I use a Bluetooth keyboard that works fine upon boot. I can enter my password to log into the session, but then when the session starts the Bluetooth turns off and I have to enable it on the settings every time. I don’t know what is causing this issue.
Hi @gtrudax,
To see what happens during boot, that might present a clue as to why it’s disabled on boot, run the following:
journalctl --boot=-1 --grep=''blue'
- The
--boot=
argument will show al messages from the previous boot. Feel free to adjust this:0
for the current boot,-1
for the previous boot,-2
for the one before that and on and so forth; - the
--grep=
argument show only the messages containing “blue”.
Edit:
Also please provide the output for:
systemctl status bluetooth.service
systemctl:
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Wed 2023-05-17 10:05:24 EDT; 10min ago
Docs: man:bluetoothd(8)
Main PID: 520 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 19060)
Memory: 2.9M
CPU: 26ms
CGroup: /system.slice/bluetooth.service
└─520 /usr/lib/bluetooth/bluetoothd
May 17 10:06:18 desktop bluetoothd[520]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_ll_1
May 17 10:06:18 desktop bluetoothd[520]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_ll_0
May 17 10:06:18 desktop bluetoothd[520]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
May 17 10:06:18 desktop bluetoothd[520]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
May 17 10:06:18 desktop bluetoothd[520]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/faststream
May 17 10:06:18 desktop bluetoothd[520]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/faststream_duplex
May 17 10:06:18 desktop bluetoothd[520]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/opus_05
May 17 10:06:18 desktop bluetoothd[520]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/opus_05
May 17 10:06:18 desktop bluetoothd[520]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSink/opus_05_duplex
May 17 10:06:18 desktop bluetoothd[520]: Endpoint registered: sender=:1.63 path=/MediaEndpoint/A2DPSource/opus_05_duplex
journalctl:
May 17 08:23:03 desktop (uetoothd)[527]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
May 17 08:23:03 desktop bluetoothd[527]: Bluetooth daemon 5.66
May 17 08:23:04 desktop bluetoothd[527]: Starting SDP server
May 17 08:23:04 desktop bluetoothd[527]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
May 17 08:23:04 desktop bluetoothd[527]: src/plugin.c:plugin_init() Failed to init vcp plugin
May 17 08:23:04 desktop bluetoothd[527]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
May 17 08:23:04 desktop bluetoothd[527]: src/plugin.c:plugin_init() Failed to init mcp plugin
May 17 08:23:04 desktop bluetoothd[527]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
May 17 08:23:04 desktop bluetoothd[527]: src/plugin.c:plugin_init() Failed to init bap plugin
May 17 08:23:04 desktop dbus-daemon[529]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.3' (uid=0 pid=527 comm="/usr/lib/bluetooth/bluetoothd")
May 17 08:23:04 desktop bluetoothd[527]: Bluetooth management interface 1.22 initialized
May 17 08:23:04 desktop NetworkManager[560]: <info> [1684326184.2818] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.42.6-1/libnm-device-plugin-bluetooth.so)
May 17 08:23:16 desktop dbus-daemon[767]: [session uid=1000 pid=767] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.19' (uid=1000 pid=939 comm="/usr/bin/kded5")
May 17 08:23:16 desktop dbus-daemon[767]: [session uid=1000 pid=767] Successfully activated service 'org.bluez.obex'
May 17 08:23:17 desktop bluetoothd[527]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/ldac
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSink/aptx_hd
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aptx_hd
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSink/aac
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aac
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSink/sbc
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/sbc
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSink/sbc_xq
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/sbc_xq
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aptx_ll_1
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aptx_ll_0
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/faststream
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/faststream_duplex
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSink/opus_05
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/opus_05
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSink/opus_05_duplex
May 17 08:23:18 desktop bluetoothd[527]: Endpoint registered: sender=:1.64 path=/MediaEndpoint/A2DPSource/opus_05_duplex
May 17 08:51:37 desktop bluetoothd[527]: Terminating
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/ldac
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSink/aptx_hd
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aptx_hd
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSink/aac
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aac
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSink/sbc
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/sbc
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSink/sbc_xq
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/sbc_xq
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aptx_ll_1
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aptx_ll_0
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/faststream
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/faststream_duplex
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSink/opus_05
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/opus_05
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSink/opus_05_duplex
May 17 08:51:37 desktop bluetoothd[527]: Endpoint unregistered: sender=:1.64 path=/MediaEndpoint/A2DPSource/opus_05_duplex
May 17 08:51:37 desktop dbus-daemon[529]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.64" (uid=1000 pid=1073 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.MediaEndpoint1.Error.NotImplemented" requested_reply="0" destination=":1.3" (uid=0 pid=527 comm="/usr/lib/bluetooth/bluetoothd")
May 17 08:51:37 desktop dbus-daemon[529]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.64" (uid=1000 pid=1073 comm="/usr/bin/wireplumber") interface="(unset)" member="(unset)" error name="org.bluez.Profile1.Error.NotImplemented" requested_reply="0" destination=":1.3" (uid=0 pid=527 comm="/usr/lib/bluetooth/bluetoothd")
May 17 08:51:37 desktop bluetoothd[527]: Stopping SDP server
May 17 08:51:37 desktop bluetoothd[527]: Exit
May 17 08:51:37 desktop systemd[1]: bluetooth.service: Deactivated successfully.
May 17 08:51:37 desktop dbus-daemon[529]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.64' (uid=1000 pid=1073 comm="/usr/bin/wireplumber")
May 17 08:51:38 desktop dbus-daemon[529]: [system] Activation via systemd failed for unit 'dbus-org.bluez.service': Refusing activation, D-Bus is shutting down.
May 17 08:51:38 desktop dbus-daemon[529]: [system] Activating via systemd: service name='org.bluez' unit='dbus-org.bluez.service' requested by ':1.64' (uid=1000 pid=1073 comm="/usr/bin/wireplumber")
Edit in response to below:
Random thought:
Because I’ve got nothing else…
Check that it’s not disabled as part of a power saving profile, or whatever you call it.
Following up.
If I manually enable bluetooth and then do a systemctl restart bluetooth, it gets disabled and I keep seeing this message.
That led me here:
Im pretty sure this is happening on:
adapter.c « src - bluez.git - Bluetooth protocol stack for Linux
Which is only called if some application is setting Powered to False, so that is not the daemon doing it automatically but something else turning Bluetooth off and by that disconnecting.
So now the question is what is causing bluetooth to power down on every startup?
journalctl --boot=1 --grep='blue'
resulted in this:
jun 02 11:05:04 gustavo-g55587 kernel: Bluetooth: Core ver 2.22
jun 02 11:05:04 gustavo-g55587 kernel: NET: Registered PF_BLUETOOTH protocol family
jun 02 11:05:04 gustavo-g55587 kernel: Bluetooth: HCI device and connection manager initialized
jun 02 11:05:04 gustavo-g55587 kernel: Bluetooth: HCI socket layer initialized
jun 02 11:05:04 gustavo-g55587 kernel: Bluetooth: L2CAP socket layer initialized
jun 02 11:05:04 gustavo-g55587 kernel: Bluetooth: SCO socket layer initialized
jun 02 11:05:05 gustavo-g55587 kernel: Bluetooth: hci0: Bootloader revision 0.1 build 42 week 52 2015
jun 02 11:05:05 gustavo-g55587 kernel: Bluetooth: hci0: Device revision is 2
jun 02 11:05:05 gustavo-g55587 kernel: Bluetooth: hci0: Secure boot is enabled
jun 02 11:05:05 gustavo-g55587 kernel: Bluetooth: hci0: OTP lock is enabled
jun 02 11:05:05 gustavo-g55587 kernel: Bluetooth: hci0: API lock is enabled
jun 02 11:05:05 gustavo-g55587 kernel: Bluetooth: hci0: Debug lock is disabled
jun 02 11:05:05 gustavo-g55587 kernel: Bluetooth: hci0: Minimum firmware build 1 week 10 2014
jun 02 11:05:05 gustavo-g55587 kernel: Bluetooth: hci0: Found device firmware: intel/ibt-17-16-1.sfi
jun 02 11:05:05 gustavo-g55587 kernel: Bluetooth: hci0: Boot Address: 0x40800
jun 02 11:05:05 gustavo-g55587 kernel: Bluetooth: hci0: Firmware Version: 108-45.22
jun 02 11:05:06 gustavo-g55587 systemd[1]: Starting Bluetooth service...
jun 02 11:05:06 gustavo-g55587 (uetoothd)[606]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
jun 02 11:05:06 gustavo-g55587 bluetoothd[606]: Bluetooth daemon 5.66
jun 02 11:05:06 gustavo-g55587 kernel: Bluetooth: hci0: Waiting for firmware download to complete
jun 02 11:05:06 gustavo-g55587 kernel: Bluetooth: hci0: Firmware loaded in 1511503 usecs
jun 02 11:05:06 gustavo-g55587 kernel: Bluetooth: hci0: Waiting for device to boot
jun 02 11:05:06 gustavo-g55587 kernel: Bluetooth: hci0: Device booted in 13667 usecs
jun 02 11:05:06 gustavo-g55587 kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
jun 02 11:05:06 gustavo-g55587 kernel: Bluetooth: BNEP (Ethernet Emulation) ver 1.3
jun 02 11:05:06 gustavo-g55587 kernel: Bluetooth: BNEP filters: protocol multicast
jun 02 11:05:06 gustavo-g55587 kernel: Bluetooth: BNEP socket layer initialized
jun 02 11:05:06 gustavo-g55587 kernel: Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-17-16-1.ddc
jun 02 11:05:06 gustavo-g55587 bluetoothd[606]: Bluetooth management interface 1.22 initialized
jun 02 11:05:06 gustavo-g55587 dbus-daemon[608]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested by ':1.1' (uid=0 pid=606 comm="/usr/lib/bluetooth/bluetoothd")
jun 02 11:05:07 gustavo-g55587 kernel: Bluetooth: hci0: Applying Intel DDC parameters completed
jun 02 11:05:07 gustavo-g55587 kernel: Bluetooth: hci0: Firmware revision 0.1 build 108 week 45 2022
jun 02 11:05:07 gustavo-g55587 systemd[1]: Started Bluetooth service.
jun 02 11:05:07 gustavo-g55587 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 11:05:07 gustavo-g55587 systemd[1]: Reached target Bluetooth Support.
jun 02 11:05:07 gustavo-g55587 kernel: Bluetooth: MGMT ver 1.22
jun 02 11:05:07 gustavo-g55587 NetworkManager[620]: <info> [1685714707.1039] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.42.6-1/libnm-device-plugin-bluetooth.so)
jun 02 11:05:07 gustavo-g55587 kernel: Bluetooth: hci0: Bad flag given (0x1) vs supported (0x0)
jun 02 11:05:26 gustavo-g55587 systemd[1494]: Reached target Bluetooth.
jun 02 11:05:28 gustavo-g55587 kernel: hid-generic 0005:046D:B367.0005: input,hidraw4: BLUETOOTH HID v0.11 Keyboard [MX MCHNCL M] on 94:b8:6d:f2:b5:dd
jun 02 11:05:42 gustavo-g55587 dbus-daemon[1784]: [session uid=1000 pid=1784] Activating via systemd: service name='org.bluez.obex' unit='dbus-org.bluez.obex.service' requested by ':1.12' (uid=1000 pid=1900 comm="/usr/bin/kded5")
jun 02 11:05:42 gustavo-g55587 systemd[1759]: Starting Bluetooth OBEX service...
jun 02 11:05:42 gustavo-g55587 dbus-daemon[1784]: [session uid=1000 pid=1784] Successfully activated service 'org.bluez.obex'
jun 02 11:05:42 gustavo-g55587 systemd[1759]: Started Bluetooth OBEX service.
jun 02 11:05:42 gustavo-g55587 kernel: Bluetooth: RFCOMM TTY layer initialized
jun 02 11:05:42 gustavo-g55587 kernel: Bluetooth: RFCOMM socket layer initialized
jun 02 11:05:42 gustavo-g55587 kernel: Bluetooth: RFCOMM ver 1.11
jun 02 11:05:44 gustavo-g55587 systemd[1494]: Stopped target Bluetooth.
jun 02 11:05:52 gustavo-g55587 pulseaudio[2996]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
jun 02 11:08:18 gustavo-g55587 systemd[1759]: Reached target Bluetooth.
jun 02 11:08:18 gustavo-g55587 kernel: hid-generic 0005:046D:B367.000D: input,hidraw11: BLUETOOTH HID v0.11 Keyboard [MX MCHNCL M] on 94:b8:6d:f2:b5:dd
jun 02 22:01:09 gustavo-g55587 kernel: hid-generic 0005:046D:B367.000E: input,hidraw11: BLUETOOTH HID v0.11 Keyboard [MX MCHNCL M] on 94:b8:6d:f2:b5:dd
jun 02 22:20:13 gustavo-g55587 systemd[1]: Stopped target Bluetooth Support.
jun 02 22:20:13 gustavo-g55587 systemd[1]: Stopping Bluetooth service...
jun 02 22:20:14 gustavo-g55587 dbus-daemon[608]: [system] Rejected send message, 0 matched rules; type="error", sender=":1.83" (uid=1000 pid=2996 comm="/usr/bin/pulseaudio --daemonize=no --log-target=jo") interface="(unset)" member="(unset)" error name="org.freedesktop.DBus.Error>
jun 02 22:20:14 gustavo-g55587 systemd[1]: bluetooth.service: Deactivated successfully.
jun 02 22:20:14 gustavo-g55587 systemd[1]: Stopped Bluetooth service.
jun 02 22:20:14 gustavo-g55587 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
jun 02 22:20:14 gustavo-g55587 systemd[1]: bluetooth.service: Consumed 5.294s CPU time.
jun 02 22:20:14 gustavo-g55587 systemd[1759]: Stopped target Bluetooth.
jun 02 22:20:14 gustavo-g55587 systemd[1759]: Stopping Bluetooth OBEX service...
jun 02 22:20:14 gustavo-g55587 systemd[1759]: Stopped Bluetooth OBEX service.
And systemctl status bluetooth.sevice
output is this one:
Active: active (running) since Fri 2023-06-02 22:22:32 -03; 4min 39s ago
Main PID: 687 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18790)
Memory: 2.9M
CPU: 89ms
└─687 /usr/lib/bluetooth/bluetoothd
jun 02 22:23:18 gustavo-g55587 bluetoothd[687]: Endpoint registered: sender=:1.84 path=/MediaEndpoint/A2DPSink/aptx
jun 02 22:23:18 gustavo-g55587 bluetoothd[687]: Endpoint registered: sender=:1.84 path=/MediaEndpoint/A2DPSource/aptx
jun 02 22:23:18 gustavo-g55587 bluetoothd[687]: Endpoint registered: sender=:1.84 path=/MediaEndpoint/A2DPSink/sbc
jun 02 22:23:18 gustavo-g55587 bluetoothd[687]: Endpoint registered: sender=:1.84 path=/MediaEndpoint/A2DPSource/sbc
jun 02 22:23:18 gustavo-g55587 bluetoothd[687]: Endpoint registered: sender=:1.84 path=/MediaEndpoint/A2DPSink/sbc_xq_453
jun 02 22:23:18 gustavo-g55587 bluetoothd[687]: Endpoint registered: sender=:1.84 path=/MediaEndpoint/A2DPSource/sbc_xq_453
jun 02 22:23:18 gustavo-g55587 bluetoothd[687]: Endpoint registered: sender=:1.84 path=/MediaEndpoint/A2DPSink/sbc_xq_512
jun 02 22:23:18 gustavo-g55587 bluetoothd[687]: Endpoint registered: sender=:1.84 path=/MediaEndpoint/A2DPSource/sbc_xq_512
jun 02 22:23:18 gustavo-g55587 bluetoothd[687]: Endpoint registered: sender=:1.84 path=/MediaEndpoint/A2DPSink/sbc_xq_552
jun 02 22:23:18 gustavo-g55587 bluetoothd[687]: Endpoint registered: sender=:1.84 path=/MediaEndpoint/A2DPSource/sbc_xq_552
Yeah it fixed the issues for a few days for me and then another update messed things up again…
