Installed
rebuild-detectoras recommend in the announcement:[2020-12-31T09:50:27+0300] [PACMAN] Running 'pacman -S rebuild-detector' [2020-12-31T09:51:01+0300] [ALPM] transaction started [2020-12-31T09:51:01+0300] [ALPM] upgraded archlinux-keyring (20201028-1 -> 20201210-1) .... [2020-12-31T09:51:04+0300] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2021-08-02 [2020-12-31T09:51:04+0300] [ALPM] upgraded manjaro-system (20201014-1 -> 20201211-1) [2020-12-31T09:51:04+0300] [ALPM-SCRIPTLET] ==> Maintaining video driver nvidia-455xx [2020-12-31T09:51:04+0300] [ALPM-SCRIPTLET] rm: cannot remove '/var/lib/mhwd/local/pci/video-nvidia-450xx/': No such file or directory [2020-12-31T09:51:04+0300] [ALPM-SCRIPTLET] cp: cannot stat '/var/lib/mhwd/db/pci/graphic_drivers/nvidia': No such file or directory [2020-12-31T09:51:05+0300] [ALPM] transaction completed [2020-12-31T09:51:05+0300] [ALPM] running '30-systemd-update.hook'... [2020-12-31T09:52:08+0300] [ALPM] transaction started [2020-12-31T09:52:08+0300] [ALPM] installed parallel (20200322-1) [2020-12-31T09:52:08+0300] [ALPM] installed pacutils (0.10.0-1) [2020-12-31T09:52:08+0300] [ALPM] installed rebuild-detector (4.1.5-1) [2020-12-31T09:52:08+0300] [ALPM] transaction completed -
Updated system with pamac CLI, and noticed these pacman logs:
[2020-12-31T10:19:52+0300] [ALPM] removed lib32-nvidia-455xx-utils (455.45.01-1) [2020-12-31T10:19:52+0300] [ALPM-SCRIPTLET] xorg configuration symlink valid... [2020-12-31T10:19:52+0300] [ALPM] removed mhwd-nvidia-455xx (455.45.01-1) [2020-12-31T10:19:52+0300] [ALPM] removed mhwd-nvidia-450xx (450.80.02-1) [2020-12-31T10:19:52+0300] [ALPM] removed mhwd-nvidia-440xx (440.100-1) [2020-12-31T10:19:52+0300] [ALPM] removed mhwd-nvidia-435xx (435.21-1.0) [2020-12-31T10:19:52+0300] [ALPM] removed mhwd-nvidia-430xx (430.64-1.0) [2020-12-31T10:19:52+0300] [ALPM] removed mhwd-nvidia-418xx (418.113-1)Seemed ok so far…
[2020-12-31T10:19:55+0300] [ALPM] warning: /etc/systemd/homed.conf installed as /etc/systemd/homed.conf.pacnewI never touched that file yet…
[2020-12-31T10:20:03+0300] [ALPM] upgraded mhwd-nvidia-390xx (390.132-1 -> 390.138-1) [2020-12-31T10:20:03+0300] [ALPM] installed mhwd-nvidia (455.45.01-3) [2020-12-31T10:20:03+0300] [ALPM] upgraded mhwd-db (0.6.5-4 -> 0.6.5-7) .... [2020-12-31T10:20:03+0300] [ALPM] installed lib32-nvidia-utils (455.45.01-3) [2020-12-31T10:20:03+0300] [ALPM-SCRIPTLET] xorg configuration symlink valid...Seems lib32-nvidia-utils (455.45.01-3) got installed again…
[2020-12-31T10:20:09+0300] [ALPM] upgraded linux59 (5.9.11-3 -> 5.9.16-1) [2020-12-31T10:20:09+0300] [ALPM-SCRIPTLET] >>> NOTE, 5.9.16 was the last maintenance release by Greg Kroah-Hartman. [2020-12-31T10:20:09+0300] [ALPM-SCRIPTLET] This kernel series is now marked EOL (end of life). [2020-12-31T10:20:09+0300] [ALPM-SCRIPTLET] [2020-12-31T10:20:09+0300] [ALPM-SCRIPTLET] It is recommend to move on to linux510 series. [2020-12-31T10:20:09+0300] [ALPM-SCRIPTLET] Use followed cmd to do that: 'sudo mhwd-kernel -i linux510'We get an heads-up to upgrade to the 5.10 kernel, okay we will…
[2020-12-31T10:20:19+0300] [ALPM] warning: /root/.zshrc installed as /root/.zshrc.pacnewWhy did this happen
(ohh well lets ignore i guess?)
Must be a DNS issue?[2020-12-31T10:20:21+0300] [ALPM] upgraded pamac-flatpak-plugin (10.0.3-1 → 10.0.3-4)
[2020-12-31T10:20:22+0300] [ALPM-SCRIPTLET] error: Can’t load uri https://flathub.org/repo/flathub.flatpakrepo: Error resolving “flathub.org”: Name or service not known
(Although i reported about this before on the git…) -
Lets install the new kernel as instructed:
sudo mhwd-kernel -i linux510.... Packages (3) linux510-5.10.2-2 linux510-broadcom-wl-6.30.223.271-9 linux510-headers-5.10.2-2 .... Optional dependencies for linux510 crda: to set the correct wireless channels of your country [installed] .... ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'default' -> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img ==> Starting build: 5.10.2-2-MANJARO -> Running build hook: [base] -> Running build hook: [systemd] -> Running build hook: [autodetect] -> Running build hook: [modconf] -> Running build hook: [block] -> Running build hook: [keyboard] -> Running build hook: [keymap] -> Running build hook: [sd-encrypt] -> Running build hook: [sd-lvm2] -> Running build hook: [filesystems] -> Running build hook: [bootsplash-manjaro] -> Running build hook: [fsck] ==> ERROR: module not found: `nvidia' ==> ERROR: module not found: `nvidia_modeset' ==> ERROR: module not found: `nvidia_uvm' ==> ERROR: module not found: `nvidia_drm' ==> Generating module dependencies ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img ==> WARNING: errors were encountered during the build. The image may not be complete.
Seems we won’t be able to boot with this kernel yet !
Problem with nVidia drivers:
- Reading Drivers removed - #9 by Aragorn,
Had to manually removenvidia-455xx-utilsbecause the nvidia drivers will now be provided bynvidia-utilsright?- pamac remove nvidia-455xx-utils
- Next running
mhwdshowed:> mhwd [1] Warning: config '/var/lib/mhwd/local/pci/video-nvidia-455xx/MHWDCONFIG' is invalid! > 0000:01:00.0 (0300:10de:1b06) Display controller nVidia Corporation: .... - So had to manually remove that also:
- sudo rm -R /var/lib/mhwd/local/pci/video-nvidia-455xx
- Next used the Auto Install Proprietary Driver option/button in the “Hardware Configuration” GUI from “Manjaro Settings Manager”
Click to see output of it in it's the window
Starting
> Using config 'video-nvidia' for device: 0000:01:00.0 (0300:10de:1b06) Display controller nVidia Corporation GP102 [GeForce GTX 1080 Ti]
> Installing video-nvidia...
Using default
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
core is up to date
extra is up to date
community is up to date
multilib is up to date
resolving dependencies...
Packages (4) lib32-nvidia-utils-455.45.01-3 linux510-nvidia-455.45.01-8 linux59-nvidia-455.45.01-6 nvidia-utils-455.45.01-2
Total Download Size: 152.72 MiB
Total Installed Size: 473.51 MiB
:: Retrieving packages...
downloading nvidia-utils-455.45.01-2-x86_64.pkg.tar.zst...
downloading linux510-nvidia-455.45.01-8-x86_64.pkg.tar.zst...
downloading linux59-nvidia-455.45.01-6-x86_64.pkg.tar.zst...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing nvidia-utils...
==> If you run into trouble with CUDA not being available, run nvidia-modprobe first.
Optional dependencies for nvidia-utils
gtk3: nvidia-settings [installed]
xorg-server-devel: nvidia-xconfig
opencl-nvidia: OpenCL support
installing lib32-nvidia-utils...
Optional dependencies for lib32-nvidia-utils
lib32-opencl-nvidia
installing linux510-nvidia...
In order to use nvidia module, reboot the system.
installing linux59-nvidia...
(1/6) Creating system user accounts...
(2/6) Reloading system manager configuration...
(3/6) Arming ConditionNeedsUpdate...
(4/6) Updating module dependencies...
(5/6) Updating Kernel initcpios for Nvidia-DRM...
==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: 'fallback'
-> -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
-> Running bu
ild hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'default'
-> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
==> Starting build: 5.9.16-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: 'fallback'
-> -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
(6/6) Updating the desktop file MIME type cache...
nvidia-utils: install reason has been set to 'explicitly installed'
lib32-nvidia-utils: install reason has been set to 'explicitly installed'
linux510-nvidia: install reason has been set to 'explicitly installed'
linux59-nvidia: install reason has been set to 'explicitly installed'
xorg configuration file: '/etc/X11/mhwd.d/nvidia.conf'
> Successfully installed video-nvidia
Done ...
So seems to have successfully installed…
(will need to test with a reboot in few)
But i noticed it reverted my current x-config selection back to the default:
> mhwd-gpu
:: status
Which i had changed to a custom version in different file, so need to modify that later after this first reboot with new kernel…
As can be seen it still generates an
[HowTo] Boot without a password for encrypted root partition
. I am using systemd-boot. I have heard that there are some issues after updating a kernel if using sd-boot and that some additional manual steps are required. I’m not sure whether or not this is accurate? I just wanted to know what I need to do before upgrading from 5.9 to 5.10. Is it as simple as following this guide?
