Hello guys,
I am back to linux after a long time and am facing issue as i dont remember alot of thing anymore. So I am using Manjaro KDE Plasma for a week now and since couple of days my internet is throttling alot and i have forgot how to diagonse and fix it.
So i need u to help me with diagnosing and fixing the issue. If u need any information about my system please let me know.
(i have also tried other solutions but nothing seem to work)
Thanks in advance
What where those?
Some nice people here have prepared a reminder of what information you should post in order for effective help to get started.
They will probably chime in at some point and give it to you - but perhaps not.
I don’t have this as a template - can only refer you to the search function to look for:
How to post
How to give information
… along those lines …
ps:
ahh - it already happened while I wrote
@andreas85 just did what I alluded to
Kernel: 6.12.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=1b9a8cba-f5e6-42a0-9e44-f72a62d20799 rw quiet splash
resume=UUID=1a845e4c-13f2-471b-ba82-1455acf2f91b udev.log_priority=3
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Laptop System: ASUSTeK product: X555LA v: 1.0 serial: <filter>
Mobo: ASUSTeK model: X555LA v: 1.0 serial: <filter>
part-nu: ASUS-NotebookSKU uuid: 5ad6a9b0-513d-81e4-3141-ac9e1705e58b
UEFI: American Megatrends v: X555LA.308 date: 08/14/2014
ID-1: BAT0 charge: 19.3 Wh (93.7%) condition: 20.6/37.3 Wh (55.3%)
power: 13.0 W volts: 7.5 min: 7.5 model: ASUSTeK X555-50 type: Li-ion
serial: N/A status: discharging cycles: 1728
System RAM: total: 8 GiB available: 7.64 GiB used: 2.13 GiB (27.9%)
igpu: 64 MiB
Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 4 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471B5173DB0-YK0 serial: N/A
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 4 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 8 total: 8
manufacturer: Hynix/Hyundai part-no: HMT451S6BFR8A-PB serial: <filter>
Device-4: ChannelB-DIMM1 type: no module installed
Message: No PCI Slot data found.
Info: model: Intel Core i3-8030U socket: rPGA988B bits: 64 type: MT MCP
arch: Haswell gen: core 4 level: v3 note: check built: 2013-15
process: Intel 22nm family: 6 model-id: 0x45 (69) stepping: 1
microcode: 0x26
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 798 min/max: 800/1800 base/boost: 1900/3800 scaling:
driver: intel_cpufreq governor: schedutil volts: 1.2 V ext-clock: 100 MHz
cores: 1: 798 2: 798 3: 798 4: 798 bogomips: 15171
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
x2apic xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK driver: i915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: Realtek USB Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0bda:57b5
Display: unspecified server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: crocus gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: LG Display 0x045c built: 2014 res: mode: 1366x768
hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2 chroma: red: x: 0.580 y: 0.345
green: x: 0.337 y: 0.573 blue: x: 0.157 y: 0.118 white: x: 0.314 y: 0.329
size: 345x194mm (13.58x7.64") diag: 396mm (15.6") ratio: 16:9
modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
drv: crocus inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.0.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4400 (HSW
GT2) device-ID: 8086:0a16 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.4.309 layers: N/A device: 0 type: integrated-gpu
name: Intel HD Graphics 4400 (HSW GT2) driver: mesa intel v: 25.0.4-arch1.1
device-ID: 8086:0a16 surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Haswell-ULT HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
API: ALSA v: k6.12.25-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.2 status: n/a (root, process) with:
vendor: ASUSTeK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter
vendor: Lite-On driver: ath9k v: kernel modules: wl pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:0036 class-ID: 0280
Device-1: Lite-On driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-6:8 chip-ID: 04ca:3010 class-ID: e001
Local Storage: total: 465.76 GiB used: 27.7 GiB (5.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD5000LPVX-80V0TT0 size: 465.76 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 1A01 scheme: MBR
ID-1: / raw-size: 186.07 GiB size: 182.09 GiB (97.86%)
used: 27.7 GiB (15.2%) fs: ext4 block-size: 4096 B dev: /dev/sda3
maj-min: 8:3 label: N/A uuid: 1b9a8cba-f5e6-42a0-9e44-f72a62d20799
ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 304 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: 8362-A9C9
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 1a845e4c-13f2-471b-ba82-1455acf2f91b
ID-1: /dev/sda4 maj-min: 8:4 size: 270.69 GiB fs: ntfs label: Personal
uuid: BEAA30A3AA305A5B
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 1-2:2 info: MosArt 2 4Ghz Wireless Transceiver [for Delux M618
Plus Vertical Mouse] type: keyboard,mouse driver: hid-generic,usbhid
interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
power: 100mA chip-ID: 062a:4c01 class-ID: 0301
Device-2: 1-5:3 info: Realtek USB Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 0bda:57b5 class-ID: 0e02 serial: <filter>
Device-3: 1-6:8 info: Lite-On type: bluetooth driver: btusb interfaces: 2
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-4: 1-8:5 info: Realtek RTS5129 Card Reader Controller
power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
Hub-2: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-3: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
System Temperatures: cpu: 48.0 C pch: 44.5 C mobo: N/A
Fan Speeds (rpm): cpu: 2800
Packages: 1353 pm: pacman pkgs: 1352 libs: 365 tools: pamac pm: flatpak
pkgs: 1
1: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
2: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
3: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
4: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
5: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
6: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 239
1: cpu: 100% command: ps pid: 3235 mem: 3.75 MiB (0.0%)
2: cpu: 44.0% command: firefox pid: 2722 mem: 554.5 MiB (7.0%)
3: cpu: 15.1% command: firefox pid: 2868 mem: 236.4 MiB (3.0%)
4: cpu: 10.6% command: firefox pid: 2953 mem: 249.5 MiB (3.1%)
5: cpu: 9.1% command: konsole pid: 3191 mem: 229.6 MiB (2.9%)
Memory top: 5 of 239
1: mem: 554.5 MiB (7.0%) command: firefox pid: 2722 cpu: 44.0%
2: mem: 437.7 MiB (5.5%) command: plasmashell pid: 750 cpu: 0.0%
3: mem: 249.5 MiB (3.1%) command: firefox pid: 2953 cpu: 10.6%
4: mem: 236.4 MiB (3.0%) command: firefox pid: 2868 cpu: 15.1%
5: mem: 229.6 MiB (2.9%) command: konsole pid: 3191 cpu: 9.1%
Processes: 239 Power: uptime: 7h 45m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 3.04 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Sudo (sudo) v: 1.9.16p2
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
Hello,
since several weeks my internet connection is very slow.
Youtube videos take several minutes to load sometimes. Other times the loading stops and it just says “no network connection”.
At other occasions I was not able to participate in BigBlueButton meetings because I was being logged out constantly.
Even googling sometimes just cancels at show only a white screen.
I do not have those issues on my ipad, which uses the same network. I tried several browsers, e.g. Firefox and Vivaldi.
I just ran commands here,i without knowing what they meant
