I am unable to get my dedicated graphics card to work on my laptop. The drivers seem to be installed, but are not running. Nvidia settings shows 2 tabs, and when loading it through command line, it says the driver isnt loaded. Any help would be appreciated. The graphics card is a RTX 2070 maxQ
output of inxi
Kernel: 6.3.4-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.3-x86_64
root=UUID=c60532ad-35bc-454c-8f98-883a89db32a0 rw quiet splash
resume=UUID=1050dceb-915e-4540-b9f5-49f15ae02214 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Razer product: Blade v: 3.04
Mobo: Razer model: CH530 serial: <superuser required> UEFI: Razer v: 1.05
date: 09/19/2019
ID-1: BAT0 charge: 68.7 Wh (96.6%) condition: 71.1/80.2 Wh (88.6%)
volts: 17.6 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: charging
System RAM: available: 15.52 GiB used: 4.36 GiB (28.1%)
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4000 min/max: 800/4500 scaling: driver: intel_pstate
governor: powersave cores: 1: 4000 2: 4000 3: 4000 4: 4000 5: 4000 6: 4000
7: 4000 8: 4000 9: 4000 10: 4000 11: 4000 12: 4000 bogomips: 62431
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Razer USA
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile] vendor: Razer USA
driver: N/A alternate: nouveau, nvidia_drm, nvidia non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f10 class-ID: 0300
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 13d3:56d5
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: modesetting failed: nvidia dri: iris
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Sharp LQ156M1JW08 built: 2019 res: 1920x1080
hz: 240 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Razer USA driver: snd_hda_intel
Device-2: NVIDIA TU106 High Definition Audio vendor: Razer USA
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.3.4-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 476.94 GiB used: 306.91 GiB (64.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-00000
lanes: 4 tech: SSD serial: <filter> fw-rev: EXA7301Q temp: 42.9 C
scheme: GPT
ID-1: / raw-size: 459.57 GiB size: 451.28 GiB (98.20%)
used: 306.91 GiB (68.0%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: c60532ad-35bc-454c-8f98-883a89db32a0
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 7E41-9CA0
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 1050dceb-915e-4540-b9f5-49f15ae02214
Device-1: 1-3:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-5:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-3: 1-7:4 info: IMC Networks Integrated Camera type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:56d5 class-ID: 0e02 serial: <filter>
Device-4: 1-8:5 info: Razer USA Blade 15 (Mid 2019) Mercury
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 3 rev: 2.0
chip-ID: 1532:0245 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Hub-3: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 73.0 C pch: 61.0 C mobo: N/A
Processes: 294 Uptime: 55m wakeups: 2609 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1833 pm: pacman pkgs: 1772 libs: 474 tools: gnome-software,pamac
pm: flatpak pkgs: 61 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Hope you manage!
Tip:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C
. For example:
LC_ALL=C bluetoothctl
Ive added my inxi, hope it helps
Please return:
mhwd -l -d
And … did you do anything to install drivers? What/how?
So to install drivers, I used the hardware tool in settings to install proprietary drivers. I should be using nvidia-prime drivers, the hybrid ones with intel. It even shows as much in the settings
mhwd -l -d :
> PCI Device: /devices/pci0000:00/0000:00:01.0/0000:01:00.0 (0300:10de:1f10)
Display controller nVidia Corporation TU106M [GeForce RTX 2070 Mobile]
> INSTALLED:
ATTACHED: PCI
VERSION: 2023.03.23
INFO: Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 8
FREEDRIVER: false
DEPENDS: video-modesetting
CONFLICTS: video*nvidia*
CLASSIDS: 0300 0302 0300
VENDORIDS: 10de 8086
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X.org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> AVAILABLE:
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2023.03.23
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 5
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 4
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X.org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:3e9b)
Display controller Intel Corporation CoffeeLake-H GT2 [UHD Graphics 630]
> INSTALLED:
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> AVAILABLE:
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 8
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2023.03.23
PRIORITY: 7
FREEDRIVER: false
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
Warning: no configs for USB devices found!
Mk. And what about
glxinfo | grep 'renderer string'
prime-run glxinfo | grep 'renderer string'
glxinfo | grep ‘renderer string’ :
OpenGL renderer string: Mesa Intel(R) UHD Graphics 630 (CFL GT2)
prime-run glxinfo | grep ‘renderer string’
X Error of failed request: BadValue (integer parameter out of range for operation)
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 24 (X_GLXCreateNewContext)
Value in failed request: 0x0
Serial number of failed request: 50
Current serial number in output stream: 51
im going to assume that the second one isn’t intended
Hmmm…
Please provide the output for:
mhwd --listinstalled
and
mhwd --list
mhwd —listinstalled
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-hybrid-intel-nvidia-prime 2023.03.23 false PCI
mhwd --list
> 0000:01:00.0 (0300:10de:1f10) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-470xx-prime 2023.03.23 false PCI
video-nvidia 2023.03.23 false PCI
video-nvidia-470xx 2023.03.23 false PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:3e9b) Display controller Intel Corporation:
Well, in the inxi
output, it states there id no driver for it. Yet,
mwhd
reports it as installed…
So all I can think of is removing them:
sudo mhwd --remove pci video-hybrid-intel-nvidia-prime
And then rebooting.
Then reinstall those drivers:
sudo mhwd --install pci video-hybrid-intel-nvidia-prime
And, obviously, rebooting again.
When done, check the inxi
output again to see if it’s installed. Report back.
well ive done as you said, remove reboot install reboot, inxi reports the same as before
Kernel: 6.3.4-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
date: 09/19/2019
ID-1: BAT0 charge: 71.2 Wh (100.0%) condition: 71.2/80.2 Wh (88.8%)
volts: 17.5 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: discharging
System RAM: available: 15.52 GiB used: 2.53 GiB (16.3%)
Speed (MHz): avg: 1733 high: 2600 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 895 2: 872 3: 801 4: 2600
5: 2600 6: 865 7: 867 8: 2600 9: 900 10: 2600 11: 2600 12: 2600
bogomips: 62431
vulnerable
class-ID: 0300
API: ALSA v: k6.3.4-2-MANJARO status: kernel-api with: aoss
tools: pw-cli,wpctl
class-ID: e001
Local Storage: total: 476.94 GiB used: 309.24 GiB (64.8%)
lanes: 4 tech: SSD serial: <filter> fw-rev: EXA7301Q temp: 45.9 C
scheme: GPT
used: 309.24 GiB (68.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
uuid: 7E41-9CA0
System Temperatures: cpu: 58.0 C pch: 61.0 C mobo: N/A
Processes: 298 Uptime: 0m wakeups: 2058 Init: systemd v: 252
Packages: 1832 pm: pacman pkgs: 1771 libs: 474 tools: gnome-software,pamac
and the nvidia settings app still has the same issue so I dont think this fixed it
is it possible the driver isnt registered to load somehow?
interesting thing ive found
driconf gives the following error, no idea if its helpfull
There are errors in a driver's configuration information:
invalid type 'string' (driver iris) (screen 0)
This should not happen. It probably means that you have to update DRIconf.
Does this imply a configuration issue?
Not me, but maybe someone else.
Anyway, just found this where it states:
If the discrete NVIDIA GPU is switched off before starting Xorg or Wayland, then the system freezes. The only possible solution is to manually disable/enable the discrete card after starting the graphical session. However, there is an ACPI DSDT fix available which fixes this problem. Check the repository and DSDT for more information.
So it might be that. In fact, it does sound like it. So, I’m guessing that, at least for now, that is your only option.
Seems right, the only issue is i need to modify the grub bootloader to get it to work. The only examples in the repo are in issues, and they are for ubuntu, so its a bit different
i think i identified the line i needed to change but when i changed it the system stopped booting, had to fix it via a live boot. Any advice, i seem to need to load an img file called razer_acpi_fix.img before the main boot img (assuming im understanding any of this correctly)
alright, ill bash my head against the problem and report back when either it works or i have brain damage lol
If you have brain damage, you might not nee able to report back.
Regarding:
@Aragorn might know how to do this or know someone that does. But I don’t, unfortunately.
So im relitively sure i got the file to load, but it didnt do anything?
I didnt get the intended output and it didnt seem to fix the issue
Interestingly the laptop seems to run a fair bit hotter with the fix than without, so its probably waking up the gpu but not doing much else?
Maybe the blade 2016 fix wont work for a blade 2019?
I think, the reverse the changes, and any more than that
well im at a dead end for now, i dont think its specific to the hardware and i think its a software issue but there are so many places this could of gone wrong that i dont even know where to start.
