I feel ya.
Can’t help you though. Sorry.
I feel ya.
For one thing your BIOS is pretty old. Is an update available ?
Nope, v1.05 is the latest version from the looks of things
Its probably from the time the laptop was released
https://drivers.razersupport.com//index.php?_m=downloads&_a=view&parentcategoryid=864&pcid=860&nav=0,350,860
Ok, so update, ive messed about a bit (mainly hard uninstalling everything related to graphics and reinstalling), and now inxi DOES report a driver
Kernel: 6.3.5-lqx1-1-lqx arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: audit=0 intel_pstate=disable hpet=disable
rcupdate.rcu_expedited=1 BOOT_IMAGE=/boot/vmlinuz-linux-lqx
root=UUID=c60532ad-35bc-454c-8f98-883a89db32a0 rw quiet splash
resume=UUID=1050dceb-915e-4540-b9f5-49f15ae02214 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: Razer product: Blade v: 3.04
Mobo: Razer model: CH530 serial: <superuser required> UEFI: Razer v: 1.05
date: 09/19/2019
ID-1: BAT0 charge: 63.2 Wh (83.8%) condition: 75.4/80.2 Wh (94.0%)
volts: 17.5 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: charging
System RAM: available: 15.52 GiB used: 4.54 GiB (29.2%)
Info: model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF0
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1058 high: 1300 min/max: 800/2601 boost: enabled scaling:
driver: acpi-cpufreq governor: ondemand cores: 1: 1300 2: 1300 3: 1295
4: 1293 5: 1157 6: 1185 7: 800 8: 800 9: 800 10: 800 11: 900 12: 1072
bogomips: 62399
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
vulnerable
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Razer USA
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2070 Mobile] vendor: Razer USA
driver: nvidia v: 525.116.04 alternate: nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f10 class-ID: 0300
Device-3: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:4 chip-ID: 13d3:56d5
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.1
compositor: kwin_x11 driver: X: loaded: modesetting dri: iris gpu: i915
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: Sharp LQ156M1JW08 built: 2019 res: 1920x1080
hz: 240 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) direct-render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Razer USA driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:a348
class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Razer USA
driver: snd_hda_intel v: kernel pcie: speed: Unknown lanes: 63 link-max:
gen: 6 speed: 64 GT/s bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
API: ALSA v: k6.3.5-lqx1-1-lqx status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:2723 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:3 chip-ID: 8087:0029
class-ID: e001
Local Storage: total: 476.94 GiB used: 313.63 GiB (65.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-00000
lanes: 4 tech: SSD serial: <filter> fw-rev: EXA7301Q temp: 38.9 C
scheme: GPT
ID-1: / raw-size: 459.57 GiB size: 451.28 GiB (98.20%)
used: 313.63 GiB (69.5%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: c60532ad-35bc-454c-8f98-883a89db32a0
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 7E41-9CA0
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 1050dceb-915e-4540-b9f5-49f15ae02214
Device-1: 1-3:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 1-5:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-3: 1-7:4 info: IMC Networks Integrated Camera type: video
driver: uvcvideo interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 500mA chip-ID: 13d3:56d5 class-ID: 0e02 serial: <filter>
Device-4: 1-8:5 info: Razer USA Blade 15 (Mid 2019) Mercury
type: keyboard,mouse driver: razerkbd,usbhid interfaces: 3 rev: 2.0
chip-ID: 1532:0245 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Hub-3: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-4: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
System Temperatures: cpu: 49.0 C pch: 51.0 C mobo: N/A
Processes: 309 Uptime: 17m wakeups: 15373 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1837 pm: pacman pkgs: 1775 libs: 466 tools: gnome-software,pamac
pm: flatpak pkgs: 62 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
inxi reports the ssame installed driver as before
however the core issue still remains of the nvidia x-server settings being empty
any suggestions?
None at all. Sorry.
I think ive found the root of the problem, running “sudo demsg” gives me this towards the end
[ 11.459160] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 525.116.04 Thu Apr 27 17:56:37 UTC 2023
[ 11.461188] NVRM: API mismatch: the client has the version 530.41.03, but
NVRM: this kernel module has the version 525.116.04. Please
NVRM: make sure that this kernel module and all NVIDIA driver
NVRM: components have the same version.
does anyone know how to rectify this?
What is tthe output of:
pamac list --installed | grep --ignore-case nvidia
lib32-nvidia-utils 530.41.03-1 multilib 194.5 MB
linux61-nvidia 530.41.03-11 extra 53.8 MB
linux63-nvidia 530.41.03-9 extra 54.2 MB
mhwd-nvidia 530.41.03-4 extra 1.6 kB
mhwd-nvidia-390xx 390.157-6 extra 1.9 kB
mhwd-nvidia-470xx 470.182.03-2 extra 1.8 kB
nvidia-prime 1.0-4 extra 112 bytes
nvidia-settings 530.41.03-3 extra 1.6 MB
nvidia-utils 530.41.03-4 extra 690.8 MB
opencl-nvidia 530.41.03-4 extra 80.5 MB
How did you go about getting it installed?
Because it looks like the same version to me.
I used the standard automatic install tools using mhwd
But the issue is that the kernel module is v525 and all the other software is v530
That’s why I asked…
Try removing all things nvidia:
pamac remove $(pamac list --quiet --installed | grep --ignore-case nvidia)
And then reinstalling again with mwhd
as you mentioned you used.
I really don’t know what effect, if any this will have. It is, however, all I can think of.)
Preparing...
Checking dependencies...
Error: Failed to prepare transaction:
could not satisfy dependencies:
- removing mhwd-nvidia breaks dependency 'mhwd-nvidia>=455' required by mhwd-db
- removing mhwd-nvidia-390xx breaks dependency 'mhwd-nvidia-390xx' required by mhwd-db
- removing mhwd-nvidia-470xx breaks dependency 'mhwd-nvidia-470xx' required by mhwd-db
sooooo thats not gonna work, im gonna try removing them with mhwd
Do it one by one. And skip the ones with the mhwd-
prefix.
That didnt fix it.
is there a way to manualy install kernel module v530 or downgrade the other software to v525
I honestly have absolutely no idea.
Perhaps @bogdancovaciu, @megavolt, or @Fabby knows, or know who knows. But me? Nope, nadda.
Sorry dude.
I think i got somewhere?
I think i might have a functional nvidia driver installed.
I decided to download the v530 .run file from nvidia. After rebooting i had no display output at first, but then i plugged in a external monitor and both the built in display and external display came on. Im pretty sure the internal display can currently only run on integrated graphics, but the external was running on dedecated. After another reboot, this time without the external display, i am now back to running intel graphics according to glxinfo, however my nvidia x-server settings now show the nvidia gpu (but not a method to switch between them). I think the last things i need to do are configure the nvidia cards output, and implement a method of switching between them.
Update, prime run works
prime-run glxinfo | grep -i "renderer string"
OpenGL renderer string: NVIDIA GeForce RTX 2070 with Max-Q Design/PCIe/SSE2
OpenGL renderer string: Mesa Intel(R) UHD Graphics 630 (CFL GT2)
Well, color me impressed! Very well done!
Just keep in mind:
You’ll need to reinstall it every time after your kernel gets updated or changed, or some such. Because it’s not a *-dkms
package. And you didn’t install it using pacman
, pamac
or mwhd
so Manjaro doesn’t know about it, either.
yes i am aware of this, the installer actualy had an option to add it to dkms but it errored when i tried.
Then it seems all’s good.
