Here’s the result of journalctl --boot=-1 --priority=3 --catalog --no-pager
nov. 05 19:17:13 ualtarh-manjaro-msi kernel: Spectre V2 : WARNING: Unprivileged eBPF is enabled with eIBRS on, data leaks possible via Spectre v2 BHB attacks!
nov. 05 19:17:14 ualtarh-manjaro-msi kernel:
nov. 05 19:27:15 ualtarh-manjaro-msi pulseaudio[882]: GetManagedObjects() failed: org.freedesktop.systemd1.NoSuchUnit: Unit dbus-org.bluez.service not found.
nov. 05 19:59:08 ualtarh-manjaro-msi systemd-coredump[5479]: Failed to connect to coredump service: Connection refused
nov. 05 19:59:12 ualtarh-manjaro-msi kernel: watchdog: watchdog0: watchdog did not stop!
I also found a file called Xorg.0.log in /var/log/ folder with a few warnings, I think the ones causing problem are at [33.173] with modules not loading properly, but I don’t know anything about all this
[ 32.834]
X.Org X Server 1.21.1.4
[ 32.834] Current Operating System: Linux ualtarh-manjaro-msi 5.15.76-1-MANJARO #1 SMP PREEMPT Sat Oct 29 14:22:16 UTC 2022 x86_64
[ 32.834] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=8f04d467-8485-44dd-a01b-1e9ceb7b9b86 rw quiet apparmor=1 security=apparmor
[ 32.834]
[ 32.834] Current version of pixman: 0.42.0
[ 32.834] Before reporting problems, check http://wiki.x.org
[ 32.834] Markers: (--) probed, (**) from config file, (==) default setting,
[ 32.834] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Nov 5 20:55:41 2022
[ 32.835] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 32.835] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 32.837] (==) ServerLayout "layout"
[ 32.837] (==) No screen section available. Using defaults.
[ 32.837] (**) |-->Screen "Default Screen Section" (0)
[ 32.837] (**) | |-->Monitor "<default monitor>"
[ 32.837] (==) No monitor specified for screen "Default Screen Section".
[ 32.837] (==) Automatically adding devices
[ 32.837] (==) Automatically enabling devices
[ 32.837] (==) Automatically adding GPU devices
[ 32.837] (==) Automatically binding GPU devices
[ 32.837] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 32.838] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 32.838] Entry deleted from font path.
[ 32.838] (Run 'mkfontdir' on "/usr/share/fonts/misc").
[ 32.838] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 32.838] (Run 'mkfontdir' on "/usr/share/fonts/TTF").
[ 32.838] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 32.838] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 32.838] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 32.838] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 32.838] (==) FontPath set to:
[ 32.838] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 32.838] (II) The server relies on udev to provide the list of input devices.
[ 32.838] (II) Module ABI versions:
[ 32.838] X.Org ANSI C Emulation: 0.4
[ 32.838] X.Org Video Driver: 25.2
[ 32.838] X.Org XInput driver : 24.4
[ 32.838] X.Org Server Extension : 10.0
[ 32.839] (++) using VT number 1
[ 32.840] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[ 32.841] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 32.841] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
[ 32.841] (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 13 paused 0
[ 32.841] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 32.841] (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
[ 32.842] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
[ 32.842] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 32.842] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 33.149] (--) PCI:*(0@0:2:0) 8086:9a60:1462:12ea rev 1, Mem @ 0x6202000000/16777216, 0x4000000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 33.149] (--) PCI: (1@0:0:0) 10de:249d:1462:12ea rev 161, Mem @ 0x81000000/16777216, 0x6000000000/8589934592, 0x6200000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
[ 33.149] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 33.149] (II) LoadModule: "glx"
[ 33.160] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 33.165] (II) Module glx: vendor="X.Org Foundation"
[ 33.165] compiled for 1.21.1.4, module version = 1.0.0
[ 33.165] ABI class: X.Org Server Extension, version 10.0
[ 33.165] (II) Applying OutputClass "intel" to /dev/dri/card0
[ 33.165] loading driver: modesetting
[ 33.165] (II) Applying OutputClass "nvidia" to /dev/dri/card1
[ 33.165] loading driver: nvidia
[ 33.165] (==) Matched modesetting as autoconfigured driver 0
[ 33.165] (==) Matched nvidia as autoconfigured driver 1
[ 33.165] (==) Matched nouveau as autoconfigured driver 2
[ 33.165] (==) Matched nv as autoconfigured driver 3
[ 33.165] (==) Matched fbdev as autoconfigured driver 4
[ 33.165] (==) Matched vesa as autoconfigured driver 5
[ 33.165] (==) Assigned the driver to the xf86ConfigLayout
[ 33.165] (II) LoadModule: "modesetting"
[ 33.166] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 33.167] (II) Module modesetting: vendor="X.Org Foundation"
[ 33.167] compiled for 1.21.1.4, module version = 1.21.1
[ 33.167] Module class: X.Org Video Driver
[ 33.167] ABI class: X.Org Video Driver, version 25.2
[ 33.167] (II) LoadModule: "nvidia"
[ 33.167] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 33.171] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 33.171] compiled for 1.6.99.901, module version = 1.0.0
[ 33.171] Module class: X.Org Video Driver
[ 33.171] (II) LoadModule: "nouveau"
[ 33.171] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 33.172] (II) Module nouveau: vendor="X.Org Foundation"
[ 33.172] compiled for 1.21.1.1, module version = 1.0.17
[ 33.172] Module class: X.Org Video Driver
[ 33.172] ABI class: X.Org Video Driver, version 25.2
[ 33.172] (II) LoadModule: "nv"
[ 33.173] (WW) Warning, couldn't open module nv
[ 33.173] (EE) Failed to load module "nv" (module does not exist, 0)
[ 33.173] (II) LoadModule: "fbdev"
[ 33.173] (WW) Warning, couldn't open module fbdev
[ 33.173] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 33.173] (II) LoadModule: "vesa"
[ 33.173] (WW) Warning, couldn't open module vesa
[ 33.173] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 33.173] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 33.173] (II) NVIDIA dlloader X Driver 520.56.06 Thu Oct 6 21:29:26 UTC 2022
[ 33.173] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 33.173] (II) NOUVEAU driver
[ 33.173] (II) NOUVEAU driver for NVIDIA chipset families :
[ 33.173] RIVA TNT (NV04)
[ 33.173] RIVA TNT2 (NV05)
[ 33.173] GeForce 256 (NV10)
[ 33.173] GeForce 2 (NV11, NV15)
[ 33.173] GeForce 4MX (NV17, NV18)
[ 33.174] GeForce 3 (NV20)
[ 33.174] GeForce 4Ti (NV25, NV28)
[ 33.174] GeForce FX (NV3x)
[ 33.174] GeForce 6 (NV4x)
[ 33.174] GeForce 7 (G7x)
[ 33.174] GeForce 8 (G8x)
[ 33.174] GeForce 9 (G9x)
[ 33.174] GeForce GTX 2xx/3xx (GT2xx)
[ 33.174] GeForce GTX 4xx/5xx (GFxxx)
[ 33.174] GeForce GTX 6xx/7xx (GKxxx)
[ 33.174] GeForce GTX 9xx (GMxxx)
[ 33.174] GeForce GTX 10xx (GPxxx)
since this file is super long I put the whole log in a pastebin : /var/log/Xorg.0.log there’s only warning after the ones above at the very end of the file.
By Googling the warning couldn't open module nv, I saw thread talking about adding graphic card’s kernet to initramfs and it might solve the problem, is the file in question in /etc/mkinitcpio.conf ?
Am really confused, thank you for your help !
