_nightcolor.desktop already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/kservices5/kcm_notifications.desktop already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/af/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ar/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ar/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ast/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ast/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ast/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ast/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/az/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/az/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/az/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/az/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/be/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/be@latin/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/be@latin/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/bg/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/bg/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/bn/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/bn_IN/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/bn_IN/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/br/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/bs/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/bs/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ca/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ca/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ca/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ca/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ca@valencia/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ca@valencia/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ca@valencia/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ca@valencia/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/cs/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/cs/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/cs/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/cs/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/csb/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/cy/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/da/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/da/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/da/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/da/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/de/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/de/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/de/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/de/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/el/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/el/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/en_GB/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/en_GB/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/en_GB/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/en_GB/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/eo/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/eo/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/es/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/es/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/es/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/es/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/et/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/et/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/et/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/et/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/eu/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/eu/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/eu/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/eu/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fa/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fa/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fi/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fi/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fi/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fi/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fr/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fr/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fr/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fr/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fy/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/fy/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ga/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ga/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/gl/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/gl/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/gl/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/gl/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/gu/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/gu/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/he/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/he/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hi/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hi/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hne/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hne/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hr/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hr/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hsb/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hsb/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hu/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hu/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hu/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/hu/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ia/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ia/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ia/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ia/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/id/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/id/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/id/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/id/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/is/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/is/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/it/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/it/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/it/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/it/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ja/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ja/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ja/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ja/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/kk/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/kk/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/km/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/km/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/kn/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/kn/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ko/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ko/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ko/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ko/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ku/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ku/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/lt/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/lt/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/lt/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/lt/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/lv/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/lv/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/mai/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/mai/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/mk/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/mk/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ml/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ml/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ml/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ml/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/mr/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/mr/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ms/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ms/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nb/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nb/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nds/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nds/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ne/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nl/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nl/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nl/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nl/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nn/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nn/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nn/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/nn/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/or/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/or/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pa/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pa/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pa/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pa/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pl/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pl/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pl/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pl/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pt/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pt/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pt/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pt/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pt_BR/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pt_BR/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pt_BR/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/pt_BR/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ro/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ro/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ro/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ro/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ru/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ru/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ru/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ru/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/se/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/si/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/si/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sk/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sk/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sk/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sk/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sl/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sl/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sl/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sl/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sq/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sq/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr@ijekavian/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr@ijekavian/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr@ijekavian/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr@ijekavianlatin/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr@ijekavianlatin/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr@ijekavianlatin/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr@latin/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr@latin/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sr@latin/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sv/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sv/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sv/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/sv/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/te/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/te/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/tg/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/tg/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/tg/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/th/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/th/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/tr/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/tr/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ug/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/ug/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/uk/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/uk/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/uk/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/uk/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/uz/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/uz@cyrillic/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/vi/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/vi/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/vi/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/vi/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/wa/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/wa/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/xh/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/zh_CN/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/zh_CN/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/zh_CN/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/zh_CN/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/zh_TW/LC_MESSAGES/kcm_autostart.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/zh_TW/LC_MESSAGES/kcm_nightcolor.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/zh_TW/LC_MESSAGES/kcm_notifications.mo already exists in filesystem (owned by plasma-desktop-primex)
- plasma-workspace: /usr/share/locale/zh_TW/LC_MESSAGES/kcmformats.mo already exists in filesystem (owned by plasma-desktop-primex)
I’m using Manjaro Gnome. The upate transaction using pamac suggests removing pacman-cli:
    - removing pamac-common breaks dependency 'pamac-      common=10.0.6-2' required by pamac-cli,
- if possible, remove pamac-cli and retry
But then, when removing pacman-cli, a number of other important things
get removed:
To remove (8):
  pamac-flatpak-plugin                  10.0.6-2  (Depends On: pamac-cli)
  gnome-shell-extension-manjaro-update  7-2       (Depends On: pamac-cli)
  software-center-web-jak               1.0.2-1   (Depends On: pamac-cli)  community
  manjaro-hello                         0.6.6-5   (Depends On: pamac-cli)  extra
  web-installer-url-handler             1.0.2-1   (Depends On: pamac-cli)  community
  pamac-gtk                             10.0.6-2  (Depends On: pamac-cli)  extra
  yaourt                                1.9-2
  pamac-cli                             10.0.6-2                           extra
That does not look desirable. How should I proceed here?
Another successful enormous stable update on 2 completely different platforms. 0 issues so far.
Updated with
sudo pacman-mirrors --fasttrack
sudo pacman -Syyu
  1. Gaming configuration
    SOFTWARE: Manjaro from LXQt minimal .iso, Manjaro’s build of Linux 5.13
    HARDWARE: Ryzen 1500X, RX 580 (Mesa)
  2. Work configuration
    SOFTWARE: Custom Manjaro Architect with spectrwm + personal dotfiles, Manjaro’s build of Linux-nvidia 5.10
    HARDWARE: Thinkpad T590, Intel iGPU + Nvidia MX250
Dash to Dock is not supporting Gnome 40 yet. You could try to install https://aur.archlinux.org/packages/gnome-shell-extension-dash-to-dock-gnome40-git
@remark: Or use the default dock from Gnome 40 (if he wants a dock who really works).
