Infinite folder loop with dolphin embedded terminal when using manjaro-zsh-config
Dolphin on manjaro encounters infinite loop, and the bug is only able to reproduce on manjaro hosts with zsh, KDE devs think this is something related to manjaro-zsh-config and manjaro-zsh-prompt.
For details, please refer to: (base64 encoded link)
aHR0cHM6Ly9idWdzLmtkZS5vcmcvc2hvd19idWcuY2dpP2lkPTUwMDYxNA==
(idk why I cannot send links, so I have to take base64 encoded link to bypass…)
Mod Note: Translation is: https://bugs.kde.org/show_bug.cgi?id=500614
Please take the time to read through the following links — among other things, it tells you how to post external links.
How to Request Support
Tips and Tricks
Resources
Also note that a new Stable Update has just been pushed out. :point_down:
You may want to update your system first, and then check whether your problem still exists after updating and rebooting.
I just checked - I steps to reproduce the issue - in textual format
  1. Open dolphin
  2. Open integrated terminal (F4)
  3. mkdir test
  4. rightclick on desktop
    • Create New
    • Link to File or Directory
    • Navigate to the test folder
    • Create the shortcut
  5. Doubleclick the shortcut
    Dolphin open in the select folder with terminal open - and is printing the navigation commands. (non displayable glyhps removed)
     ~/Desktop/test   cd                          ✔
     /   cd /home/fh/Desktop/test                 ✔
     ~/Desktop/test  cd /home/fh                  ✔
     ~  cd /home/fh/Desktop/test                  ✔
     ~/Desktop/test                               ✔
  • Open the test folder using the shortcut
    Screenshot 1
  • Create a new folder inside test → test2 → open the test2 folder’s in dolphin → displays empty
    Screenshot 2
  • Close dolphin with Home and test tab open
  • This will produce a loop - it will eventually die
    Screenshot 3
This does look strange - I give you that - I am no expert on zsh - so I cannot say if it is one or another.
If it is zsh configuration causing this the upstream source is
Please open an issue with the developer.
