im very new in manjaro …
ive problem by microphone & recorder in manjaro
i cannot use both of them…
post output from:
inxi -Fazy
click this icon in editor: </> and put the output there
hi
if you say putting $inxi -Fazy in terminal
thats not worked ;
thanks .
you type this in the terminal:
inxi -Fazy
of course it works…
this is not working…
ive not microphen …
tanks.
you type this command:
inxi -Fazy
then you copy the output from that command and click this icon in editor: </> and put the output from the inxi -Fazy command there
