I updated my system then rebooted and got the following message on screen:-
Warning: /lib/modules/5.10.2-2-MANJARO/modules.devname not found - ignoring
mount: /new_root: unknown filesystem type ‘ext4’.
You are now being dropped into an emergency shell.
sh: can’t access tty; job control turned off
[rootfs ]#
My keyboard and mouse don’t work when this message is displayed.
Do you still have another kernel version installed?
Enter grub menu by press and hold ESC key.
In grub, go to advanced options (not sure how exactly it is called) and try the fallback image or another kernel version if installed.
If you get into your system again, reinstall the kernel:
sudo pacman -S linux510
If not, you will need to chroot into you install. Follow @stephane’s link for instructions.
Thanks Taylor. I didn’t have a Timeshift backup but uninstalling the Nvidia drivers and mhwd allowed me to boot Manjaro up again. I have installed kernel 5.10 and the package linux510-nvidia however 455 driver is not listed for install in Manjaro Settings Manager.
I don’t want have troubles, when I do a complete update.
On my other System with nVidia I can not use xbacklight anymore, and the Update made some strange changes which I don’t understand. I don’t understand how I can solve my nVidia Problems.
What means
Kann Abhängigkeiten nicht erfüllen:
das Entfernen von mhwd-db verletzt Abhängigkeit von ‘mhwd-db’ benötigt von mhwd,
wenn möglich, entferne mhwd und versuche es erneut
Also if I ignore all needed updates and want only update FF, this message appear.
What have FF to do with mhwd? confused
There are a lot packages with “mhwd” installed. Or does it mean, that I only have to uninstall the package mhwd-db 0.6.5-4? And otherwise the update ist not running fine?
I’ve got installed nvidia-utils and linux510-nvidia and nothing else. Still I can’t manage to install any nvidia drivers with mhwd -a pci nonfree 0300 or listed in Manjaro Hardware Configuration.
Thanks for the update.
Xfce with RX 5500 XT and amdgpu driver here.
After the new update I had a black screen freeze when I started my pc the next day. Switching kernel with the bootloader from 5.10 to 5.9 fixed it for me.
BUT I thought I follow the solution where you have to edit grub and put the amdgpu.dc=0 line in so I could use 5.10 again. I used the nano editor for it as discribed. I did “sudo update-grub” and rebooted.
But then I couldn’t get to the terminal or tty because of a freeze with graphical glitches before login screen.
I had to boot to the console to edit the grub file with nano again. For that I googled about how to boot to console/tty by editing the kernel parameters from the grub menu (I’m not allowed to include a link obviously) and followed the instructions from the first google suggestion. Then I did “sudo nano /etc/default/grub” and removed amdgpu.dc=0 again. That didn’t fixed it even for 5.9. Still freeze with all 3 available kernels in the grub menu. But strangely removing “quiet” and amdgpu.dc=0" fixed it all.
Finally for me the solution was booting from grub directly to the console/tty, then “sudo nano /etc/default/grub” then removing “quiet” and “amdgpu.dc=0” from the GRUB_CMDLINE_LINUX_DEFAULT= line and then “sudo update-grub”, reboot. Some weird log info…restart again.
Now it’s all good and working with kernel 5.10.
I hope this helps anyone with a similar problem because it drove me crazy
I have DELL (Intel + nVidia Quadro NVS 135M). Installed the 340xx driver (dkms 5.4) according to the manual in the forum header. Everything works fine. Thanks philm. Great activity for the New Year. If not for this activity, I would have had to drink a lot of vodka))
Is anyone else seeing a huge spike in power usage? I have a ThinkPad X1E. My idle power draw was around 5W, now it’s 25W when CPU is idle. I upgraded to the latest Nvidia 455 drivers, but running on intel graphics through optimus-manager.
