Manjaro stuck on boot screen
I have been using Manjaro for a few months now perfectly fine. Today, I was getting a new monitor set up, and had been messing around with the display settings and rebooted it a few times with the os working fine. Then one of the times after I adjusted the display settings again, it got stuck at the boot screen:
/dev/nvme0n1p2: recovering journal
/dev/nvme0n1p2: clean, 684050/61030400 files, 104342209/244112696
I’ve tried booting it a few times and left it for a while to see if it would eventually work, but it never did. I then installed a small partition to test things and that partition worked. I’ve looked around and tried several solutions but nothing’s working. Is the original partition lost? If so, is there any way to get my files from the original partition or is everything lost?
  Kernel: 5.15.60-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    root=UUID=a759baa7-9cc3-4141-a88a-86638a9ef8ab rw quiet
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop System: Gigabyte product: Z690I A ULTRA LITE v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: Z690I A ULTRA LITE serial: <superuser required>
    UEFI: American Megatrends LLC. v: F1 date: 04/08/2022
  RAM: total: 15.47 GiB used: 1.87 GiB (12.1%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: 12th Gen Intel Core i5-12600K bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
    family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0x22
  Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
    cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
    L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
  Speed (MHz): avg: 798 high: 801 min/max: 800/4900:3600 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 801 3: 781 4: 800
    5: 800 6: 800 7: 800 8: 801 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
    15: 800 16: 799 bogomips: 118000
    de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
    hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida intel_pt invpcid
    invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
    movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
    pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid
    rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep smx
    split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
    tm2 tme tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
    xsaveopt xsaves xtopology xtpr
    prctl and seccomp
  Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
  Device-1: AMD Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M]
    vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 03:00.0
    chip-ID: 1002:73df class-ID: 0300
  Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
    loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58")
  Monitor-1: DP-3 mapped: DisplayPort-2 model: ViewSonic VX2768-2KPC
    serial: <filter> built: 2022 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
    max: 2560x1440 min: 720x400
  OpenGL: renderer: AMD Radeon RX 6700 XT (navy_flounder LLVM 14.0.6 DRM
    3.42 5.15.60-1-MANJARO) v: 4.6 Mesa 22.1.6 direct render: Yes
  Device-1: Intel Alder Lake-S HD Audio vendor: Gigabyte driver: snd_hda_intel
    bus-ID: 1-2:2 v: kernel chip-ID: 0414:a014 alternate: snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 class-ID: 0300 chip-ID: 8086:7ad0 class-ID: 0403
  Device-2: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
    class-ID: 0403
  Device-3: Giga-Byte USB Audio type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Sound Server-1: ALSA v: k5.15.60-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.56 running: yes
  Device-1: Intel Alder Lake-S PCH CNVi WiFi vendor: Rivet Networks
    driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:7af0 class-ID: 0280
  Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0
    chip-ID: 8086:15f3 class-ID: 0200
  IF: enp5s0 state: down mac: <filter>
    bus-ID: 1-14:9 chip-ID: 8087:0026 class-ID: e001
  Local Storage: total: 938.79 GiB used: 8.79 GiB (0.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
    1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
    speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 4B2QEXM7
    temp: 39.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 type: USB model: USB DISK 2.0 size: 7.28 GiB
    block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
    rev: PMAP scheme: MBR
  ID-1: / raw-size: 133.42 GiB size: 130.26 GiB (97.64%) used: 8.79 GiB (6.7%)
    fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
    uuid: a759baa7-9cc3-4141-a88a-86638a9ef8ab
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
    (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: NO_LABEL
    uuid: C6EA-2577
  ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 797.8 GiB fs: ext4 label: N/A
    uuid: aede8599-ced8-466d-a9e5-c40931f7ffc3
  ID-2: /dev/sda1 maj-min: 8:1 size: 3.32 GiB fs: iso9660
  ID-3: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: C80E-8B3F
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
  Device-1: 1-2:2 info: Giga-Byte USB Audio type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
    speed: 480 Mb/s power: 100mA chip-ID: 0414:a014 class-ID: 0300
  Device-2: 1-4:3 info: Corsair Harpoon Wireless Mouse type: HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 1b1c:1b5e class-ID: 0300 serial: <filter>
  Device-3: 1-5:4 info: Apple Aluminium Keyboard (ANSI) type: Keyboard,Mouse
    driver: apple,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
    chip-ID: 05ac:024f class-ID: 0301
  Hub-2: 1-11:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-3: 1-12:6 info: Genesys Logic Hub ports: 2 rev: 2.0 speed: 480 Mb/s
  Device-1: 1-12.1:8 info: Kingston Platinum USB drive mini
    type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0
    speed: 480 Mb/s power: 100mA chip-ID: 13fe:4200 class-ID: 0806
    serial: <filter>
  Device-2: 1-13:7 info: Integrated Express ITE Device type: HID
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-3: 1-14:9 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
    interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
    class-ID: e001
  Hub-4: 2-0:1 info: Super-speed hub ports: 9 rev: 3.1 speed: 20 Gb/s
  System Temperatures: cpu: 29.0 C mobo: N/A gpu: amdgpu temp: 38.0 C
    mem: 38.0 C
  Fan Speeds (RPM): N/A gpu: amdgpu fan: 0
  Processes: 339 Uptime: 6m wakeups: 0 Init: systemd v: 251 default: graphical
  tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6 Packages: pacman: 1171
  lib: 316 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
  running-in: konsole inxi: 3.3.20
I don’t know if this makes a difference but the command used to copy this info is from the test partition and not the partition that isn’t loading.
I’m using the Plasma DE.
Thanks for the help!
Welcome to Manjaro! :smiling_face_with_three_hearts:
  1. Please read the information behind this link. It will help you to post necessary information. [HowTo] Provide System Information
  2. Please press the three dots below your post and then press the :pencil2:
  • If you give us information about your system, we can see what we’re talking about and make better suggestions.
  • You can do this by using inxi in a terminal or in console.
  • Personally identifiable information such as serial numbers and MAC addresses are filtered out by this command
  • Presenting the information in this way allows everyone to be familiar with the format and quickly find the items they need without missing anything.
  1. Copy the output from inxi (including the command) and paste it into your post.
  • To make it more readable, add 3 backticks ``` on an extra line before and after the pasted text.
    (Wisdom lies in reading :wink: )
How to boot from USB into live Manjaro (for repair):
Hi @miraclemax, and welcome!
This is just a message, usually hidden when everything starts correctly, telling you everything on that SSD is fine.
You didn’t mention which DE you use, which would be necessary to know if this is to be troubleshot (Is that even a word?_
So, I think it’s kind of obvious by now, that in order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Also, if your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
I followed the wiki page linked in the page you linked and reinstalled the grub bootloader but it’s still not loading.
Then try to boot the Manjaro USB stick and check the filesystem.
The message means, that the filesystem is not unmounted correctly.
I beg to differ.
I get the same message on each and every startup. Have been for 2+ years now. And my drive is healthy as a, well, a new, young SSD. I also never turn off my PC without a proper shutdown. And I’ve also never had any data loss. Besides, this :point_down:
Clearly states the drive is clean.
Edit:
I just remembered, I also read somewhere that the message is displayed because of nvidia drivers. Counter-intuitive and doesn’t make even the slightest bit of sense, but there it is.
Edit #2:
However, booting into a live environment and from there entering a chroot environment, to obtain logs might not be to bad of an idea.
How to chroot
  1. Ensure you’ve got a relatively new ISO or at least one with a still supported LTS kernel.
  2. Write/copy/dd the ISO to a USB thumb drive.
  3. When done, boot with the above mentioned USB thumb drive into the live environment.
  4. Once booted, open a terminal and enter the following command to enter the chroot encironment:
manjaro-chroot -a
  1. If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot environment.
But, be careful, as you’re now in an actual root environment on your computer, so any changes you make will persist after a restart.
From within the chroot environment, please run the following and provide the output here:
journalctl --boot=-1 --priority=4 --no-pager
Explanation:
  • The --boot= argument limits the log files to the previous boot (-1). Feel free to adjust the value as necessary: - for the previous boot, -2 the one before it, -3 the one before that, and so on, and so forth;
  • the --priority= arguments limit the messages to warnings and errors only;
  • the --mo-pager argument removes the need for human interaction to view the full log, making it ideal for use to obtain logs for providing to the forum here.
When I type in the first command, all it says is
zsh: command not found: manjaro-chroot
The command is manjaro-chroot -a .
manjaro-chroot is available on live-cd/usb :wink: (not in a normal install)
