[root tip] [How To] Mini guide to build Manjaro ISO
Build Manjaro ISO
Prerequisites
  1. lots of diskspace (skip this if your root is sufficiently large)
  2. installing the tools
  3. tools configuration
  4. building
Diskspace
You need a lot diskspace - 15-20G per iso you intend to build
The tools
Install the manjaro-tools needed for building an ISO
sudo pacman -Syu git manjaro-tools-iso-git
Configure tools
With the tools installed copy the default tools configuration to your home
cp -R /etc/manjaro-tools  ~/.config
Modify the tools configuration to point to your storage partition’s mount point - use your favorite editor to edit the file
micro ~/.config/manjaro-tools/manjaro-tools.conf
Then use git to clone the iso profiles repo in your home
git clone https://gitlab.manjaro.org/profiles-and-settings/iso-profiles
Create a config file ~/.config/manjaro-tools/iso-profiles.conf with content
run_dir=/home/<your-username>/iso-profiles
Building
The building can be as simple as
buildiso -p kde
If you did not change the paths in manjaro-tools.conf the resulting kde ISO is stored at
/var/cache/manjaro-tools/iso/manjaro/kde
Advanced Use
The ISO cake layers
Package Lists Configuration Files File system Overlays / Shadows
Packages-Mhwd mhwdfs.sfs
Packages-Live live-overlay livefs.sfs desktop
Packages-Desktop desktop-overlay desktopfs.sfs root
Packages-Root root-overlay rootfs.sfs
The desktop.sfs and rootfs.sfs is unpacked by the installer to make the final system.
Customising the desktop packages
Inside the iso-profiles folder - create a new folder to hold you custom profile (assuming you cloned the iso-profiles to your home)
cd ~/iso-profiles
mkdir custom
Copy the profile you want to use e.g. KDE Plasma
cp -R manjaro/kde custom/plasma
Edit the file ~/iso-profiles/custom/plasma/Packages-Desktop - add and remove packages as you see fit.
Sample Customised Packages-Desktop
adobe-source-sans-pro-fonts
alsa-firmware
alsa-utils
ark
avahi
bluedevil
breeze-gtk
dolphin
dolphin-plugins
ffmpeg
ffmpegthumbs                       # video thumbnails
firefox
grub-btrfs
grub-theme-manjaro
gwenview
htop
inxi
kate
kcalc
kde-gtk-config
kdegraphics-thumbnailers           # PDF and PS thumbnails
kdeplasma-addons
kfind
kgamma
khelpcenter
kimageformats                      # support for dds, xcf, exr, psd, and more image formats
kinfocenter
kio-extras
kmenuedit
konsole
kscreen
kscreenlocker
ksshaskpass
ksystemlog
kwallet-pam
kwalletmanager
kwayland-integration
kwin
kwrited
libcanberra
libdvdcss
libva-intel-driver
libva-mesa-driver
manjaro-alsa
manjaro-application-utility
manjaro-browser-settings
manjaro-gstreamer
manjaro-hello
manjaro-kde-settings
manjaro-modem
manjaro-pipewire
mesa-utils
mobile-broadband-provider-info
modemmanager
networkmanager
networkmanager-l2tp
networkmanager-openconnect
networkmanager-openvpn
networkmanager-vpnc
noto-fonts                         # default font
nss-mdns                           # NSS support for mDNS (optdepend for avahi)
ntp
numlockx
okular
openssh
p7zip                              # 7Z format support
pamac-cli
pamac-gtk3
papirus-icon-theme                 # manjaro-application-utility icons
perl-file-mimeinfo
phonon-qt6-vlc
plasma-browser-integration
plasma-desktop
plasma-nm
plasma-pa
plasma-systemmonitor               # plasma-meta, replaces ksysguard
plasma-thunderbolt
plasma-workspace                   # required by plasma-desktop, etc., replaces plasma-wayland-session
plymouth
plymouth-kcm
plymouth-theme-manjaro
power-profiles-daemon
powerdevil
qt6-imageformats                   # support for tiff, webp, and more image formats
qt6-virtualkeyboard                # required by plasma-workspace
samba
sddm
sddm-breath-theme
sddm-kcm
smbclient
smplayer
smplayer-skins
smplayer-themes
spectacle                          # screenshots
sshfs                              # remote filesystem browser
systemsettings
terminus-font
ttf-dejavu
ttf-hack
udiskie
udisks2
unarchiver                         # RAR format support
usb_modeswitch
xdg-desktop-portal-kde
xdg-user-dirs
xdg-utils
xf86-input-elographics
xf86-input-evdev
xf86-input-libinput
xf86-input-void
To build a minimal profile without multilib packages
buildiso -p plasma -b stable -k linux612 -n
The resulting ISO can be found in /var/cache/manjaro-tools/custom/plasma
That’s it - piece of :cake: - right?
Very Advanced Use
Build an ISO from current system
There is no GUI to create an ISO from current state.
Technically you can use buildiso so I have outlined the commands necessary
I recommend to test them as they are written from memory - flash memory - the kind of memory which is gone in a flash :slight_smile: - after you have tested them you create a script to do lifting for you.
Steps
1. Create a folder in the root filesystem to hold your system
sudo mkdir /mybuild
2. Set permissions on the folder
Setting your user as owner which automagically gives rw access
sudo chown $USER:$USER /mybuild
3. Clone the iso-profiles repo into /mybuild
git clone https://gitlab.manjaro.org/profiles-and-settings/iso-profiles /mybuild/iso-profiles
4. Create a folder to hold your build
mkdir /mybuild/iso-profiles/$USER
5. Copy the relevant profile-folder into mybuild
In this case it is Plasma - it would work for any edition - ensure a unique name the folder - it must be unambigious across iso-profiles subfolders
cp -R /mybuild/iso-profiles/manjaro/kde /mybuild/iso-profiles/$USER/my-kde
6. Clean up your system for orphans
pamac remove --orphans
7. Create a package list of your current system
Excluding custom packages
pacman -Qqen > ~/my-packages.txt
8. Create new filtered list
Use the comm utility comparing the two files ~/my-packages.txt and /rootfs-pkgs.txt and pipe the result to replace the my-kde profile’s Packages-Desktop file
comm -23 <(sort ~/my-packages.txt) <(cat /rootfs-pkgs.txt | cut -d' ' -f1 | sort) > /mybuild/iso-profiles/$USER/my-kde/Packages-Desktop
9. Create the folder to hold your personal settings
mkdir -p /mybuild/iso-profiles/$USER/my-kde/desktop-overlay/etc/skel
10. Copy the content of your home
Close all open applications - apps which may keep files open in relevant folders. E.g. browsers and mail clients.
Copy the content of your home into the desktop-overlay/etc/skel folder - make sure to be selective and remove unwanted files like Documents and Pictures and whatnot - watch out for hidden files and folders e.g. ~/.mozilla
cp -R $HOME/. /mybuild/iso-profiles/$USER/my-kde/desktop-overlay/etc/skel
11. Run buildiso
Use the -t target directory argument to place your build inside the /mybuild folder.
If you have used buildiso previously with another profile-root you need to edit the file ~/.config/manjaro-tools/iso-profiles.conf to point to the folder /mybuild/iso-profiles
buildiso -p my-kde -t /mybuild
The size of the final ISO will be reflected by the packagelist and the size of your $HOME folder
More reading
More info can be found at the wiki - including how to include your own web based package repository
https://wiki.manjaro.org/index.php/Build_Manjaro_ISOs_with_buildiso
How create iso from current manjaro without a terminal?
How to build a black Manjaro?
Ultima Thule ISO
I need help for building an iso of manjaro
ISO Building and skel for the i3 ISO profile
Will this make a way to install it too?
Cosmic edition of Manjaro
How to use Manjaro-tools to create a barebone system?
MinisForum manjaro ISO
Question regarding connecting multiple displays using integrated graphics
Trying to build an iso from current system
Build Manjaro KDE iso image
Current Manjaro version
Installer without graphical interface
Penguins-eggs anyone?
[Testing Update] 2024-11-16 - Kernels, Mesa, Systemd, LxQt 2.1, Libreoffice
Installing my home-built ISO in Virtualbox will not show the login screen
Looking for a minimal Manjaro Scratch ISO without any pre-installed desktop environment or window manager
Installierbares Live System erstellen
Manjaro Live ISO maker
Question: Is it possible to omit kdeconnect and its daemon from the minimal ISO of KDE?
Manjaro Cinnamon community image
[Stable Update] 2026-05-02 - Kernels, Plasma, GNOME, Mesa, Systemd, VirtualBox, LibreOffice
Update ISO request, stable iso are above 3month old
RE: Mini guide to build Manjaro ISO
Manjaro-tools Fails to build Mhwd
Buildiso not working missing manjaro-live-setup command
Is all the configuration used in the live iso environment same as the installed one?
Is it possible to get a version of manjaro where you can choose what comes with it?
Build distro based on Manjaro Linux
[root tip] Topic Collection List View
Build/distribute custom Manjaro spins using GitHub Actions?
Manjaro lxqt for manjaro community
KDE, Stability of Manjaro
This is not a support thread.
If you have questions please create a new topic - link to this.
