I installed open source nvidia drivers to play game then screen became black and saying input not support []
I used to have LOTS of problems with nvidia when i used Ubuntu, now problems in Manjaro
How can i fix it?
How can i fix it?
Hi @IHATENVIDIA, and welcome!
Well, there can be many causes to this. Best would be to boot into a Live ISO environment, and from there, open this page and provide more information and, if applicable, some extra information.
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=tr tz=UTC
misobasedir=manjaro misolabel=MANJARO_KDE_2120 quiet systemd.show_status=1
apparmor=1 security=apparmor driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: H110M-S2V v: N/A
serial: <superuser required>
Mobo: Gigabyte model: H110M-S2V-CF v: x.x serial: <superuser required>
UEFI: American Megatrends v: F20 date: 11/16/2016
RAM: total: 7.72 GiB used: 2.04 GiB (26.4%)
RAM Report:
Info: model: Intel Core i5-7500 bits: 64 type: MCP arch: Kaby Lake family: 6
model-id: 0x9E (158) stepping: 9 microcode: 0xEA
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
desc: 1x6 MiB
Speed (MHz): avg: 999 high: 1000 min/max: 800/3800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1000 2: 1000 3: 1000
4: 997 bogomips: 27208
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
art avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm mca
mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
rdrand rdseed rdtscp rep_good sdbg sep smap smep smx ss ssbd sse sse2
xsaves xtopology xtpr
Type: l1tf
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:1c82 class-ID: 0300
Display: x11 server: X.org 1.21.1.2 compositor: kwin_x11 driver:
loaded: modesetting alternate: fbdev,vesa resolution: <missing: xdpyinfo>
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fb9
class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: Gigabyte driver: r8169 v: kernel port: d000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 1.03 TiB used: 0 KiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDA120G
size: 111.79 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 30RL scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-21WN4A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Kingston
model: DataTraveler 2.0 size: 7.27 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
Message: No partition data found.
ID-1: /dev/sdb1 maj-min: 8:17 size: 300 MiB fs: vfat label: NO_LABEL
uuid: 39FC-E511
ID-2: /dev/sdc1 maj-min: 8:33 size: 3.56 GiB fs: iso9660
ID-3: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 8D59-F16D
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-1:2 info: Toshiba Kingston DataTraveler 102/2.0 / HEMA Flash
Drive 2 GB / PNY Attache 4GB Stick
type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s power: 300mA chip-ID: 0930:6545 class-ID: 0806
serial: <filter>
Device-2: 1-10:3 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nouveau temp: 29.0 C
Processes: 206 Uptime: 5m wakeups: 0 Init: systemd v: 249 tool: systemctl
Compilers: gcc: N/A Packages: pacman: 1230 lib: 332 flatpak: 0 Shell: Zsh
v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
I opened with live os. Now what to do? These Nvidia problems are really annoying man. Thx
How recent is the Live environment’s ISO you’re booting from?
Well it is USB that i used to install Manjaro 2 days ago. I booted from usb. It was the last version of kde manjaro when i made this usb.
There is not much you can do with the nouveau driver. It works for basic things, but since it stays always on the base cock and does not clock up for more speed, the gaming experience is very limited.
So if you want to game, then there no other way. Install the nvidia driver:
sudo mhwd --remove pci video-nvidia
sudo mhwd --install pci video-nvidia-470xx
I would suggest the 470 driver for the 10xx series, instead of the 495xx.
Error: config ‘video-nvidia’ is not installed!
I dont want to game, i want to open computer first
It would seem you’d need to boot into a live ISO environment, enter a chroot environment, an fix the drivers from there.
root:su -
If it asks you for a password, the password in the live environment is manjaro, both for the normal user, as well as root.
manjaro-chroot -a
Be careful: you are now root on your system, so whatever you do will effect it directly and permanently!!!
chroot environment, install the correct drivers:mhwd --install video-nvidia-470xx
chroot environment:exit
And reboot.
I’ll take any thanks you’re throwing around.
[manjaro ~]# manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
==> ERROR: No Linux partitions detected!
well… i encrypted my drive when i installed Manjaro, maybe thats why i can’t see.
I believe so.
And for that reason, I don’t think I can help you further than this. I don’t have, use or even know drive encryption…
Is there a way can i boot the pc without installing drivers?
You can always get to emergency shell. But there, I don’t know what to do, say, or hor to move on, so can’t help you, sorry!
Well then you need to decrypt like in that example:
cryptsetup open /dev/sda2 root-fs --key-file /etc/mykeyfile
and mount it:
sudo mount /dev/mapper/root-fs /mnt
sudo mount /dev/sda1 /mnt/boot/efi
then chroot:
manjaro-chroot /mnt /bin/bash
Of course you need to adjust it to your needs. Copy&Paste will not work.
Add this to the kernel parameter in grub:
systemd.unit=multi-user.target
you can edit the menu entry and add this on the line which starts with linux.
You will just get a terminal like on a server setup.
grub? i can acces to terminal with alt + ctrl + f2
oh well, then…
could you check the xorg log?
cat /var/log/Xorg.0.log | less
Uploading goes like that (maybe easier for sharing):
cat /var/log/Xorg.0.log | curl -F'file=@-' https://0x0.st
Or maybe just try to start it directly:
startx /usr/bin/startplasma-x11
or like that:
sudo systemctl restart display-manager
and i closed pc
just send me to error, the black screen error. I already can see the kde login and passord interface at start. But when i login there is error.
This made show kde plasma start screen and nothing happened,same error
I honestly think i should install fresh Manjaro and use without touching driver thing or try to play games.
Honestly gaming in Linux sucks.
What error? I am sorry, without the log nobody can say anything. There can be many issues involved.
Beside that i have also a GTX 1050 ti and have no problems when playing games. Yeah sometimes it is not a out-of-the-box experience and you need to tinker. But better than nothing. Games which are officially supported for linux just work, at least my bought games.
If gaming is your main purpose to run a computer, then better stop here and install Windows.
Driver is the problem.
Error is just black screen and monitor text on middle [input not supported]
