Hello! So all of a sudden when I use steam and play games using my controller, my game freeze and I have to restart my pc. I can play games while not using a controller, but as soon as I plug it in, the pc just freeze and I cant do anything. I have tried two different controllers, different USB outlets etc.
Two days ago everything worked just fine, so I have no idea what the problem might be… Hopefully someone here might be able to help or atleast explain to me what the problem is!
mar 07 13:58:51 mattiasdator kernel:
mar 07 13:58:59 mattiasdator kernel: usb 2-1.3: 1:1: cannot get freq at ep 0x81
mar 07 13:58:59 mattiasdator kernel: usb 2-1.3: 2:1: cannot get freq at ep 0x1
mar 07 13:59:24 mattiasdator pulseaudio[775]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes incl>
mar 07 14:05:35 mattiasdator kernel: xpad 2-1.8:1.0: xpad_try_sending_next_out_packet - usb_submit_urb failed with result -19
mar 07 14:05:53 mattiasdator systemd-coredump[2343]: [🡕] Process 1640 (steam) of user 1000 dumped core.
Module /home/mattias/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/steam with build->
Module /home/mattias/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/serverbrowser.so >
Module /home/mattias/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/friendsui.so with>
Module /home/mattias/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/steamservice.so w>
Module /home/mattias/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/libopenvr_api.so >
Module /app/lib/i386-linux-gnu/libgmp.so.10.4.0 with build-id 54592504ff74d5e9a3da25ee7f739bc87ec62115
Module /app/lib/i386-linux-gnu/libunistring.so.2.1.0 with build-id 5529bc5d179fe94eab1977cb5dfb9a4419a>
Module /app/lib/i386-linux-gnu/libp11-kit.so.0.3.0 with build-id d976d5cd35a806b3058d859d3a5c10c36afcb>
Module /app/lib/i386-linux-gnu/libgnutls.so.30.30.0 with build-id 9ab5762d34b26fcc4142659e37a213b359ae>
Module /home/mattias/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/steamclient.so wi>
Module /app/lib/i386-linux-gnu/libidn2.so.0.3.7 with build-id eb3259576a31fd454804f429915955a3fedbf7e9
Module /app/lib/i386-linux-gnu/libtasn1.so.6.6.2 with build-id 5de84f6c478fa9b3f70b7900b985416e69982518
Module /app/lib/i386-linux-gnu/libuuid.so.1.3.0 with build-id cf3a54bf81d7dfa9b7b40e67ef28e41db75ec699
Module /app/lib/i386-linux-gnu/libltdl.so.7.3.1 with build-id ee0efe47b660f9315c1770f89afd493a10b3496f
Module /home/mattias/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/libvorbisfile.so.>
Module /home/mattias/.var/app/com.valvesoftware.Steam/.local/share/Steam/ubuntu12_32/chromehtml.so wit>
Module /app/lib/i386-linux-gnu/libICE.so.6.3.0 with build-id 2ef7e6d1c1d4612712f700d920935f769a011095
Module /app/lib/i386-linux-gnu/libSM.so.6.0.1 with build-id decb0769ff584dbf6ec52055f432bcdbbbacb69b
Module /app/lib/i386-linux-gnu/libopenal.so.1.21.1 with build-id dbc3d5325cd0f5063811632a1db95c5a30ca2>
lines 1-27
im sorry but I dont really understand anything lol! So I dunno what to do, since that text doesn’t make any sense for me. What I can say is that everything works just fine when not using a controller inside a steam game. It boots fine and so on! It’s only when I either plug in a controller while inside a game on steam, or start a game with a controller already plugged in. No idea why, it might be because an update? I can’t go back before an update since I dont have any saved things before one…
lines 1-25
