Hey guys so my girlfriend got a ROG STRIX G15 but shes wanted Manjaro so I installed Manjaro Gnome. The first issue I released that happened was there was no sound unless I plugged headphones in so I found this
Edit /etc/modprobe.d/alsa-base.conf and put options snd-hda-intel model=asus-zenbook in the empty conf file
And that now the speakers work but the next issue is now the audio doesn’t switch to headphones when they are plugged in the headphone jack, would I be able to get some help fixing that please?
Here is all the hardware info
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=eee24559-754f-4198-b806-524388322468 rw quiet splash apparmor=1
security=apparmor resume=UUID=b0c8f261-4972-4096-8537-d8102b788db7
udev.log_priority=3
Desktop: GNOME v: 42.3.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM
v: 42.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: ROG Strix G512LU_G512LU v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G512LU v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: G512LU.310 date: 07/13/2020
ID-1: BAT0 charge: 42.9 Wh (66.2%) condition: 64.8/66.0 Wh (98.1%)
volts: 15.7 min: 15.7 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 1
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165)
stepping: 2 microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 997 high: 1000 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 975 2: 1000 3: 1000
4: 1000 5: 1000 6: 1000 7: 1000 8: 1000 9: 1000 10: 1000 11: 1000 12: 1000
bogomips: 62431
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: ASUSTeK driver: i915
v: kernel arch: Gen9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile] vendor: ASUSTeK
driver: nvidia v: 515.57 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Turing process: TSMC 12nm
built: 2018-22 pcie: gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2191 class-ID: 0300
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa gpu: i915 display-ID: :1 screens: 1
Screen-1: 0 s-res: 1920x1080 s-size: <missing: xdpyinfo>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1521 built: 2020 res: 1920x1080
hz: 144 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.3
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU116 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:1aeb class-ID: 0403
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno2 state: down mac: <filter>
bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 104.82 GiB (22.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8
lanes: 4 type: SSD serial: <filter> rev: 002C temp: 30.9 C scheme: GPT
ID-1: / raw-size: 459.68 GiB size: 451.4 GiB (98.20%)
used: 104.82 GiB (23.2%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16.96 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 40.0 C pch: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 315 Uptime: 30m wakeups: 1 Memory: 15.42 GiB
used: 2.88 GiB (18.7%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: 1253
pacman: 1246 lib: 338 flatpak: 7 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.19
also could these patches be put into Manjaro so it’s a more out of the box experience for users?
Thank you guys for all the help you have done with all my posts.
