A post was split to a new topic: Touche application is working on Xorg but not on Wayland
@philm mugshot is outdated and needs Python 3.10 rebuild.
SoftMaker has updated softmaker-office-2021 from revision 1040 (2021-12-02) to revision 1042 (2021-12-17).
This update comes only two weeks after the last update. It must be a minor update, because usually SoftMaker publishes a detailed list of changes with each update. This time, however, the change log only contains the cryptic paraphrase: Miscellaneous bug fixes in all programs. So it’s hard to say what has actually changed.
A post was merged into an existing topic: Update requests for packages imported from Arch Linux
Nvidia has released version 390.147 of the legacy proprietary driver for Fermi GPUs. This version mainly fixes the compatibility issues with Xorg server 21.1.1, along with some other improvements.
I have modified the patch required to run this driver on kernel 5.16-rc5 so that it is possible to install and run the driver on that kernel. Please have a look at Patch and PKGBUILD for running 390.147 with kernel 5.16-rc5 (#1) · Issues · Packages / Extra / linux515-extramodules / nvidia-390xx · GitLab
UPDATE: The driver also runs with kernel 5.16-rc6; no modifications to the patch are necessary.
@oberon there is a new version of kwinft released 1 week ago, can you update the package?
There is a new version of ZFS (2.1.2)
@Yochanan
I’ve pushed a rebuild of mutter-x11-scaling to use libsysprof-capture.
Also pushed bmenu 0.18-1 with some fixes. (Thanks to @cscs )
4 posts were split to a new topic: Linux-driver-management prevents latest stable update due to it’s dependence on hwdata
thunarx-python from the community repo has to be rebuilt against Python 3.10. For some reason, it looks for libpython3.9.so.1.0:
ldd /usr/lib/thunarx-3/thunarx-python.so | grep -i python
# libpython3.9.so.1.0 => not found
Hi,
when will be the Gnome extention Dash to Dock (gnome-shell-extension-dash-to-dock) updated next?
There is a annoying bug that let the windows counter indicator numbers are totally wrong. There is a closed issue
that links to this commit
Last Manjaro repo commit is from December 7, 2021
There is no new extensions.gnome.org-v7x release published, but maybe commits can be merged too.
Thanks.
@Yochanan
I’ve pushed autogit 1.6.0 to Gitlab.
Manjaro provides pacman-static in its core repository, however, it hasn’t been updated in a while (it’s at 5.2.1). The PKGBUILD is also out-of-date, and does not work.
I would like to ask for it to be removed or updated (e.g. there is an up-to-date PKGBUILD in the AUR).
@oberon
discover-snap needs an update. The current version in the manjaro repos is 5.18.0, the actual current version (as available on the AUR) is 5.24.0.
The UI of 5.18.0 is quite broken, while 5.24.0 works perfectly, just like regular discover
Just pushed 5.24.2.1-1 to stable / testing and 5.24.3-1 to unstable.
SoftMaker has updated softmaker-office-2021 from revision 1042 (2021-12-17) to revision 1044 (2022-03-22).
Judging by the change log, the update contains a few minor program corrections.
Unfortunately, the bugs in the German grammar checker Duden Korrektor have not been fixed yet. Since Duden Korrektor is a third-party program, SoftMaker is dependent on the manufacturer to provide an updated version, which SoftMaker then has to integrate into the Office application.
@oberon ktrip is outdated in the community repositories. The current version the manjaro repos is 21.05-1, the actual current version is 22.02.
When installing ktrip from the repositories the UI seems to completely broken, as I’m unable to to do anything than using the settings or open the about page. Could you update the package?
Thank you. We missed that. Updating.
systemd-boot-manager v0.9-1 (Build date: 22 Feb 2020) is obsolete in the Manjaro repos and has the some bugs e.g. “discard” does not work.
I know the bug was fixed in the current version from gitlab 1 year ago:
Can you update it in the Manjaro repos?
Thanks!
