Some Nvidia cards don’t work with the current 465.31 drivers when used with Display Port and/or 4k Monitors. More about the issue at the Nvidia Developer Forum. We recommend to switch to Nouveau driver as needed. If you however need the Nvidia driver, you can get the PKGBUILDs of the 460.73.01 version and build your driver locally with makepkg or use the pre-compiled packages: nvida-utils, dkms and lib32 + precompiled .
OS prober does not run and add other operating systems
Please click the â–ş at the beginning of this line to view this solution
To restore, please execute: echo GRUB_DISABLE_OS_PROBER=false|sudo tee -a /etc/default/grub && sudo update-grub
The php package has been updated to version 8.0. Please refer to the upstream migration guide. As some applications are not compatible with PHP 8 yet we provide a php7 package which can be installed alongside version 8. Packages that depend on PHP reflect this update and will require php7 if needed. You might need to update your configuration accordingly. PHP 7 binaries and configuration have the “7” suffix:
Note that support for php7 will be limited and likely be dropped in about a year depending on how soon the majority of applications will be compatible with version 8.
Chromium losing Sync support in early March
2021-02-03 - Evangelos Foutras
Google has announced that they are going to block everything but Chrome from accessing certain Google features (like Chrome sync) starting on March 15. This decision by Google is going to affect Arch’s chromium package a bit earlier, on March 2, when Chromium 89 gets released.
We know for sure that data syncing will stop working (passwords, bookmarks, etc.). Other features such as geolocation or enhanced spell check might continue to function for a bit longer. Extensions integrating with Google Drive might misbehave and LibreOffice will lose access to documents stored there.
Other distros such as openSUSE and Fedora have already removed the soon-to-be-limited API keys from their Chromium 88 packages. Fedora’s advisory provides a great deal of perspective on this and I also found this Hackaday post to be quite informative.
We recommend to switch over to Nouveau drivers if your card is mentioned here and the feature you need is not in red TO DOhere for your particular card.
If you however still need proprietary drivers, you may want to execute the following to ensure all parts of the nVidia drivers get installed properly:
sudo mhwd -a pci nonfree 0300
If proprietary drivers don't fix everything, please click the â–ş at the beginning of this line to view more info
For AMD GPU users having a black screen with kernel 5.10
Please click the â–ş at the beginning of this line to view more info
Due to a bug in the AMD drivers, please try the following first:
For GRUB:
Open a terminal or a TTY
Open /etc/default/grub in your favourite CLI editor (nano vi, emacs`)
Find the line: GRUB_CMDLINE_LINUX_DEFAULT="
Add amdgpu.dc=0
Save
Execute sudo update-grub and reboot
For systemd-boot:
Open /boot/loader/entries/manjarolinux5.10.conf in your favourite CLI editor (nano vi, emacs`)
Add amdgpu.dc=0 to the end of the line options
Save & reboot
For rEFInd:
Open /boot/refind_linux.conf in your favourite CLI editor (nano vi, emacs`)
Find the line: "Boot using default options" "root=
Add amdgpu.dc=0
Save & reboot
Possible 2 Min delay on shutdown with Gnome
If you got the problem with shutdown delay (about 2min) on Gnome, here is a workaround:
Edit /usr/lib/systemd/user/gnome-session-restart-dbus.service in your favourite editor as root and add Slice=-.slice as a line all by itself like this:
You get [PKGNAME] warning: directory permissions differ on [Directory name]
followed by:
Filesystem: NNN package MMM
The solution:
sudo chmod MMM DirectoryName
Where obviously MMM is the second number you see (the correct one)
The explanation:
Your package expects the security permissions to be MMM but your system is set to NNN. This is just a warning (today) but to ensure you remain up-to-date with the latest and greatest security rules it’s advised to execute the above command.
Systemd error message: .slice: Failed to migrate controller cgroups
If you have a similar error message like this:
systemd[1004]: -.slice: Failed to migrate controller cgroups from /user.slice/user-1000.slice/user@1000.service, ignoring: Permission denied
… you may need to add this Grub parameter to your /etc/default/grub file in line GRUB_CMDLINE_LINUX_DEFAULT: systemd.unified_cgroup_hierarchy=true. To update your grub menu, call: sudo update-grub. For more information on that issue, see also Arch Forum.
Python 3.9 Requires Rebuilds
Instructions for quickly and easily rebuilding affected AUR packages:
# Install yay
sudo pacman -S --needed --noconfirm yay
# Rebuild AUR python packages
yay -S --noconfirm $(pacman -Qqo "/usr/lib/python3.8/site-packages")
The libtraceevent package prior to version 5.9-1 was missing a soname link. This has been fixed in 5.9-1, so the upgrade will need to overwrite the untracked files created by ldconfig. If you get any of these errors
libtraceevent: /usr/lib/libtraceevent.so.1 exists in filesystem
PAM and PAMBASE got updated, which might prevent you from login
Due to updates from pambase and pam you might take care about any .pacnew files in /etc/pam.d as for example pam_tally, pam_tally2 and pam_cracklib got deprecated. Read in the ArchWiki about managing those files.
Typical issue:
For recovery, it is enough to boot with kernel option “systemd.unit=rescue.target”, then proceed into /etc/pam.d and merge “system-auth” and “system-auth.pacnew”
System takes a long time to boot
If you’ve got errors like Failed to start Network Manager Wait Online. you can try removing systemd from passwd and group in /etc/nsswitch.conf as described here Update: If you can see the line dbus-daemon[1453]: [system] Connection has not authenticated soon enough, closing it (auth_timeout=30000ms, elapsed: 45146ms)
in in your dbus log ( journalctl -b -u dbus ), the new/better workaround is to switch cups from service to socket as described here: systemctl disable cups.service systemctl enable cups.socket
I think I’ve some font problems
With the update of fontconfig some major rules how fonts get applied changed. Make sure that your system has ttf-dejavu installed. A more in depth explanation can be found here.
Gnome-shell-extension-pop-shell is currently incompatible with wayland
… and causes the system to freeze when the first window is tiled and can render it unbootable. Solution is a hard reset and disabling either pop shell or wayland. If the system becomes unbootable, use a live USB to edit /etc/gdm/custom.conf to disable wayland and reboot.
> warning: could not get file information for usr/lib/python3.9/site-packages/MarkupSafe-1.1.1-py3.9.egg-info/
> warning: could not get file information for usr/lib/python3.9/site-packages/MarkupSafe-1.1.1-py3.9.egg-info/PKG-INFO
> warning: could not get file information for usr/lib/python3.9/site-packages/MarkupSafe-1.1.1-py3.9.egg-info/SOURCES.txt
> warning: could not get file information for usr/lib/python3.9/site-packages/MarkupSafe-1.1.1-py3.9.egg-info/dependency_links.txt
> warning: could not get file information for usr/lib/python3.9/site-packages/MarkupSafe-1.1.1-py3.9.egg-info/top_level.txt
> warning: could not get file information for usr/lib/python3.9/site-packages/markupsafe/__pycache__/__init__.cpython-39.opt-1.pyc
> warning: could not get file information for usr/lib/python3.9/site-packages/markupsafe/__pycache__/_compat.cpython-39.opt-1.pyc
> warning: could not get file information for usr/lib/python3.9/site-packages/markupsafe/__pycache__/_constants.cpython-39.opt-1.pyc
> warning: could not get file information for usr/lib/python3.9/site-packages/markupsafe/__pycache__/_native.cpython-39.opt-1.pyc
Have an issue with certain apps on 5.12.x, 5.11.x works fine. Biggest issue is that inability to start openarena - the desktop crashes and restarts. It’s on an acer laptop with a old 2nd generation on-board intel gpu, i.e.
Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller
Happy to provide any information that you need to diagnose the issue.
That really is easier said than done because running it in any way restarts the whole of X giving me the login dialog again. Also, it’s not an AUR package - it’s purely downloaded from openarena.ws
Updated moments ago , and noticed several problems ranging from being unable to boot with kernel 4.19.190-2 by getting systemd.udev errors …
All the new ( 5.x) kernels are “Bootable” though …
Another annoying detail is , for example unable to play any of the Steam games like :
“./StarConflict: /usr/lib32/libcurl.so.4: version `CURL_OPENSSL_3’ not found (required by ./StarConflict)”
Any ideas how to solve this one ? as yesterday everything was OK …
Hello,
I have the same issue reported in the previous update, but I think I have found the responsible: systemd!
Here the steps I done before the update:
I concour with @zomberman …
All the hassle with this latest update is directly related to the systemd package .
If I downgrade manually to systemd version 247.7 the system executes and boots Kernel 4.19 correctly and none of the Steam errors appear …
Although if I simply downgrade to the systemd previous 248.2 version I still was not able to boot with kernel 4.19…
So you have proven it perfectly. Verified!
Unstable is no option, systemd is the same version as testing at this time.
And: I run a different system, kernel 510 and 512 at unstable - everything fine…
Can be magic.
