Wifi Not working and no wifi network showing up
Wifi was working fine 1 week age. Suddenly It doesn’t connect to my home router and Now it won’t even show any wifi network.
inxi --full --verbosity=7 --filter --no-host
  Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux
    base: Arch Linux
  Type: Portable System: Dell product: Inspiron N4010 v: A13
    serial: <superuser required>
  Mobo: Dell model: N/A v: A13 serial: <superuser required> BIOS: Dell
    v: A13 date: 03/31/2011
  ID-1: BAT0 charge: 2.6 Wh (100.0%) condition: 2.6/4.4 Wh (59.7%)
    volts: 11.1 min: 11.1 model: SIMPLO Dell type: Li-ion serial: <filter>
    status: charging
  RAM: total: 3.64 GiB used: 2.12 GiB (58.2%)
  RAM Report:
  Info: dual core model: Intel Core i5 M 480 bits: 64 type: MT MCP
    smt: enabled arch: Westmere rev: 5 cache: L1: 128 KiB L2: 512 KiB L3: 3 MiB
  Speed (MHz): avg: 1418 high: 1463 min/max: 1199/2667 boost: enabled
    cores: 1: 1354 2: 1463 3: 1438 4: 1418 bogomips: 21290
  Flags: acpi aperfmperf apic arat arch_perfmon bts clflush cmov
    constant_tsc cpuid cx16 cx8 de ds_cpl dtes64 dtherm dts ept est
    flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce mmx
    monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pdcm pebs pge pni
    popcnt pse pse36 pti rdtscp rep_good sep ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc vme vmx vnmi vpid xtopology
    xtpr
  Device-1: Intel Core Processor Integrated Graphics vendor: Dell
    driver: i915 v: kernel ports: active: LVDS-1 empty: DP-1,HDMI-A-1,VGA-1
    bus-ID: 00:02.0 chip-ID: 8086:0046 class-ID: 0300
  Device-2: Microdia Sonix 1.3 MP Laptop Integrated Webcam type: USB
    driver: uvcvideo bus-ID: 1-1.4:4 chip-ID: 0c45:6480 class-ID: 0e02
  Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
    X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
    screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31")
  Monitor-1: LVDS-1 model: LG Display 0x0291 res: 1366x768 hz: 60 dpi: 112
    size: 310x174mm (12.2x6.85") diag: 355mm (14") modes: 1366x768
  Message: Unable to show GL data. Required tool glxinfo missing.
  Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
    class-ID: 0403
  Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.48 running: yes
  Device-1: Intel Centrino Wireless-N 1000 [Condor Peak] driver: iwlwifi
    v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:0083
    class-ID: 0280
  IF: wlp3s0 state: down mac: <filter>
  Device-2: Qualcomm Atheros AR8152 v1.1 Fast Ethernet vendor: Dell
    driver: atl1c v: kernel pcie: speed: 2.5 GT/s lanes: 1 port: 2000
    bus-ID: 04:00.0 chip-ID: 1969:2060 class-ID: 0200
  IF: enp4s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 465.76 GiB used: 280.89 GiB (60.3%)
  ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545050A7E680
    size: 465.76 GiB speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter>
    rev: AF10 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GT32N rev: A201
    dev-links: cdrom
  ID-1: / size: 80.51 GiB used: 27.58 GiB (34.3%) fs: ext4 dev: /dev/sda2
    label: N/A uuid: cee3c34f-4ca3-432d-9778-1ffbc8db20e9
  ID-2: /mnt/mustafizur size: 376.39 GiB used: 253.31 GiB (67.3%) fs: ext4
    dev: /dev/sda1 label: mustafizur uuid: 4cb3444a-d036-4072-8e5a-60bbe7f70b77
  Hub-1: 1-0:1 info: Full speed or root hub ports: 3 rev: 2.0 speed: 480 Mb/s
    speed: 480 Mb/s chip-ID: 8087:0020 class-ID: 0900
  Hub-3: 1-1.1:3
    info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
    rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
  Device-1: 1-1.1.1:5 info: Dell Integrated Keyboard type: Keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 2mA
    chip-ID: 413c:8161 class-ID: 0301
  Device-2: 1-1.1.2:7 info: Dell Integrated Touchpad [Synaptics]
    type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 12 Mb/s power: 2mA chip-ID: 413c:8162 class-ID: 0301
  Device-3: 1-1.4:4 info: Microdia Sonix 1.3 MP Laptop Integrated Webcam
    type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
    power: 500mA chip-ID: 0c45:6480 class-ID: 0e02
  Device-4: 1-1.5:6 info: Realtek RTS5138 Card Reader Controller
    type: Mass Storage driver: ums-realtek interfaces: 1 rev: 2.0
    speed: 480 Mb/s power: 500mA chip-ID: 0bda:0138 class-ID: 0806
    serial: <filter>
  Hub-4: 2-0:1 info: Full speed or root hub ports: 3 rev: 2.0
  Hub-5: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 2-1.1:3 info: SiGma Micro Keyboard TRACER Gamma Ivory
    type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s power: 98mA chip-ID: 1c4f:0002 class-ID: 0300
  Device-2: 2-1.2:4 info: Logitech Unifying Receiver type: Keyboard,Mouse
    driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 98mA chip-ID: 046d:c534 class-ID: 0301
  System Temperatures: cpu: 66.0 C mobo: 0.0 C
  Fan Speeds (RPM): cpu: 0
  Processes: 235 Uptime: 17m wakeups: 1 Init: systemd v: 250 Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1315 Shell: Zsh v: 5.8.1
  running-in: xfce4-terminal inxi: 3.3.15
ifconfig
enp4s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.27.144.53  netmask 255.255.240.0  broadcast 10.27.159.255
        inet6 fe**::************  prefixlen 64  scopeid 0x20<link>
        ether **************  txqueuelen 1000  (Ethernet)
        RX packets 858046  bytes 160751353 (153.3 MiB)
        RX errors 0  dropped 1376  overruns 0  frame 0
        TX packets 22128  bytes 2627195 (2.5 MiB)
        TX errors 0  dropped 0 overruns 0  carrier 5  collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 159  bytes 10951 (10.6 KiB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 159  bytes 10951 (10.6 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
wlp3s0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether *************  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        TX packets 26  bytes 3625 (3.5 KiB)
I have already tried
sudo systemctl restart NetworkManager
sudo ip link set dev wlp3s0 up
RTNETLINK answers: Operation not permitted
nmcli device wifi list
IN-USE  BSSID  SSID  MODE  CHAN  RATE  SIGNAL  BARS  SECURITY
From my previous post someone requested
rfkill
ID TYPE DEVICE      SOFT      HARD
 0 wlan phy0   unblocked unblocked
But none worked.
i have checked if wifi works on Live Boot but it doesn’t work there either.
