Virtscreen error
I try to use the virtscreen package to use my phone as a second screen.
when I hit the “Enable virtual screen” button I get a window with the message “no virtual screen name found”.
Is there a way to fix this?
Hi @hafid,
You gave no indication of what you’re trying to do, and there’s absolutely no information for anyone to work with, and sadly I’ve never come across a working crystal ball, so we need you to provide information. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
Additionally, perhaps this is of some help:
Thank you very much for your valuable remarks on how to post in this site. I take note!
I don’t use nvidia
If you had provided some of the information previously requested, we’d know you don’t use Nvidia. Without that information, we can only guess; and not many appreciate having to guess.
So, why not give some of the information shown in the first link @Mirdarthos gave you? It will help us greatly. Cheers.
virtscreen is an unsupported custom script from AUR
Usage of custom scripts from AUR infers Arch Linux package level - this is only obtainable using Manjaro unstable branch.
To switch branches see Switching Branches - Manjaro
The TLDR
sudo pacman-mirrors -aS unstable && sudo pacman -Syu
:warning:
Orphaned
Last Updated: 2019-11-14 21:36 (UTC)
The rebuild the custom script
pamac build virtscreen
2023-11-26T14:31:00Z python quamash dependency fails to build with AttributeError
See the AUR script page AUR (en) - python-quamash - this will also show the package is orphaned and unmaintained.
sorry for my little knowledge but which information is needed and how to get it?
My mistake, I thought this was among the links Mithardos had given:
System information, recent logs, etc – that explains how to find them. Cheers.
Familiarize yourself with how to find, and share system information - that will be of help at another time for another issue.
For the topic at hand the information is irrelevant as the custom package is dead and you should remove it.
