Well, after last update, my pulseeffects didn’t work anymore.
From what I read, I had the choice between pulseeffects-legacy and becoming full pipewire, I choose the latter.
Didn’t do it very clean way though :
[2021-02-09T20:18:59+0100] [ALPM] installed gnome-settings-daemon (3.38.1-1)
[2021-02-09T20:16:54+0100] [ALPM] installed sof-firmware (1.6.1-1)
[2021-02-09T20:16:27+0100] [ALPM] installed libgweather (3.36.1-1)
[2021-02-09T20:15:26+0100] [ALPM] installed lib32-fluidsynth (2.1.7-1)
[2021-02-09T20:15:26+0100] [ALPM] installed lib32-sdl2 (2.0.14-1)
[2021-02-09T20:15:26+0100] [ALPM] installed lib32-libpulse (14.2-2)
[2021-02-09T20:15:26+0100] [ALPM] installed lib32-libasyncns (0.8+3+g68cd5af-2)
[2021-02-09T20:15:26+0100] [ALPM] installed lib32-libinstpatch (1.1.6-1)
[2021-02-09T20:12:38+0100] [ALPM] installed lib32-portaudio (1:19.6.0-4)
[2021-02-09T19:56:37+0100] [ALPM] installed gst-plugin-pipewire (1:0.3.21-1)
[2021-02-09T19:56:37+0100] [ALPM] installed manjaro-pipewire (20210109-1)
[2021-02-09T19:56:37+0100] [ALPM] installed pipewire-jack (1:0.3.21-1)
[2021-02-09T19:56:37+0100] [ALPM] installed pipewire-alsa (1:0.3.21-1)
[2021-02-09T19:56:37+0100] [ALPM] installed wireplumber (0.3.0-1)
[2021-02-09T19:56:37+0100] [ALPM] installed libpipewire02 (0.2.7-1)
[2021-02-09T19:56:37+0100] [ALPM] installed pipewire-pulse (1:0.3.21-1)
[2021-02-09T19:54:57+0100] [ALPM] removed pulseaudio (14.2-2)
[2021-02-09T19:54:57+0100] [ALPM] removed pulseaudio-alsa (1:1.2.2-2)
[2021-02-09T19:54:57+0100] [ALPM] removed libgweather (3.36.1-1)
[2021-02-09T19:54:56+0100] [ALPM] removed gnome-settings-daemon (3.38.1-1)
[2021-02-09T19:54:53+0100] [ALPM] removed eolie (0.9.101-1)
[2021-02-09T19:54:52+0100] [ALPM] removed pulseaudio-bluetooth (14.2-2)
[2021-02-09T19:54:52+0100] [ALPM] removed xfce4-pulseaudio-plugin (0.4.3-1.1)
[2021-02-09T19:54:51+0100] [ALPM] removed pulseaudio-ctl (1.67-1)
[2021-02-09T19:54:51+0100] [ALPM] removed pulseaudio-zeroconf (14.2-2)
[2021-02-09T19:54:51+0100] [ALPM] removed sof-firmware (1.6.1-1)
[2021-02-09T19:54:51+0100] [ALPM] removed pavucontrol (1:4.0-2)
[2021-02-09T19:54:50+0100] [ALPM] removed pulseaudio-lirc (14.2-2)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-libinstpatch (1.1.6-1)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-libasyncns (0.8+3+g68cd5af-2)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-libpulse (14.2-2)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-libcanberra-pulse (0.30+2+gc0620e4-3)
[2021-02-09T19:54:50+0100] [ALPM] removed pulseaudio-equalizer (14.2-2)
[2021-02-09T19:54:50+0100] [ALPM] removed pulseaudio-jack (14.2-2)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-sdl2 (2.0.14-1)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-portaudio (1:19.6.0-4)
[2021-02-09T19:54:50+0100] [ALPM] removed lib32-fluidsynth (2.1.7-1)
[2021-02-09T19:54:50+0100] [ALPM] removed pulseaudio-rtp (14.2-2)
[2021-02-09T19:54:50+0100] [ALPM] removed manjaro-pulse (20210109-1)
[2021-02-09T19:54:50+0100] [ALPM] removed xfce4-volumed-pulse (0.2.3-1)
The issues are:
- I find no GUI to check which devices are running
- HDMI doesn’t work anymore (my external loudspeaker are on HMDI)
- sound is just hashed and horrible
What did I miss ?
[sum@ordi1 ~]$ inxi -Fxxxx
Host: ordi1 Kernel: 5.10.13-2-MANJARO x86_64 bits: 64 compiler: gcc
v: 10.2.1 Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel, plank
wm: xfwm4 dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: K53SD v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: K53SD v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: K53SD.208 date: 08/10/2012
ID-1: BAT0 charge: 16.9 Wh condition: 16.9/57.2 Wh (30%) volts: 12.4/11.1
model: ASUSTek K53--52 type: Li-ion serial: N/A status: Full
Info: Dual Core model: Intel Core i3-2350M bits: 64 type: MT MCP
arch: Sandy Bridge rev: 7 L2 cache: 3 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 18367
Speed: 985 MHz min/max: 800/2300 MHz Core speeds (MHz): 1: 985 2: 853
3: 915 4: 798
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0116
class ID: 0300
Device-2: NVIDIA GF119M [GeForce 610M] vendor: ASUSTeK driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:1058 class ID: 0300
Device-3: Alcor Micro Asus Integrated Webcam type: USB driver: uvcvideo
bus ID: 1-1.2:3 chip ID: 058f:a014 class ID: 0e02
Display: x11 server: X.Org 1.20.10 driver: loaded: modesetting,nouveau
alternate: fbdev,intel,nv,vesa resolution: 1: 1366x768~60Hz
2: 1680x1050~60Hz 3: 1024x768~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20 class ID: 0403
Sound Server: ALSA v: k5.10.13-2-MANJARO
Device-1: Intel Centrino Wireless-N 100 driver: iwlwifi v: kernel
port: d000 bus ID: 03:00.0 chip ID: 8086:08ae class ID: 0280
IF: wlp3s0 state: up mac: 78:92:9c:95:7a:b2
Device-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet vendor: ASUSTeK
driver: atl1c v: kernel port: 9000 bus ID: 05:00.0 chip ID: 1969:1083
class ID: 0200
IF: enp5s0 state: down mac: 10:bf:48:0f:dd:cf
Local Storage: total: 931.51 GiB used: 461.89 GiB (49.6%)
ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB
size: 931.51 GiB speed: 3.0 Gb/s serial: S2TTJ9CC400760 rev: 0001
ID-1: / size: 95.62 GiB used: 37.12 GiB (38.8%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 246.1 MiB used: 278 KiB (0.1%) fs: vfat
dev: /dev/sda1
ID-3: /home size: 819.53 GiB used: 424.76 GiB (51.8%) fs: ext4
dev: /dev/sda3
ID-1: swap-1 type: file size: 256 MiB used: 524 KiB (0.2%) priority: 50
file: /var/lib/systemd-swap/swapfc/1
System Temperatures: cpu: 58.0 C mobo: N/A gpu: nouveau temp: 55.0 C
Fan Speeds (RPM): cpu: 2500
Processes: 257 Uptime: 57m wakeups: 1 Memory: 11.48 GiB
used: 5.98 GiB (52.1%) Init: systemd v: 247 Compilers: gcc: 10.2.0
Packages: 1905 pacman: 1867 flatpak: 38 Shell: Bash v: 5.1.0
running in: xfce4-terminal inxi: 3.3.00
[sum@ordi1 ~]$
[sum@ordi1 ~]$ sudo dmesg | grep rro
[ 0.798269] RAS: Correctable Errors collector initialized.
[ 30.164256] ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000003) is beyond end of object (length 0x0) (20200925/exoparg2-393)
[ 30.164267] ACPI Error: Aborting method \_SB.PCI0.GFX0._DSM due to previous error (AE_AML_PACKAGE_LIMIT) (20200925/psparse-529)
[ 30.164597] ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000003) is beyond end of object (length 0x0) (20200925/exoparg2-393)
[ 30.164605] ACPI Error: Aborting method \_SB.PCI0.GFX0._DSM due to previous error (AE_AML_PACKAGE_LIMIT) (20200925/psparse-529)
[ 30.164613] ACPI Error: Aborting method \_SB.PCI0.PEG0.GFX0._DSM due to previous error (AE_AML_PACKAGE_LIMIT) (20200925/psparse-529)
[sum@ordi1 ~]$ sudo dmesg | grep aile
[ 20.172427] systemd[1]: haveged.service: Failed with result 'exit-code'.
[ 30.164280] ACPI: \_SB_.PCI0.GFX0: failed to evaluate _DSM (0x300b)
[ 30.164625] ACPI: \_SB_.PCI0.PEG0.GFX0: failed to evaluate _DSM (0x300b)
[ 106.122114] audit: type=1103 audit(1612939076.892:82): pid=1478 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="sum" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[sum@ordi1 ~]$
