I enabled AutoEnable option, and the Bluetooth is available at the login screen, but it will be disabled as I login, I need to enable it manually. I am a starter at linux, can you help me with that?
Hi @devin,
Please provide the output of:
systemctl status bluetooth.service
Tip:
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
For more information, please see:
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Hi, @Mirdarthos
Here is the output:
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Thu 2023-06-29 21:49:58 CST; 2min 21s ago
Docs: man:bluetoothd(8)
Main PID: 4811 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18904)
Memory: 1.1M
CPU: 383ms
CGroup: /system.slice/bluetooth.service
└─4811 /usr/lib/bluetooth/bluetoothd
Jun 29 21:49:58 devin-man bluetoothd[4811]: Endpoint registered: sender=:1.76 path=/MediaEndpoint/A2DPSink/sbc
Jun 29 21:49:58 devin-man bluetoothd[4811]: Endpoint registered: sender=:1.76 path=/MediaEndpoint/A2DPSource/sbc
Jun 29 21:49:58 devin-man bluetoothd[4811]: Endpoint registered: sender=:1.76 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Jun 29 21:49:58 devin-man bluetoothd[4811]: Endpoint registered: sender=:1.76 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Jun 29 21:49:58 devin-man bluetoothd[4811]: Endpoint registered: sender=:1.76 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Jun 29 21:49:58 devin-man bluetoothd[4811]: Endpoint registered: sender=:1.76 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Jun 29 21:49:58 devin-man bluetoothd[4811]: Endpoint registered: sender=:1.76 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Jun 29 21:49:58 devin-man bluetoothd[4811]: Endpoint registered: sender=:1.76 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Jun 29 21:49:58 devin-man bluetoothd[4811]: src/device.c:set_wake_allowed_complete() Set device flags return status: Invalid Parameters
Jun 29 21:49:59 devin-man bluetoothd[4811]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Is your system a computer or a laptop? Actually, please go through this and provide the info:
This is the system info.
Kernel: 6.1.31-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=786eafd2-d905-4802-98da-d6fb952d96b4 rw quiet splash
udev.log_priority=3 i8042.dumbkbd nouveau.modeset=0 acpi=force
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.9 wm: kwin_wayland vt: 2
Type: Laptop System: LENOVO product: 82NC v: Lenovo XiaoXinPro 14IHU 2021
serial: <superuser required> Chassis: type: 10 v: Lenovo XiaoXinPro 14IHU
2021 serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0T76479 WIN
serial: <superuser required> UEFI: LENOVO v: FJCN65WW date: 07/22/2021
ID-1: BAT1 charge: 53.5 Wh (94.9%) condition: 56.4/61.0 Wh (92.5%)
volts: 17.2 min: 15.4 model: Sunwoda L19D4PH3 type: Li-poly serial: <filter>
status: not charging
Device-1: hidpp_battery_1 model: Logitech MX Master 3S serial: <filter>
charge: 50% rechargeable: yes status: discharging
Info: model: 11th Gen Intel Core i5-11320H bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 2
microcode: 0x2A
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2545 high: 4499 min/max: 400/4500 scaling:
driver: intel_pstate governor: performance cores: 1: 3200 2: 958 3: 3200
4: 3200 5: 1385 6: 721 7: 3200 8: 4499 bogomips: 51008
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:9a49 class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 04f2:b6cb
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 res: 1646x1029 size: N/A modes: N/A
API: OpenGL v: 4.6 Mesa 23.0.4 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
API: ALSA v: k6.1.31-2-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0026
class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: up address: <filter>
Local Storage: total: 476.94 GiB used: 47.63 GiB (10.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HBJQ-000L2
lanes: 4 tech: SSD serial: <filter> fw-rev: 3L1QEXF7 temp: 38.9 C
scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 47.59 GiB (48.6%)
fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
used: 34.1 MiB (13.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 53.0 C mobo: N/A
Processes: 272 Uptime: 1m wakeups: 35 Memory: available: 15.41 GiB
used: 3.85 GiB (25.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: 1346
pm: pacman pkgs: 1340 libs: 419 tools: pamac,yay pm: flatpak pkgs: 6
Shell: Bash v: 5.1.16 running-in: console inxi: 3.3.27
Because of that t might be disabled for battery saving. Please provide the output of:
systemctl status tlp
Unit tlp.service could not be found.
Well, that might be a problem. However, a GUI app might help. Sp let’s install it. Run:
pamac install tlpui
This will pull in and use tlp, the actual software we’re after.
Yes, I installed tlpui, what do I need to configure?
I had the same issue until an update fixed it.
In this post, @Drito says that
EDIT: that happens when I restart the Xorg desktop without restarting computer.
And this issue surely happened every time my computer shutdown abnormally which is caused by sddm.
sddm restarted when I shutdown, it will cause the computer freezed when shuting down.
I guese the issue of Bluetooth is related to this, but I don’t know how to fix that.
Mod edit:- Corrected borked URLs.
Do you have the issue that manjaro hangs at shutdown for 90 seconds caused by sddm?
I don’t think so. Sometimes it takes longer to shutdown but I never had an issue with it.
Hi @devin
I was having the same issue as gtrudax and searching for a solution I stumbled upon your comment.
I am having this 90 seconds issue besides the bluetooth disabled after login, do you have a tip for me? ![]()
Thanks!
/etc/systemd/system.conf.d/75-faster-shutdown.conf
[Manager]
DefaultTimeoutStartSec=15s
DefaultTimeoutStopSec=15s
DefaultTimeoutAbortSec=15s
DefaultRestartSec=15s
