Hello everyone,
Could you help me about this problem in my pc with manjaro?
I am running 4 drives (2 SSD and 2 HDD), but i can only write to my system drive. The other ones can be read but not written to (according to the file permissions I should be able to read and write).
As I am new to Linux, I have an instance of Windows 11 installed on the other SSD (m.2 nvme), both HDDs (SATA) and the Windows SSD run with ntfs.
The 3 non-Linux drives all show up in /run/media/username/drive-name.
If I boot into Windows, I can write to all drives except the Linux one, which does not even show up as mounted.
Thanks for the help in advance. If you need some more information, let me know.
In order for us or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Itâs most likely a permission problem. Especially with ntfs. And you shouldnât (and I hope you donât) expect Windows to be able to use, or even just read, any âLinuxâ filesystem without installingâŚstuffâŚ
Hope you manage!
System inforamtion:
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: H410M PRO (MS-7C89) v: 1.1
serial: <superuser required> UEFI: American Megatrends v: F.20
date: 06/10/2020
RAM: total: 15.56 GiB used: 2.71 GiB (17.4%)
RAM Report:
Info: 8-core model: Intel Core i7-10700F bits: 64 type: MT MCP smt: enabled
arch: Comet Lake rev: 5 cache: L1: 512 KiB L2: 2 MiB L3: 16 MiB
Speed (MHz): avg: 800 high: 801 min/max: 800/4800 cores: 1: 800 2: 800
3: 800 4: 800 5: 800 6: 801 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800
13: 799 14: 800 15: 800 16: 800 bogomips: 92838
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
xsaves xtopology xtpr
Device-1: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 510.54 pcie: speed: 5 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f06 class-ID: 0300
Device-2: Sunplus Innovation FHD Camera Microphone type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 1-5.3.1:6 chip-ID: 1bcf:28c4
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: nvidia gpu: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: HDMI-0 res: 3440x1440 hz: 60 dpi: 107
size: 819x346mm (32.24x13.62") diag: 889mm (35") modes: N/A
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Comet Lake PCH-V cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a3f0
class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Sunplus Innovation FHD Camera Microphone type: USB
Device-4: C-Media USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5.3.2:7
chip-ID: 0d8c:0012 class-ID: 0300
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.48 running: yes
Device-1: Intel Ethernet I219-V vendor: Micro-Star MSI driver: e1000e
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:0d55 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie:
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-7:3 chip-ID: 8087:0029 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 2.97 TiB used: 988.27 GiB (32.5%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 980 PRO 1TB
size: 931.51 GiB speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 3B2QGXA7 temp: 33.9 C scheme: GPT
ID-2: /dev/nvme1n1 vendor: Western Digital
model: PC SN530 SDBPNPZ-512G-1032 size: 476.94 GiB speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 21111000 temp: 29.9 C
scheme: GPT
ID-3: /dev/sda vendor: Western Digital model: WD10EZEX-22MFCA0
size: 931.51 GiB speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-4: /dev/sdb vendor: Apple model: HDD HTS547575A9E384 size: 698.64 GiB
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: D70F scheme: GPT
ID-1: / size: 468.09 GiB used: 24.49 GiB (5.2%) fs: ext4
dev: /dev/nvme1n1p2 label: N/A uuid: 0b4fea78-6afe-4423-a0a6-10fd7db1e52f
ID-2: /boot/efi size: 299.4 MiB used: 292 KiB (0.1%) fs: vfat
dev: /dev/nvme1n1p1 label: NO_LABEL uuid: A28E-FE3E
ID-3: /run/media/simons/Data size: 909.11 GiB used: 333.37 GiB (36.7%)
fs: ntfs dev: /dev/sda1 label: Data uuid: 78BA6D2EBA6CE9D8
ID-4: /run/media/simons/Foto BackUp size: 698.44 GiB
used: 428.37 GiB (61.3%) fs: ntfs dev: /dev/sdb2 label: Foto BackUp
uuid: 8E8CFBE28CFBC2AF
ID-5: /run/media/simons/Windows size: 930.51 GiB used: 202.04 GiB (21.7%)
fs: ntfs dev: /dev/nvme0n1p3 label: Windows uuid: 94AC6989AC696728
ID-1: /dev/nvme0n1p1 size: 100 MiB fs: vfat label: SYSTEM uuid: B669-1AEB
ID-2: /dev/nvme0n1p2 size: 128 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p4 size: 800 MiB fs: ntfs label: N/A
uuid: 34BA3C23BA3BE052
ID-4: /dev/sda2 size: 22.38 GiB fs: ntfs label: BIOS_RVY
uuid: B6DA6ED5DA6E9203
ID-5: /dev/sdb1 size: 200 MiB fs: vfat label: EFI uuid: 2860-11F4
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Hub-2: 1-5:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-3: 1-5.3:4 info: Hitachi ports: 4 rev: 2.0 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Device-1: 1-5.3.1:6 info: Sunplus Innovation FHD Camera Microphone
type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 1bcf:28c4 class-ID: 0102
serial: <filter>
Device-2: 1-5.3.2:7 info: C-Media USB Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0012 class-ID: 0300
Device-3: 1-5.3.3:8 info: Logitech Corded Keyboard K280e
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 1.1
speed: 1.5 Mb/s power: 98mA chip-ID: 046d:c328 class-ID: 0300
Device-4: 1-5.3.4:9 info: Logitech G502 SE HERO Gaming Mouse
type: Mouse,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Device-5: 1-7:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Device-6: 1-8:5 info: Micro Star MYSTIC LIGHT type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 1462:7c89 class-ID: 0300 serial: <filter>
Hub-4: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 36 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 47%
Processes: 357 Uptime: 44m wakeups: 0 Init: systemd v: 250 Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1166 pacman: 1159 snap: 7 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.14
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
I have posted the system information. No, I did not expect to be able to read/write to the Linux drive from Windows, but as the drives show up the other was around, I hoped to be able to do so from within Linux
You shouldnât have the drives mounted in /run as itâs not guaranteed to always be the same. Itâs not reliable. I think youâd do well the work thorough this:
Difficulty: â
â
âââ
1. INTRODUCTION
Microsoft Windows started its life as a graphical user interface on top of MS-DOS, a 16-bit single-user, single-tasking operating system that in turn originated as 86DOS, an unauthorized 16-bit rewrite (by Tim Paterson of Seattle Computer) of Digital Researchâs originally 8-bit CP/M operating system. Both CP/M and MS-DOS were at the time developed for computers that did not support any other storage media than floppy disks.
Considering this legacy, MicrosofâŚ
Difficulty: â
ââââ
Disk device recognition
Manjaro uses udev (see Arch Wiki ) to load devices at boot time. The loading of devices is arbitrary and therefore you cannot predict which device will be available at a given path.
But static device names do exist and you can assign specific locations to your device and thus ensure e.g. scripts will work as expected.
What to learn
Overview of system mount units
Structure and Content of a mount unit
Mount at boot (immediate mount)
Mount on demand (mâŚ
Trying to follow the 2nd linked tutorial, but failing at retrieving the UUID of my drives
If I enter the command, i get the error:
lsblk: /run/media/username/Device-name: kein blockorientiertes Gerät (I have my system in german, error translates to âno block-orientated deviceâ)
Make sure windows is shut down fully - disable fast startup or however the function is called.
If you donât, the filesystem is not marked as âcleanâ and it can only be mounted read only by Linux.
You can run this to get needed info at once
lsblk -f
If I do this, I get two different String formats:
94AC6989AC696728
Is it correct anyways?
yes - use the one matching the partition you want to mount e.g. sdy2
I have now set up one drive like this:
[Unit]
Description=Mount Backup disk (/Data/Data)
[Mount]
What=78BA6D2EBA6CE9D8
Where=/Data/Data
#Type=
#Options=
#TimeoutSec=seconds
[Install]
WantedBy=multi-user.target
I expect to see changes after a reboot, rigth?
Gaenseblume:
Must be
What=/dev/disk/by-uuid/78BA6D2EBA6CE9D8
You donât have to reboot - test it immediately (filename must be Data-Data.mount to match your path /Data/Data )
systemctl start Data-Data.mount
Then browse the mountpoint - if you are satisfied
systemctl enable Data-Data.mount
Job failed. See "journalctl -xe" for details.
In the mount point, there is an empty folder with 420 GB of available space (should be ~530 GB)
I am now at the point, where I have all drives mounted to /Data/Drive-name.
All files show up as expected, but I am still unable to write to the drives
The padlocks, which where previously on every single folder, are now gone too.
This is what the permissions window for one of the folders look like, it says âRead & Writeâ in all boxes
one more try, then I give up:
in windows, make sure you disable fast startup or whatever it is called
shut it down fully
else the drives filesystems will be not clean, not cleanly unmounted
and can only be accessed to read from, but not to write at
when you want to use them in Linux.
Have you made sure that this is not the issue?
i have disabled fast start up in bios and Windows is shutdown the way you are intended to. Ill go and have a look if i can find some fast startup option within Windows
Edit: There is an option in the control panel called fast startup. I have disabled it now, but it seems like that was not the problemâŚ
I maybe wrong but your image shows the owner of files as root which means only root can read and write.You need to change the ownership to whatever user you want to be able to let read and write.A regular user can not write to files owned by root.
Other users also have permission to read/write (3rd box)
