Audio doesn't work in internal speaker but it works on Headphones
Hey there, I just installed Manjaro for first time on my Asus Rog Laptop.
The Sound it’s not working from Internal Speakers only on Headphones or Bluethooth.
Please help.
Output of inxi -Fza:
  Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=dd557d72-d1fb-4e4c-abe6-f157663c842a rw quiet splash apparmor=1
  Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 40.0
  Type: Laptop System: ASUSTeK product: ROG Strix G712LV_G712LV v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: G712LV v: 1.0 serial: <filter>
  UEFI: American Megatrends v: G712LV.311 date: 01/08/2021
  ID-1: BAT0 charge: 36.4 Wh (63.6%) condition: 57.2/66.0 Wh (86.7%)
  volts: 15.7 min: 15.7 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
  status: Discharging cycles: 51
  Info: 8-Core model: Intel Core i7-10875H bits: 64 type: MT MCP
  arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: E0
  cache: L2: 16 MiB
  bogomips: 73598
  Speed: 900 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 900 2: 900
  3: 900 4: 900 5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900
  13: 900 14: 900 15: 900 16: 900
  Device-1: Intel UHD Graphics vendor: ASUSTeK driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: ASUSTeK
  driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f15 class-ID: 0300
  Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
  loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.2
  direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  chip-ID: 8086:06c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.25 running: no
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  port: 5000 bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
  IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
  chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 953.87 GiB used: 13.05 GiB (1.4%)
  model: PC SN530 SDBPNPZ-1T00-1002 size: 953.87 GiB block-size:
  physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
  serial: <filter> rev: 21106000 temp: 25.9 C scheme: GPT
  ID-1: / raw-size: 300.78 GiB size: 294.99 GiB (98.08%)
  used: 13.02 GiB (4.4%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
  used: 25.2 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 43.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2600
  Processes: 339 Uptime: 38m wakeups: 4 Memory: 15.42 GiB
  used: 3.05 GiB (19.8%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: 10.2.0 Packages: pacman: 1207 lib: 318 flatpak: 0 Shell: Zsh v: 5.8
  running-in: gnome-terminal inxi: 3.3.04
Output of sudo journalctl -b0 :
Apr 24 18:03:56 manjaromachine kernel: microcode: microcode updated early to re>
Apr 24 18:03:56 manjaromachine kernel: Linux version 5.10.30-1-MANJARO (buildus>
Apr 24 18:03:56 manjaromachine kernel: Command line: BOOT_IMAGE=/boot/vmlinuz-5>
Apr 24 18:03:56 manjaromachine kernel: x86/fpu: Supporting XSAVE feature 0x001:>
Apr 24 18:03:56 manjaromachine kernel: x86/fpu: Supporting XSAVE feature 0x002:>
Apr 24 18:03:56 manjaromachine kernel: x86/fpu: Supporting XSAVE feature 0x004:>
Apr 24 18:03:56 manjaromachine kernel: x86/fpu: Supporting XSAVE feature 0x008:>
Apr 24 18:03:56 manjaromachine kernel: x86/fpu: Supporting XSAVE feature 0x010:>
Apr 24 18:03:56 manjaromachine kernel: x86/fpu: Supporting XSAVE feature 0x200:>
Apr 24 18:03:56 manjaromachine kernel: x86/fpu: xstate_offset[2]:  576, xstate_>
Apr 24 18:03:56 manjaromachine kernel: x86/fpu: xstate_offset[3]:  832, xstate_>
Apr 24 18:03:56 manjaromachine kernel: x86/fpu: xstate_offset[4]:  896, xstate_>
Apr 24 18:03:56 manjaromachine kernel: x86/fpu: xstate_offset[9]:  960, xstate_>
Apr 24 18:03:56 manjaromachine kernel: x86/fpu: Enabled xstate features 0x21f, >
Apr 24 18:03:56 manjaromachine kernel: BIOS-provided physical RAM map:
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x0000000000000000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x000000000009e000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x000000000009f000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x00000000000a0000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x0000000000100000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x00000000940a1000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x0000000098002000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x0000000098132000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x0000000098387000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x0000000098a94000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x0000000098d4e000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x0000000098d4f000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x00000000e0000000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x00000000fe000000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x00000000fec00000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x00000000fed00000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x00000000fee00000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x00000000ff000000-0x000>
Apr 24 18:03:56 manjaromachine kernel: BIOS-e820: [mem 0x0000000100000000-0x000>
Apr 24 18:03:56 manjaromachine kernel: NX (Execute Disable) protection: active
Apr 24 18:03:56 manjaromachine kernel: efi: EFI v2.70 by American Megatrends
Apr 24 18:03:56 manjaromachine kernel: efi: ACPI=0x98131000 ACPI 2.0=0x98131014>
Apr 24 18:03:56 manjaromachine kernel: SMBIOS 3.2.0 present.
Apr 24 18:03:56 manjaromachine kernel: DMI: ASUSTeK COMPUTER INC. ROG Strix G71>
Apr 24 18:03:56 manjaromachine kernel: tsc: Detected 2300.000 MHz processor
Apr 24 18:03:56 manjaromachine kernel: tsc: Detected 2299.968 MHz TSC
Apr 24 18:03:56 manjaromachine kernel: [Firmware Bug]: TSC ADJUST: CPU0: -53101>
Apr 24 18:03:56 manjaromachine kernel: e820: update [mem 0x00000000-0x00000fff]>
Apr 24 18:03:56 manjaromachine kernel: e820: remove [mem 0x000a0000-0x000fffff]>
Apr 24 18:03:56 manjaromachine kernel: last_pfn = 0x45e800 max_arch_pfn = 0x400>
Apr 24 18:03:56 manjaromachine kernel: MTRR default type: write-back
Apr 24 18:03:56 manjaromachine kernel: MTRR fixed ranges enabled:
Apr 24 18:03:56 manjaromachine kernel:   00000-9FFFF write-back
Apr 24 18:03:56 manjaromachine kernel:   A0000-BFFFF uncachable
Apr 24 18:03:56 manjaromachine kernel:   C0000-FFFFF write-protect
Apr 24 18:03:56 manjaromachine kernel: MTRR variable ranges enabled:
Apr 24 18:03:56 manjaromachine kernel:   0 base 00C0000000 mask 7FC0000000 unca>
Apr 24 18:03:56 manjaromachine kernel:   1 base 00A0000000 mask 7FE0000000 unca>
Apr 24 18:03:56 manjaromachine kernel:   2 base 009C000000 mask 7FFC000000 unca>
Apr 24 18:03:56 manjaromachine kernel:   3 base 009B000000 mask 7FFF000000 unca>
Apr 24 18:03:56 manjaromachine kernel:   4 base 2000000000 mask 6000000000 unca>
Apr 24 18:03:56 manjaromachine kernel:   5 base 1000000000 mask 7000000000 unca>
Apr 24 18:03:56 manjaromachine kernel:   6 base 0800000000 mask 7800000000 unca>
Apr 24 18:03:56 manjaromachine kernel:   7 base 4000000000 mask 4000000000 unca>
Apr 24 18:03:56 manjaromachine kernel:   8 disabled
Apr 24 18:03:56 manjaromachine kernel:   9 disabled
Apr 24 18:03:56 manjaromachine kernel: x86/PAT: Configuration [0-7]: WB  WC  UC>
Apr 24 18:03:56 manjaromachine kernel: last_pfn = 0x98d4f max_arch_pfn = 0x4000>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Early table checksum verification >
Apr 24 18:03:56 manjaromachine kernel: ACPI: RSDP 0x0000000098131014 000024 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: XSDT 0x0000000098130728 0000EC (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: FACP 0x0000000098124000 000114 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: DSDT 0x00000000980DE000 045628 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: FACS 0x0000000098385000 000040
Apr 24 18:03:56 manjaromachine kernel: ACPI: MCFG 0x000000009812F000 00003C (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0x000000009812C000 0020AD (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0x000000009812B000 000A52 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0x0000000098125000 005DAE (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: FIDT 0x00000000980DD000 00009C (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: ECDT 0x00000000980DC000 0000C1 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0x00000000980DB000 00010B (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0x00000000980D7000 0031DA (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0x00000000980D4000 00276E (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: HPET 0x00000000980D3000 000038 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0x00000000980D2000 000D57 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: NHLT 0x00000000980D1000 00002D (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LPIT 0x00000000980D0000 000094 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0x00000000980CC000 002720 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: DBGP 0x00000000980CB000 000034 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: DBG2 0x00000000980CA000 000054 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0x00000000980C8000 0000AE (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: BGRT 0x00000000980C7000 000038 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: TPM2 0x00000000980C6000 00004C (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: DMAR 0x00000000980C9000 0000A8 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0x00000000980C3000 002360 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: WSMT 0x00000000980CF000 000028 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: APIC 0x00000000980C2000 00012C (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: FPDT 0x00000000980C1000 000044 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving FACP table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving DSDT table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving FACS table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving MCFG table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving SSDT table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving FIDT table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving ECDT table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving HPET table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving NHLT table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving LPIT table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving DBGP table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving DBG2 table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving BGRT table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving TPM2 table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving DMAR table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving WSMT table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving APIC table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Reserving FPDT table memory at [me>
Apr 24 18:03:56 manjaromachine kernel: esrt: Reserving ESRT space from 0x000000>
Apr 24 18:03:56 manjaromachine kernel: e820: update [mem 0x91a0b000-0x91a0bfff]>
Apr 24 18:03:56 manjaromachine kernel: check: Scanning 1 areas for low memory c>
Apr 24 18:03:56 manjaromachine kernel: Using GB pages for direct mapping
Apr 24 18:03:56 manjaromachine kernel: Secure boot disabled
Apr 24 18:03:56 manjaromachine kernel: RAMDISK: [mem 0x367a3000-0x373c8fff]
Apr 24 18:03:56 manjaromachine kernel: ACPI: Local APIC address 0xfee00000
Apr 24 18:03:56 manjaromachine kernel: No NUMA configuration found
Apr 24 18:03:56 manjaromachine kernel: Faking a node at [mem 0x0000000000000000>
Apr 24 18:03:56 manjaromachine kernel: NODE_DATA(0) allocated [mem 0x45e7fc000->
Apr 24 18:03:56 manjaromachine kernel: Zone ranges:
Apr 24 18:03:56 manjaromachine kernel:   DMA      [mem 0x0000000000001000-0x000>
Apr 24 18:03:56 manjaromachine kernel:   DMA32    [mem 0x0000000001000000-0x000>
Apr 24 18:03:56 manjaromachine kernel:   Normal   [mem 0x0000000100000000-0x000>
Apr 24 18:03:56 manjaromachine kernel:   Device   empty
Apr 24 18:03:56 manjaromachine kernel: Movable zone start for each node
Apr 24 18:03:56 manjaromachine kernel: Early memory node ranges
Apr 24 18:03:56 manjaromachine kernel:   node   0: [mem 0x0000000000001000-0x00>
Apr 24 18:03:56 manjaromachine kernel:   node   0: [mem 0x000000000009f000-0x00>
Apr 24 18:03:56 manjaromachine kernel:   node   0: [mem 0x0000000000100000-0x00>
Apr 24 18:03:56 manjaromachine kernel:   node   0: [mem 0x0000000098d4e000-0x00>
Apr 24 18:03:56 manjaromachine kernel:   node   0: [mem 0x0000000100000000-0x00>
Apr 24 18:03:56 manjaromachine kernel: Initmem setup node 0 [mem 0x000000000000>
Apr 24 18:03:56 manjaromachine kernel: On node 0 totalpages: 4139072
Apr 24 18:03:56 manjaromachine kernel:   DMA zone: 64 pages used for memmap
Apr 24 18:03:56 manjaromachine kernel:   DMA zone: 24 pages reserved
Apr 24 18:03:56 manjaromachine kernel:   DMA zone: 3998 pages, LIFO batch:0
Apr 24 18:03:56 manjaromachine kernel:   DMA zone: 28770 pages in unavailable r>
Apr 24 18:03:56 manjaromachine kernel:   DMA32 zone: 9411 pages used for memmap
Apr 24 18:03:56 manjaromachine kernel:   DMA32 zone: 602274 pages, LIFO batch:63
Apr 24 18:03:56 manjaromachine kernel:   DMA32 zone: 48990 pages in unavailable>
Apr 24 18:03:56 manjaromachine kernel:   Normal zone: 55200 pages used for memm>
Apr 24 18:03:56 manjaromachine kernel:   Normal zone: 3532800 pages, LIFO batch>
Apr 24 18:03:56 manjaromachine kernel:   Normal zone: 6144 pages in unavailable>
Apr 24 18:03:56 manjaromachine kernel: Reserving Intel graphics memory at [mem >
Apr 24 18:03:56 manjaromachine kernel: ACPI: PM-Timer IO Port: 0x1808
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x02] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x03] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x04] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x05] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x06] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x07] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x08] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x09] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x0a] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x0b] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x0c] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x0d] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x0e] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x0f] high edge>
Apr 24 18:03:56 manjaromachine kernel: ACPI: LAPIC_NMI (acpi_id[0x10] high edge>
Apr 24 18:03:56 manjaromachine kernel: IOAPIC[0]: apic_id 2, version 32, addres>
Apr 24 18:03:56 manjaromachine kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 globa>
Apr 24 18:03:56 manjaromachine kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 globa>
Apr 24 18:03:56 manjaromachine kernel: ACPI: IRQ0 used by override.
Apr 24 18:03:56 manjaromachine kernel: ACPI: IRQ9 used by override.
Apr 24 18:03:56 manjaromachine kernel: Using ACPI (MADT) for SMP configuration >
Apr 24 18:03:56 manjaromachine kernel: ACPI: HPET id: 0x8086a201 base: 0xfed000>
Apr 24 18:03:56 manjaromachine kernel: e820: update [mem 0x91a9c000-0x91afafff]>
Apr 24 18:03:56 manjaromachine kernel: TSC deadline timer available
Apr 24 18:03:56 manjaromachine kernel: smpboot: Allowing 16 CPUs, 0 hotplug CPUs
Apr 24 18:03:56 manjaromachine kernel: PM: hibernation: Registered nosave memor>
Apr 24 18:03:56 manjaromachine kernel: [mem 0x9f800000-0xdfffffff] available fo>
Apr 24 18:03:56 manjaromachine kernel: Booting paravirtualized kernel on bare h>
Apr 24 18:03:56 manjaromachine kernel: clocksource: refined-jiffies: mask: 0xff>
Apr 24 18:03:56 manjaromachine kernel: setup_percpu: NR_CPUS:320 nr_cpumask_bit>
Apr 24 18:03:56 manjaromachine kernel: percpu: Embedded 55 pages/cpu s188416 r8>
Apr 24 18:03:56 manjaromachine kernel: pcpu-alloc: s188416 r8192 d28672 u262144>
Apr 24 18:03:56 manjaromachine kernel: pcpu-alloc: [0] 00 01 02 03 04 05 06 07 >
Apr 24 18:03:56 manjaromachine kernel: Built 1 zonelists, mobility grouping on.>
Apr 24 18:03:56 manjaromachine kernel: Policy zone: Normal
Apr 24 18:03:56 manjaromachine kernel: Kernel command line: BOOT_IMAGE=/boot/vm>
Apr 24 18:03:56 manjaromachine kernel: Dentry cache hash table entries: 2097152>
Apr 24 18:03:56 manjaromachine kernel: Inode-cache hash table entries: 1048576 >
Apr 24 18:03:56 manjaromachine kernel: mem auto-init: stack:byref_all(zero), he>
Apr 24 18:03:56 manjaromachine kernel: Memory: 16008080K/16556288K available (1>
Apr 24 18:03:56 manjaromachine kernel: random: get_random_u64 called from __kme>
Apr 24 18:03:56 manjaromachine kernel: SLUB: HWalign=64, Order=0-3, MinObjects=>
Apr 24 18:03:56 manjaromachine kernel: ftrace: allocating 41708 entries in 163 >
Apr 24 18:03:56 manjaromachine kernel: ftrace: allocated 163 pages with 4 groups
Apr 24 18:03:56 manjaromachine kernel: rcu: Hierarchical RCU implementation.
Apr 24 18:03:56 manjaromachine kernel: rcu:         RCU restricting CPUs from N>
Apr 24 18:03:56 manjaromachine kernel:         Rude variant of Tasks RCU enable>
Apr 24 18:03:56 manjaromachine kernel:         Tracing variant of Tasks RCU ena>
Apr 24 18:03:56 manjaromachine kernel: rcu: RCU calculated value of scheduler-e>
Apr 24 18:03:56 manjaromachine kernel: rcu: Adjusting geometry for rcu_fanout_l>
Apr 24 18:03:56 manjaromachine kernel: NR_IRQS: 20736, nr_irqs: 2184, prealloca>
Apr 24 18:03:56 manjaromachine kernel: Console: colour dummy device 80x25
Apr 24 18:03:56 manjaromachine kernel: printk: console [tty0] enabled
Apr 24 18:03:56 manjaromachine kernel: ACPI: Core revision 20200925
Apr 24 18:03:56 manjaromachine kernel: clocksource: hpet: mask: 0xffffffff max_>
Apr 24 18:03:56 manjaromachine kernel: APIC: Switch to symmetric I/O mode setup
Apr 24 18:03:56 manjaromachine kernel: DMAR: Host address width 39
Apr 24 18:03:56 manjaromachine kernel: DMAR: DRHD base: 0x000000fed90000 flags:>
Apr 24 18:03:56 manjaromachine kernel: DMAR: dmar0: reg_base_addr fed90000 ver >
Apr 24 18:03:56 manjaromachine kernel: DMAR: DRHD base: 0x000000fed91000 flags:>
Apr 24 18:03:56 manjaromachine kernel: DMAR: dmar1: reg_base_addr fed91000 ver >
Apr 24 18:03:56 manjaromachine kernel: DMAR: RMRR base: 0x000000986fd000 end: 0>
Apr 24 18:03:56 manjaromachine kernel: DMAR: RMRR base: 0x0000009b000000 end: 0>
Apr 24 18:03:56 manjaromachine kernel: DMAR-IR: IOAPIC id 2 under DRHD base  0x>
Apr 24 18:03:56 manjaromachine kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed>
Apr 24 18:03:56 manjaromachine kernel: DMAR-IR: Queued invalidation will be ena>
Apr 24 18:03:56 manjaromachine kernel: DMAR-IR: Enabled IRQ remapping in x2apic>
Apr 24 18:03:56 manjaromachine kernel: x2apic enabled
Apr 24 18:03:56 manjaromachine kernel: Switched APIC routing to cluster x2apic.
Apr 24 18:03:56 manjaromachine kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic>
Apr 24 18:03:56 manjaromachine kernel: clocksource: tsc-early: mask: 0xffffffff>
Apr 24 18:03:56 manjaromachine kernel: Calibrating delay loop (skipped), value >
Apr 24 18:03:56 manjaromachine kernel: pid_max: default: 32768 minimum: 301
Apr 24 18:03:56 manjaromachine kernel: LSM: Security Framework initializing
Apr 24 18:03:56 manjaromachine kernel: Yama: becoming mindful.
Apr 24 18:03:56 manjaromachine kernel: AppArmor: AppArmor initialized
Apr 24 18:03:56 manjaromachine kernel: Mount-cache hash table entries: 32768 (o>
Apr 24 18:03:56 manjaromachine kernel: Mountpoint-cache hash table entries: 327>
Apr 24 18:03:56 manjaromachine kernel: mce: CPU0: Thermal monitoring enabled (T>
Apr 24 18:03:56 manjaromachine kernel: process: using mwait in idle threads
Apr 24 18:03:56 manjaromachine kernel: Last level iTLB entries: 4KB 64, 2MB 8, >
Apr 24 18:03:56 manjaromachine kernel: Last level dTLB entries: 4KB 64, 2MB 0, >
Apr 24 18:03:56 manjaromachine kernel: Spectre V1 : Mitigation: usercopy/swapgs>
Apr 24 18:03:56 manjaromachine kernel: Spectre V2 : Mitigation: Enhanced IBRS
Apr 24 18:03:56 manjaromachine kernel: Spectre V2 : Spectre v2 / SpectreRSB mit>
Apr 24 18:03:56 manjaromachine kernel: Spectre V2 : mitigation: Enabling condit>
Apr 24 18:03:56 manjaromachine kernel: Speculative Store Bypass: Mitigation: Sp>
Apr 24 18:03:56 manjaromachine kernel: Freeing SMP alternatives memory: 36K
Apr 24 18:03:56 manjaromachine kernel: smpboot: CPU0: Intel(R) Core(TM) i7-1087>
Apr 24 18:03:56 manjaromachine kernel: Performance Events: PEBS fmt3+, Skylake >
Apr 24 18:03:56 manjaromachine kernel: ... version:                4
Apr 24 18:03:56 manjaromachine kernel: ... bit width:              48
Apr 24 18:03:56 manjaromachine kernel: ... generic registers:      4
Apr 24 18:03:56 manjaromachine kernel: ... value mask:             0000ffffffff>
Apr 24 18:03:56 manjaromachine kernel: ... max period:             00007fffffff>
Apr 24 18:03:56 manjaromachine kernel: ... fixed-purpose events:   3
Apr 24 18:03:56 manjaromachine kernel: ... event mask:             000000070000>
Apr 24 18:03:56 manjaromachine kernel: rcu: Hierarchical SRCU implementation.
Apr 24 18:03:56 manjaromachine kernel: NMI watchdog: Enabled. Permanently consu>
Apr 24 18:03:56 manjaromachine kernel: smp: Bringing up secondary CPUs ...
Apr 24 18:03:56 manjaromachine kernel: x86: Booting SMP configuration:
Apr 24 18:03:56 manjaromachine kernel: .... node  #0, CPUs:        #1
Apr 24 18:03:56 manjaromachine kernel: [Firmware Bug]: TSC ADJUST differs withi>
Apr 24 18:03:56 manjaromachine kernel:   #2  #3  #4  #5  #6  #7  #8  #9 #10 #11>
Apr 24 18:03:56 manjaromachine kernel: smp: Brought up 1 node, 16 CPUs
Apr 24 18:03:56 manjaromachine kernel: smpboot: Max logical packages: 1
Apr 24 18:03:56 manjaromachine kernel: smpboot: Total of 16 processors activate>
Apr 24 18:03:56 manjaromachine kernel: devtmpfs: initialized
Apr 24 18:03:56 manjaromachine kernel: x86/mm: Memory block size: 128MB
Apr 24 18:03:56 manjaromachine kernel: PM: Registering ACPI NVS region [mem 0x9>
Apr 24 18:03:56 manjaromachine kernel: clocksource: jiffies: mask: 0xffffffff m>
Apr 24 18:03:56 manjaromachine kernel: futex hash table entries: 4096 (order: 6>
Apr 24 18:03:56 manjaromachine kernel: pinctrl core: initialized pinctrl subsys>
Apr 24 18:03:56 manjaromachine kernel: PM: RTC time: 16:03:55, date: 2021-04-24
Apr 24 18:03:56 manjaromachine kernel: NET: Registered protocol family 16
Apr 24 18:03:56 manjaromachine kernel: DMA: preallocated 2048 KiB GFP_KERNEL po>
Apr 24 18:03:56 manjaromachine kernel: DMA: preallocated 2048 KiB GFP_KERNEL|GF>
Apr 24 18:03:56 manjaromachine kernel: audit: initializing netlink subsys (disa>
Apr 24 18:03:56 manjaromachine kernel: audit: type=2000 audit(1619280235.090:1)>
Apr 24 18:03:56 manjaromachine kernel: thermal_sys: Registered thermal governor>
Apr 24 18:03:56 manjaromachine kernel: cpuidle: using governor ladder
Apr 24 18:03:56 manjaromachine kernel: cpuidle: using governor menu
Apr 24 18:03:56 manjaromachine kernel: ACPI: bus type PCI registered
Apr 24 18:03:56 manjaromachine kernel: acpiphp: ACPI Hot Plug PCI Controller Dr>
Apr 24 18:03:56 manjaromachine kernel: PCI: MMCONFIG for domain 0000 [bus 00-ff>
Apr 24 18:03:56 manjaromachine kernel: PCI: MMCONFIG at [mem 0xe0000000-0xeffff>
Apr 24 18:03:56 manjaromachine kernel: PCI: Using configuration type 1 for base>
Apr 24 18:03:56 manjaromachine kernel: ENERGY_PERF_BIAS: Set to 'normal', was '>
Apr 24 18:03:56 manjaromachine kernel: Kprobes globally optimized
Apr 24 18:03:56 manjaromachine kernel: HugeTLB registered 1.00 GiB page size, p>
Apr 24 18:03:56 manjaromachine kernel: HugeTLB registered 2.00 MiB page size, p>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Added _OSI(Module Device)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Added _OSI(Processor Device)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Added _OSI(3.0 _SCP Extensions)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Added _OSI(Processor Aggregator De>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Added _OSI(Linux-Dell-Video)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Au>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphi>
Apr 24 18:03:56 manjaromachine kernel: ACPI: 11 ACPI AML tables successfully ac>
Apr 24 18:03:56 manjaromachine kernel: ACPI: EC: EC started
Apr 24 18:03:56 manjaromachine kernel: ACPI: EC: interrupt blocked
Apr 24 18:03:56 manjaromachine kernel: ACPI: EC: EC_CMD/EC_SC=0x66, EC_DATA=0x62
Apr 24 18:03:56 manjaromachine kernel: ACPI: EC: Boot ECDT EC used to handle tr>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Dynamic OEM Table Load:
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0xFFFFA0B0C17FEA00 0000FC (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: \_SB_.PR00: _OSC native thermal LV>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0xFFFFA0B0C1306400 000400 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0xFFFFA0B0C1A50000 00051E (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0xFFFFA0B0C18CDA00 00016C (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0xFFFFA0B0C1A5D000 000BEA (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0xFFFFA0B0C1A51800 000778 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0xFFFFA0B0C1301400 0003D7 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0xFFFFA0B0C1A5E000 000D22 (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: SSDT 0xFFFFA0B0C1300000 0003CA (v0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Interpreter enabled
Apr 24 18:03:56 manjaromachine kernel: ACPI: (supports S0 S3 S4 S5)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Using IOAPIC for interrupt routing
Apr 24 18:03:56 manjaromachine kernel: PCI: Using host bridge windows from ACPI>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Enabled 10 GPEs in block 00 to 7F
Apr 24 18:03:56 manjaromachine kernel: ACPI: Power Resource [PG00] (on)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Power Resource [BTPR] (on)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Power Resource [USBC] (on)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Power Resource [V0PR] (on)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Power Resource [V1PR] (on)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Power Resource [V2PR] (on)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Power Resource [WRST] (on)
Apr 24 18:03:56 manjaromachine kernel: ACPI: Power Resource [PIN] (off)
Apr 24 18:03:56 manjaromachine kernel: ACPI: PCI Root Bridge [PCI0] (domain 000>
Apr 24 18:03:56 manjaromachine kernel: acpi PNP0A08:00: _OSC: OS supports [Exte>
Apr 24 18:03:56 manjaromachine kernel: acpi PNP0A08:00: _OSC: OS now controls [>
Apr 24 18:03:56 manjaromachine kernel: PCI host bridge to bus 0000:00
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: root bus resource [io  >
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: root bus resource [mem >
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: root bus resource [bus >
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:00.0: [8086:9b44] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:01.0: [8086:1901] type 01 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:01.0: PME# supported from D0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:02.0: [8086:9bc4] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:02.0: reg 0x10: [mem 0xc3000>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:02.0: reg 0x18: [mem 0xa0000>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:02.0: reg 0x20: [io  0x5000->
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:02.0: BAR 2: assigned to efi>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:04.0: [8086:1903] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:04.0: reg 0x10: [mem 0xc5410>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:08.0: [8086:1911] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:08.0: reg 0x10: [mem 0xc5428>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:12.0: [8086:06f9] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:12.0: reg 0x10: [mem 0xc5427>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:14.0: [8086:06ed] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:14.0: reg 0x10: [mem 0xc5400>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:14.0: PME# supported from D3>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:14.2: [8086:06ef] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:14.2: reg 0x10: [mem 0xc5420>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:14.2: reg 0x18: [mem 0xc5426>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:14.3: [8086:06f0] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:14.3: reg 0x10: [mem 0xc541c>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:14.3: PME# supported from D0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:15.0: [8086:06e8] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:15.0: reg 0x10: [mem 0x00000>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:15.1: [8086:06e9] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:15.1: reg 0x10: [mem 0x00000>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:16.0: [8086:06e0] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:16.0: reg 0x10: [mem 0xc5423>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:16.0: PME# supported from D3>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1d.0: [8086:06b0] type 01 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1d.0: PME# supported from D0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1d.0: PTM enabled (root), 4n>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1d.6: [8086:06b6] type 01 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1d.6: PME# supported from D0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1d.6: PTM enabled (root), 4n>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1f.0: [8086:068d] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1f.3: [8086:06c8] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xc5418>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1f.3: reg 0x20: [mem 0xc5100>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1f.3: PME# supported from D3>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1f.4: [8086:06a3] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1f.4: reg 0x10: [mem 0xc5422>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1f.4: reg 0x20: [io  0xefa0->
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1f.5: [8086:06a4] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1f.5: reg 0x10: [mem 0xfe010>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.0: [10de:1f15] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.0: reg 0x10: [mem 0xc4000>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.0: reg 0x14: [mem 0xb0000>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.0: reg 0x1c: [mem 0xc0000>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.0: reg 0x24: [io  0x4000->
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.0: reg 0x30: [mem 0xc5000>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.0: PME# supported from D0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.0: 63.008 Gb/s available >
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.1: [10de:10f9] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.1: reg 0x10: [mem 0xc5080>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.2: [10de:1ada] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.2: reg 0x10: [mem 0xc2000>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.2: reg 0x1c: [mem 0xc2040>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.2: PME# supported from D0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.3: [10de:1adb] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.3: reg 0x10: [mem 0xc5084>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.3: PME# supported from D0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:01.0: PCI bridge to [bus 01]
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:01.0:   bridge window [io  0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:01.0:   bridge window [mem 0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:02:00.0: [15b7:5009] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:02:00.0: reg 0x10: [mem 0xc5300>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:02:00.0: reg 0x20: [mem 0xc5304>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1d.0: PCI bridge to [bus 02]
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1d.0:   bridge window [mem 0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:03:00.0: [10ec:8168] type 00 cl>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:03:00.0: reg 0x10: [io  0x3000->
Apr 24 18:03:56 manjaromachine kernel: pci 0000:03:00.0: reg 0x18: [mem 0xc5204>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:03:00.0: reg 0x20: [mem 0xc5200>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:03:00.0: supports D1 D2
Apr 24 18:03:56 manjaromachine kernel: pci 0000:03:00.0: PME# supported from D0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1d.6: PCI bridge to [bus 03]
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1d.6:   bridge window [io  0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:1d.6:   bridge window [mem 0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 >
Apr 24 18:03:56 manjaromachine kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 >
Apr 24 18:03:56 manjaromachine kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 >
Apr 24 18:03:56 manjaromachine kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 >
Apr 24 18:03:56 manjaromachine kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 >
Apr 24 18:03:56 manjaromachine kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 >
Apr 24 18:03:56 manjaromachine kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 >
Apr 24 18:03:56 manjaromachine kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 >
Apr 24 18:03:56 manjaromachine kernel: ACPI: EC: interrupt unblocked
Apr 24 18:03:56 manjaromachine kernel: ACPI: EC: event unblocked
Apr 24 18:03:56 manjaromachine kernel: ACPI: EC: GPE=0x27
Apr 24 18:03:56 manjaromachine kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: Boot ECDT EC>
Apr 24 18:03:56 manjaromachine kernel: ACPI: \_SB_.PCI0.LPCB.EC0_: EC: Used to >
Apr 24 18:03:56 manjaromachine kernel: iommu: Default domain type: Translated
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:02.0: vgaarb: setting as boo>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:02.0: vgaarb: VGA device add>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.0: vgaarb: VGA device add>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:02.0: vgaarb: no bridge cont>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.0: vgaarb: bridge control>
Apr 24 18:03:56 manjaromachine kernel: vgaarb: loaded
Apr 24 18:03:56 manjaromachine kernel: SCSI subsystem initialized
Apr 24 18:03:56 manjaromachine kernel: libata version 3.00 loaded.
Apr 24 18:03:56 manjaromachine kernel: ACPI: bus type USB registered
Apr 24 18:03:56 manjaromachine kernel: usbcore: registered new interface driver>
Apr 24 18:03:56 manjaromachine kernel: usbcore: registered new device driver usb
Apr 24 18:03:56 manjaromachine kernel: pps_core: LinuxPPS API ver. 1 registered
Apr 24 18:03:56 manjaromachine kernel: pps_core: Software ver. 5.3.6 - Copyrigh>
Apr 24 18:03:56 manjaromachine kernel: PTP clock support registered
Apr 24 18:03:56 manjaromachine kernel: EDAC MC: Ver: 3.0.0
Apr 24 18:03:56 manjaromachine kernel: Registered efivars operations
Apr 24 18:03:56 manjaromachine kernel: NetLabel: Initializing
Apr 24 18:03:56 manjaromachine kernel: NetLabel:  domain hash size = 128
Apr 24 18:03:56 manjaromachine kernel: NetLabel:  protocols = UNLABELED CIPSOv4>
Apr 24 18:03:56 manjaromachine kernel: NetLabel:  unlabeled traffic allowed by >
Apr 24 18:03:56 manjaromachine kernel: PCI: Using ACPI for IRQ routing
Apr 24 18:03:56 manjaromachine kernel: PCI: pci_cache_line_size set to 64 bytes
Apr 24 18:03:56 manjaromachine kernel: e820: reserve RAM buffer [mem 0x0009e000>
Apr 24 18:03:56 manjaromachine kernel: e820: reserve RAM buffer [mem 0x91a0b000>
Apr 24 18:03:56 manjaromachine kernel: e820: reserve RAM buffer [mem 0x91a9c000>
Apr 24 18:03:56 manjaromachine kernel: e820: reserve RAM buffer [mem 0x940a1000>
Apr 24 18:03:56 manjaromachine kernel: e820: reserve RAM buffer [mem 0x98d4f000>
Apr 24 18:03:56 manjaromachine kernel: e820: reserve RAM buffer [mem 0x45e80000>
Apr 24 18:03:56 manjaromachine kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0,>
Apr 24 18:03:56 manjaromachine kernel: hpet0: 8 comparators, 64-bit 24.000000 M>
Apr 24 18:03:56 manjaromachine kernel: clocksource: Switched to clocksource tsc>
Apr 24 18:03:56 manjaromachine kernel: VFS: Disk quotas dquot_6.6.0
Apr 24 18:03:56 manjaromachine kernel: VFS: Dquot-cache hash table entries: 512>
Apr 24 18:03:56 manjaromachine kernel: AppArmor: AppArmor Filesystem Enabled
Apr 24 18:03:56 manjaromachine kernel: pnp: PnP ACPI init
Apr 24 18:03:56 manjaromachine kernel: system 00:00: [mem 0x40000000-0x403fffff>
Apr 24 18:03:56 manjaromachine kernel: system 00:00: Plug and Play ACPI device,>
Apr 24 18:03:56 manjaromachine kernel: system 00:01: [io  0x0680-0x069f] has be>
Apr 24 18:03:56 manjaromachine kernel: system 00:01: [io  0x164e-0x164f] has be>
Apr 24 18:03:56 manjaromachine kernel: system 00:01: Plug and Play ACPI device,>
Apr 24 18:03:56 manjaromachine kernel: system 00:02: [io  0x1854-0x1857] has be>
Apr 24 18:03:56 manjaromachine kernel: system 00:02: Plug and Play ACPI device,>
Apr 24 18:03:56 manjaromachine kernel: pnp 00:03: Plug and Play ACPI device, ID>
Apr 24 18:03:56 manjaromachine kernel: system 00:04: [io  0x1800-0x18fe] could >
Apr 24 18:03:56 manjaromachine kernel: system 00:04: [mem 0xfd000000-0xfd69ffff>
Apr 24 18:03:56 manjaromachine kernel: system 00:04: [mem 0xfd6c0000-0xfd6cffff>
Apr 24 18:03:56 manjaromachine kernel: system 00:04: [mem 0xfd6f0000-0xfdffffff>
Apr 24 18:03:56 manjaromachine kernel: system 00:04: [mem 0xfe000000-0xfe01ffff>
Apr 24 18:03:56 manjaromachine kernel: system 00:04: [mem 0xfe200000-0xfe7fffff>
Apr 24 18:03:56 manjaromachine kernel: system 00:04: [mem 0xff000000-0xffffffff>
Apr 24 18:03:56 manjaromachine kernel: system 00:04: Plug and Play ACPI device,>
Apr 24 18:03:56 manjaromachine kernel: system 00:05: [io  0x2000-0x20fe] has be>
Apr 24 18:03:56 manjaromachine kernel: system 00:05: Plug and Play ACPI device,>
Apr 24 18:03:56 manjaromachine kernel: system 00:06: [mem 0xfed10000-0xfed17fff>
Apr 24 18:03:56 manjaromachine kernel: system 00:06: [mem 0xfed18000-0xfed18fff>
Apr 24 18:03:56 manjaromachine kernel: system 00:06: [mem 0xfed19000-0xfed19fff>
Apr 24 18:03:56 manjaromachine kernel: system 00:06: [mem 0xe0000000-0xefffffff>
Apr 24 18:03:56 manjaromachine kernel: system 00:06: [mem 0xfed20000-0xfed3ffff>
Apr 24 18:03:56 manjaromachine kernel: system 00:06: [mem 0xfed90000-0xfed93fff>
Apr 24 18:03:56 manjaromachine kernel: system 00:06: [mem 0xfed45000-0xfed8ffff>
Apr 24 18:03:56 manjaromachine kernel: system 00:06: [mem 0xfee00000-0xfeefffff>
Apr 24 18:03:56 manjaromachine kernel: system 00:06: Plug and Play ACPI device,>
Apr 24 18:03:56 manjaromachine kernel: system 00:07: [mem 0xfe038000-0xfe038fff>
Apr 24 18:03:56 manjaromachine kernel: system 00:07: Plug and Play ACPI device,>
Apr 24 18:03:56 manjaromachine kernel: pnp: PnP ACPI: found 8 devices
Apr 24 18:03:56 manjaromachine kernel: clocksource: acpi_pm: mask: 0xffffff max>
Apr 24 18:03:56 manjaromachine kernel: NET: Registered protocol family 2
Apr 24 18:03:56 manjaromachine kernel: tcp_listen_portaddr_hash hash table entr>
Apr 24 18:03:56 manjaromachine kernel: TCP established hash table entries: 1310>
Apr 24 18:03:56 manjaromachine kernel: TCP bind hash table entries: 65536 (orde>
Apr 24 18:03:56 manjaromachine kernel: TCP: Hash tables configured (established>
Apr 24 18:03:56 manjaromachine kernel: MPTCP token hash table entries: 16384 (o>
Apr 24 18:03:56 manjaromachine kernel: UDP hash table entries: 8192 (order: 6, >
Apr 24 18:03:56 manjaromachine kernel: UDP-Lite hash table entries: 8192 (order>
Apr 24 18:03:56 manjaromachine kernel: NET: Registered protocol family 44
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:15.0: BAR 0: assigned [mem 0>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:15.1: BAR 0: assigned [mem 0>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: resource 4 [io  0x0000->
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: resource 5 [io  0x0d00->
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: resource 6 [mem 0x000a0>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: resource 7 [mem 0x000e0>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: resource 8 [mem 0x000e4>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: resource 9 [mem 0x000e8>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: resource 10 [mem 0x000e>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: resource 11 [mem 0x000f>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: resource 12 [mem 0x9f80>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:00: resource 13 [mem 0xfc80>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:01: resource 0 [io  0x4000->
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:01: resource 1 [mem 0xc4000>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:01: resource 2 [mem 0xb0000>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:02: resource 1 [mem 0xc5300>
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:03: resource 0 [io  0x3000->
Apr 24 18:03:56 manjaromachine kernel: pci_bus 0000:03: resource 1 [mem 0xc5200>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:00:02.0: Video device with shad>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.1: D0 power state depends>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.2: D0 power state depends>
Apr 24 18:03:56 manjaromachine kernel: pci 0000:01:00.3: D0 power state depends>
Apr 24 18:03:56 manjaromachine kernel: PCI: CLS 64 bytes, default 64
Apr 24 18:03:56 manjaromachine kernel: Trying to unpack rootfs image as initram>
Apr 24 18:03:56 manjaromachine kernel: Freeing initrd memory: 12440K
Apr 24 18:03:56 manjaromachine kernel: PCI-DMA: Using software bounce buffering>
Apr 24 18:03:56 manjaromachine kernel: software IO TLB: mapped [mem 0x000000008>
Apr 24 18:03:56 manjaromachine kernel: platform rtc_cmos: registered platform R>
Apr 24 18:03:56 manjaromachine kernel: check: Scanning for low memory corruptio>
Apr 24 18:03:56 manjaromachine kernel: Initialise system trusted keyrings
Apr 24 18:03:56 manjaromachine kernel: Key type blacklist registered
Apr 24 18:03:56 manjaromachine kernel: workingset: timestamp_bits=41 max_order=>
Apr 24 18:03:56 manjaromachine kernel: zbud: loaded
Apr 24 18:03:56 manjaromachine kernel: Key type asymmetric registered
Apr 24 18:03:56 manjaromachine kernel: Asymmetric key parser 'x509' registered
Apr 24 18:03:56 manjaromachine kernel: Block layer SCSI generic (bsg) driver ve>
Apr 24 18:03:56 manjaromachine kernel: io scheduler mq-deadline registered
Apr 24 18:03:56 manjaromachine kernel: io scheduler kyber registered
Apr 24 18:03:56 manjaromachine kernel: io scheduler bfq registered
Apr 24 18:03:56 manjaromachine kernel: atomic64_test: passed for x86-64 platfor>
Apr 24 18:03:56 manjaromachine kernel: pcieport 0000:00:01.0: PME: Signaling wi>
Apr 24 18:03:56 manjaromachine kernel: pcieport 0000:00:1d.0: PME: Signaling wi>
Apr 24 18:03:56 manjaromachine kernel: pcieport 0000:00:1d.0: AER: enabled with>
Apr 24 18:03:56 manjaromachine kernel: pcieport 0000:00:1d.0: DPC: enabled with>
Apr 24 18:03:56 manjaromachine kernel: pcieport 0000:00:1d.0: DPC: error contai>
Apr 24 18:03:56 manjaromachine kernel: pcieport 0000:00:1d.6: PME: Signaling wi>
Apr 24 18:03:56 manjaromachine kernel: pcieport 0000:00:1d.6: AER: enabled with>
Apr 24 18:03:56 manjaromachine kernel: pcieport 0000:00:1d.6: DPC: enabled with>
Apr 24 18:03:56 manjaromachine kernel: pcieport 0000:00:1d.6: DPC: error contai>
Apr 24 18:03:56 manjaromachine kernel: shpchp: Standard Hot Plug PCI Controller>
Apr 24 18:03:56 manjaromachine kernel: efifb: probing for efifb
Apr 24 18:03:56 manjaromachine kernel: efifb: showing boot graphics
Apr 24 18:03:56 manjaromachine kernel: efifb: framebuffer at 0xa0000000, using >
Apr 24 18:03:56 manjaromachine kernel: efifb: mode is 1920x1080x32, linelength=>
Apr 24 18:03:56 manjaromachine kernel: efifb: scrolling: redraw
Apr 24 18:03:56 manjaromachine kernel: efifb: Truecolor: size=8:8:8:8, shift=24>
Apr 24 18:03:56 manjaromachine kernel: fbcon: Deferring console take-over
Apr 24 18:03:56 manjaromachine kernel: fb0: EFI VGA frame buffer device
Apr 24 18:03:56 manjaromachine kernel: intel_idle: MWAIT substates: 0x11142120
Apr 24 18:03:56 manjaromachine kernel: Monitor-Mwait will be used to enter C-1 >
Apr 24 18:03:56 manjaromachine kernel: Monitor-Mwait will be used to enter C-2 >
Apr 24 18:03:56 manjaromachine kernel: Monitor-Mwait will be used to enter C-3 >
Apr 24 18:03:56 manjaromachine kernel: ACPI: \_SB_.PR00: Found 3 idle states
Apr 24 18:03:56 manjaromachine kernel: intel_idle: v0.5.1 model 0xA5
Apr 24 18:03:56 manjaromachine kernel: intel_idle: Local APIC timer is reliable>
Apr 24 18:03:56 manjaromachine kernel: ACPI: AC Adapter [AC0] (off-line)
Apr 24 18:03:56 manjaromachine kernel: input: Lid Switch as /devices/LNXSYSTM:0>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Lid Switch [LID]
Apr 24 18:03:56 manjaromachine kernel: input: Sleep Button as /devices/LNXSYSTM>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Sleep Button [SLPB]
Apr 24 18:03:56 manjaromachine kernel: input: Power Button as /devices/LNXSYSTM>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Power Button [PWRB]
Apr 24 18:03:56 manjaromachine kernel: ACPI: Power Button [PWRF]
Apr 24 18:03:56 manjaromachine kernel: thermal LNXTHERM:00: registered as therm>
Apr 24 18:03:56 manjaromachine kernel: ACPI: Thermal Zone [THRM] (48 C)
Apr 24 18:03:56 manjaromachine kernel: Serial: 8250/16550 driver, 32 ports, IRQ>
Apr 24 18:03:56 manjaromachine kernel: Non-volatile memory driver v1.3
Apr 24 18:03:56 manjaromachine kernel: AMD-Vi: AMD IOMMUv2 driver by Joerg Roed>
Apr 24 18:03:56 manjaromachine kernel: AMD-Vi: AMD IOMMUv2 functionality not av>
Apr 24 18:03:56 manjaromachine kernel: battery: ACPI: Battery Slot [BAT0] (batt>
Apr 24 18:03:56 manjaromachine kernel: nvme 0000:02:00.0: platform quirk: setti>
Apr 24 18:03:56 manjaromachine kernel: nvme nvme0: pci function 0000:02:00.0
Apr 24 18:03:56 manjaromachine kernel: ehci_hcd: USB 2.0 'Enhanced' Host Contro>
Apr 24 18:03:56 manjaromachine kernel: ehci-pci: EHCI PCI platform driver
Apr 24 18:03:56 manjaromachine kernel: ohci_hcd: USB 1.1 'Open' Host Controller>
Apr 24 18:03:56 manjaromachine kernel: ohci-pci: OHCI PCI platform driver
Apr 24 18:03:56 manjaromachine kernel: uhci_hcd: USB Universal Host Controller >
Apr 24 18:03:56 manjaromachine kernel: usbserial: USB Serial support registered>
Apr 24 18:03:56 manjaromachine kernel: rtc_cmos rtc_cmos: RTC can wake from S4
Apr 24 18:03:56 manjaromachine kernel: rtc_cmos rtc_cmos: registered as rtc0
Apr 24 18:03:56 manjaromachine kernel: rtc_cmos rtc_cmos: setting system clock >
Apr 24 18:03:56 manjaromachine kernel: rtc_cmos rtc_cmos: alarms up to one mont>
Apr 24 18:03:56 manjaromachine kernel: intel_pstate: Intel P-state driver initi>
Apr 24 18:03:56 manjaromachine kernel: intel_pstate: HWP enabled
Apr 24 18:03:56 manjaromachine kernel: ledtrig-cpu: registered to indicate acti>
Apr 24 18:03:56 manjaromachine kernel: hid: raw HID events driver (C) Jiri Kosi>
Apr 24 18:03:56 manjaromachine kernel: ashmem: initialized
Apr 24 18:03:56 manjaromachine kernel: intel_pmc_core INT33A1:00:  initialized
Apr 24 18:03:56 manjaromachine kernel: drop_monitor: Initializing network drop >
Apr 24 18:03:56 manjaromachine kernel: Initializing XFRM netlink socket
Apr 24 18:03:56 manjaromachine kernel: NET: Registered protocol family 10
Apr 24 18:03:56 manjaromachine kernel: Segment Routing with IPv6
Apr 24 18:03:56 manjaromachine kernel: RPL Segment Routing with IPv6
Apr 24 18:03:56 manjaromachine kernel: NET: Registered protocol family 17
Apr 24 18:03:56 manjaromachine kernel: microcode: sig=0xa0652, pf=0x20, revisio>
Apr 24 18:03:56 manjaromachine kernel: microcode: Microcode Update Driver: v2.2.
Apr 24 18:03:56 manjaromachine kernel: IPI shorthand broadcast: enabled
Apr 24 18:03:56 manjaromachine kernel: sched_clock: Marking stable (476874147, >
Apr 24 18:03:56 manjaromachine kernel: registered taskstats version 1
Apr 24 18:03:56 manjaromachine kernel: Loading compiled-in X.509 certificates
Apr 24 18:03:56 manjaromachine kernel: Loaded X.509 cert 'Build time autogenera>
Apr 24 18:03:56 manjaromachine kernel: zswap: loaded using pool zstd/z3fold
Apr 24 18:03:56 manjaromachine kernel: Key type ._fscrypt registered
Apr 24 18:03:56 manjaromachine kernel: Key type .fscrypt registered
Apr 24 18:03:56 manjaromachine kernel: Key type fscrypt-provisioning registered
Apr 24 18:03:56 manjaromachine kernel: AppArmor: AppArmor sha1 policy hashing e>
Apr 24 18:03:56 manjaromachine kernel: PM:   Magic number: 1:3:86
Apr 24 18:03:56 manjaromachine kernel: RAS: Correctable Errors collector initia>
Apr 24 18:03:56 manjaromachine kernel: nvme nvme0: allocated 32 MiB host memory>
Apr 24 18:03:56 manjaromachine kernel: nvme nvme0: 16/0/0 default/read/poll que>
Apr 24 18:03:56 manjaromachine kernel:  nvme0n1: p1 p2 p3 p4 p5 p6 p7
Apr 24 18:03:56 manjaromachine kernel: Freeing unused decrypted memory: 2036K
Apr 24 18:03:56 manjaromachine kernel: Freeing unused kernel image (initmem) me>
Apr 24 18:03:56 manjaromachine kernel: Write protecting the kernel read-only da>
Apr 24 18:03:56 manjaromachine kernel: Freeing unused kernel image (text/rodata>
Apr 24 18:03:56 manjaromachine kernel: Freeing unused kernel image (rodata/data>
Apr 24 18:03:56 manjaromachine kernel: x86/mm: Checked W+X mappings: passed, no>
Apr 24 18:03:56 manjaromachine kernel: rodata_test: all tests were successful
Apr 24 18:03:56 manjaromachine kernel: Run /init as init process
Apr 24 18:03:56 manjaromachine kernel:   with arguments:
Apr 24 18:03:56 manjaromachine kernel:     /init
Apr 24 18:03:56 manjaromachine kernel:     splash
Apr 24 18:03:56 manjaromachine kernel:   with environment:
Apr 24 18:03:56 manjaromachine kernel:     HOME=/
Apr 24 18:03:56 manjaromachine kernel:     TERM=linux
Apr 24 18:03:56 manjaromachine kernel:     BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64
Apr 24 18:03:56 manjaromachine kernel: i8042: PNP: PS/2 Controller [PNP030b:PS2>
Apr 24 18:03:56 manjaromachine kernel: i8042: PNP: PS/2 appears to have AUX por>
Apr 24 18:03:56 manjaromachine kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:00:14.0: xHCI Host Control>
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:00:14.0: new USB bus regis>
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:00:14.0: hcc params 0x2000>
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:00:14.0: cache line size o>
Apr 24 18:03:56 manjaromachine kernel: usb usb1: New USB device found, idVendor>
Apr 24 18:03:56 manjaromachine kernel: usb usb1: New USB device strings: Mfr=3,>
Apr 24 18:03:56 manjaromachine kernel: usb usb1: Product: xHCI Host Controller
Apr 24 18:03:56 manjaromachine kernel: usb usb1: Manufacturer: Linux 5.10.30-1->
Apr 24 18:03:56 manjaromachine kernel: usb usb1: SerialNumber: 0000:00:14.0
Apr 24 18:03:56 manjaromachine kernel: hub 1-0:1.0: USB hub found
Apr 24 18:03:56 manjaromachine kernel: hub 1-0:1.0: 16 ports detected
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:00:14.0: Host supports USB>
Apr 24 18:03:56 manjaromachine kernel: usb usb2: New USB device found, idVendor>
Apr 24 18:03:56 manjaromachine kernel: usb usb2: New USB device strings: Mfr=3,>
Apr 24 18:03:56 manjaromachine kernel: usb usb2: Product: xHCI Host Controller
Apr 24 18:03:56 manjaromachine kernel: usb usb2: Manufacturer: Linux 5.10.30-1->
Apr 24 18:03:56 manjaromachine kernel: usb usb2: SerialNumber: 0000:00:14.0
Apr 24 18:03:56 manjaromachine kernel: hub 2-0:1.0: USB hub found
Apr 24 18:03:56 manjaromachine kernel: hub 2-0:1.0: 8 ports detected
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:01:00.2: xHCI Host Control>
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:01:00.2: new USB bus regis>
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:01:00.2: hcc params 0x0180>
Apr 24 18:03:56 manjaromachine kernel: usb usb3: New USB device found, idVendor>
Apr 24 18:03:56 manjaromachine kernel: usb usb3: New USB device strings: Mfr=3,>
Apr 24 18:03:56 manjaromachine kernel: usb usb3: Product: xHCI Host Controller
Apr 24 18:03:56 manjaromachine kernel: usb usb3: Manufacturer: Linux 5.10.30-1->
Apr 24 18:03:56 manjaromachine kernel: usb usb3: SerialNumber: 0000:01:00.2
Apr 24 18:03:56 manjaromachine kernel: hub 3-0:1.0: USB hub found
Apr 24 18:03:56 manjaromachine kernel: hub 3-0:1.0: 2 ports detected
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:01:00.2: Host supports USB>
Apr 24 18:03:56 manjaromachine kernel: usb usb4: We don't know the algorithms f>
Apr 24 18:03:56 manjaromachine kernel: usb usb4: New USB device found, idVendor>
Apr 24 18:03:56 manjaromachine kernel: usb usb4: New USB device strings: Mfr=3,>
Apr 24 18:03:56 manjaromachine kernel: usb usb4: Product: xHCI Host Controller
Apr 24 18:03:56 manjaromachine kernel: usb usb4: Manufacturer: Linux 5.10.30-1->
Apr 24 18:03:56 manjaromachine kernel: usb usb4: SerialNumber: 0000:01:00.2
Apr 24 18:03:56 manjaromachine kernel: hub 4-0:1.0: USB hub found
Apr 24 18:03:56 manjaromachine kernel: hub 4-0:1.0: 4 ports detected
Apr 24 18:03:56 manjaromachine kernel: input: AT Translated Set 2 keyboard as />
Apr 24 18:03:56 manjaromachine kernel: EXT4-fs (nvme0n1p7): mounted filesystem >
Apr 24 18:03:56 manjaromachine kernel: random: fast init done
Apr 24 18:03:56 manjaromachine systemd[1]: systemd 247.6-1.0-manjaro running in>
Apr 24 18:03:56 manjaromachine systemd[1]: Detected architecture x86-64.
Apr 24 18:03:56 manjaromachine systemd[1]: Set hostname to <manjaromachine>.
Apr 24 18:03:56 manjaromachine kernel: usb 1-3: new low-speed USB device number>
Apr 24 18:03:56 manjaromachine kernel: random: lvmconfig: uninitialized urandom>
Apr 24 18:03:56 manjaromachine systemd[1]: Queued start job for default target >
Apr 24 18:03:56 manjaromachine systemd[1]: Created slice system-getty.slice.
Apr 24 18:03:56 manjaromachine systemd[1]: Created slice system-modprobe.slice.
Apr 24 18:03:56 manjaromachine systemd[1]: Created slice system-systemd\x2dfsck>
Apr 24 18:03:56 manjaromachine systemd[1]: Created slice User and Session Slice.
Apr 24 18:03:56 manjaromachine systemd[1]: Started Forward Password Requests to>
Apr 24 18:03:56 manjaromachine systemd[1]: Set up automount Arbitrary Executabl>
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Login Prompts.
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Remote File Systems.
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Slices.
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Swap.
Apr 24 18:03:56 manjaromachine systemd[1]: Listening on Device-mapper event dae>
Apr 24 18:03:56 manjaromachine systemd[1]: Listening on LVM2 poll daemon socket.
Apr 24 18:03:56 manjaromachine systemd[1]: Listening on Process Core Dump Socke>
Apr 24 18:03:56 manjaromachine systemd[1]: Listening on Journal Audit Socket.
Apr 24 18:03:56 manjaromachine systemd[1]: Listening on Journal Socket (/dev/lo>
Apr 24 18:03:56 manjaromachine systemd[1]: Listening on Journal Socket.
Apr 24 18:03:56 manjaromachine systemd[1]: Listening on udev Control Socket.
Apr 24 18:03:56 manjaromachine systemd[1]: Listening on udev Kernel Socket.
Apr 24 18:03:56 manjaromachine systemd[1]: Mounting Huge Pages File System...
Apr 24 18:03:56 manjaromachine systemd[1]: Mounting POSIX Message Queue File Sy>
Apr 24 18:03:56 manjaromachine systemd[1]: Mounting Kernel Debug File System...
Apr 24 18:03:56 manjaromachine systemd[1]: Mounting Kernel Trace File System...
Apr 24 18:03:56 manjaromachine systemd[1]: Mounting Temporary Directory (/tmp).>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Load AppArmor profiles...
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Create list of static devic>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Monitoring of LVM2 mirrors,>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Load Kernel Module configfs>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Load Kernel Module drm...
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Load Kernel Module fuse...
Apr 24 18:03:56 manjaromachine systemd[1]: Condition check resulted in Set Up A>
Apr 24 18:03:56 manjaromachine systemd[1]: Condition check resulted in File Sys>
Apr 24 18:03:56 manjaromachine kernel: random: lvm: uninitialized urandom read >
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Load Kernel Modules...
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Remount Root and Kernel Fil>
Apr 24 18:03:56 manjaromachine systemd[1]: Condition check resulted in Repartit>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Coldplug All udev Devices...
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Setup Virtual Console...
Apr 24 18:03:56 manjaromachine systemd[1]: Mounted Huge Pages File System.
Apr 24 18:03:56 manjaromachine systemd[1]: Mounted POSIX Message Queue File Sys>
Apr 24 18:03:56 manjaromachine systemd[1]: Mounted Kernel Debug File System.
Apr 24 18:03:56 manjaromachine systemd[1]: Mounted Kernel Trace File System.
Apr 24 18:03:56 manjaromachine systemd[1]: Mounted Temporary Directory (/tmp).
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Create list of static devic>
Apr 24 18:03:56 manjaromachine systemd[1]: modprobe@configfs.service: Succeeded.
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Load Kernel Module configfs.
Apr 24 18:03:56 manjaromachine systemd[1]: modprobe@drm.service: Succeeded.
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Load Kernel Module drm.
Apr 24 18:03:56 manjaromachine kernel: EXT4-fs (nvme0n1p7): re-mounted. Opts: (>
Apr 24 18:03:56 manjaromachine systemd[1]: Mounting Kernel Configuration File S>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Remount Root and Kernel Fil>
Apr 24 18:03:56 manjaromachine systemd[1]: Condition check resulted in First Bo>
Apr 24 18:03:56 manjaromachine systemd[1]: Condition check resulted in Rebuild >
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Load/Save Random Seed...
Apr 24 18:03:56 manjaromachine systemd[1]: Condition check resulted in Create S>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Create Static Device Nodes >
Apr 24 18:03:56 manjaromachine systemd[1]: Mounted Kernel Configuration File Sy>
Apr 24 18:03:56 manjaromachine kernel: fuse: init (API version 7.32)
Apr 24 18:03:56 manjaromachine systemd[1]: modprobe@fuse.service: Succeeded.
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Load Kernel Module fuse.
Apr 24 18:03:56 manjaromachine systemd[1]: Mounting FUSE Control File System...
Apr 24 18:03:56 manjaromachine systemd[1]: Mounted FUSE Control File System.
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Create Static Device Nodes >
Apr 24 18:03:56 manjaromachine systemd[1]: Started Entropy Daemon based on the >
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Journal Service...
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Rule-based Manager for Devi>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Setup Virtual Console.
Apr 24 18:03:56 manjaromachine kernel: usb 1-3: New USB device found, idVendor=>
Apr 24 18:03:56 manjaromachine kernel: usb 1-3: New USB device strings: Mfr=0, >
Apr 24 18:03:56 manjaromachine kernel: usb 1-3: Product: USB GAMING MOUSE
Apr 24 18:03:56 manjaromachine kernel: audit: type=1400 audit(1619280236.390:2)>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Coldplug All udev Devices.
Apr 24 18:03:56 manjaromachine kernel: audit: type=1130 audit(1619280236.390:3)>
Apr 24 18:03:56 manjaromachine kernel: audit: type=1400 audit(1619280236.400:4)>
Apr 24 18:03:56 manjaromachine kernel: audit: type=1400 audit(1619280236.400:5)>
Apr 24 18:03:56 manjaromachine systemd-journald[319]: Journal started
Apr 24 18:03:56 manjaromachine systemd-journald[319]: Runtime Journal (/run/log>
Apr 24 18:03:56 manjaromachine audit[311]: AVC apparmor="STATUS" operation="pro>
Apr 24 18:03:56 manjaromachine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967>
Apr 24 18:03:56 manjaromachine audit[312]: AVC apparmor="STATUS" operation="pro>
Apr 24 18:03:56 manjaromachine systemd-modules-load[294]: Inserted module 'cryp>
Apr 24 18:03:56 manjaromachine systemd-modules-load[294]: Module 'msr' is built>
Apr 24 18:03:56 manjaromachine systemd[1]: Started Journal Service.
Apr 24 18:03:56 manjaromachine kernel: audit: type=1130 audit(1619280236.400:6)>
Apr 24 18:03:56 manjaromachine systemd-random-seed[304]: Kernel entropy pool is>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Flush Journal to Persistent>
Apr 24 18:03:56 manjaromachine apparmor.systemd[287]: Restarting AppArmor
Apr 24 18:03:56 manjaromachine apparmor.systemd[287]: Reloading AppArmor profil>
Apr 24 18:03:56 manjaromachine haveged[318]: haveged: command socket is listeni>
Apr 24 18:03:56 manjaromachine systemd-journald[319]: Time spent on flushing to>
Apr 24 18:03:56 manjaromachine systemd-journald[319]: System Journal (/var/log/>
Apr 24 18:03:56 manjaromachine kernel: audit: type=1130 audit(1619280236.410:7)>
Apr 24 18:03:56 manjaromachine kernel: audit: type=1130 audit(1619280236.430:8)>
Apr 24 18:03:56 manjaromachine kernel: audit: type=1400 audit(1619280236.440:9)>
Apr 24 18:03:56 manjaromachine kernel: input: Asus Wireless Radio Control as /d>
Apr 24 18:03:56 manjaromachine audit[310]: AVC apparmor="STATUS" operation="pro>
Apr 24 18:03:56 manjaromachine systemd[1]: Started Rule-based Manager for Devic>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Show Plymouth Boot Screen...
Apr 24 18:03:56 manjaromachine systemd[1]: Started Show Plymouth Boot Screen.
Apr 24 18:03:56 manjaromachine systemd[1]: Condition check resulted in Dispatch>
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Local Encrypted Volum>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Flush Journal to Persistent>
Apr 24 18:03:56 manjaromachine kernel: audit: type=1130 audit(1619280236.450:10>
Apr 24 18:03:56 manjaromachine kernel: ACPI BIOS Error (bug): Could not resolve>
Apr 24 18:03:56 manjaromachine kernel: ACPI Error: Aborting method \_SB.IETM.ID>
Apr 24 18:03:56 manjaromachine kernel: ACPI Warning: \_SB.IETM._TRT: Return Pac>
Apr 24 18:03:56 manjaromachine kernel: acpi PNP0C14:03: duplicate WMI GUID 0590>
Apr 24 18:03:56 manjaromachine kernel: acpi PNP0C14:04: duplicate WMI GUID 0590>
Apr 24 18:03:56 manjaromachine mtp-probe[378]: checking bus 1, device 2: "/sys/>
Apr 24 18:03:56 manjaromachine mtp-probe[378]: bus: 1, device: 2 was not an MTP>
Apr 24 18:03:56 manjaromachine kernel: intel_pch_thermal 0000:00:12.0: enabling>
Apr 24 18:03:56 manjaromachine kernel: proc_thermal 0000:00:04.0: enabling devi>
Apr 24 18:03:56 manjaromachine kernel: Linux agpgart interface v0.103
Apr 24 18:03:56 manjaromachine kernel: intel_rapl_common: Found RAPL domain pac>
Apr 24 18:03:56 manjaromachine kernel: intel_rapl_common: Found RAPL domain dram
Apr 24 18:03:56 manjaromachine kernel: usb 1-5: new low-speed USB device number>
Apr 24 18:03:56 manjaromachine audit[308]: AVC apparmor="STATUS" operation="pro>
Apr 24 18:03:56 manjaromachine systemd[1]: Found device WDC PC SN530 SDBPNPZ-1T>
Apr 24 18:03:56 manjaromachine kernel: tsc: Refined TSC clocksource calibration>
Apr 24 18:03:56 manjaromachine kernel: clocksource: tsc: mask: 0xffffffffffffff>
Apr 24 18:03:56 manjaromachine kernel: intel-lpss 0000:00:15.0: enabling device>
Apr 24 18:03:56 manjaromachine kernel: idma64 idma64.0: Found Intel integrated >
Apr 24 18:03:56 manjaromachine kernel: proc_thermal 0000:00:04.0: Creating sysf>
Apr 24 18:03:56 manjaromachine kernel: intel-lpss 0000:00:15.1: enabling device>
Apr 24 18:03:56 manjaromachine kernel: idma64 idma64.1: Found Intel integrated >
Apr 24 18:03:56 manjaromachine kernel: i2c_hid i2c-ELAN1203:00: supply vdd not >
Apr 24 18:03:56 manjaromachine kernel: i2c_hid i2c-ELAN1203:00: supply vddl not>
Apr 24 18:03:56 manjaromachine kernel: nvidia: loading out-of-tree module taint>
Apr 24 18:03:56 manjaromachine kernel: nvidia: module license 'NVIDIA' taints k>
Apr 24 18:03:56 manjaromachine kernel: Disabling lock debugging due to kernel t>
Apr 24 18:03:56 manjaromachine haveged[318]: haveged: ver: 1.9.14; arch: x86; v>
Apr 24 18:03:56 manjaromachine haveged[318]: haveged: cpu: (L4 VC); data: 32K (>
Apr 24 18:03:56 manjaromachine haveged[318]: haveged: tot tests(BA8): A:1/1 B:1>
Apr 24 18:03:56 manjaromachine haveged[318]: haveged: fills: 0, generated: 0
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Load/Save Random Seed.
Apr 24 18:03:56 manjaromachine kernel: random: crng init done
Apr 24 18:03:56 manjaromachine audit[309]: AVC apparmor="STATUS" operation="pro>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Load AppArmor profiles.
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Load AppArmor profiles mana>
Apr 24 18:03:56 manjaromachine snapd-apparmor[386]: find: ‘/var/lib/snapd/appar>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Load AppArmor profiles mana>
Apr 24 18:03:56 manjaromachine kernel: nvidia: module verification failed: sign>
Apr 24 18:03:56 manjaromachine kernel: mei_me 0000:00:16.0: enabling device (00>
Apr 24 18:03:56 manjaromachine kernel: usb 1-5: New USB device found, idVendor=>
Apr 24 18:03:56 manjaromachine kernel: usb 1-5: New USB device strings: Mfr=1, >
Apr 24 18:03:56 manjaromachine kernel: usb 1-5: Product: USB KEYBOARD
Apr 24 18:03:56 manjaromachine kernel: usb 1-5: Manufacturer: SINO WEALTH
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Monitoring of LVM2 mirrors,>
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Local File Systems (P>
Apr 24 18:03:56 manjaromachine systemd[1]: Condition check resulted in Virtual >
Apr 24 18:03:56 manjaromachine systemd[1]: Starting File System Check on /dev/d>
Apr 24 18:03:56 manjaromachine kernel: input: PC Speaker as /devices/platform/p>
Apr 24 18:03:56 manjaromachine systemd-fsck[396]: fsck.fat 4.2 (2021-01-31)
Apr 24 18:03:56 manjaromachine systemd-fsck[396]: /dev/nvme0n1p3: 186 files, 25>
Apr 24 18:03:56 manjaromachine kernel: i801_smbus 0000:00:1f.4: SPD Write Disab>
Apr 24 18:03:56 manjaromachine kernel: cfg80211: Loading compiled-in X.509 cert>
Apr 24 18:03:56 manjaromachine kernel: i801_smbus 0000:00:1f.4: SMBus using PCI>
Apr 24 18:03:56 manjaromachine kernel: nvidia-nvlink: Nvlink Core is being init>
Apr 24 18:03:56 manjaromachine kernel: nvidia 0000:01:00.0: enabling device (00>
Apr 24 18:03:56 manjaromachine kernel: nvidia 0000:01:00.0: vgaarb: changed VGA>
Apr 24 18:03:56 manjaromachine kernel: i2c i2c-2: 2/4 memory slots populated (f>
Apr 24 18:03:56 manjaromachine kernel: cfg80211: Loaded X.509 cert 'sforshee: 0>
Apr 24 18:03:56 manjaromachine kernel: i2c i2c-2: Successfully instantiated SPD>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished File System Check on /dev/d>
Apr 24 18:03:56 manjaromachine systemd[1]: Mounting /boot/efi...
Apr 24 18:03:56 manjaromachine kernel: r8169 0000:03:00.0: enabling device (000>
Apr 24 18:03:56 manjaromachine systemd[1]: Mounted /boot/efi.
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Local File Systems.
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Tell Plymouth To Write Out >
Apr 24 18:03:56 manjaromachine systemd[1]: Condition check resulted in Store a >
Apr 24 18:03:56 manjaromachine systemd[1]: Condition check resulted in Commit a>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Create Volatile Files and D>
Apr 24 18:03:56 manjaromachine systemd[1]: Received SIGRTMIN+20 from PID 214 (p>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Create Volatile Files and D>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Tell Plymouth To Write Out >
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Network Time Synchronizatio>
Apr 24 18:03:56 manjaromachine systemd[1]: Condition check resulted in Update i>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Update UTMP about System Bo>
Apr 24 18:03:56 manjaromachine kernel: Intel(R) Wireless WiFi driver for Linux
Apr 24 18:03:56 manjaromachine kernel: iwlwifi 0000:00:14.3: enabling device (0>
Apr 24 18:03:56 manjaromachine kernel: iwlwifi 0000:00:14.3: api flags index 2 >
Apr 24 18:03:56 manjaromachine kernel: iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSIO>
Apr 24 18:03:56 manjaromachine kernel: iwlwifi 0000:00:14.3: loaded firmware ve>
Apr 24 18:03:56 manjaromachine audit[426]: SYSTEM_BOOT pid=426 uid=0 auid=42949>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Update UTMP about System Bo>
Apr 24 18:03:56 manjaromachine systemd-modules-load[294]: Inserted module 'nvid>
Apr 24 18:03:56 manjaromachine kernel: libphy: r8169: probed
Apr 24 18:03:56 manjaromachine kernel: r8169 0000:03:00.0 eth0: RTL8168h/8111h,>
Apr 24 18:03:56 manjaromachine kernel: r8169 0000:03:00.0 eth0: jumbo features >
Apr 24 18:03:56 manjaromachine kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel >
Apr 24 18:03:56 manjaromachine kernel: RAPL PMU: API unit is 2^-32 Joules, 5 fi>
Apr 24 18:03:56 manjaromachine kernel: RAPL PMU: hw unit of domain pp0-core 2^->
Apr 24 18:03:56 manjaromachine kernel: RAPL PMU: hw unit of domain package 2^-1>
Apr 24 18:03:56 manjaromachine kernel: RAPL PMU: hw unit of domain dram 2^-14 J>
Apr 24 18:03:56 manjaromachine kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-1>
Apr 24 18:03:56 manjaromachine kernel: RAPL PMU: hw unit of domain psys 2^-14 J>
Apr 24 18:03:56 manjaromachine kernel: cryptd: max_cpu_qlen set to 1000
Apr 24 18:03:56 manjaromachine kernel: AVX2 version of gcm_enc/dec engaged.
Apr 24 18:03:56 manjaromachine kernel: AES CTR mode by8 optimization enabled
Apr 24 18:03:56 manjaromachine kernel: nvidia-modeset: Loading NVIDIA Kernel Mo>
Apr 24 18:03:56 manjaromachine kernel: [drm] [nvidia-drm] [GPU ID 0x00000100] L>
Apr 24 18:03:56 manjaromachine kernel: [drm] Initialized nvidia-drm 0.0.0 20160>
Apr 24 18:03:56 manjaromachine kernel: usb 1-8: new full-speed USB device numbe>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Load Kernel Modules.
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Apply Kernel Variables...
Apr 24 18:03:56 manjaromachine systemd-sysctl[447]: Not setting net/ipv4/conf/a>
Apr 24 18:03:56 manjaromachine systemd-sysctl[447]: Not setting net/ipv4/conf/d>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Apply Kernel Variables.
Apr 24 18:03:56 manjaromachine systemd[1]: Starting CLI Netfilter Manager...
Apr 24 18:03:56 manjaromachine ufw-init[455]: Skip starting firewall: ufw (not >
Apr 24 18:03:56 manjaromachine systemd[1]: Finished CLI Netfilter Manager.
Apr 24 18:03:56 manjaromachine kernel: input: ELAN1203:00 04F3:307A Mouse as /d>
Apr 24 18:03:56 manjaromachine kernel: input: ELAN1203:00 04F3:307A Touchpad as>
Apr 24 18:03:56 manjaromachine kernel: hid-generic 0018:04F3:307A.0001: input,h>
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:01:00.2: remove, state 4
Apr 24 18:03:56 manjaromachine kernel: usb usb4: USB disconnect, device number 1
Apr 24 18:03:56 manjaromachine systemd[1]: Started Network Time Synchronization.
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target System Initialization.
Apr 24 18:03:56 manjaromachine systemd[1]: Started CUPS Scheduler.
Apr 24 18:03:56 manjaromachine systemd[1]: Started Daily Cleanup of Temporary D>
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Paths.
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target System Time Set.
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target System Time Synchroni>
Apr 24 18:03:56 manjaromachine systemd[1]: Started Daily rotation of log files.
Apr 24 18:03:56 manjaromachine systemd[1]: Started Daily man-db regeneration.
Apr 24 18:03:56 manjaromachine systemd[1]: Started Monthly clean packages cache.
Apr 24 18:03:56 manjaromachine systemd[1]: Started Generate mirrorlist weekly.
Apr 24 18:03:56 manjaromachine systemd[1]: Started pkgfile database update time>
Apr 24 18:03:56 manjaromachine systemd[1]: Started Daily verification of passwo>
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Timers.
Apr 24 18:03:56 manjaromachine systemd[1]: Listening on CUPS Scheduler.
Apr 24 18:03:56 manjaromachine systemd[1]: Listening on D-Bus System Message Bu>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Socket activation for snapp>
Apr 24 18:03:56 manjaromachine systemd[1]: Listening on Socket activation for s>
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Sockets.
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Basic System.
Apr 24 18:03:56 manjaromachine systemd[1]: Started D-Bus System Message Bus.
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Network Manager...
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:01:00.2: USB bus 4 deregis>
Apr 24 18:03:56 manjaromachine kernel: usb usb3: USB disconnect, device number 1
Apr 24 18:03:56 manjaromachine kernel: xhci_hcd 0000:01:00.2: USB bus 3 deregis>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Clean up modules from old k>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Authorization Manager...
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Snap Daemon...
Apr 24 18:03:56 manjaromachine audit: BPF prog-id=7 op=LOAD
Apr 24 18:03:56 manjaromachine audit: BPF prog-id=8 op=LOAD
Apr 24 18:03:56 manjaromachine systemd[1]: Starting User Login Management...
Apr 24 18:03:56 manjaromachine linux-module-cleanup[466]: cat: /usr/lib/modules>
Apr 24 18:03:56 manjaromachine systemd[1]: linux-module-cleanup.service: Succee>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Clean up modules from old k>
Apr 24 18:03:56 manjaromachine audit[1]: SERVICE_STOP pid=1 uid=0 auid=42949672>
Apr 24 18:03:56 manjaromachine polkitd[462]: Started polkitd version 0.118
Apr 24 18:03:56 manjaromachine NetworkManager[460]: <info>  [1619280236.9805] N>
Apr 24 18:03:56 manjaromachine NetworkManager[460]: <info>  [1619280236.9805] R>
Apr 24 18:03:56 manjaromachine systemd[1]: Started Network Manager.
Apr 24 18:03:56 manjaromachine NetworkManager[460]: <info>  [1619280236.9823] b>
Apr 24 18:03:56 manjaromachine systemd[1]: Reached target Network.
Apr 24 18:03:56 manjaromachine systemd[1]: Starting CUPS Scheduler...
Apr 24 18:03:56 manjaromachine systemd[1]: Started Mullvad VPN daemon.
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Permit User Sessions...
Apr 24 18:03:56 manjaromachine NetworkManager[460]: <info>  [1619280236.9873] m>
Apr 24 18:03:56 manjaromachine dbus-daemon[458]: [system] Activating via system>
Apr 24 18:03:56 manjaromachine systemd[1]: Finished Permit User Sessions.
Apr 24 18:03:56 manjaromachine systemd[1]: Starting GNOME Display Manager...
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Hold until boot process fin>
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Terminate Plymouth Boot Scr>
Apr 24 18:03:56 manjaromachine audit: BPF prog-id=9 op=LOAD
Apr 24 18:03:56 manjaromachine audit: BPF prog-id=10 op=LOAD
Apr 24 18:03:56 manjaromachine systemd[1]: Starting Hostname Service...
Apr 24 18:03:56 manjaromachine snapd[463]: AppArmor status: apparmor is enabled>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_daemon::version][I>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_daemon][INFO] Logg>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_daemon::rpc_unique>
Apr 24 18:03:57 manjaromachine systemd[1]: Received SIGRTMIN+21 from PID 214 (p>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_daemon][INFO] Mana>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_rpc::address_cache>
Apr 24 18:03:57 manjaromachine systemd[1]: Finished Hold until boot process fin>
Apr 24 18:03:57 manjaromachine systemd[1]: Finished Terminate Plymouth Boot Scr>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_daemon::relays][DE>
Apr 24 18:03:57 manjaromachine systemd[1]: Started CUPS Scheduler.
Apr 24 18:03:57 manjaromachine snapd[463]: daemon.go:347: started snapd/2.49.2->
Apr 24 18:03:57 manjaromachine polkitd[462]: Loading rules from directory /etc/>
Apr 24 18:03:57 manjaromachine polkitd[462]: Loading rules from directory /usr/>
Apr 24 18:03:57 manjaromachine polkitd[462]: Finished loading, compiling and ex>
Apr 24 18:03:57 manjaromachine systemd[1]: Started Authorization Manager.
Apr 24 18:03:57 manjaromachine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967>
Apr 24 18:03:57 manjaromachine polkitd[462]: Acquired the name org.freedesktop.>
Apr 24 18:03:57 manjaromachine systemd[1]: Starting Modem Manager...
Apr 24 18:03:57 manjaromachine ModemManager[525]: <info>  ModemManager (version>
Apr 24 18:03:57 manjaromachine systemd-logind[464]: Watching system buttons on >
Apr 24 18:03:57 manjaromachine kernel: usb 1-8: New USB device found, idVendor=>
Apr 24 18:03:57 manjaromachine kernel: usb 1-8: New USB device strings: Mfr=1, >
Apr 24 18:03:57 manjaromachine kernel: usb 1-8: Product: N-KEY Device
Apr 24 18:03:57 manjaromachine kernel: usb 1-8: Manufacturer: ASUSTeK Computer >
Apr 24 18:03:57 manjaromachine systemd-logind[464]: New seat seat0.
Apr 24 18:03:57 manjaromachine dbus-daemon[458]: [system] Successfully activate>
Apr 24 18:03:57 manjaromachine systemd[1]: Started Hostname Service.
Apr 24 18:03:57 manjaromachine systemd[1]: Started Modem Manager.
Apr 24 18:03:57 manjaromachine systemd[1]: Started User Login Management.
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.0876] h>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.0883] d>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.0888] m>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.0889] m>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1005] L>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1014] L>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1099] L>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1106] L>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1112] L>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1116] L>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1119] m>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1120] m>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1121] m>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1126] d>
Apr 24 18:03:57 manjaromachine dbus-daemon[458]: [system] Activating via system>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1128] s>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1139] d>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1143] m>
Apr 24 18:03:57 manjaromachine systemd[1]: Starting Network Manager Script Disp>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1158] m>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1185] o>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.1195] m>
Apr 24 18:03:57 manjaromachine systemd[1]: Started Network Manager Script Dispa>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_daemon::relays][IN>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_daemon::settings][>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_daemon::version_ch>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_daemon::account_hi>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_daemon][DEBUG] No >
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [mullvad_daemon][INFO] Auto>
Apr 24 18:03:57 manjaromachine mullvad-daemon[489]: [talpid_core::firewall][INF>
Apr 24 18:03:57 manjaromachine kernel: loop: module loaded
Apr 24 18:03:57 manjaromachine kernel: usb 1-14: new full-speed USB device numb>
Apr 24 18:03:57 manjaromachine kernel: snd_hda_intel 0000:00:1f.3: DSP detected>
Apr 24 18:03:57 manjaromachine kernel: snd_hda_intel 0000:00:1f.3: enabling dev>
Apr 24 18:03:57 manjaromachine kernel: checking generic (a0000000 7f0000) vs hw>
Apr 24 18:03:57 manjaromachine kernel: fb0: switching to inteldrmfb from EFI VGA
Apr 24 18:03:57 manjaromachine kernel: i915 0000:00:02.0: vgaarb: deactivate vg>
Apr 24 18:03:57 manjaromachine kernel: i915 0000:00:02.0: vgaarb: changed VGA d>
Apr 24 18:03:57 manjaromachine kernel: i915 0000:00:02.0: [drm] Finished loadin>
Apr 24 18:03:57 manjaromachine kernel: iwlwifi 0000:00:14.3: Detected Intel(R) >
Apr 24 18:03:57 manjaromachine kernel: [drm] Initialized i915 1.6.0 20200917 fo>
Apr 24 18:03:57 manjaromachine kernel: ACPI: Video Device [GFX0] (multi-head: y>
Apr 24 18:03:57 manjaromachine kernel: input: Video Bus as /devices/LNXSYSTM:00>
Apr 24 18:03:57 manjaromachine kernel: ACPI: Video Device [PEGP] (multi-head: n>
Apr 24 18:03:57 manjaromachine kernel: snd_hda_intel 0000:00:1f.3: bound 0000:0>
Apr 24 18:03:57 manjaromachine kernel: fbcon: i915drmfb (fb0) is primary device
Apr 24 18:03:57 manjaromachine kernel: fbcon: Deferring console take-over
Apr 24 18:03:57 manjaromachine kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb >
Apr 24 18:03:57 manjaromachine kernel: usb 1-14: New USB device found, idVendor>
Apr 24 18:03:57 manjaromachine kernel: usb 1-14: New USB device strings: Mfr=0,>
Apr 24 18:03:57 manjaromachine kernel: iwlwifi 0000:00:14.3: base HW address: c>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.5075] d>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.5082] m>
Apr 24 18:03:57 manjaromachine kernel: thermal thermal_zone6: failed to read ou>
Apr 24 18:03:57 manjaromachine systemd[1]: Listening on Load/Save RF Kill Switc>
Apr 24 18:03:57 manjaromachine systemd[1]: Starting Load/Save RF Kill Switch St>
Apr 24 18:03:57 manjaromachine systemd[1]: tmp-sanity\x2dmountpoint\x2d41921005>
Apr 24 18:03:57 manjaromachine kernel: squashfs: version 4.0 (2009/01/31) Phill>
Apr 24 18:03:57 manjaromachine kernel: intel_rapl_common: Found RAPL domain pac>
Apr 24 18:03:57 manjaromachine kernel: intel_rapl_common: Found RAPL domain core
Apr 24 18:03:57 manjaromachine kernel: intel_rapl_common: Found RAPL domain unc>
Apr 24 18:03:57 manjaromachine kernel: intel_rapl_common: Found RAPL domain dram
Apr 24 18:03:57 manjaromachine kernel: intel_rapl_common: Found RAPL domain psys
Apr 24 18:03:57 manjaromachine kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2>
Apr 24 18:03:57 manjaromachine kernel: asus_wmi: ASUS WMI generic driver loaded
Apr 24 18:03:57 manjaromachine kernel: asus_wmi: Initialization: 0x1
Apr 24 18:03:57 manjaromachine kernel: asus_wmi: BIOS WMI version: 9.0
Apr 24 18:03:57 manjaromachine kernel: asus_wmi: SFUN value: 0x21
Apr 24 18:03:57 manjaromachine kernel: asus-nb-wmi asus-nb-wmi: Detected ATK, n>
Apr 24 18:03:57 manjaromachine kernel: asus-nb-wmi asus-nb-wmi: Detected ATK, e>
Apr 24 18:03:57 manjaromachine kernel: input: Asus WMI hotkeys as /devices/plat>
Apr 24 18:03:57 manjaromachine kernel: snd_hda_codec_realtek hdaudioC0D0: autoc>
Apr 24 18:03:57 manjaromachine kernel: snd_hda_codec_realtek hdaudioC0D0:    sp>
Apr 24 18:03:57 manjaromachine kernel: snd_hda_codec_realtek hdaudioC0D0:    hp>
Apr 24 18:03:57 manjaromachine kernel: snd_hda_codec_realtek hdaudioC0D0:    mo>
Apr 24 18:03:57 manjaromachine kernel: snd_hda_codec_realtek hdaudioC0D0:    in>
Apr 24 18:03:57 manjaromachine kernel: snd_hda_codec_realtek hdaudioC0D0:      >
Apr 24 18:03:57 manjaromachine kernel: battery: new extension: ASUS Battery Ext>
Apr 24 18:03:57 manjaromachine kernel: iTCO_vendor_support: vendor-support=0
Apr 24 18:03:57 manjaromachine kernel: iTCO_wdt: Intel TCO WatchDog Timer Drive>
Apr 24 18:03:57 manjaromachine kernel: iTCO_wdt: Found a Intel PCH TCO device (>
Apr 24 18:03:57 manjaromachine kernel: iTCO_wdt: initialized. heartbeat=30 sec >
Apr 24 18:03:57 manjaromachine kernel: ee1004 2-0050: 512 byte EE1004-compliant>
Apr 24 18:03:57 manjaromachine kernel: ee1004 2-0052: 512 byte EE1004-compliant>
Apr 24 18:03:57 manjaromachine kernel: r8169 0000:03:00.0 eno2: renamed from et>
Apr 24 18:03:57 manjaromachine snapd[463]: daemon.go:440: adjusting startup tim>
Apr 24 18:03:57 manjaromachine systemd[1]: Started GNOME Display Manager.
Apr 24 18:03:57 manjaromachine systemd[1]: Reached target User and Group Name L>
Apr 24 18:03:57 manjaromachine systemd[1]: Starting Accounts Service...
Apr 24 18:03:57 manjaromachine systemd[1]: Started Snap Daemon.
Apr 24 18:03:57 manjaromachine systemd[1]: Reached target Multi-User System.
Apr 24 18:03:57 manjaromachine systemd[1]: Reached target Graphical Interface.
Apr 24 18:03:57 manjaromachine systemd[1]: Starting TLP system startup/shutdown>
Apr 24 18:03:57 manjaromachine accounts-daemon[589]: started daemon version 0.6>
Apr 24 18:03:57 manjaromachine systemd[1]: Created slice system-systemd\x2dback>
Apr 24 18:03:57 manjaromachine systemd[1]: Starting Load/Save Screen Backlight >
Apr 24 18:03:57 manjaromachine systemd[1]: Started Accounts Service.
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.7163] r>
Apr 24 18:03:57 manjaromachine systemd[1]: Started Load/Save RF Kill Switch Sta>
Apr 24 18:03:57 manjaromachine audit[603]: USER_AUTH pid=603 uid=0 auid=4294967>
Apr 24 18:03:57 manjaromachine audit[603]: USER_ACCT pid=603 uid=0 auid=4294967>
Apr 24 18:03:57 manjaromachine audit[603]: CRED_ACQ pid=603 uid=0 auid=42949672>
Apr 24 18:03:57 manjaromachine systemd[1]: Created slice User Slice of UID 120.
Apr 24 18:03:57 manjaromachine systemd[1]: Starting User Runtime Directory /run>
Apr 24 18:03:57 manjaromachine systemd-logind[464]: New session 1 of user gdm.
Apr 24 18:03:57 manjaromachine systemd[1]: Finished User Runtime Directory /run>
Apr 24 18:03:57 manjaromachine systemd[1]: Starting User Manager for UID 120...
Apr 24 18:03:57 manjaromachine dbus-daemon[458]: [system] Activation via system>
Apr 24 18:03:57 manjaromachine systemd[641]: pam_systemd_home(systemd-user:acco>
Apr 24 18:03:57 manjaromachine audit[641]: USER_ACCT pid=641 uid=0 auid=4294967>
Apr 24 18:03:57 manjaromachine audit[641]: CRED_ACQ pid=641 uid=0 auid=42949672>
Apr 24 18:03:57 manjaromachine systemd[641]: pam_warn(systemd-user:setcred): fu>
Apr 24 18:03:57 manjaromachine systemd[641]: pam_unix(systemd-user:session): se>
Apr 24 18:03:57 manjaromachine systemd[641]: pam_env(systemd-user:session): dep>
Apr 24 18:03:57 manjaromachine audit[641]: USER_START pid=641 uid=0 auid=120 se>
Apr 24 18:03:57 manjaromachine audit: BPF prog-id=11 op=LOAD
Apr 24 18:03:57 manjaromachine audit: BPF prog-id=11 op=UNLOAD
Apr 24 18:03:57 manjaromachine snapd[463]: stateengine.go:150: state ensure err>
Apr 24 18:03:57 manjaromachine NetworkManager[460]: <info>  [1619280237.8108] d>
Apr 24 18:03:57 manjaromachine systemd-xdg-autostart-generator[667]: Configurat>
Apr 24 18:03:57 manjaromachine kernel: iwlwifi 0000:00:14.3 wlo1: renamed from >
Apr 24 18:03:57 manjaromachine tlp[598]: Applying power save settings...done.
Apr 24 18:03:57 manjaromachine systemd[641]: Queued start job for default targe>
Apr 24 18:03:57 manjaromachine systemd[641]: -.slice: Failed to migrate control>
Apr 24 18:03:57 manjaromachine systemd[641]: Created slice User Application Sli>
Apr 24 18:03:57 manjaromachine systemd[641]: Reached target Paths.
Apr 24 18:03:57 manjaromachine systemd[641]: Reached target Timers.
Apr 24 18:03:57 manjaromachine systemd[641]: Starting D-Bus User Message Bus So>
Apr 24 18:03:57 manjaromachine systemd[641]: Listening on GnuPG network certifi>
Apr 24 18:03:57 manjaromachine systemd[641]: Listening on GnuPG cryptographic a>
Apr 24 18:03:57 manjaromachine systemd[641]: Listening on p11-kit server.
Apr 24 18:03:57 manjaromachine systemd[641]: Listening on Multimedia System.
Apr 24 18:03:57 manjaromachine systemd[641]: Listening on Sound System.
Apr 24 18:03:57 manjaromachine systemd[641]: Listening on D-Bus User Message Bu>
Apr 24 18:03:57 manjaromachine systemd[641]: Reached target Sockets.
Apr 24 18:03:57 manjaromachine systemd[641]: Reached target Basic System.
Apr 24 18:03:57 manjaromachine systemd[1]: Started User Manager for UID 120.
Apr 24 18:03:57 manjaromachine systemd[641]: Starting Update XDG user dir confi>
Apr 24 18:03:57 manjaromachine systemd[1]: Started Session 1 of user gdm.
Apr 24 18:03:57 manjaromachine systemd[641]: xdg-user-dirs-update.service: Succ>
Apr 24 18:03:57 manjaromachine systemd[641]: Finished Update XDG user dir confi>
Apr 24 18:03:57 manjaromachine systemd[641]: Reached target Main User Target.
Apr 24 18:03:57 manjaromachine systemd[641]: Startup finished in 104ms.
Apr 24 18:03:57 manjaromachine kernel: input: ELAN1203:00 04F3:307A Mouse as /d>
Apr 24 18:03:57 manjaromachine kernel: input: ELAN1203:00 04F3:307A Touchpad as>
Apr 24 18:03:57 manjaromachine kernel: hid-multitouch 0018:04F3:307A.0001: inpu>
Apr 24 18:03:57 manjaromachine gdm-launch-environment][603]: pam_env(gdm-launch>
Apr 24 18:03:57 manjaromachine audit[603]: USER_START pid=603 uid=0 auid=120 se>
Apr 24 18:03:57 manjaromachine tlp[598]: Setting battery charge thresholds...do>
Apr 24 18:03:57 manjaromachine systemd[1]: Finished TLP system startup/shutdown.
Apr 24 18:03:58 manjaromachine kernel: input: USB GAMING MOUSE  as /devices/pci>
Apr 24 18:03:58 manjaromachine kernel: hid-generic 0003:18F8:0FC0.0002: input,h>
Apr 24 18:03:58 manjaromachine kernel: mousedev: PS/2 mouse device common for a>
Apr 24 18:03:58 manjaromachine kernel: input: USB GAMING MOUSE  Keyboard as /de>
Apr 24 18:03:58 manjaromachine kernel: input: USB GAMING MOUSE  Consumer Contro>
Apr 24 18:03:58 manjaromachine kernel: input: USB GAMING MOUSE  System Control >
Apr 24 18:03:58 manjaromachine kernel: hid-generic 0003:18F8:0FC0.0003: input,h>
Apr 24 18:03:58 manjaromachine kernel: input: SINO WEALTH USB KEYBOARD as /devi>
Apr 24 18:03:58 manjaromachine NetworkManager[460]: <info>  [1619280238.1210] d>
Apr 24 18:03:58 manjaromachine kernel: hid-generic 0003:258A:0001.0004: input,h>
Apr 24 18:03:58 manjaromachine kernel: input: SINO WEALTH USB KEYBOARD System C>
Apr 24 18:03:58 manjaromachine kernel: Generic FE-GE Realtek PHY r8169-300:00: >
Apr 24 18:03:58 manjaromachine kernel: input: SINO WEALTH USB KEYBOARD Consumer>
Apr 24 18:03:58 manjaromachine kernel: hid-generic 0003:258A:0001.0005: input,h>
Apr 24 18:03:58 manjaromachine kernel: input: ASUSTeK Computer Inc. N-KEY Devic>
Apr 24 18:03:58 manjaromachine kernel: hid-generic 0003:0B05:1866.0006: input,h>
Apr 24 18:03:58 manjaromachine kernel: hid-generic 0003:0B05:1866.0007: input,h>
Apr 24 18:03:58 manjaromachine kernel: input: HDA Intel PCH Headset Mic as /dev>
Apr 24 18:03:58 manjaromachine NetworkManager[460]: <info>  [1619280238.4424] s>
Apr 24 18:03:58 manjaromachine NetworkManager[460]: <info>  [1619280238.4434] d>
Apr 24 18:03:58 manjaromachine NetworkManager[460]: <info>  [1619280238.4435] d>
Apr 24 18:03:58 manjaromachine kernel: r8169 0000:03:00.0 eno2: Link is Down
Apr 24 18:03:58 manjaromachine kernel: input: HDA Intel PCH Headphone as /devic>
Apr 24 18:03:58 manjaromachine kernel: input: HDA Intel PCH HDMI/DP,pcm=3 as /d>
Apr 24 18:03:58 manjaromachine kernel: input: HDA Intel PCH HDMI/DP,pcm=7 as /d>
Apr 24 18:03:58 manjaromachine kernel: hid-generic 0003:0B05:1866.0008: input,h>
Apr 24 18:03:58 manjaromachine kernel: usbcore: registered new interface driver>
Apr 24 18:03:58 manjaromachine kernel: usbhid: USB HID core driver
Apr 24 18:03:58 manjaromachine kernel: input: HDA Intel PCH HDMI/DP,pcm=8 as /d>
Apr 24 18:03:58 manjaromachine kernel: input: HDA Intel PCH HDMI/DP,pcm=9 as /d>
Apr 24 18:03:58 manjaromachine kernel: input: HDA Intel PCH HDMI/DP,pcm=10 as />
Apr 24 18:03:58 manjaromachine mtp-probe[824]: checking bus 1, device 2: "/sys/>
Apr 24 18:03:58 manjaromachine mtp-probe[824]: bus: 1, device: 2 was not an MTP>
Apr 24 18:03:58 manjaromachine systemd[641]: Reached target Sound Card.
Apr 24 18:03:58 manjaromachine systemd[1]: Condition check resulted in Save/Res>
Apr 24 18:03:58 manjaromachine systemd[1]: Condition check resulted in Manage S>
Apr 24 18:03:58 manjaromachine systemd[1]: Reached target Sound Card.
Apr 24 18:03:58 manjaromachine systemd[1]: Finished Load/Save Screen Backlight >
Apr 24 18:03:58 manjaromachine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967>
Apr 24 18:03:58 manjaromachine systemd[1]: Startup finished in 5.295s (firmware>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (--) Log file renam>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (WW) Failed to open>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: X.Org X Server 1.20>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: X Protocol Version >
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: Build Operating Sys>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: Current Operating S>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: Kernel command line>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: Build Date: 13 Apri>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: Current version of >
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         Before repo>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         to make sur>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: Markers: (--) probe>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         (++) from c>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         (WW) warnin>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (==) Log file: "/va>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (==) Using config d>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (==) Using system c>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (==) ServerLayout ">
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (==) No screen sect>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (**) |-->Screen "De>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (**) |   |-->Monito>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (==) No monitor spe>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         Using a def>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (==) Automatically >
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (==) Max clients al>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (WW) The directory >
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         Entry delet>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (==) FontPath set t>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         /usr/share/>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (==) ModulePath set>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (II) The server rel>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         If no devic>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (II) Module ABI ver>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         X.Org ANSI >
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         X.Org Video>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         X.Org XInpu>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]:         X.Org Serve>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (++) using VT numbe>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (II) systemd-logind>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (II) xfree86: Addin>
Apr 24 18:03:58 manjaromachine /usr/lib/gdm-x-session[801]: (**) OutputClass "n>
Apr 24 18:03:58 manjaromachine NetworkManager[460]: <info>  [1619280238.6502] d>
Apr 24 18:03:57 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:37;?:0 f>
Apr 24 18:03:57 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:38;?:0 f>
Apr 24 18:03:57 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:38;outpu>
Apr 24 18:03:57 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:38;input>
Apr 24 18:03:57 manjaromachine audit[538]: NETFILTER_CFG table=mullvadmangle4:3>
Apr 24 18:03:57 manjaromachine audit[538]: NETFILTER_CFG table=mullvadmangle4:4>
Apr 24 18:03:57 manjaromachine audit[538]: NETFILTER_CFG table=mullvadmangle6:4>
Apr 24 18:03:57 manjaromachine audit[538]: NETFILTER_CFG table=?:0;?:0 family=0>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:38;outpu>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:38;input>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:38;?:0 f>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:43;?:0 f>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:43;outpu>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:43;input>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=mullvadmangle4:4>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=mullvadmangle6:4>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=?:0;?:0 family=0>
Apr 24 18:03:58 manjaromachine mullvad-daemon[489]: [talpid_core::firewall][INF>
Apr 24 18:03:58 manjaromachine mullvad-daemon[489]: [mullvad_rpc::rest][ERROR] >
Apr 24 18:03:58 manjaromachine mullvad-daemon[489]: [mullvad_daemon::relays][ER>
Apr 24 18:03:58 manjaromachine mullvad-daemon[489]: [mullvad_daemon][INFO] Acco>
Apr 24 18:03:58 manjaromachine mullvad-daemon[489]: [mullvad_daemon::wireguard]>
Apr 24 18:03:58 manjaromachine dbus-daemon[458]: [system] Activating via system>
Apr 24 18:03:58 manjaromachine kernel: cgroup: cgroup: disabling cgroup2 socket>
Apr 24 18:03:58 manjaromachine systemd[1]: Starting WPA supplicant...
Apr 24 18:03:58 manjaromachine NetworkManager[460]: <info>  [1619280238.8567] c>
Apr 24 18:03:58 manjaromachine audit[460]: USYS_CONFIG pid=460 uid=0 auid=42949>
Apr 24 18:03:58 manjaromachine NetworkManager[460]: <info>  [1619280238.8573] a>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:46;?:0 f>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:46;outpu>
Apr 24 18:03:58 manjaromachine audit[538]: NETFILTER_CFG table=mullvad:46;input>
Apr 24 18:03:58 manjaromachine mullvad-daemon[489]: [mullvad_daemon][DEBUG] New>
Apr 24 18:03:58 manjaromachine mullvad-daemon[489]: [mullvad_daemon][INFO] Bloc>
Apr 24 18:03:58 manjaromachine dbus-daemon[458]: [system] Successfully activate>
Apr 24 18:03:58 manjaromachine systemd[1]: Started WPA supplicant.
Apr 24 18:03:58 manjaromachine wpa_supplicant[883]: Successfully initialized wp>
Apr 24 18:03:59 manjaromachine mtp-probe[894]: checking bus 1, device 3: "/sys/>
Apr 24 18:03:59 manjaromachine mtp-probe[894]: bus: 1, device: 3 was not an MTP>
Apr 24 18:03:59 manjaromachine mtp-probe[897]: checking bus 1, device 4: "/sys/>
Apr 24 18:03:59 manjaromachine mtp-probe[897]: bus: 1, device: 4 was not an MTP>
Apr 24 18:03:59 manjaromachine NetworkManager[460]: <info>  [1619280239.1728] d>
Apr 24 18:03:59 manjaromachine NetworkManager[460]: <info>  [1619280239.1730] W>
Apr 24 18:03:59 manjaromachine NetworkManager[460]: <info>  [1619280239.1734] m>
Apr 24 18:03:59 manjaromachine NetworkManager[460]: <info>  [1619280239.1739] d>
Apr 24 18:03:59 manjaromachine NetworkManager[460]: <info>  [1619280239.1749] d>
Apr 24 18:03:59 manjaromachine NetworkManager[460]: <info>  [1619280239.1761] d>
Apr 24 18:03:59 manjaromachine NetworkManager[460]: <warn>  [1619280239.1767] s>
Apr 24 18:03:59 manjaromachine systemd-logind[464]: Watching system buttons on >
Apr 24 18:03:59 manjaromachine mtp-probe[967]: checking bus 1, device 3: "/sys/>
Apr 24 18:03:59 manjaromachine mtp-probe[967]: bus: 1, device: 3 was not an MTP>
Apr 24 18:03:59 manjaromachine mtp-probe[968]: checking bus 1, device 4: "/sys/>
Apr 24 18:03:59 manjaromachine mtp-probe[968]: bus: 1, device: 4 was not an MTP>
Apr 24 18:03:59 manjaromachine kernel: Bluetooth: Core ver 2.22
Apr 24 18:03:59 manjaromachine kernel: NET: Registered protocol family 31
Apr 24 18:03:59 manjaromachine kernel: Bluetooth: HCI device and connection man>
Apr 24 18:03:59 manjaromachine kernel: Bluetooth: HCI socket layer initialized
Apr 24 18:03:59 manjaromachine kernel: Bluetooth: L2CAP socket layer initialized
Apr 24 18:03:59 manjaromachine kernel: Bluetooth: SCO socket layer initialized
Apr 24 18:03:59 manjaromachine /usr/lib/gdm-x-session[801]: (--) PCI:*(0@0:2:0)>
Apr 24 18:03:59 manjaromachine /usr/lib/gdm-x-session[801]: (--) PCI: (1@0:0:0)>
Apr 24 18:03:59 manjaromachine /usr/lib/gdm-x-session[801]: (WW) Open ACPI fail>
Apr 24 18:03:59 manjaromachine /usr/lib/gdm-x-session[801]: (II) LoadModule: "g>
Apr 24 18:03:59 manjaromachine /usr/lib/gdm-x-session[801]: (II) Loading /usr/l>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) Module glx: ve>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]:         compiled fo>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]:         ABI class: >
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) Applying Outpu>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]:         loading dri>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (==) Matched modese>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (==) Matched intel >
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (==) Matched nvidia>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (==) Matched nouvea>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (==) Matched nv as >
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (==) Matched fbdev >
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (==) Matched vesa a>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (==) Assigned the d>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) LoadModule: "m>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) Loading /usr/l>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) Module modeset>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]:         Module clas>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) LoadModule: "i>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (WW) Warning, could>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (EE) Failed to load>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) LoadModule: "n>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) Module nvidia:>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) LoadModule: "f>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) LoadModule: "v>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modesetting: D>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) NVIDIA dlloade>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) NVIDIA Unified>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: xf86EnableIOPorts: >
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): us>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) systemd-logind>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) Loading sub mo>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) Module fb: ven>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) LoadModule: "w>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) Module wfb: ve>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) LoadModule: "r>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) Module "ramdac>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (WW) VGA arbiter: c>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Cr>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]:         "Default Sc>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (==) modeset(0): De>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (==) modeset(0): RG>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) LoadModule: "g>
Apr 24 18:04:00 manjaromachine kernel: usbcore: registered new interface driver>
Apr 24 18:04:00 manjaromachine kernel: Bluetooth: hci0: Firmware revision 0.0 b>
Apr 24 18:04:00 manjaromachine systemd[641]: Reached target Bluetooth.
Apr 24 18:04:00 manjaromachine systemd[1]: Starting Bluetooth service...
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) Module glamore>
Apr 24 18:04:00 manjaromachine bluetoothd[989]: Bluetooth daemon 5.58
Apr 24 18:04:00 manjaromachine systemd[1]: Started Bluetooth service.
Apr 24 18:04:00 manjaromachine audit[1]: SERVICE_START pid=1 uid=0 auid=4294967>
Apr 24 18:04:00 manjaromachine systemd[1]: Reached target Bluetooth.
Apr 24 18:04:00 manjaromachine bluetoothd[989]: Starting SDP server
Apr 24 18:04:00 manjaromachine bluetoothd[989]: Bluetooth management interface >
Apr 24 18:04:00 manjaromachine kernel: Bluetooth: BNEP (Ethernet Emulation) ver>
Apr 24 18:04:00 manjaromachine kernel: Bluetooth: BNEP filters: protocol multic>
Apr 24 18:04:00 manjaromachine kernel: Bluetooth: BNEP socket layer initialized
Apr 24 18:04:00 manjaromachine kernel: NET: Registered protocol family 38
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): gl>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Ou>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): ED>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Ma>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Ye>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Di>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): 8 >
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Ga>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): No>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Su>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Fi>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Pr>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): re>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): bl>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): cl>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): h_>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): v_>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Ra>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0):  N>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0):   >
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Mo>
Apr 24 18:04:00 manjaromachine /usr/lib/gdm-x-session[801]: (II) modeset(0): Mo>```
Alsa information is here:
https://alsa-project.org/db/?f=0e75063da049d43f7f31d2adce98069c5a4e388b
Screenshot of hdajackretask is here.
What are the options inside the hdajackretask drop-down menu???
:thinking:
Thanks for reply @Fabby .
Dropdown menu it’s like:
Headphone
Line Our (Front)
Line Out (Center/LFE)
Line Out (Back)
Line Out (Side)
Internal Speaker
Internal Speaker (LFE)
Internal Speaker (Back)
Dock Headphone
Dock Line Out
Not Connected.
  • Take any three of the unconnected pins and connect them to: (So 3 (three) unconnected pins to each and one of the above)
  • Click Apply now and test
  • If you get an error message, click Install Boot override and test
:crossed_fingers:
@Fabby I did that and I got something like Testing Dummy Sound but it didn’t work. :frowning:
I rebooted tried again I lost that Dummy Sound I got Internal Speaker but still same.
I tried with Boot Overide and still same.
screenshot, please?
@Fabby
Weird…
Can I have a screenshot of the hdajackretask window too to have a look at its current config, please?
:pray:
@Fabby first thanks for your time.
Here you go:
That should have worked if you:
  • clicked click Install Boot override
  • rebooted
  • tested
so I’m going to call someone else in. Can you:
alsa-info --update
execute the newly downloaded script (if any) with the --upload parameter and provide its output?
:sob:
@Fabby
It’s really weird tbh, it’s like hardware problem but in windows is working fine. I forgot to mention that I tried Fedora, Arch, Debian and it didn’t work in neither of them before.
When I try alsa-info it doesn’t find the command so I have to add “.sh” so “alsa-info.sh --update”, after update here is the info that I uploaded.
http://alsa-project.org/db/?f=1978ca0133dca3bba39d660b4cfb3ff788343bd0
Thanks.
@nikgnomic In the last 2 days could help 2 people with hdajackretask but not this one…
Inxi output
  Kernel: 5.10.30-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  root=UUID=dd557d72-d1fb-4e4c-abe6-f157663c842a rw quiet splash apparmor=1
  Desktop: GNOME 3.38.4 tk: GTK 3.24.28 wm: gnome-shell dm: GDM 40.0
  Type: Laptop System: ASUSTeK product: ROG Strix G712LV_G712LV v: 1.0
  serial: <filter>
  Mobo: ASUSTeK model: G712LV v: 1.0 serial: <filter>
  UEFI: American Megatrends v: G712LV.311 date: 01/08/2021
  ID-1: BAT0 charge: 36.4 Wh (63.6%) condition: 57.2/66.0 Wh (86.7%)
  volts: 15.7 min: 15.7 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
  status: Discharging cycles: 51
  Info: 8-Core model: Intel Core i7-10875H bits: 64 type: MT MCP
  arch: Comet Lake family: 6 model-id: A5 (165) stepping: 2 microcode: E0
  cache: L2: 16 MiB
  bogomips: 73598
  Speed: 900 MHz min/max: 800/5100 MHz Core speeds (MHz): 1: 900 2: 900
  3: 900 4: 900 5: 900 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900
  13: 900 14: 900 15: 900 16: 900
  Device-1: Intel UHD Graphics vendor: ASUSTeK driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
  Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: ASUSTeK
  driver: nvidia v: 460.67 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
  chip-ID: 10de:1f15 class-ID: 0300
  Display: x11 server: X.org 1.20.11 compositor: gnome-shell driver:
  loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.0.2
  direct render: Yes
  Device-1: Intel Comet Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  v: kernel alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3
  chip-ID: 8086:06c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.10.30-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.25 running: no
  Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
  port: 5000 bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  vendor: ASUSTeK driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
  IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:5
  chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 953.87 GiB used: 13.05 GiB (1.4%)
  model: PC SN530 SDBPNPZ-1T00-1002 size: 953.87 GiB block-size:
  physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
  serial: <filter> rev: 21106000 temp: 25.9 C scheme: GPT
  ID-1: / raw-size: 300.78 GiB size: 294.99 GiB (98.08%)
  used: 13.02 GiB (4.4%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
  used: 25.2 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 43.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 2600
  Processes: 339 Uptime: 38m wakeups: 4 Memory: 15.42 GiB
  used: 3.05 GiB (19.8%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: 10.2.0 Packages: pacman: 1207 lib: 318 flatpak: 0 Shell: Zsh v: 5.8
  running-in: gnome-terminal inxi: 3.3.04
:thinking:
Sorry for the delay on this one
I knew there was something odd about Asus ALC294 but I missed the possible solution from last year and went off around the wider internet for information
There was a post on here in Nov 2020 from a user with a ROG Strix G512LV
No sound from laptop's speakers - #4 by bogdancovaciu
based on a confirmed patch solution for ASUS ROG G512LU on Bugzilla
https://bugzilla.kernel.org/show_bug.cgi?id=206589#c7
( If the other solution does not work out the patch file option is worth trying, but it might not have the correct HDA Verbs for this laptop. I only know the basic theory of how HDA verbs work so I would not know how to work out hex numbers for HDA verbs if the suggested values did not work out)
The modprobe patch used by Manjaro OP is also confirmed on Askubuntu to work for Asus ROG Strix G15 G512LW , G17 G712LU and G712LV - No sound ALC294 Asus ROG Strix 512 Ubuntu 20.04.01
So I suggest:
run hdajackretask, click Remove boot override and reboot system to unmodified state with no retasks
Then use this command to add the modprobe option
echo 'options snd_hda_intel model=asus-zenbook ' | sudo tee --append /etc/modprobe.d/alsa-alc294-patch.conf
reboot again to make sure the model option is loaded
@nikgnomic @Fabby I am really sorry for delay response but I wasn’t home, I tried that solution offered from that user that you mention and it seems it worked but changing the volume of the sound it’s not working.
The solution was to put this line
options snd-hda-intel model=asus-zenbook
at
/etc/modprobe.d/alsa-base.conf
If you know anyway to fix volume of it that would be awesome if not it’s still okay,
Thanks guys <3
similar problem for me, though on different hardware, alc256. unfortunately neither hdajackretask, nor ‘options snd-hda-intel model=asus-zenbook’ solves it for me. interesting that going with real time kernel makes it work, but creates other problems, that’s why this is not the solution.
I have seen comments that this can be only a partial solution that only allows 0% or 100% volume in ALSA
The other modprobe option using patch file mentioned in the bugzilla report (alc294-sound-patch.fw) might work better for this particular laptop. But the patch was originally for an Asus zenbook, and an experienced Linux audio expert was not keen on this as a solution for other laptop models
Zenbook Mint 19 Cinnamon: No sound from laptop speakers - Linux Mint Forums
The verbs necessary will differ depending on the model of Zenbook
I think that it is more likely that the verbs will not be correct for this system and the modprobe option will fail
The optimal solution is to find the correct configuration verbs for the audio codec on this laptop model when it is working correctly (on Windows) to create a Linux patch with working audio verbs
There is a tutorial explaining how to get audio verbs from a Windows VM, but this would be difficult for an inexperienced Linux user to implement
How to sniff verbs from a Windows sound driver · ryanprescott/realtek-verb-tools Wiki · GitHub
I have never used a vm or HDA verbs to work out audio codec issues so this is beyond my experience
But other Manjaro users have posted about using HDA verbs to patch audio codecs:
Sound from speakers no sound from 3.5mm jack-audio - #20 by ZeroAnarchy
Hp Spectre 2020 - Speakers not working, the headphones do - #33 by Herschenglime
[HowTo] set up the audio card in Samsung Galaxy Book
