The mouse/keyboard is free after turn off monitor, Any help?
Good day, I have an 8 Gb raspberry Pi 4 B, when I turn off the monitor (it is a television connected to the HDMI port) and turn it on again, the image freezes, I cannot move the mouse, the keyboard does not respond, the only option I have is to restart the system, turning it off and on from the power source.
What options can I take to avoid this problem, since I cannot have the screen on all the time?
This is the neofetch and uname result of my system:
edgar@
OS: Manjaro ARM Linux aarch64
Host: Raspberry Pi 4 Model B Rev 1.4
Kernel: 6.1.69-1-MANJARO-RPI4
Packages: 1128 (pacman)
Shell: bash 5.2.21
Resolution: 1920x1080
DE: Plasma 5.27.10
WM: kwin
Theme: [Plasma], Breeze [GTK2/3]
Icons: [Plasma], breeze-dark [GTK2/3]
Terminal: konsole
CPU: (4) @ 2.2GHz
Memory: 2214MiB / 7789MiB (28%)
uname -a
Linux edgar-pi 6.1.69-1-MANJARO-RPI4 #1 SMP PREEMPT Thu Dec 21 16:01:20 UTC 2023 aarch64 GNU/Linux
Thanking you for your kind participation and comments, I will provide any other information that is required.
Hi @Kerverosmx, and welcome!
In order for us, or anyone for that matter, to be able to provide assistance, more information is necessary. To that end, please see:
Please also note and heed: Forum Rules - Manjaro
Hope you manage!
:bangbang: Tip: :bangbang:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Or three (3) tilde signs, like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
:bangbang::bangbang: Additionally
If your language isn’t English, please prepend any and all terminal commands with LC_ALL=C. For example:
LC_ALL=C bluetoothctl
I would suggest the same I suggested here:
