having the same issue. system spontaniously freezes (nno reaction to anything), only hardware reset helps.
firefox is crashes while browsing on youtube.
did you find a solution?
When I boot it goes into a black screen after grub, but after a couple of minutes it goes to the desktop. Then the desktop freezes and the solution is to press ctrl+alt+F2 and then ctrl+alt+F1 to return to the desktop and from now on everything seems to run fine. I have an nvidia gtx970 and I installed the nvidia drivers with
sudo mhwd -a pci nonfree 0300
Also, the compositor seems to crash kwin
OpenGL compositing (the default) has crashed KWin in the past.
This was most likely due to a driver bug.
If you think that you have meanwhile upgraded to a stable driver,
you can reset this protection but be aware that this might result in an immediate crash!
Alternatively, you might want to use the XRender backend instead.
I had problems in the past in the newer kernel when fullscreen video from firefox would saw black and turning on and off the compositor by shift+alt+F12 would do the trick. Then I found that an option on desktop effects could solve it, the fullscreen option. So, something was not working right with nvidia drivers and the newer kernels.
My system,
cpu: intel i7-3770K, gpu: nvidia GTX970
Can confirm is happen to me as well,it has been reported,i think the new patch is coming January 9th.
https://bugs.kde.org/show_bug.cgi?id=430374
Remove pipewire-pulse
pipewire-alsa, pipewire-pulse, and pipewire-jack are normally not needed unless one wants to use PipeWire as a PulseAudio/JACK replacement.
hi @philm I found a small bug in one of the recommended commands:
right after --install
has to be either pci
or usb
, in this case it should be pci
. the command was giving an error but in the usage it stated (pci|usb) so I figured it out.
Thanks for you help, was able to fix my system.
the solutions are two:
1- use kernel 5.4 with free drivers
2- Thanks to the explanation that I quote below (using the option to do it by terminal, because using the AUR option in pamac it throws an error and does not finish installing it) I could install the proprietary driver 340 in kernel 5.4 and 5.10 and for now no longer I suffer from slowdowns or frozen.
With the Stable-Update on the 2020-12-30 we decided to Remove outdated Nvidia Drivers. This resulted in a massive negative feedback and broken systems.
Nvidia informed about their support timeframes a while ago. 390xx will be supported through the end of 2022. However they are slow in providing needed patches. The Linux community patched them so far. 340xx got dropped already. Officially they only support till Kernel 5.4 and Xorg-Server 1.20 series. In AUR you may find patches till 5.10 .
NVIDIA Developer Forums – 4 Mar 13
Current graphics driver releases
Current releases Current long-lived branch release: 450.80.02 (x86_64) Current official release: 455.45.01 (x86_64) Current beta release: 460.27.04 (x86_64) Legacy releases 390.138 (x86 / x86_64 / ARM) - GF1xx “Fermi” GPUs 340.108 (x86 /…
Reading time: 1 mins Likes: 1
Manjaro is known for its large range of Kernel support and is also known for multiple Nvidia drivers support. However it is harder to support those old drivers, due to GPL issues and other things. So we had to drop some modules of 390xx drivers until Nvidia will fix that.
So what can I do as user to still get those drivers still on Manjaro?
Get involved
You can compile the drivers on your own. Best would be to use DKMS, so when there is a kernel update, those drivers get updated also.
Prepare your system for building drivers
- you may want to install development tools:
sudo pacman -S git base-devel
- then you may want to install your proper kernel headers:
sudo pacman -S $(mhwd-kernel -li | grep '*' | cut -d ' ' -f5 | awk '{print $0,"-headers"}' | sed s'/ //'g)
340xx (dkms 5.4 - 5.10)
You need to get the sources first:
git clone https://gitlab.manjaro.org/packages/extra/nvidia-340xx-utils.git git clone https://gitlab.manjaro.org/packages/multilib/lib32-nvidia-340xx-utils.git git clone https://github.com/philmmanjaro/nvidia-340xx-dkms.git
Then compile all packages with makepkg :
cd nvidia-340xx-utils && makepkg -si cd ../lib32-nvidia-340xx-utils && makepkg -si cd ../nvidia-340xx-dkms && makepkg -si
With this you will have 340xx driver, even Manjaro officially dropped it.
340xx (dkms 4.4 - 4.19)
Since the dkms only works from 5.4 upwards, you may need to compile your kernel drivers manually. utils are still needed! Replace YY either with
44
,49
,414
or419
:git clone https://gitlab.manjaro.org/packages/extra/linuxYY-extramodules/nvidia-340xx cd nvidia-340xx && makepkg -sif
You may need to recompile this package as soon as we add a new kernel and also don’t forget to bump the PKGREL.
Other 4YYxx drivers (example for linux54)
Note: You need to replace
4YY
with one of the followings:418
,430
,435
,440
,450
. linux54 can be replaced as needed. If you don’t find the driver for your kernel, you can ping us.You need to get the sources first
git clone https://gitlab.manjaro.org/packages/extra/nvidia-4YYxx-utils.git git clone https://gitlab.manjaro.org/packages/multilib/lib32-nvidia-4YYxx-utils.git git clone https://gitlab.manjaro.org/packages/extra/linux54-extramodules/nvidia-4YYxx.git
I used Pamac to remove the nvidia drivers. Left mhwd alone. Installed 5.10. Rebooted, went into TTY to sudo mhwd -a pci nonfree 0300.
Worked.
Update went smooth, but after reboot the graphics are messed up (i3 community edition). After switching resolution to lower and then back to high resolution using xrandr/arandr it works again. My system’s graphics are:
Graphics: Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
Device-2: Chicony HP HD Camera type: USB driver: uvcvideo bus ID: 1-6:3
Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting resolution: 1366x768~60Hz
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.1 direct render: Yes
But next reboot messes up again. Any idea, how this could be fixed without switching resolution?
any reason why with this update the grub
conflicts with grub-customizer
See here:
Someone added grub-customizer to conflics in grub package. Is there any reason to it?
Well, it went pretty well, given my config it’s pretty normal (5.4 LTS kernel , Xfce, Intel processor and Intel graphic chipset). I still had to hack a little to get Ninja-IDE to work (AUR (en) - Accounts & Python 3.9 break ninja-ide · Issue #2112 · ninja-ide/ninja-ide · GitHub) and reinstall all my Python user modules. Only pyarrow (essential for the covidify module) is a problem for me (pyarrow wheel for python 3.9 · Issue #9081 · apache/arrow · GitHub). I have to wait for a wheel to be available for Python 3.9.
Hi, I saw the notification from the homepage, I seem to be affected. can I ask If I’ll have an issue after updating, I’m kinda Noob, still just learning. What must I do before updating?
perl: warning: Setting locale failed. perl: warning: Please check that your locale settings: LANGUAGE = "", LC_ALL = (unset), LC_MONETARY = "en_US.UTF-8", LC_MEASUREMENT = "en_SG.UTF-8", LC_TIME = "en_US.UTF-8", LC_NUMERIC = "en_GB.UTF-8", LANG = "en_GB.UTF-8" are supported and installed on your system. perl: warning: Falling back to a fallback locale ("en_GB.UTF-8"). System: Host: Lair Kernel: 5.4.80-2-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.20.4 Distro: Manjaro Linux Machine: Type: Laptop System: Dell product: Inspiron 5558 v: N/A serial: <superuser/root required> Mobo: Dell model: 0TYKPW v: A00 serial: <superuser/root required> UEFI: Dell v: A17 date: 05/14/2019 CPU: Info: Dual Core Intel Core i5-5200U [MT MCP] speed: 1685 MHz min/max: 500/2700 MHz Graphics: Device-1: Intel HD Graphics 5500 driver: i915 v: kernel Device-2: NVIDIA GK208BM [GeForce 920M] driver: N/A Device-3: Suyin Integrated_Webcam_HD type: USB driver: uvcvideo Display: x11 server: X.Org 1.20.10 driver: intel resolution: 1920x1080~60Hz OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 20.2.3 Network: Device-1: Intel Wireless 3160 driver: iwlwifi Device-2: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169 Drives: Local Storage: total: 1.20 TiB used: 688.13 GiB (56.0%) Info: Processes: 191 Uptime: 1h 16m Memory: 7.69 GiB used: 3.09 GiB (40.1%) Shell: Bash inxi: 3.1.08
It worked (i had no doubt); i installed the rebuild-checker, and performed the system update with the italian mirrors, that are, for some for me unknwon reasons, a lot faster than the -f 3 argument (2-3 mbits against 200-300 kbits); thanks a lot Wollie.
This particular update gave me issues with audio popping/clicking noise when any program started or stopped using my sound card (Intel 7 Series/C216 Family High Definition Audio)… quite annoying with headphones. The “solution” I found was to disable power saving for the snd_hda_intel module, but I’m not too happy about having to do that. It was working fine for almost 2 years, and I haven’t modified my audio settings in those 2 years, so I’m not sure what’s going on.
package grub-customizer is not compatible with this update:
:: grub and grub-customizer are in conflict. Remove grub-customizer? [y/N]
@LS650V, have a look into this thread, it explains, why.
Did we not already establish this is a symptom of grub-customizer ?
To be fair I dont know for sure … but from my view the correlation seems strong …
(and yes … now that you have used it … your grub is basically ‘broken’ and you have to ‘undo’ GC)
Hi. I gave a second chance to manjaro. After clean installing OS I’m still struggling with the same problem. On first boot after installing whole OS i see in mhwd GUI that there is a 455 version of drivers are available to install. I am such a user that before using system I let the system update itself. That’s what I did, and unfortunately for me in mhwd GUI I lost all NVIDIA driver versions except 390 available to install. I have a GTX 650 Ti Super GPU and according to the NVIDIA website, for the latest released driver (455) my card is supported.
How to fix that to install latest NVIDIA driver 455 via mhwd?
Kernel: 5.10.2-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=c79209d9-8416-47b1-a8a9-472b737df337 rw quiet apparmor=1
security=apparmor resume=UUID=d358d149-6ed5-41f5-b20d-7683346173ac
udev.log_priority=3
Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: MSI model: Z270 PC MATE (MS-7A72) v: 1.0
serial: <filter> UEFI: American Megatrends v: 1.A0 date: 07/04/2018
Info: Dual Core model: Intel Pentium G4560 bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
L2 cache: 3 MiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28009
Speed: 800 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Type: l1tf
Device-1: NVIDIA GK106 [GeForce GTX 650 Ti] vendor: Micro-Star MSI
driver: nouveau v: kernel bus ID: 01:00.0 chip ID: 10de:11c6
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 2880x900 s-dpi: 96 s-size: 762x238mm (30.0x9.4")
s-diag: 798mm (31.4")
Monitor-1: DVI-I-1 res: 1440x900 hz: 60 dpi: 89 size: 410x257mm (16.1x10.1")
diag: 484mm (19.1")
Monitor-2: DVI-D-1 res: 1440x900 hz: 60 dpi: 90 size: 408x255mm (16.1x10.0")
diag: 481mm (18.9")
OpenGL: renderer: NVE6 v: 4.3 Mesa 20.3.1 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a2f0
Device-2: NVIDIA GK106 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0e0b
Sound Server: ALSA v: k5.10.2-2-MANJARO
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: f000 bus ID: 00:1f.6 chip ID: 8086:15b8
IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 698.65 GiB used: 9.85 GiB (1.4%)
model: SSD 970 EVO Plus 250GB size: 232.89 GiB block size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXM7
temp: 33.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500DM002-1BD142
size: 465.76 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: KC44
ID-1: / raw size: 223.79 GiB size: 219.28 GiB (97.98%) used: 9.85 GiB (4.5%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 27.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1080
Processes: 189 Uptime: 45m wakeups: 0 Memory: 7.73 GiB
used: 2.15 GiB (27.8%) Init: systemd v: 247 Compilers: gcc: N/A Packages:
pacman: 1273 lib: 381 flatpak: 0 Shell: Bash v: 5.1.0 running in: konsole
inxi: 3.2.01
/var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-prime/MHWDCONFIG.old
/var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG.old
/var/lib/mhwd/db/pci/graphic_drivers/hybrid-amd-nvidia-prime/MHWDCONFIG.old
/var/lib/mhwd/ids/pci/nvidia.ids.old
> All PCI configs:
NAME VERSION FREEDRIVER TYPE
video-virtualmachine 2020.03.26 true PCI
video-sisusb 2020.01.18 true PCI
video-nvidia-390xx 2020.11.30 false PCI
video-s3 2020.01.18 true PCI
video-vesa 2017.03.12 true PCI
video-voodoo 2017.03.12 true PCI
video-hybrid-intel-nvidia-390xx-bumblebee 2020.11.30 false PCI
video-modesetting 2020.01.13 true PCI
video-openchrome 2020.01.18 true PCI
video-rendition 2020.01.18 true PCI
network-rt3562sta 2013.12.07 true PCI
network-slmodem 2013.12.07 true PCI
network-r8168 2016.04.20 true PCI
network-broadcom-wl 2018.10.07 true PCI
Warning: No USB configs found!
dont care about fisrt post , so you dont read
