splox
January 19, 2023, 5:49am
#1
Hello, first off all excuse some wrongdoings i will have while explaining my problem, im using Linux and Manjaro for the first time in my life and im just 2 weeks in the expirience.
My problem is that after i “hard shut downed” my laptop with holding the start key for some seconds and starting him again later that day my wifi where not showing anymore.
I’ve read some troubleshootings and tried finding the card in my system but it seems like the system is not knowing anymore that the card is inside (the ethernet is showing up and working, ive build a workaround with a smartphone on usb tehtering to gain access because im in a hospital and have only wifi access).
Maybe its also a problem with the special touch key (the things over the laptop keyboards) which normally would light up when touched and activate the whole wifi card thingy. some of the other keys work like activating bluetooth but wifi is not, also using the Fn key to activate it like that also doesent work (while making the screen brighter or change sound loudness works)
i wanted to post my inxi -Fazy output but it tells me i cant post links… hmm…
Edit: somehow the touch button for the wifi worked now again and lighted up and even the fn key worked again but still no wifi aviable in the network center , just again phone via usb tethering
You can’t post links as a new member - has to do with trust levels in the forum software.
However, there normally is no link in the output of that command.
Try properly formatting it as preformatted text
this button in the top row of the window you type in : </>
or see this:
[HowTo] Post screenshots and links
splox
January 19, 2023, 11:11am
#3
Kernel: 5.15.85-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=f79f43d2-f04a-4237-b8f6-6aa3102904b9 rw rootflags=subvol=@ quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Micro-Star product: GT680R/GX680R/GT683R v: N/A
Mobo: Micro-Star model: MS-16F2 serial: <superuser required>
BIOS: American Megatrends v: E16F2IMS V3.0D date: 03/03/2011
ID-1: BAT1 charge: 32.6 Wh (97.9%) condition: 33.3/86.6 Wh (38.4%)
volts: 12.4 min: 11.1 model: MS-16F2 type: Unknown serial: N/A status: N/A
Info: model: Intel Core i5-2410M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2617 high: 2667 min/max: 800/2900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2667 2: 2582 3: 2646
4: 2574 bogomips: 18364
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
vulnerable
prctl and seccomp
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GF106M [GeForce GT 555M] vendor: Micro-Star MSI
driver: nvidia v: 390.157 alternate: nouveau,nvidia_drm non-free:
series: 390.xx+ status: legacy-active (EOL~late 2022) arch: Fermi
code: GF1xx process: 40/28nm built: 2010-16 pcie: gen: 2 speed: 5 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:0dcd class-ID: 0300
Display: x11 server: X.Org v: 21.1.6 compositor: kwin_x11 driver: N/A
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
s-diag: 391mm (15.39")
Monitor-1: LVDS-0 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.54x7.6") diag: 394mm (15.53") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 390.157 renderer: GeForce GT 555M/PCIe/SSE2
direct render: Yes
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
Device-2: NVIDIA GF106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0be9 class-ID: 0403
Sound API: ALSA v: k5.15.85-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
vendor: Micro-Star MSI driver: r8168 v: 8.050.03-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0
Device-2: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:0083 class-ID: 0280
IF-ID-1: enp0s26u1u5 state: unknown speed: -1 duplex: half mac: <filter>
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: f020 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 232.89 GiB used: 67.81 GiB (29.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4B6Q scheme: MBR
ID-1: / raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
used: 67.81 GiB (29.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
ID-3: /var/log raw-size: 232.88 GiB size: 232.88 GiB (100.00%)
System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 52 C
Processes: 230 Uptime: 4m wakeups: 1 Memory: 7.74 GiB used: 1.98 GiB (25.5%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1355 libs: 377
tools: pamac pm: flatpak pkgs: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.24
splox
January 19, 2023, 11:43am
#4
and this is the output of lshw -C network
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0000:02:00.0
logical name: enp2s0
version: 06
serial: 6c:62:6d:31:9a:f8
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8168 driverversion=8.050.03-NAPI latency=0 link=no multicast=yes port=twisted pair
resources: irq:34 ioport:d000(size=256) memory:ec104000-ec104fff memory:ec100000-ec103fff
*-network
description: Network controller
product: Centrino Wireless-N 1000 [Condor Peak]
vendor: Intel Corporation
physical id: 0
bus info: pci@0000:03:00.0
version: 00
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: driver=iwlwifi latency=0
resources: irq:37 memory:ec000000-ec001fff
*-network
physical id: 6
bus info: usb@1:1.5
logical name: enp0s26u1u5
serial: da:aa:e7:90:6a:8b
capabilities: ethernet physical
configuration: autonegotiation=off broadcast=yes driver=rndis_host driverversion=5.15.85-1-MANJARO duplex=half firmware=RNDIS device ip=192.168.86.240 link=yes multicast=yes port=twisted pair
j8a
January 19, 2023, 1:49pm
#5
HI @splox ,
Welcome to the forum, I can recommend you from other posts in the forum that the card is very old and does not have support on linux. Please, consider to buy an usb wifi adapter.
You could read them yourself in the links below:
‘Wifi Not working and no wifi network showing up ’
‘Wifi on but no networks show in list ’
‘Trouble with WiFi on laptop :intermittently turns off and must reboot; but now won't come on at all - #3 by j8a ’
Hope it help, regards
splox
January 19, 2023, 4:07pm
#6
I tried the options which where used in the links but nothing helped…
Now also the touch wifi on/off button stopped his light and the system is again not even seeing the wifi card, even when i had a moment today where the button was working.
Does anyone know what happend there?
Cant try to run a wifi card which is deactivated by some internal funky laptop special buttons…
